OK so recently I bought a 1997 Honda prelude SH and shortly after purchasing it is the ECU went bad. Thankfully I was able to get an ECU with the whole immobilizer set up and key off of eBay for like $260. Got my car back from the shop yesterday and it starts just fine and is running just fine. No noticeable issues at all. Just as flawless as when I bought it.
However.....
The shop pointed out to me that ever since installing the new ECU and immobilizer, the check engine light is now on and it is throwing the codes P0453 and P0450. These codes are both EVAP/emissions codes related to the fuel tank pressure sensor.
Now my question is, is this something to do with the ECU that was put in my car? The fact that it is out of a 2000 model SH and mine is a 1997 SH? Or did my car all of a sudden developed an EVAP leak/FTP sensor failure while it was sitting idly not running for three weeks while the shop was trying to get to fixing it? I just find that a little hard to believe considering before the ECU failed the check engine light never came on in my car. Granted I had not had it for very long, but my mechanic friend had checked it out before the ECU failed and he said the ECU did not show a check engine light being on in the last 90 days.
Is there some ECU incompatibility or difference in emissions standards parameters from the 1997 SH to the 2000 SH that would cause the new ECU to throw these codes or is there really an FTP sensor issue with my car? Either way I'm going to get it looked at soon as I recuperate financially from this most recent repair. But I am just curious as to if any of you could offer some insight. Thank you!!
However.....
