Ok so i decided that a 2jz just wasnt a good idea. I have now purchased a 98 prelude with h22a4 engine for 200 dollars. It has an auto tanny but id like to buy a reasonably priced h22 standard tranny. If anyone knows of somebody with one i am interested in buying.
You won't need just a standard transmission, but a new ECU, wiring harness, hydraulic clutch etc. I'm around your age (22) and even I know you're just making this harder than it needs to be.
If you want to use the h22a4 from the 1998 Prelude, you're gonna need to pull the engine out of that car, take out the wiring harness for extra material ( you'll need it for fabrication ) as well as the motor mounts. Sell the rest of the car to a Pick N Pull or something. Then, find a 1996-2001 Honda Prelude with a manual transmission, rip out the hardware you'll need from there.
After this, you'll need to become buddies with a local machine shop as they'll need to fabricate you a lot of parts to make this work. That's the point I'm making to you.
See, in my case, what I'm going for is first restoring my 1991 red 3rd Gen Prelude, interior and all, and then later, down the road, going for a swap to a manual when the automatic transmission inevitably meets its end. I'm not going to swap a newer VTEC motor in because, frankly, its too much work and too expensive, and while fixing the Prelude's interior will cost me around $400 for what i need to do, and the swap to a manual will cost me many hours and whatever I can find a decent mileage manual for (probably around $500-800) a full motor swap will be many times any potential car collector value.
