H22 rebuild issues!! - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 08-10-2012, 10:14 AM   #1
98H22Prelude
Getting Comfortable
98H22Prelude is on a distinguished road
I have a 98 base prelude and it was burning almost 2 quarts of oil a week so I decided to fully rebuild it. I bought an entire rebuild kit, a spare head, and a skunk 2 intake manifold. I tore it down and rebuilt the motor then when I start it the car is just blowing white smoke, and after the motor goes through its warm up cycle the idle starts to jump up and down from about 1400 to 2000 RPMS. I need help figuring out this issue and fast. Any help would be greatly appreciated.
98H22Prelude is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-10-2012, 10:48 AM   #2
hatedenemy
Lude Boss
hatedenemy's Avatar
hatedenemy will become famous soon enoughhatedenemy will become famous soon enough
Send a message via AIM to hatedenemy
sounds like coolant
does the smoke have a smell?
the used head, was the surface checked on on the head and deck of the block?
Might need to have those surfaces checked and a new headgasket
You can try to run a block test through the coolant system. There is a chemical based tool that pressed onto the rad where the cap would go. The fluid in side the tool will change colors from blue to yellow/green in the presence of exhaust gases. Its not always accurate but in the sense of testing negative may not mean youre in the clear. If it tests out positive then you can certain thats whats going on
__________________
BB Squad #16 (v.2)
hatedenemy is offline   Reply With Quote Quick reply to this message
Old 08-10-2012, 07:35 PM   #3
98H22Prelude
Getting Comfortable
Originally Posted by hatedenemy View Post
sounds like coolant
I actually didnt end up using the new head I used the my old one and it was fine before the rebuild thats why I can't figure out why its burning coolant
Old 08-11-2012, 12:41 AM   #4
Prudz_lude
Donating Mod
Prudz_lude's Avatar
Prudz_lude is a splendid one to beholdPrudz_lude is a splendid one to beholdPrudz_lude is a splendid one to beholdPrudz_lude is a splendid one to beholdPrudz_lude is a splendid one to beholdPrudz_lude is a splendid one to beholdPrudz_lude is a splendid one to beholdPrudz_lude is a splendid one to behold
the bouncing ideal can be alot of things, but if it is burning coolant, i'm betting that you have air in your system as well causing the idle to jump like it is. TPS, IACV, FITV, vac leaks, air in the coolant can all cause the idle to bounce like that.
__________________
BB Squad #23 (v.2)
Prudz_lude is offline   Reply With Quote Quick reply to this message
Old 08-11-2012, 07:14 AM   #5
Wing8806
Faptastic
Curveball Champion, Alien Clones Champion
Wing8806's Avatar
Wing8806 is a name known to allWing8806 is a name known to allWing8806 is a name known to allWing8806 is a name known to allWing8806 is a name known to allWing8806 is a name known to all
I checked all the vacuum lines, they're are no leaks - although he is using a stock TB on the Skunk2 IM, I thought there was something on the inside of the TB that needed to be blocked off but I can't remember for the life of me.
Right now the smoke is the major issue, the stock IM can always go back on last minute just to get the car running - and I believe there was some "grinding" noise as well, unless that issue was resolved since I last spoke with the OP.
Once a motor has been opened - i'll be the first to say i'm pretty useless. OP needs his car for work and is a new 'luder here in DE, so any help would be greatly appreciated.
__________________
2001 Prelude - Project
2008 Mugen Si - Daily
Do not trust Kane666 aka Jason Myers.
Wing8806 is offline   Reply With Quote Quick reply to this message
Old 08-12-2012, 06:44 PM   #6
hatedenemy
Lude Boss
hatedenemy's Avatar
You separated the head from the block which means you should still check surface flatness. The surface maynot be the issue if you have things like reused head studs and improper torque sequence
Bouncing idle as others said are secondary issue. Find the issues to the white smoke and resolve will allow you to properly address that. You might feeled urged to try andu resolve the bouncing idle first but in my opinion you will not accurately diagnose that issue
You said you reused your head and rebuilt the motor due to burning oil. Were you certain the cause was from blow by? What about the head, was this rebuilt?
Where are you located? I imagine up north in new castle?
__________________
BB Squad #16 (v.2)
Old 08-12-2012, 07:03 PM   #7
98vtec
bangin' gears
98vtec's Avatar
98vtec is a name known to all98vtec is a name known to all98vtec is a name known to all98vtec is a name known to all98vtec is a name known to all98vtec is a name known to all
Prelude of the Month
There is a difference between burning coolant and leaking coolant. Burning means its in the chamber. The only way that really happens is through the headgasket. Do a leakdown test or a compression test
Sent from my DROID BIONIC using Tapatalk 2
__________________
instagram - @850fab
facebook - @850Fabrication
98vtec is offline   Reply With Quote Quick reply to this message
Old 08-12-2012, 08:39 PM   #8
98H22Prelude
Getting Comfortable
I reused the same head but I had it magnafluxed to check for cracks and make sure it was straight. I put cleaner valves, titanium retainers, and aftermarket springs in it as well. I also did all new valve seals. I thought about the issue with head studs. I bought new ARP head studs. In my small block chevy I had to put sealant on the head bolts becaus they went into part of the cooling system. Are hondas the same way? Cause I put nothing on the new head studs and i thought that might have something to do with the burning coolant.
Old 08-13-2012, 06:40 PM   #9
hatedenemy
Lude Boss
hatedenemy's Avatar
98vtec is right if you are burning coolant then you will have coolant in the chamber.
You could possibly peek down in via spark plug holes into each chamber
Though I dont know of much that would cause white smoke other than coolant/water. I suppose some oils can burn white but I cant comment much there
I do know engines should produce white smoke initially due to using assembly lubes
I hope you did not put assembly lube on the piston rings.
You should use clean engine oil on your new head studs.
Improper torque and sequence will not seal the head down.
__________________
BB Squad #16 (v.2)
Old 08-15-2012, 04:01 AM   #10
98H22Prelude
Getting Comfortable
I ran a compression test to try and diagnose what the issue is. Here are my results: #1: 210 PSI, #2: 205 PSI, #3: 210 PSI, #4: 220 PSI. Does anyone have any idea what my problem could be, or someone I could have fix this. I need my car back ASAP!
Old 08-15-2012, 08:10 AM   #11
hatedenemy
Lude Boss
hatedenemy's Avatar
that does look good
I imagine you ran that comp test after the engine was warm right?
You could try doing 2-3 hard pulls up the street and pull the spark plugs to see how its burning. Make sure you have no oil coated plugs.
A leakdown test is more accurate for exposing a problem area and that is probably your next best test.
Does the engine run great? Besides that crappy idle that is.
And I dont believe I have asked yet, does it produce white smoke all the time? during start up? on throttle off throttle?
Keep an exact idea of where you fluid levels are now and before every time you run the engine.
If you really are burning any fluids you should be seeing a fluid level drop.
__________________
BB Squad #16 (v.2)
Old 08-15-2012, 02:41 PM   #12
98H22Prelude
Getting Comfortable
Yes it constantly blows white smoke. I dont want to run it very long cause there is grinding sound coming from the timing belt area.
Old 08-15-2012, 05:06 PM   #13
hatedenemy
Lude Boss
hatedenemy's Avatar
DOH! Grinding sound!?!?!!? thar should be noo grinding sound. YES dont run your rebuilt motor until you find out what is up!
Was anything reused for timing belt? Try turning the engine ccw with a ratchet and find that noise. Possibly a bad bearing on a pulley if the sound is external.
__________________
BB Squad #16 (v.2)
Old 08-15-2012, 08:55 PM   #14
98H22Prelude
Getting Comfortable
Im pretty sure ive narrowed it down to the head gasket being bad. Im gonna go buy another one and replace it and see where im at. As far as the auto tensioner what should I do with that? I dont have the proper tool to install it and ive heard alot that they are junk and I should switch to a manual tensioner. How can I do that, and where can I get one?
Old 08-15-2012, 09:42 PM   #15
hatedenemy
Lude Boss
hatedenemy's Avatar
Sweet.
You can go H23 manual tensioner conversion OR you can buy the kstuned manual tensioner. The Kstuned tensioner is aftermarket but its essentially a direct replacement of just the auto adjuster. Check out Rosko racing in the vendor area. He has those in stock. Im not sure if your post count will hinder you.
And just for kicks. The tool you speak of, are you referring to the bracket holder used to hold the auto tensioner compressed while you get it in place? Its usually bolted to block right near.
__________________
BB Squad #16 (v.2)
Old 08-15-2012, 10:18 PM   #16
98H22Prelude
Getting Comfortable
is that piece really on the block? I didnt see one anywhere.
Old 08-16-2012, 11:33 AM   #17
hatedenemy
Lude Boss
hatedenemy's Avatar
Well its removable. There is just a convenient space where you can bolt down. Its only needed for when you install the automatic tensioner. I wouldn't sweat it though since you interested in going to a manual tensioner which is highly recommended.
If you did you want one though I am sure you can get one from the for sale section once your post count reaches 100+
You probably wont have any luck at a junk yard thats for sure.
You are looking for #25 "14540-P13-003" if I understand you correctly. You wont need it though.
__________________
BB Squad #16 (v.2)
Old 08-21-2012, 01:12 PM   #18
hatedenemy
Lude Boss
hatedenemy's Avatar
Did you have the time to redo the headgasket? I meant to state earlier to make sure you have the dowel pins installed. Those things can fall out sometimes. Im sure you have them since it would be a bitch to reinstall correctly anyway
__________________
BB Squad #16 (v.2)
Old 08-21-2012, 01:54 PM   #19
98H22Prelude
Getting Comfortable
I had the company that sold me the head gasket refund some money. I bought a brian crower head gasket, and a gates high performance timing belt. I also ordered a manual tensioner from rosko. I hope after I reinstall all this it will fix my issue
Old 08-21-2012, 02:33 PM   #20
hatedenemy
Lude Boss
hatedenemy's Avatar
You have it taken apart already though? You really should double check your head surface for warpage. Do you have a precision straight edge? You can just place the straight edge over the surface and shine a LED flash light over the head and look for the light poking under. Measure the gap with the same feeler gauge set you would use for valve adjustment.
With the timing belt out of the way spin the pulleys. Make sure they are moving freely without notchy movement.
You said something about a grinding noise that I didnt quite get. Did you get to the bottom of whatever that noise wass?
If you dont mind me asking where are you located? If you need help with things man dont hesitate and I can try to help when/where ever possible
__________________
BB Squad #16 (v.2)
Old 08-22-2012, 10:38 AM   #21
98H22Prelude
Getting Comfortable
I have a feeling the grinding noise is due to the new bearings i put on my timing belt assembly. I think one of them got wet. I live right in wilmington delaware
Old 08-22-2012, 08:43 PM   #22
hatedenemy
Lude Boss
hatedenemy's Avatar
Have you removed the head yet?
Im wondering if you have been able to confirm head gasket blow out
At that point you can dig deeper into timing area noise.
Grinding noise can sometimes be due to the timing belt walking towards the edge of a pulley. Eventually rubbing. Simple valve cover pull should show you if the belt was rubbing even in the slightest amount. Youll usually notice a super fine black powder/dust in the valve cover that is over and around the top of the timing belt.
You might want to think about a fresh intake manifold gasket and install the stock manifold. If you already have a metal gasket and might be able to eek by just by being super careful. But, if the gasket doesn't seal, youll need a new one on hand.
The reason I suggest that though is to simplify the situation until everything is smoothed out.
Depending on which side of Wilmington your in, I can most certainly ride up and lend a hand turning a wrench if you need one.
But that depends on what your schedule is looking like since I probably wouldn't be able to head north until friday/weekend
edit: It might also be worth your while to try and find some carbonless impression paper. place the paper between the mating surfaces without a gasket and torque the head down. youll be able to pick out any light spots on the paper easily and know problem areas.
unfortunately bad results will require resurface which I am sure you know the deal.
you might be able to massage some areas into spec depending on how bad things are. but my viewpoint is merely speculation without seeing whatsup
__________________
BB Squad #16 (v.2)
Old 08-23-2012, 01:39 PM   #23
98H22Prelude
Getting Comfortable
I havent begun to tear it back down yet cause Im waiting on my parts to arrive. If you wouldnt mind helping me out with the timing belt assembly that would be great. This is my first honda rebuild so any help would be great. I dont know if you know the wilmington area but I live right off of kirkwood hwy off milltown road near dickinson high school
Old 08-23-2012, 08:38 PM   #24
hatedenemy
Lude Boss
hatedenemy's Avatar
oh damn google maps says your just 47 miles at 52 minutes. 33 miles of that is on route 1 so that means itll be less than 52 minutes hah. I think I know the area that your in. Your just north of the christiana mall. I do remember some nasty ass pot holes up in your area! But i have blades on now so it should be good lol
What kind of concerns do you have with the timing belt stuff though? Are you just lacking some tools to make life easy or something specific that your not 100% on?
Id like to know if you think your lacking some certain tools. I might have them and it would be beneficial to know so that I can grab them.
And are you doing this in a garage or like in your driveway on jack stands? In that case...weather permitting haha
I know you just did the timing belt since you rebuilt the motor but do you feel you messed up something that explains why you have some grinding sound?
I need to know what exactly you have "new" and which pieces you are reusing that have all of the original mileage on them.
__________________
BB Squad #16 (v.2)
Old 08-24-2012, 01:33 AM   #25
98H22Prelude
Getting Comfortable
I very easily could have messed up the timing belt somehow. I also dont really have all the proper tools im only a sophmore in college so its on jack stands in my driveway.
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
