Status
Not open for further replies.
1 - 10 of 10 Posts
Has anyone else had this problem?
After it rains, I am finding that when I approach my first stop my passenger becomes drenched in water. The front drains are not clogged but I can't find the near one (if there is one). Any tips on what I should do?
Thanks
^^^^^guess I can't type as fast as I thought.
Welcome to the board.
First off, many have had that problem and there are many solutions on the board. Have you used the search?
With that said, there are two rear drains and they could be clogged. They drain behind the rear wheel under the bumper cover. I believe if you pull the side panels around the rear windows you can get to the drains on the sunroof pan.
the rear drains are on the sides in the trunk, one on each side. pull back the interior on each side, and look inside by the rears of the quarter panels. there will be a big clear hose, and a black rubber plug down in the bottom. the plugs usually clog up with dirt and junk. just clean em out real good and put em back together, problem solved
Donates his big Member
^^ ha doesn't get much simpler than that!
1 - 10 of 10 Posts
Status
