Axle Removal **write-up** - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 11-13-2006, 04:20 PM   #1
1funryd
Elite Member
1funryd's Avatar
1funryd is a jewel in the rough1funryd is a jewel in the rough1funryd is a jewel in the rough1funryd is a jewel in the rough
Send a message via AIM to 1funryd Send a message via MSN to 1funryd Send a message via Yahoo to 1funryd
Axle Removal **write-up**Updated 1-27-07
Update to the thread is a video for a Honda Accord that is the same procedure as our ludes, the differences will the way the tie rod is sitting but everything this guy does is the correct way to replace an Axle in our cars and most other cars as well.
Replacing an Axle in a Honda: http://yootuubee.com/video/WSdSmH2xa...)-honda-accord
Here is another write-up organized by me through the help of other Luders experience. These pictures are for illustration only and are not an actual Lude, but still the same procedure.
I will update pictures and pertant information as I come across it.
And since this is related to "Lower Ball Joint Removal" here is the link to that thread:
Front Lower Control Arm Ball Joint *Write-Up*
I would also like to add this link for those who want to rebuild their - CV Joints -
Half Shaft - CV Joint Repack and Boot Replace
This write up is very informative and helpful to the do it yourselfer's out there.
**Write-Up**
1 Remove tire(s) - Lug wrench
2 Remove axle nut (have fun! easier with tire on ground and center cap removed for axle socket to fit through) 36MM for 90-91 or 32MM for 88-89
Make sure to take a chizzle or flat head screwdriver to bend out that little notch that is indented toward the groove on the axle. You will see what I mean when you take off your wheel cap.
(please note that depending on when and who changed out the axle last, the axle nut might differ in size - 32-36, so please check this before doing anything as to not waste time.)
You will need these tools, but an impact gun is always the easiest way to go.
3 after jacking car back up, remove lower control arm balljoint nut - 17mm?
4 use tie rod end puller to undo lower ball joint (careful of threads!)
(This is also a ball joint puller, it is safer so as not to damage the ball joints, but if you are replacing the whole ball joint as well, you can use a pickle fork as well. Please remember this for illustration and is to show you how to use this tool, this is not the actual ball joint you are going to remove at this time, unless you decide to do it at the same time since you will have everything off.)
Pickle Fork Method, this is the acutual ball joint that will be removed while removing the axle.
5 undo bottom of shock from lower control arm - 17 mm...2 two of them since the bolt will spin - remove that bolt
6 separate the knuckle and slide it out the way while the axle slides out of it then pry the tranny side with a large flathead or prybar.
Please note, that you might have to take a solid peice of metal like the back end of a chizzle, and use it to pound out the axle if it does not come out easy.
When you start pushing it out it will look like the picture below, you will need to push it out, you might need a pry bar to help relieve tension on the supension to get out, but it will come out, so just keep working at it.
Do not over pound it if it is not moving as you will start to damage that end of the axle.
I hope this helps out everyone!
Sean
__________________
My Facebook page -
Sean
3rd Gen Aftermarket Manager
(Clik Here)
Email:
(1Funryd - H22 Swap) - Ludcifer - INX - MustardCat(B20a)
1funryd is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-17-2006, 08:26 AM   #2
Chief Mac
Getting Comfortable
Chief Mac is on a distinguished road
1funryd,
Hafa Adai’ Bro, great write-up on the axle shaft(s) R&R. Autozone is a prime source for renting tools that makes this job easier, too. Just be aware that the use of a pickle fork sometimes damages tie rod and ball joint grease boot(s) beyond usefulness. So if anyone is expecting to reuse the grease boot(s) for either tie rod or ball joint, do not damage the grease boot(s). Grease is the lubrication that makes our components survive as long as they do. The tool rental is not expensive and you get some money back when you return the tool undamaged, at least this has been Autozone’s policy from since forever.
Great Job on this write-up, Bro. The community needs this kind of procedural knowledge shared and often. The inclusion of pictures really helps your discussion points. I am glad to assist if called on.
Chief Mac
Chief Mac is offline   Reply With Quote Quick reply to this message
Old 11-17-2006, 11:09 AM   #3
gatkins94
Elite Member
gatkins94 is on a distinguished road
I love to see this type of help!
Thanks for taking that time!
gatkins94 is offline   Reply With Quote Quick reply to this message
Old 11-17-2006, 06:41 PM   #4
mtllude
mtllude is on a distinguished road
i know i'll prolly get flammed for this... but if you whack the lower control arm on the side, right next to where the ball joint goes in, as long as the nut and cotter pin is out, the ball joint will pop out... don't destroy the control arm, but if you have no puller or pickle fork... it works well, and is much faster...
mtllude is offline   Reply With Quote Quick reply to this message
Old 11-17-2006, 06:54 PM   #5
dano
Prelude Aficionado
dano has disabled reputation
Nope..that is the classic way to get a "tapered pin" joint apart. The problem is that you really need to whack the joint at more than one spot, and that can be a problem.
I must add this... When you reattach the strut fork to the lower control arm don't tighten the long bolt (grease that puppy) and nut all the way until the weight of the car moves the arm to normal ride height. In other words put a jack under the outer ball joint and jack it up till the car begins to move or run the car up onto ramps. If you tighten this bolt with the suspension hanging, you will preload the rubber bushing which is ungood. Ditto for the inside lower control arm bushing..but I'm not sure why that was removed for this job.
__________________
dano is offline   Reply With Quote Quick reply to this message
Old 11-17-2006, 07:38 PM   #6
Import_Tuna
Rep me if you hate my ass
Import_Tuna's Avatar
Import_Tuna will become famous soon enoughImport_Tuna will become famous soon enough
Send a message via MSN to Import_Tuna
Dano is correct. You always must torque suspension fasteners with the wheels on and with the car resting on the floor. Of course, doing it this way is often a real pain in the ass, so you can simulate the car being in a relaxed position by jacking up underneath the lower ball joint just as Dano described. Much easier.
I have to draw attention to this picture. In school last year, we learned that you're really not supposed to let the axle hang all willy nilly. Of course, if you're replacing it, it doesn't matter, but normally, if you're reusing the axle, you should support the outboard end of it with mechanic's wire or with a rope or something. Otherwise, I would think that allowing the axle to hang in such an extreme position might put unnecessary stress on the inboard joint, and in the big picture, this could shorten its life.
--J
__________________
IF2 Purple Dildo Group Buy Manager
Danny's birthday wishes are worth less than the feces and breadcrumb pie Tuna baked last night.
this entire thread is now considered a bunch of overreacting, false assumptions, misunderstandings, miscommunication, lack of communication, and opinions based on hatred that was based on all of these previous things.
Import_Tuna is offline   Reply With Quote Quick reply to this message
Old 11-17-2006, 11:27 PM   #7
montx
Lude Addict
montx is on a distinguished road
Send a message via MSN to montx
Really great write-up. Thanks for the hard work! I'm currently STUCK at the damper fork bolt. T hat bitch is a BITCh to get out lol
__________________
montx is offline   Reply With Quote Quick reply to this message
Old 11-29-2006, 07:40 PM   #8
1funryd
Elite Member
1funryd's Avatar
Bump for those looking!!
__________________
My Facebook page -
Sean
(Clik Here)
Email:
Old 11-29-2006, 08:51 PM   #9
Hprelude5R
Hprelude5R's Avatar
Hprelude5R will become famous soon enoughHprelude5R will become famous soon enough
Has this not been added to the FAQ?
Don't look at me, just asking.
Hprelude5R is offline   Reply With Quote Quick reply to this message
Old 11-29-2006, 09:24 PM   #10
scPrelude
Lude Cray
scPrelude's Avatar
scPrelude is on a distinguished road
Send a message via AIM to scPrelude Send a message via Yahoo to scPrelude
(((THUMBS UP)))..once agian great work! ((pats you on the back))
__________________
1988 Si 4ws b20a a few mod's
2001 Yamaha Warrior w/ 06 raptor motor (350)(AKA: WAPTOR)
2010 Harley-Davidson Sportster Iron 883 matte silver!
Operation Iraqi Freedom/Operation New Dawn 2010-2011
**DONATE TO PRELUDEBIBLE.COM To donate through Paypal, the Paypal ID is: ***
What is life without honor? Degradation is worse than death.
TO HELL W/ WINDOWS.. I RUN LINUX
scPrelude is offline   Reply With Quote Quick reply to this message
Old 11-30-2006, 06:25 AM   #11
Ben1818
True Luder
Ben1818 is on a distinguished road
now how about rebuilding them getting them out is the easy part
Ben1818 is offline   Reply With Quote Quick reply to this message
Old 11-30-2006, 08:35 AM   #12
dano
Prelude Aficionado
Rebuilding is pretty much limited to re-packing with grease and putting on new boots. Pretty simple. Unless your axel had a torn boot and you caught it right away, you are probably better off with a rebuilt axel for some place like PEP BOYS.
__________________
Old 11-30-2006, 11:22 AM   #13
88SE Lude
Prelude Aficionado
88SE Lude's Avatar
88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of
Why go to the trouble and extra time of removing the lower arm?
It's not needed and I never do that unless I'm removing it anyway.
you can leave the lower arm in place and just remove the damper fork from the arm and damper.
__________________
"You are not entitled to an opinion. An opinion is what you have when you don't have any facts. When you have the facts, you don't need an opinion"
MustardCat - "You have free access to people with decades worth of experience here. Being asked to format your posts in a readable manner is very reasonable. Call your local Honda dealer and see how much they want per hour to have a master tech diagnose your problem..."
88SE Lude is offline   Reply With Quote Quick reply to this message
Old 01-27-2007, 03:01 PM   #14
1funryd
Elite Member
1funryd's Avatar
Exclamation Update on the front page!
Check the front page for an updated pic of the axle
Sean
__________________
My Facebook page -
Sean
(Clik Here)
Email:
Old 01-27-2007, 04:37 PM   #15
Bobnova
New title is new
Bobnova's Avatar
Location: Humboldt County (FAR northwest CA, on the coast)
Bobnova has a spectacular aura aboutBobnova has a spectacular aura about
Send a message via AIM to Bobnova
Don't remove the lower control arm bushing, only the ball joint.
Don't remove the tie rod end, either.
Only the balljoint at the end of the lower control arm, and the shock mount.
You can then lift the hub up out of the lower control arm (once it's broken free) and push it to the side once you have the axle out.
No need to remove the upper end of the shock mount, either.
__________________
--Bobnova '89 2.0SI 4ws(309k miles), '76 Triumph TR7 FHC (63k miles)
24 years of professional automotive experience, specializing in Honda/Toyota/Subaru.
Bobnova is offline   Reply With Quote Quick reply to this message
Old 05-17-2009, 11:14 AM   #16
Shadly
Lude Cray
Shadly's Avatar
Shadly is on a distinguished road
Trying to get that fork bolt out. It's really pissing me off. I broke two screwdriver tips off in trying to bend the notch out, so they're stuck in there. Also, I was going to track down an impact wrench to have at it. I tried a 32 mm socket, and it looks like it is just chipping the bolt. Is there anyway that it could be smaller than this or is that out of the question? Does anyone have any other suggestions for me?
Shadly is offline   Reply With Quote Quick reply to this message
Old 05-17-2009, 12:55 PM   #17
3rdgenpartfinder
3rdgenpartfinder has a little shameless behaviour in the past
u must have alot of rust
3rdgenpartfinder is offline   Reply With Quote Quick reply to this message
Old 05-17-2009, 01:00 PM   #18
Shadly
Lude Cray
Shadly's Avatar
If you had to cut it, is the bolt you would be screwing up in the process be from the axle, or is it something connected to the HUB? In other words, what does that nut connect to: the axle I am replacing, or something I need to be functional afterwards?
Old 05-17-2009, 01:59 PM   #19
Shadly
Lude Cray
Shadly's Avatar
Took my Dremmel to it with a cut off tool.
That's right you son of a bitch, get the fuck off my car.
Old 05-17-2009, 03:23 PM   #20
thisbejeffe
Lude Addict
thisbejeffe is on a distinguished road
Send a message via AIM to thisbejeffe
I still need to buy a dremmel! I hear they are one of the best tools you can own.
__________________
1988 Honda Prelude 4ws - Sold 9/30/11
1999 Honda Prelude Base
thisbejeffe is offline   Reply With Quote Quick reply to this message
Old 05-17-2009, 03:50 PM   #21
Shadly
Lude Cray
Shadly's Avatar
How do you get the axle back into the tranny? That metal ring on the axle on that side seems to be preventing it. What is the purpose of this ring besides keeping you from fixing your car?
Old 05-17-2009, 05:15 PM   #22
1funryd
Elite Member
1funryd's Avatar
Use a rubber malet and bang the axle into the tranny from the outer spline, not too hard though, just enough force to pop it back in.
__________________
My Facebook page -
Sean
(Clik Here)
Email:
Old 05-17-2009, 05:50 PM   #23
Shadly
Lude Cray
Shadly's Avatar
I got Humpty Dumpty back together again. The braintrusts that work at my local Autozone sold me the wrong axle. That's why it didn't just "snap" into place.
Old 08-27-2010, 03:35 PM   #24
luda lover
Newbie
luda lover is on a distinguished road
half of those guys dont even know what kind of oil to put in a manual transmission.
luda lover is offline   Reply With Quote Quick reply to this message
Old 10-19-2010, 01:20 PM   #25
3gPreludetuner24
Lude Boss
3gPreludetuner24's Avatar
3gPreludetuner24 is on a distinguished road
Prelude of the Month
Lol.....yup....I remember one of those morons told me it was ok to used Automatic Transmission fluid in my MT. LMAO! What an idiot. Hahahahahah..He was dead serious too. I told him that was not true and that it would cause serious problems to a MT. Fuken Vatozone!!!!!!!!!!
3gPreludetuner24 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
