1 - 2 of 2 Posts
So I just bought a 01 prelude sh with a blown motor thought all 97-01 were exactly the same then bought a motor out of an 00 right off and just put tanny on the new motor then when to replace the trans axle and realized the oil filter adapter is in the way after doing some research I discovered that mine has atts and the motor I bought came out of one without atts is there anything I can do to move oil filter adapter or any other way I can use this motor and am I going to run into anymore problems or do I have to get another motor cant seem to find any info online called a honda dealer and they couldnt help either
Super Moderator
There are oil filter relocation kits available.
You're using an SH trans on a base block??
1 - 2 of 2 Posts
