It's been a long time since I started a thread for anything....so here goes. I fixed up a 1990 3g awhile back (07-08 or so) with the help of this forum. That one went the way of the carrier pigeon not that long after. I've never been lude-less since those days - bought another shortly thereafter that didn't need a lot of work, and I just didn't need to be here all the time for it, so I was scarce from the forum for a time. Sometime in between then and now, my account with Photobucket was discontinued, and now any photos I posted once upon a time are all gone. I know I made some write-ups and how to's that are now picture-less, so I'll see what I can do to fix them up while I work on this new project. Over the summer (2020) I discovered that the lude which has treated me so well over the last decade or so had developed a very serious rust problem in the left front strut tower. I took some pics of it then, but I seem to not have them anymore....suffice it to say that all along the interior seam where the strut tower attaches to the frame has started to rot away. The problem is bad enough that you can see through it in several locations, and probably put some fingers through it into the wheel well in a couple. I'm not going to attempt to repair a structural problem of this magnitude - I'm sure a good welder could fix it up, but I'm not a good welder. Ever see any of Hert's early welding work on the Hoonigan youtube channel before Dan and Suppy took him under their wings for training? My welding is of that quality or worse. LOL That, and the old welder I had decided it didn't want to work anymore, and I'd need it fixed or need a new one to continue practicing.
Anyway, I recently got ahold of a pair of 3g chassis - an '89 and another '90. Both are 4ws. Got 'em cheap because neither runs. The '89 is an automatic and is in better shape, apart from the trunk floor where it meets the rear quarter panels, but the previous owner told me the timing belt is no good, and it probably has some bent valves. The '90 is a manual, is in a little worse shape, but repairable. Previous owner abused it and there's a hole in the B21A1 block under the hood. He also took a hacksaw to the shifter, lowered it by chopping the springs and otherwise just did a lot of stupid stuff to the car, to include losing the title....but the strut towers are in fine shape, and I can drop a running engine in there with no problems and use my runner for parts for it. I'll get a bonded title when it's fixed...or just put my plates on it and pretend that it's the same car, since it's a red '90 like mine, and no one will know the difference unless I want to sell it....which I won't. LOL
Those cars are both at a friend's house out of town so that the city I live in doesn't see a bunch of unregistered non-running vehicles in my driveway or yard and decide to have a problem with it. It's winter now and there's snow on the ground - work on the two chassis is going to wait until spring because it sucks being outside working on a car in sub-zero weather. Meanwhile, I have the old B21A1 that came out of my first lude sitting on a stand in my garage....like it has been for the last 13 years or so because I never did anything with it after I pulled it from that car. Dropped a B20A5 in its place and never looked back. Now I'm seeing a use for that engine, and it's not in the most terrible shape I've ever seen, so I've decided to rebuild it and put it in the '90 to replace the one with the thrown rod. I'm not looking to race with it, or any of that - I just want a car that's fun to drive, and I've loved my 3g's ever since my first one. That engine did consume and leak a lot of oil when it was in the car, with 262k on the clock. When I removed the head, I found a burnt exhaust valve that will have to be replaced, and all the valve guide seals are bad. The block seems pretty good, to be honest - the FRM cylinder walls have hardly any wear at all, even with the amount of miles on the engine. Only a tiny ridge at the tops of the cylinders. Still turns over by hand very easy and smooth. I haven't got it all apart yet and seen the condition of the crank and bearings, but judging by feel, I don't expect them to be bad. It's dirty as hell right now, and needs a cleaning. So does the head....while we're on the head, I also need to locate the rest of the parts to it that I took off....13 years ago....and stashed someplace in my garage. LMAO Last night I managed to find the valve cover with oil cap, most of the head bolts, both cams and gears, all the rockers from the intake side, 5 of the 6 cam caps from the intake side and about half of the cap bolts. The rest of the stuff...I dunno. I'm sure they're here somewhere, but I'm going to have to clean and look. I'm disassembling as I have time and taking the smaller parts to work to run through one of the parts washers a couple times when my shift is over, and keeping them safe in the meantime.
Even in a worst case scenario where I can't find everything I'm supposed to have, I have another B21A1 head on that bad block in the '90 chassis that I can use. Even if that one is somehow damaged, I know I can salvage enough parts from it to make my old one work. If all else fails, I know that I can drop the entire long block from my runner into it....but I'd like to try this first.
It's going to be a slow moving thread, guys. Don't push for often and quick updates - it's not the only thing on my plate...but it is an important one, so updates will definitely come. Pics for those who care to see. Taillamp style should tell everyone which is which, but just in case, the one with the sawblade wheels on it is the '89 and the other, decidedly shittier looking one is the '90.
Those pics were taken at tail end of October - unfortunately it doesn't look like that outside now, which is one of the reasons this will be a slow mover to start with. That all said, I'm going to call it a day for now! Cheers!
