1 - 16 of 16 Posts
here's pics for when the car was for sale
paid $6500 as is 2 years ago
Engine:
stock H22A4 2.2 litre
stock M2Y4 tranny
Interior:
stock black leather, heated seats
stock carbon fibre trim
Exterior:
used type s front lip
Suspension:
stock
Future mods:
have to fix the ac, clock, wiring for stock stereo
coilovers with as wide as possible in 16" (or 17) rim on all 4 corners
anything to get it lighter, carbon fibre hood, …
must say, most parts for preludes have been discontinued !!
Repairs so far:
new stock flex pipe/pipe a, gaskets, cat. conv. covers
new stock right rear bearing assembly
new door weatherstrips and moulding assemblies
oil cooler o ring, cam cap seals, distributor o ring, vtec solenoid gasket, valve cover and spark plug gaskets, timing belt, water pump, balance shaft belt, front and rear balance shaft oil seals, cam seals, crank oil seal, dip stick o ring, oil cap o ring, drive and power steering belt
2 parking lot accidents (both to the driver's side fender ! so lucky !)
on future mods:
a ton but also go to mention still looking for all parts for a fog light install, a black type s rear deck, some more of the type s carbon fibre trim pieces, digital climate control, ….
Discussion Starter #4
got to add some early repairs:
aftermarket rad, rotors, pads
changed to air cabin filter (thank you write-ups !!)
Discussion Starter #9
long time no update...
got the following new stock parts replaced with original honda parts:
exhaust from cat back
fuel filter
distributer cap and rotor
spark plugs and wires
thermostat
radiator hoses
pcv valve, grommet and hose
got the following aftermarket parts in:
koyo radiator, oem replacement
windshield
the car is running real smooth now, still got a random sounding knocking sound from the front driver's side when over 120 kilometres/70 miles per hour and when raining only and can only hear it if the window is open
Discussion Starter #11
RIP to the 2001 Honda Accord Special Edition !!!!!!!!!
-SOHC 2.3l that put out 150 hp
-double wishbone suspension on all 4 corners
-drove it over 380,000 kms/235,000 miles and it never died or broke down on me
such a great sedan that took hard driving with ease
may your parts be spread far and wide !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Discussion Starter #12
...cleaned up the interior
...would you all believe i was driving for many months without the fans connected?? ...was driving on the highway and having some fun with accelerating etc, AC cranked on high, one of the hottest days, come off the highway and see my needle rising ....so decided to change out most of the fluids
...went with synthetic 5w30 for the first time
...so, for sure this time, this is the smoothest and most responsive I had the car running (i've said this before when the fans weren't connected lol)
...also spent almost $400 on a optima yellow top - my hope is that since i barely drive the car it'll last more than 8 or so years the last battery lasted and that it won't leak like the last battery
8 years seems pretty good on a candian tire battery. When I bought my battery from the dealer a couple years back the parts guy seemed convinced it wouldn't last more than 3-4 years...then again he wanted me to have it installed there to get 2 more years of warranty...
Discussion Starter #14
yeah for sure the canadian tire one lasted a long time, ...credit goes to indoor parking and cleaning the terminals with baking soda and water?
interesting that the dealer would extend the warranty if they installed, ...what's the minimum charge, half hour of labour? ...i wouldn't have gone for that deal, but that's from knowing that the dealer is always twice the price, and yes, i've paid a lot to honda dealerships over the years
I have no idea what the additional charge would have been, the idea of having somebody else install a battery for me seemed ridiculous.
Discussion Starter #16
agree of course, that would be a total waste of money even with the additional warranty,
...on extra cost for extended warranties i have never been sold, too much fine print most of the time and the extra cost kills the price :)
1 - 16 of 16 Posts
