i could do good, but dont mod your self out to fast....heres what you can do to stay in a stock class (H Stock) and still have fun with your car.
-New perfomance shocks, the nicer the better, Koni's if you can get them.
phone number to call...859-586-4100. it will cost around 800 dollars for all four.
-Cat back exhuast, and cat back will do, but make sure its Cat Back only!!
-Tires, the idea here is to not hold back at all on tires...Kuhmo v710's if you can! If not you can settle for the V700 much cheaper, but not sure if they will have a size that will fit the 13" wheel. Its probably going to be a good idea to get a set of extra wheels, and if you can, i would highly recommend you get some 14" wheels, stock honda wheels that is. You can go wider on wheel size, and your not really suppose to get larger wheels either, but not many will know that you are as long as you have 14'' wheels of an 89 SE-i accord or something.
-Ditch the front sway bar. Take out or remove there front sway bar. The rules say that you can upgrade the front sway bar, but if your weary of removing the front sway bar, then ask your local SCCA club if you can get a larger rear, if so, go with the addco rear sway bar.
-cars older than 92 can get stainless steel brake lines for saftey reasons. Go to
www.tirerack.com and order yourself a pair of lines for an 86 Acura Integra. They dont make them for our car but the good news is that the 86 Integra used the same Brake Lines as the 85-87 Prelude Si's.
-Get New brake pads. Performace brake pads. Hawk HPS's should be good all the way around.
-K&N drop in filter. They make them for our cars and its cheapest to get them from Advanced AutoParts, but if your really cheap like me, you can also remove the stock air filter. Just make sure there are no leaves in the intake piping.
With these legal mods, your car would be awesome to drive and very competive in HS, provided you spend lots of time racing nearly every race you can. Seat time is the most valuable thing you spend your money on, but if you want to set your prelude up, this is the best way.
