Ok, doing some research... and I have come across that the 3g accord (not sure of what year exactly, but am assuming 88-89) have the PJO and PH4 designations. Our ludes are PJO, so pretty much anything can be used from an accord with that same designation. Can you use the stuff from a PH4 as well? I have come across some things I really need for my engine rebuild, but they are PH4 from a 3g accord.
Also, are the accord ECUs any different from ours? or same?
Thanks
the motors on all injected 3rd gen accords will bolt into the lude as for ECU's the 86-87 lxi's are the same as the SI but the 88-89's are diffrent and will not work unless you 1 replace the intake to the dual-stage lxi one and the exhaust manifoild with the accord's 4-2-1 header style one that has 2 O2 sensors..and rewire the engine harness and repin a few ecu wires . I did this swap it's alot of work for the 10hp! but I threw a rod on my BT so the A20 was the way to go...
I was wondering because I came across a set of pistons for the accord with the PH4 designation. Any ideas?
