1 - 13 of 13 Posts
My car randomly turned off on me while i was driving and it didnt want to start after that. Motor wise everything is brand new, and after that happened I changed the fuel filter, dizzy, coil pack, spark plugs and wires, main relay, and ignition switch but for some reason im not getting any spark to my plugs. Does any one know what it could be?:skull:
H22a4!
'01 Milano Red - BB615
Check fuses.
Are you getting spark? Are you getting fuel?
not to thread jack but im having similar problems but wont start if engines is up to temp. crankshaft position sensor maybe?
I had the same symptoms, albeit my distributor has an internal coil. The seal (not the O-ring, but the one on the spindle of the rotor) failed and the distributor housing got filled with oil from the engine.
Not sure if it caused a short or the coil is completely gone but I'm running on a replacement now.
@98SHyang - main relay, maybe?
1 - 13 of 13 Posts
