WRITE UP!!! Integra Type R TB install (B21) - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 11-22-2007, 12:05 PM   #1
Preludetyper
Lude Cray
Preludetyper's Avatar
Preludetyper is on a distinguished road
Send a message via AIM to Preludetyper
Introduction:
This is a write-up on how to modify and install an overbore 65mm Integra Type R throttle body on to a B21 Intake manifold. This write-up also includes what parts youll need to do the job the RIGHT way, and what tools youll need to complete the mod.
Background info:
First things first. I chose the Type R throttle body for the fact that it did not use the FICV on the bottom of the throttle body. All other b-series uses this valve on the bottom and to me its just in the way. However you could just make a block off plate, but hey...thats more work. I also used a 65mm throttle body (aftermarket). The stock Type R throttle body is a 62mm and would work great as well. And to be honest I believe that the stock Type R throttle body would be an easier mod and install to perform due to a smaller bore. Stock PRELUDE throttle body (left) 65mm Type R (Right)
Picture of other b-series with the FICV on throttle body:
Okay on to the parts and tools....
Here is a parts list that I used to complete this operation:
1. Throttle Body-Type R shown. Other b-series will bolt up the same way once modified. Will require same mod as Type R but others will have the FICV ^^^.
2. Gaskets--All O-rings for sensors and valves on Intake manifold and this includes the FUEL INJECTORS O-RINGS!!!!!-REPLACE THEM!!!
Here are the part numbers I used for the gaskets and O-ringsB21 ONLY)
Honda Pt. #
#16077-PR3-005
#17341-PT2-000
#91304-PE2-005
#36455-PM3-J01
{#18721-PJ0-660} EGR gaskets
{#18715-PB2-000}
Beck/Arnley Pt.# (For B20/B21)
#158-0308 x4
FelPro IM gasket Set
# MS 94836
3. Socket head Allen bolts (M8x1.25mmx30mm) x4 which will be used to replace the studs in the IM that hold the TB on , and other M8x1.25mm bolts in various lengths for replacing other factory IM bolts and studs. The extra bolts are not necessary to change. Can reuse stock bolts.
4. Tools- Of course youll need ratchets, sockets, screw drivers, etc.
Also an air rasp to open up the intake manifold, grinding stones, drill press would help, and a welder<--I didnt use. Scrap pieces of aluminum.
Okay....On to the FUN part.....
Here is a picture of the gasket that has been modified. This is the same pattern that you want to use to drill the holes out on the new TB.
I made these holes in the TB with a drill and an air rasp. It took quite a while to open up the holes enough to pass over the studs on the intake manifold. I drilled and cleaned out the holes until it slid onto the studs. I do not have pictures of the modified throttle body. But I will do the best I can with internet pictures to show how to do all the mods.
Below is a picture of the hole that WAS NOT in my Type R throttle body. So I had to drill this hole so that the air boost valve, FICV, etc would work properly... The hole that needs to be drilled is shown in the pic with a circle. This is not an actual picture of my throttle body, but similar.
Also, the map sensor path will need to be modified. The path on the backside of the throttle body needs to be filled with either aluminum pieces or welded up and filed flush. I pressed pieces of aluminum into the area. The reason being is that the bigger throttle body is wider. Being that the map sensor path has to go around the outside of the bore, it results in the path being exposed to the atmosphere. The path actually goes outside of the gasket and outside of the edge of the Intake manifold. So Here is a pic of where to modify the path. To finish with the map sensor path youll need to put a vacuum "T" or 90 into the hole where the map sensor would bolt up on any newer honda. Pic below
Here is pic of vacuum 90 I pushed into the hole up-top....
Here is a picture of the back with drawn on modified holes.
Okay you are now done with the TB modification. I hope that this helped. On to the Manifold....
The Intake manifold
The intake manifold needs to be completely disassembled. All sensors and valves must be removed and gaskets replaced. I also removed the injectors. But before you reassemble the manifold you will need to have the plenum over bored to match the bore of the throttle body. I also slightly ported and polished my plenum and runners. I bored mine out with an air rasp with a grinding stone until desired size. Worked really well!!! Then I polished the inside once again to achieve a smooth finish. After all the machine and grinding, and cutting were done on the manifold I then took it to a machine shop to have it acid dipped. That way all of the metal shavings were removed and the outside would be clean like new!! You then want to remove all the studs on the plenum so that you can replace them with the socket head allen bolts. YOU HAVE TO DO THIS!!! If not you will never get the throttle body bolted to the IM due to the fact that the nuts will rub the outside diameter of the TB. The reason they will rub is because after you move the 2 right side holes over then they are too close to the TB outside bore. SO, to fix this problem I removed the studs and replaced them with socket head allen bolts. BUT you have to modify the heads of the bolts to be used in the modified holes. To do this I put the threaded end of the 2 bolts into the chuck of a cordless drill. Then I got a part-off wheel (Grinding disc). I used the drill to spin the bolt and the grinder to grind the size of the bolt head down, so that it will fit through the TB and not rub the bore. Here are some pics of the stuff described above:
More pics of Manifold and gaskets:
Fuel Injector O-RINGS
Modified Bolts
Sensor/valve gaskets for IM
Okay guys I think that about wraps it up....If I see any problems Ill edit the post, but I think I covered all that I can. I hope this helps some of you guys out that would like to tackle this modification. Some of you turbo guys could really benefit from this. Well here it is and GOOD LUCK!! GIVE ME SOME REP!!
__________________
CHECK OUT MY B20A5 BUILD UPDATES AT TOP OF POST!
LUDE OR GET LUDED!
Preludetyper is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-22-2007, 12:41 PM   #2
boostedlude3g
master bater
boostedlude3g's Avatar
boostedlude3g will become famous soon enough
Send a message via AIM to boostedlude3g
Prelude of the Month
Very nice. Long awaited and worth it.
__________________
-wayne-
310whp 296tq
Originally Posted by bnr324life
btw wayne,
that sweater your wearing beside your lude is super gay, nice car tho.
Originally Posted by King Prelude
A fusion of current and late model Japanese muscle == One heavily modded 3rd gen...Something you dont see everyday.
boostedlude3g is offline   Reply With Quote Quick reply to this message
Old 11-22-2007, 12:52 PM   #3
redloudlude
Lude Boss
redloudlude's Avatar
redloudlude has disabled reputation
Dam that must lay some power down just add more fuel, I say rc injectors.
__________________
black 89 prelude h22a ,red 89 b20a5, 3rd gen nothing better!
redloudlude is offline   Reply With Quote Quick reply to this message
Old 11-22-2007, 03:05 PM   #4
CADster
Kickass truck missed
CADster's Avatar
CADster will become famous soon enoughCADster will become famous soon enough
hell yea.... very, very cool !!!!
thanks for this. i already bought a bigger TB and
was just waiting on how this was going to pan out.
question -
why does this path need to be modified ?
seems to me that it goes to the same place,so why would it matter ?
great writeup and i was just playing in the other thread
__________________
"Straight-line acceleration is probably the first aspect of automotive performance
that any intelligent driver gets bored with." - Peter Holden Gregg
CADster is offline   Reply With Quote Quick reply to this message
Old 11-22-2007, 03:13 PM   #5
flylwsi
REST IN PEACE
flylwsi's Avatar
flylwsi will become famous soon enoughflylwsi will become famous soon enough
Send a message via AIM to flylwsi
does it go somewhere different on the IM and needs the path rerouted?
does seem it goes to the same place... (to the center of the bore)
Never pay again for live sex! | Hot girls doing naughty stuff for free! | Chat for free!
__________________
GPS lap timers... 10% off w/code: 4280f1
antypoetry: i can't help it
heyfrench: nah, they're retards
heyfrench: and they make you have to be a dick
flylwsi is offline   Reply With Quote Quick reply to this message
Old 11-22-2007, 03:49 PM   #6
secluded luder
secluded luder will become famous soon enough
Send a message via AIM to secluded luder Send a message via Yahoo to secluded luder
Is there a cost analysis of what you spent?
secluded luder is offline   Reply With Quote Quick reply to this message
Old 11-22-2007, 04:33 PM   #7
Preludetyper
Lude Cray
NO you must redo the MAP path. Re-read my post. It says that the TB is WIDER than the IM. Being that the bore is bigger the map path is also bigger and it makes it come out past the edge of the IM. NOT to mention that the NEW bolt hole crosses into the edge of the MAP path. Heres an Illustration.....
__________________
LUDE OR GET LUDED!
Old 11-22-2007, 05:27 PM   #8
team123luder
Elite Member
team123luder's Avatar
team123luder has a spectacular aura aboutteam123luder has a spectacular aura aboutteam123luder has a spectacular aura about
Send a message via AIM to team123luder Send a message via MSN to team123luder
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
__________________
SOLD!!!
team123luder is offline   Reply With Quote Quick reply to this message
Old 11-22-2007, 06:00 PM   #9
Preludetyper
Lude Cray
Throttle body = $140.00
Gaskets=$100.00
Hardware=$35.00
Total=$275.00
__________________
LUDE OR GET LUDED!
Old 11-22-2007, 06:20 PM   #10
dankvilla
Elite Member
dankvilla's Avatar
dankvilla is on a distinguished road
how much would you charge to just do it?
dankvilla is offline   Reply With Quote Quick reply to this message
Old 11-22-2007, 06:34 PM   #11
Preludetyper
Lude Cray
Ummm....I have no idea. It wouldnt be cheap though.
__________________
LUDE OR GET LUDED!
Old 11-22-2007, 07:33 PM   #12
curtis12
curtis12 is on a distinguished road
That is awsome great write up. Looks very clean. When you bored out the plenum, did you bore it out with with the drill press and grinding stone? Did you do the same with the intake runners, or did you send it out and have a machine shop do it before you got it dipped?
curtis12 is offline   Reply With Quote Quick reply to this message
Old 11-22-2007, 08:33 PM   #13
Whit90si
Ludacious
Whit90si's Avatar
Whit90si is on a distinguished road
Great work I love the knowledge base, the group buys, and all the other stuff here on PP.com.... But my favorite is the custom mods that guys like you MAKE WORK. Great ingenuity.
__________________
1990 Prelude Si ~ since 1993
1991 Prelude 2.0Si ~ in pieces
1999 Honda XR250R
2000 F350 7.3 liter diesel
Whit90si is offline   Reply With Quote Quick reply to this message
Old 11-23-2007, 05:30 PM   #14
Preludetyper
Lude Cray
Well I hope that this write up was helpful to those of you that looked at it, and are interested in the modification. I would like for this thread to be stickied if possible, for future luders.
__________________
LUDE OR GET LUDED!
Old 11-23-2007, 06:33 PM   #15
indy3gSi
Lude Addict
indy3gSi's Avatar
indy3gSi has disabled reputation
Send a message via AIM to indy3gSi
noticeable power gain?
__________________
indy3gSi is offline   Reply With Quote Quick reply to this message
Old 11-23-2007, 06:47 PM   #16
team123luder
Elite Member
I ran a 60mm TB and noticed a nice power gain... especially midrange
__________________
SOLD!!!
Old 11-28-2007, 09:40 AM   #17
1funryd
Elite Member
1funryd's Avatar
1funryd is a jewel in the rough1funryd is a jewel in the rough1funryd is a jewel in the rough1funryd is a jewel in the rough
Send a message via AIM to 1funryd Send a message via MSN to 1funryd Send a message via Yahoo to 1funryd
I added this to the **3rd Gen Performance Upgrade Inventory** for all to see, under the FAQ sticky's.
Sean
__________________
My Facebook page -
Sean
3rd Gen Aftermarket Manager
(Clik Here)
Email:
(1Funryd - H22 Swap) - Ludcifer - INX - MustardCat(B20a)
1funryd is offline   Reply With Quote Quick reply to this message
Old 11-28-2007, 04:44 PM   #18
elmotive
Ludacious
elmotive's Avatar
elmotive is on a distinguished road
Send a message via ICQ to elmotive
Could you give me a link to the 62mm TB Preeludetyper? I want to try that one to see if it fits with less modification. I'm going for medium tuned NA B20A9.
__________________
1991 PRELUDE B20A9 D2A4 2.5 INCH CUSTOM MADE MANDREL BENT EXHAUST AC CC LEATHER POWER DOOR LOCKS-WINDOWS-SUNROOF-MIRRORS ADJ HEADLIGHTS POWER STEERING 215/40-16 2WS BLACK CENTER ARMREST FRONT AND REAR CROSS DRILLED ROTORS HEATED AND ELECTRIC FOLDING MIRRORS HEATED FRONT SEATS OEM REAR BOOT LID WING OEM FRONT AND REAR LIP
x2 elmotive we're makin a team today! your stealing the words right out of my mouth, its making my life way to easy haha
elmotive is offline   Reply With Quote Quick reply to this message
Old 01-30-2008, 07:49 PM   #19
plushh
Elite Member
plushh's Avatar
plushh is on a distinguished road
Send a message via AIM to plushh
that is awsome!
good work
__________________
--------Write ups and projects--------
plushh is offline   Reply With Quote Quick reply to this message
Old 02-17-2008, 10:11 AM   #20
VTEC Inside
Elite Member
VTEC Inside's Avatar
VTEC Inside is on a distinguished road
Send a message via ICQ to VTEC Inside Send a message via Skype™ to VTEC Inside
Very nice write up!
I was just wondering can you bore the plenum to 65mm? I read from motoxxxman that you can't bore more than 62mm.
__________________
My B20A9 TURBO BUILD:
My TRANNY REBUILD(LSD and Accord 5th gear):
Check out my rides
THE POWER OF DREAMS
VTEC Inside is offline   Reply With Quote Quick reply to this message
Old 11-18-2008, 06:23 PM   #21
yota4x405
True Luder
yota4x405's Avatar
yota4x405 is on a distinguished road
I know that this is an old thread but I was just wondering why we cannot just use an aftermarket throttle body for an f22 it is a direct bolt on and just the stock one is like .5mm larger than ours (I found out about the direct bolt on out of desperation needed 1 tried 1 u know)
__________________
Y-49 88 Si B20a5 Turbo 203hp @ 6100 and 197 @ 3100 on 11psi t-25 .48 trim
R-51 89 Si B20a5 bone frigging stock
The only reason water is used threw a turbo is for stock setups. It actually heats the turbo up quicker so its at operating temperature faster. Sorry, but im not into running hot ass water through my turbo.
Classic moron!!!
WTB:
Nussing right now
yota4x405 is offline   Reply With Quote Quick reply to this message
Old 11-18-2008, 06:44 PM   #22
1funryd
Elite Member
1funryd's Avatar
If it works then, post pictures and do a write up. No one has said anything because know one has tried or they did not want to share their experiment.
__________________
My Facebook page -
Sean
(Clik Here)
Email:
Old 11-18-2008, 06:46 PM   #23
yota4x405
True Luder
yota4x405's Avatar
gotcha im not real good at how to's or pics but i will do my best
__________________
Classic moron!!!
WTB:
Nussing right now
Old 11-18-2008, 07:00 PM   #24
1funryd
Elite Member
1funryd's Avatar
How to post up pictures you want show:
1. Go to www.photobucket.com and register(its free)
2. Upload your pictures. Once your photos are uploaded, just clik on the photo you want to link to your post or thread. Make sure to keep the thread open in a separate window so you will be able to "copy & paste" to your post reply.
3. Right clik on the photo after you have opened up your photo.
4.Select "Properties"
5. Highlight the Address(URL) example:
http://i53.photobucket.com/albums/g63/seantydingco/ps4.jpg?t=1174847693
6. Right clik on the highlighted Address(URL) and clik "copy"
7. Now go back to the Post Reply window and clik on the "Insert Image" icon will look like this below.
8. Now just erase whatever is in the address bar, and right clik in the address bar and paste the (URL)Address into the address bar, and clik "OK"
9. Your picutre will be linked to your post. Now just repeat the process for anymore pictures you want to link.
Now hurry up and show us what you are talking about. We like pictures!!!
Sean
__________________
My Facebook page -
Sean
(Clik Here)
Email:
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
H22 Vtec SWAP conversion WRITE uP; An Introduction. Long. afterburners 3rd Gen 89 06-02-2012 09:35 PM
ludespeed turbo kit installation instructions??? jdmSiT 3rd Gen 8 09-05-2009 07:48 PM
Japanese Kids Show Features TYPE R Integra, S2000, skids... LOL m1k30rz General 19 04-16-2007 08:18 AM
Integra Type R 96 Spec!!!!!!! 2000BB6 General 26 04-06-2006 05:28 PM
JDM H23A Information?? Qnz92Lude 4th Gen 40 01-29-2006 12:00 AM
vB.Sponsors
PreludePower Forums
