DIY: Official 5th Gen Timing Belt Job Procedure! (by JLUDE 03/11/08) - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 03-11-2008, 12:43 PM   #1
JLude
Idiotic Thread Locker!
JLude's Avatar
JLude is just really niceJLude is just really niceJLude is just really niceJLude is just really nice
Send a message via AIM to JLude
Thumbs up DIY: Official 5th Gen Timing Belt Job Procedure! (by JLUDE 03/11/08)
First things first: This writeup is intended solely as guidance for those skilled enough to attempt a job of this level themselves. Just because I did it does not mean you can! I'm an engineer and have a lot of experience working on cars otherwise I would never attempt this job myself. That said it is still a medium level job as far as tools required and degree of difficulty. It is a very time consuming job and some parts can be very tedious and having small hands is almost required for certain things!
I don't mean to scare you guys away but just so you are aware...there is a reason that shops charge $350 - $800 just for the labor on this job!
TIPS:
- Have a shop break your crank pulley bolt loose first! Without EagleEyez's shop I would have been in some trouble!
- You'll need at least a full weekend dedicated to this job if you've never done something like this before.
- Make sure you take your time. This is a pretty critical job that if messed up...could spell disaster for your motor!
- Label all parts removed, especially bolts and nuts as to where they go! I use ziplock bags stored in a 5 gallon bucket to keep anything from happening to them! That can be one of the most frustrating things...to loose a 10 cent bolt that prevents you from finishing the job!
- All the info for parts, Helms Manual, Manual tensioner writeup is in this thread:
https://www.preludepower.com/forums/s...d.php?t=279992
1. I removed the bumper cover and headlight to make it easier to work.
- Drain the motor oil into a clean container and save for later reuse.
- Drain the coolant into a clean container and save for later reuse.
- Disconnect the battery negative (-) black terminal.
I also covered the fender with a terry towel to protect it. Then raise the front of the vehicle on jack stands and remove the driver side wheel:
2. You can start by disconnecting the alternator wires and swinging them out of the way:
3. Next we will remove the power steering pump:
*Note: Do NOT remove the metal line that goes into the top of the PS pump! Just leave it attached and the pump will swing out of the way just fine.
4. Next remove the splash shield from the crank pulley end
5. Remove the spark plug wires and valve cover:
6. Remove alternator:
7. Remove Alternator and PS pump brackets:
8. Remove upper timing cover:
9. Loosen the Cam Gears if you plan to replace the cam seals:
10. Remove timing belt from the cam gears:
11. Remove under cam plastic plate and remove old cam seals:
__________________
Building your custom HID Projector RETROFITS since 2005! PM FOR DETAILS.
Former 5th, 4th and 3rd gen Prelude owner. Current: 2004 Toyota Tundra V8 DC 4x4, '00 Civic LX beater, '06 Yamaha FZ6S, '07 Victory Kingpin - Still a Prelude enthusiast!
JLude is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-11-2008, 12:45 PM   #2
JLude
JLude's Avatar
12. Install new cam seals:
13. Remove the lower timing cover. Keep in mind that there is a wire loom on the back side of it that connects to the crank sensors...you must disconnect this wire from the cover first...take your time.
The crank pulley must be removed to free lower cover:
14. Lower cover out of the way:
15. Remove the side engine mount:
16. Remove the autotensioner assy. (refer to the auto to manual tensioner swap writeups)
17. If replacing the crank shaft oil seal, remove the crank angle sensor assy. (4, 10mm bolts) and carefully remove the timing belt drive gear from the crankshaft. Remove the old crank shaft oil seal:
Replace with new crank shaft oil seal! Make sure it seats uniform...I used a small hammer and blunt tipped tapper
18. Remove old water pump and install new:
19. Install manual tensioner parts (see manual tensioner writeups):
20. If replacing the balance shaft seal:
Be sure to install the balance shaft seal retainer!
21. Installing new Timing Belt:
Reinstall the plastic plate under the cam gears, then reinstall the cam gears
(yes I realize that in this pic the plastic plate isn't under the cam gears)
Then hold and tighten each cam gear to the torque specified in the Helms manual
Place each cam gear at TDC according to the Helms Manual:
Put the crank timing belt drive pulley at TDC according to the Helms manual. There are little marks on it that must line up with the pointer.
Install the timing belt over the crank drive gear, be sure not to turn the crank shaft once set at TDC!
This is the tricky part: While keeping the cam gears at TDC, wrap the timing belt around the front gear and then the rear, use a zip tie to help you hold it in the correct position on the first cam gear while you work the belt over the water pump and tensioner pulley!
I had to pull the tensioner pulley off of it's pivot point in order to get the timing belt over the pulley...yes it's going to be tight!
Once you are on, turn the engine counterclockwise using the crank pulley placed over the crank shaft and gloves to turn it. This is MUCH easier if you remove the spark plugs first:
Once you've turned the engine several revolutions recheck that the cam gears are both at TDC when the crank gear is at TDC...if they match up, you are good to go!
22. Install the balance belt. Follow the proceedure in Helms to align the rear pulley. You will need a 100mm x 6mm bolt to insert in the maintenance hole at the back of the block to hold the rear balance shaft in the correct position while you install the new balance belt
****There is a groove in the shaft of the front balance shaft that must line up with the pointer while you install the balance shaft belt. If it's off by one tooth you'll know it, the groove won't even be close to lining up with the pointer.
23. Set the correct tension on the timing belt and balance shaft belts!
I went by feel since I've done timing belts before. I found that the timing belt was just right with the tensioner as loose as it goes! The balance belt needed to be about half way between the tensioners travel from loose to tight to have the right deflection for me.
If anyone has the correct belt deflection numbers please share them!
Once you set the tension you must tighten the tensioner adjusting nut (14mm) to the correct torque and then tighten the small bolt that goes to the pivot arm. Turn the engine several revolutions counterclockwise by hand to be sure there is free movement.
24. Reinstall the lower timing cover:
********First install the side engine mount!
Note: one of these pics shows the lower cover with the engine mount off so you can see more detail.
25. Reinstall the upper timing cover and the 2 rubber seals that go over the 2 adjuster bolts that go through the lower timing cover:
26. Reinstall the rest of the side engine mount
27. Reinstall the valve cover. Be sure to use a new gasket set for the valve cover or at least apply some RTV to the seals, especially the corners of the seals near the cam ends.
28. Reinstall the PS and alternator brackets, heat shield, alternator, PS pump and both drive belts.
29. Refill the motor oil.
30. Refill the coolant.
31. Reconnect anything else that may be disconnected (ie: PS pump line, alternator wire loom, PCV valve, spark plugs and wires, etc etc. Use your best judgement to be sure everything is in order before starting the car!
32. Reconnect the battery Negative terminal.
33. Leave the radiator cap off
34. Open the coolant bleeder valve on the top of the thermostat:
35. Start the car and make sure it feels and sounds right! If all is good, let it reach operating temperature and eventually coolant and air will start flowing from the coolant bleeder valve...once there is no more air, close the bleeder valve. Close the radiator cap. turn the car off and let it cool down. Once cool, remove radiator cap and top off coolant level.
36. Check oil level and check for fluid leaks.
37. Torque your crank pulley bolt to 180 ft lbs! No, that's not a typo! It's best to use an impact torque wrench so as not to turn the engine backwards!
38. Test drive!
39. You did it! Now go have a brew and take a long nap! That was HARD WORK! You now know why they charge so much for the Full Timing belt job!
__________________
Old 03-11-2008, 01:01 PM   #3
KATVAMPIRLUDE
Lude Cray
KATVAMPIRLUDE's Avatar
KATVAMPIRLUDE is on a distinguished road
lol......damn, I will definately know why "they" charge so much for T-Belt job!!!!(Tax return FTW!!) I can't do that myself, or with my Dad and brother and several friends!
I def need to get my T-Belt, fuel filter and such done before the Skyline Meet!
once again Jesse.....that is a hell of a write-up!! nice job.
KATVAMPIRLUDE is offline   Reply With Quote Quick reply to this message
Old 03-11-2008, 01:18 PM   #4
prelude1897
prelude1897's Avatar
prelude1897 is a jewel in the roughprelude1897 is a jewel in the roughprelude1897 is a jewel in the rough
Send a message via AIM to prelude1897
good stuff
__________________
97 Prelude-wrecked
00 Prelude-daily driver
99 Prelude-RHD Prelude
98 Prelude-Parts Car-SOLD
97 Prelude-RHD project#2
99 Prelude-Parts car-SOLD
01 Prelude-Parts car-SOLD
94 Prelude-VTEC status-Traded
98 Prelude-traded for 94 prelude
97 Prelude-Parts car-SOLD
Retrofit Service PM me
prelude1897 is offline   Reply With Quote Quick reply to this message
Old 03-11-2008, 01:38 PM   #5
1fastlude
Prelude Aficionado
1fastlude's Avatar
1fastlude has a spectacular aura about1fastlude has a spectacular aura about1fastlude has a spectacular aura about
Send a message via AIM to 1fastlude Send a message via Yahoo to 1fastlude
Damn... Yeah that would def take a whole weekend for ur first time. Nice write-up. I almost tempted to do it myself and save me $300 in labor..
__________________
06 gsxr 600
rep me if I've helped you in anyway....
RIP-01 boosted lude- 368whp 274tq @ 11 psi
1fastlude is offline   Reply With Quote Quick reply to this message
Old 03-11-2008, 01:53 PM   #6
viper_boy403
Vrooom PSHHHH
viper_boy403's Avatar
viper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to behold
Send a message via AIM to viper_boy403
GREAT writeup! is it just me or does your exhaust cam look really worn on cylinder 2? maybe it's just oil, i dunno
__________________
- Competition Clutch - MFactory - Prosport - Skunk2 - Neptune - Innovate - Seibon - H&R- KYB - Tial - Injector Dynamics -
- Energy Suspension - Vibrant - Aeromotive - Synchrotech - Quaife - GE - Hawk - Innovative Mounts - CP - Eagle -
BOOSTED
1997 San Marino red base
-Andrew-
Fuck bitches... acquire boost.
viper_boy403 is offline   Reply With Quote Quick reply to this message
Old 03-11-2008, 01:58 PM   #7
JLude
JLude's Avatar
It does look that way...but it feels smooth to my finger so I dunno what that is about. Maybe it's just the temper on the metal is different there?
EDIT: actually now that I look at it, that's just because the point of the lobes on cylinder 2 happened to be facing the camera in that shot of the valve train.
__________________
Old 03-11-2008, 02:29 PM   #8
EagleEyez
I am Prelude
EagleEyez's Avatar
EagleEyez has a spectacular aura aboutEagleEyez has a spectacular aura about
Lookin good bro......thanks for the REP. You got trigger happy with that camera huh? LOL
__________________
Jason was an Army Ranger...if it's too much for him we might as well just pack up our balls and go home.
"I have captured and secured the H22 beast! Let the building comence"!
"The beast has been borne again! Test drive proves....."Masterpiece"
-Hand Built by EagleEyez-
EagleEyez is offline   Reply With Quote Quick reply to this message
Old 03-11-2008, 02:38 PM   #9
JLude
JLude's Avatar
LOL, yea that's only about 2/3 of the pictures I took, too!
I figured if you're going to do a writeup, more pictures is always better!
__________________
Old 03-11-2008, 02:48 PM   #10
EagleEyez
I am Prelude
EagleEyez's Avatar
Oh so true. Its much easier to see it rather than read it!
__________________
Old 03-11-2008, 03:13 PM   #11
daluder
Lude Boss
daluder's Avatar
daluder is on a distinguished road
wow...amazing write-up. Write-ups usually make me wanna attempt things but doing a timing belt job is totally out of my league. lol props to you! So...how much would you charge for you to do this? lol with Manual tensioner. How many cases of beer would it take? lol
oh yeah, I tried to rep you but it told me to spread the love to someone else before giving it to you again. lol
__________________
2008 World Series Champions Philadelphia Phillies
holy sh*t..holy sh*t..
daluder is offline   Reply With Quote Quick reply to this message
Old 03-11-2008, 03:24 PM   #12
pacman
True Luder
pacman's Avatar
pacman is on a distinguished road
Awesome writeup. Too bad I already paid like a grand to have Honda to do this :P
I was too chicken to try that crank bolt.
__________________
You just like it loud and ricey sounding, he is an old man, let him lose 5 hp becuase its a tiny restrictive, remember old people and loud dont mix....
pacman is offline   Reply With Quote Quick reply to this message
Old 03-11-2008, 03:43 PM   #13
Smitty2001
Lude Boss
Smitty2001's Avatar
Smitty2001 has a spectacular aura aboutSmitty2001 has a spectacular aura about
Awesome stuff. Thanks for the great write up! Rep Given for sure.
__________________
Smitty2001 is offline   Reply With Quote Quick reply to this message
Old 03-11-2008, 03:53 PM   #14
masonhenson
True Luder
masonhenson's Avatar
masonhenson is on a distinguished road
i was considering trying this over the summer.. definitely not
__________________
masonhenson is offline   Reply With Quote Quick reply to this message
Old 03-11-2008, 04:04 PM   #15
LEGiTLUDA
Ludacious
LEGiTLUDA's Avatar
LEGiTLUDA will become famous soon enough
i also need to see the pic of this great Man JLude
awesome job
__________________
LEGiTLUDA is offline   Reply With Quote Quick reply to this message
Old 03-11-2008, 04:16 PM   #16
Kinetic_Lude
Lude Dude
Kinetic_Lude's Avatar
Kinetic_Lude is on a distinguished road
So it's safe to break loose the crank pulley bolt at a shop then drive the car?
__________________
Cardomain Page ->
Kinetic_Lude is offline   Reply With Quote Quick reply to this message
Old 03-11-2008, 04:53 PM   #17
JLude
JLude's Avatar
At least 15, 12-bottle cases of corona, killians and Heinies! It's a LOT of work. I really don't feel like going through that again anytime soon!
lol.
awesome job
You mean this mug?
Have it broken loose, then have them apply a small amount of antiseize lube and retorque it to 80 or 100 ft lbs. It won't go anywhere on one drive. Then back at home it was easy to break loose again with the breaker bar. Thanks to Jason (EagleEyez) for breaking my SOB of a crank bolt loose!
__________________
Old 03-11-2008, 06:02 PM   #18
asianchinotyper
Elite Member
asianchinotyper is on a distinguished road
Send a message via AIM to asianchinotyper
thats an excellent writeup.. mad props to u, you could have done this job alot quicker yet u wanted to help everyone else out and take pictures =]
asianchinotyper is offline   Reply With Quote Quick reply to this message
Old 03-11-2008, 08:45 PM   #19
LEGiTLUDA
Ludacious
LEGiTLUDA's Avatar
You mean this mug?
now i know my hero's face
__________________
Old 03-11-2008, 09:25 PM   #20
fix
Getting Comfortable
fix is on a distinguished road
Awesome write up! I did this same procedure about a month ago and this really would have helped.
__________________
2001 SH
fix is offline   Reply With Quote Quick reply to this message
Old 03-11-2008, 09:33 PM   #21
WPTpokeRS
Lude Dude
WPTpokeRS's Avatar
WPTpokeRS is on a distinguished road
wow... i'll bookmark this page
__________________
RAY "the Poker GOD!!!"..."I can always use a woman's touch."
WPTpokeRS is offline   Reply With Quote Quick reply to this message
Old 03-11-2008, 10:12 PM   #22
AkumaR6
Lude Dude
AkumaR6's Avatar
AkumaR6 will become famous soon enough
awesome write-up! the only thing i dont get is how you removed the cam and balance shaft seals. i dont see a way to pry them out
__________________
SOLD - 2001 Honda Prelude - JDM Fogs, RSX-S Wheels - Now featuring cleaned EGR ports:
SOLD - 2003 Yamaha R6
Do NOT trust jesus98lude cuz he will not pay you "when he gets the money" like he promised. He went and sold the rims, yet he never has the money. I will remove this if he ever pays me
AkumaR6 is offline   Reply With Quote Quick reply to this message
Old 03-11-2008, 10:15 PM   #23
DarkBB6
Getting Comfortable
DarkBB6 is on a distinguished road
Good write-up, alot of details but I don't think I will ever attempt this.
__________________
2001 Prelude Base:
Engine: AEM CAI
Suspension: Tien S-techs /w Tokico Blues
Exterior: OEM Lip kit, OEM Fogs, 20% Tint, Painted Red Brake Calipers
More to come!!
DarkBB6 is offline   Reply With Quote Quick reply to this message
Old 03-11-2008, 10:24 PM   #24
Krayzie
Lude Dude
Krayzie is on a distinguished road
wtf.... yea I don't feel like breaking my lude by attempting this lol
nice writeup tho!
Jlude: a little off topic but how hard would you say installing a shock/spring combo would be? easy as installing a sway bar?
Krayzie is offline   Reply With Quote Quick reply to this message
Old 03-11-2008, 11:32 PM   #25
2kredbb6
Lude Cray
2kredbb6's Avatar
2kredbb6 will become famous soon enough
Send a message via Yahoo to 2kredbb6
Excellent write up! But like most of the previous posts i cant even attampt to do it myself.. or with dad or with friends.
__________________
Better to be Judged by 12 than to be carried by 6.
PS3 id-AE23
2kredbb6 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Resource For 5th Gens (TSB's/Parts/Sites/Reviews/How-To's) charliec 5th Gen 0 06-19-2004 05:34 PM
3rd gen vs. 4th gen vs. 5th gen maxxboost89 Street Racing 4 10-07-2003 07:33 PM
Anyone have the TSB for the belt tensioner on the 5th gen? ludenutz 5th Gen 7 08-20-2003 06:58 AM
3rd gens suck!!!!!!! - ya you heard me! dcore 3rd Gen 52 10-29-2002 03:15 PM
4th Gen Vs. 5th Gen - Which is better? OniBonesSi 5th Gen 11 10-14-2002 05:51 AM
vB.Sponsors
PreludePower Forums
