stripped socket lug/tuner lug - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 05-14-2008, 08:58 AM   #1
CADster
Kickass truck missed
CADster's Avatar
CADster will become famous soon enoughCADster will become famous soon enough
Prelude of the Month
how do you extract a tuner lug when the socket pocket is whats stripped ?
i am taking about this style :
__________________
"Straight-line acceleration is probably the first aspect of automotive performance
that any intelligent driver gets bored with." - Peter Holden Gregg
CADster is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-14-2008, 09:02 AM   #2
GUESSMAN
Lude Boss
GUESSMAN's Avatar
GUESSMAN will become famous soon enough
The only thing I can think about doing is drilling out the center of the stud and just put a new stud in. I had to replace 3 studs on the front on my DD the other day and I used a drill and started out with small bits untill I used the closest bit to the stud size. They are easy to break off after hollowing it out.
Hope that helps
__________________
88' S JDM H22A (Sleeper Mode "S")
Check this thread out for Electrical Componets and location: Warning takes a while to load all the pictures!!!!!!
Check out this thread for my H22A start-up 12-5-08!!!!
GUESSMAN is offline   Reply With Quote Quick reply to this message
Old 05-14-2008, 09:11 AM   #3
CADster
CADster's Avatar
ouch... thats going to hurt.
but thanks for the input.. keep them coming.
i thought of spot welding an allen wrench on it.
but i dont know what that will do to my wheel.
__________________
Old 05-14-2008, 09:17 AM   #4
daustin1989
daustin1989 is on a distinguished road
Doubt it'd do much. If you're really concerned about the wheel, wrap some ice on the rear side of the wheel and try and get something cold at least around the lug that needs removed. Because the wheels are subject to high heat especially at high speeds and hard braking, I would not imagine a spot weld doing much, if any at all, if it is quick. I would only advise against prolonged periods of high heat.
Hell I had the same worry about when I welded a new piece of upper frame to the lip under the top part of the windshield of my old Camry. I thought I would melt the plastic of the interior so I kept the spot welds very short and kept ice on the roof around where I was welding and it was fine.
daustin1989 is offline   Reply With Quote Quick reply to this message
Old 05-14-2008, 09:25 AM   #5
GUESSMAN
Lude Boss
GUESSMAN's Avatar
Yeah, use a wet rag around the wheel and just take a mig and tack a few welds and see if that works...Sorry, I forget some people know how to weld. You should good if you don't put a ton of heat on it.
__________________
Old 05-14-2008, 09:31 AM   #6
CADster
CADster's Avatar
i dont know how to weld.. but i know people who do
thanks for the advice.
__________________
Old 05-14-2008, 09:32 AM   #7
gc8dc95
Lude Boss
gc8dc95 is on a distinguished road
Thats what I do. Weld a nut on the end of it quick and then wrench it off.
gc8dc95 is offline   Reply With Quote Quick reply to this message
Old 05-14-2008, 10:01 AM   #8
lowfatc10
True Luder
lowfatc10 is on a distinguished road
Cad, I run into this kind of problem a lot. I work on machines for a living. Most of the machines use socket head cap screws, what some people call "Allen" screws. When they get stripped or worn, there are a few things you can do.
1. Grind down the worn section of the hex wrench. In your case it would be the worn key. The idea is that you will have a nice clean, fresh section to put into the lug. Obviously this doesn't work if your key isn't long enough to support grinding down.
2. Use an abrasive anti-camout fluid. Comes in a little bottle or tube. It is abrasive suspended in a liquid. You put a drop or two on the worn screw/wrench and it gives extra bite to keep the tool/screw from slipping. This stuff works awesome, one of the best 3 to 4 dollar items you can put in your toolbox. I have seen this at McMaster.com and also at Sears in the screwdriver section.
3. When all else fails, use an appropriate size Torx bit. You know, the kind used on Ford brake calipers, Honda seat belt bolts and/or strikers.
The best ones are the hardened ones. Just line up the "points" of the Torx bit with the worn corners of the nut and tap/hammer it into the worn out nut. You want it to be a real tight fit.
If all that fails, you may want to start think about a large EZ out, but the nut may not be deep enough to use it. You could also cut a slot in it with a cutoff wheel or Dremel and try to use a screwdriver or chisel to turn it. Sears has a line of screw/bolt extractors out that may help, but they fit around the outside of the bolt head and you may not have clearance on your wheel.
Last thing would be to go to one of the larger tire shops in your area, the one that sells lots of wheels. Their customers are always losing wheel lock keys and they have special sockets that will remove wheel locks.
lowfatc10 is offline   Reply With Quote Quick reply to this message
Old 05-14-2008, 10:10 AM   #9
1funryd
Elite Member
1funryd's Avatar
1funryd is a jewel in the rough1funryd is a jewel in the rough1funryd is a jewel in the rough1funryd is a jewel in the rough
Send a message via AIM to 1funryd Send a message via MSN to 1funryd Send a message via Yahoo to 1funryd
Very good information, I added this to the 3rd Gen Performance Upgrade thread #70.
Sean
__________________
My Facebook page -
Sean
3rd Gen Aftermarket Manager
(Clik Here)
Email:
(1Funryd - H22 Swap) - Ludcifer - INX - MustardCat(B20a)
1funryd is offline   Reply With Quote Quick reply to this message
Old 05-14-2008, 10:21 AM   #10
CADster
CADster's Avatar
mucho good stuff here, thanks.
that abrasive fluid gives me an idea..... wrap my tuner bit with aluminum foil.. this should fill in the gaps just fine and it might give me the bite i need.
i think im going to try this to see how it works... its not like i got anything to loose
__________________
Old 05-14-2008, 11:00 AM   #11
'89NClude
Elite Member
'89NClude's Avatar
'89NClude is on a distinguished road
so its your socket/'key' thats worn? i have lugs just like those. you can just go buy a 12 mm hex key, they sell them at advanced/autozone. the set looks similar to this, mine came with 10mm 12mm and 14mm.
I had to do this once, i didn't have my socket in the car and i got a flat tire out on the interstate, around an hour and a half away from home. Luckily another luder came the the rescue and gave me a ride to advanced, where I bought a set of three sockets, the 12 mm one happened to fit my lugs. hope this helps.
__________________
-1991 Prelude SI - b20a + bolt ons + 4ws swap + turbo in the making
Psalm 40:1
I waited patiently for the Lord; and he inclined unto me and heard my cry.
'89NClude is offline   Reply With Quote Quick reply to this message
Old 05-14-2008, 04:38 PM   #12
CADster
CADster's Avatar
pretty much, yea. both are worn. between the two it would not come off.
aluminum foil - FTL
my idea did not work at all.
torx bit - FTW
worked like a charm.
thanks everyone
__________________
Old 05-14-2008, 05:16 PM   #13
daustin1989
aluminum foil - FTL
torx bit - FTW
thanks everyone
Glad to hear you didn't have to go the long and time consuming route of welding something to the tuner lug and yanking it out that way.
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Stripped Lug Nut one_love General 9 04-14-2008 10:48 AM
4th gen conversion to 5th gen Lug COnversion BB4__NoShyt Suspension/Wheels/Tires/Brakes 1 02-21-2008 09:00 AM
Lug Conversion Tengoku 3rd Gen 20 01-12-2007 03:38 PM
stripped downpipe nut 2ndgenludedude 2nd Gen 2 02-12-2005 12:47 PM
stripped front lug 3rdGensOwn 3rd Gen 10 11-10-2003 06:01 PM
vB.Sponsors
PreludePower Forums
