3rd Gen_ H22 Swap Part Deux: The Remountening - Page 2 - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 05-03-2015, 11:34 PM   #26
Beagles
Lude Cray
Beagles's Avatar
Beagles is a jewel in the roughBeagles is a jewel in the roughBeagles is a jewel in the roughBeagles is a jewel in the rough
It's always a pleasure to watch your progress mustard. You have what seems to be a very zen approach to the 3rd gen.
"I'd like more ground clearance from this H swap... guess I'll just get more ground clearance."
Keep up the amazing work!
Beagles is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-06-2015, 03:35 AM   #27
frijoles
Elite Member
frijoles's Avatar
frijoles will become famous soon enoughfrijoles will become famous soon enough
Hot damn, that's nice.
Ground clearance was the whole reason I decided against the H swap and I changed to a B swap.
__________________
Build thread:
Accord Wagon build thread:
frijoles is offline   Reply With Quote Quick reply to this message
Old 05-08-2015, 01:02 PM   #28
RobbieRob
Getting Comfortable
RobbieRob is on a distinguished road
Nice fabrication man. Looking good
RobbieRob is offline   Reply With Quote Quick reply to this message
Old 05-09-2015, 11:15 PM   #29
MustardCat
Memento Mori
MustardCat's Avatar
MustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the Internet
I really thought I would learn to live with it. Never did.
Thanks.
8 MAY 15:
Making some poly bushings work for the radius rods. I'm using a 13mm socket shoved into the center hole as a centering device for the 7/8" holesaw:
Checked header clearance on the front subframe, all good:
I had a big downpipe dent from a previous "incident". I welded a spare bolt onto it and used a prybar to work it out:
Here is where I bent the clutch dampener for now:
9 MAY 15:
Paint day.
Rear subframe:
Hood:
There were two problems with the engine finish. I originally painted it during the winter and I think some moisture was trapped under the paint. That caused bits of bad oxidation to poke through everywhere. Also the VHT paint I used (which I've used on blocks before) turned yellow this time for some reason. I sanded all the old stuff off and painted it with 500 cast aluminium paint from Duplicolor this time:
MustardCat is offline   Reply With Quote Quick reply to this message
Old 05-10-2015, 10:34 PM   #30
MustardCat
Memento Mori
MustardCat's Avatar
10 MAY 15:
Did a little bit today, got side tracked by other stuff.
Reinstalled hood:
Installed upgraded end links and poly bushings for front swaybar:
Took the mounts apart and prepped them to get powder coated:
Old 05-10-2015, 11:49 PM   #31
cudaboy
Elite Member
cudaboy's Avatar
cudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internet
Send a message via Yahoo to cudaboy
So is that what is needed to make those strut rod bushings work on stock 3rd gen front subframe? I figured it would be something simple like that. I have just been holding off installing everything as I am trying to save money for purchasing used steering knuckles/hubs so they can be powder coated like my control arms only gloss black instead of charcoal metallic with clear for the arms. I just have had to put the money into other stuff lately.
By the way those bushings your using should be a direct fit for the rear strut/radius rods.
I have had my bushings laying out waiting on me to take some corrective pictures but I have sorted through almost all that. When I get some time I will relist / rehost a ton of prothane es bushing pics.
I actually have all three sets of Honda / acura bushings for these strut radius rods. Plus I got to add those integra or what ever the cross reference was that was a perfect fit for press in polyurethane whiteline that 10kpos or someone tried after what Jon has said all this time would work. Uca's. It be nice to know if prothane got their shit together and started supplying the right bushings for that model. The ones Sean got for the uca from prothane would fall right through the collars of the stock 3rd gen collars.
__________________
CUDABOY'S STRUT TOWER BAR GROUP BUY: I HAVE 1 FRONT OF BLACK ON BLACK W/SILVER BAR FRONT $150/SH +3 SETS F/R U CHOOSE COLOR MINI G.B. $265 SH.
'91 Si 4ws 5spd(black) "Black Betty"
'70 'Cuda 340 C.I.D. Alpine White, Black Vynil Top, Leather Interior, Rim Blow, Overhead Consolette. Factory Posi 3.55:1, 15" ralleyes, --Fully Loaded and Extremely Rare!
cudaboy is offline   Reply With Quote Quick reply to this message
Old 05-11-2015, 08:48 AM   #32
frijoles
Elite Member
frijoles's Avatar
I found that the CB7 radius rod bushings fit perfectly in the rear radius rods, however, I never bought the front ones as I was always planning on just running rod ends.
__________________
Build thread:
Old 05-18-2015, 11:32 PM   #33
MustardCat
Memento Mori
MustardCat's Avatar
I'm still waiting to get the mounts back from powder coating, they should be done Wed or Thurs. I also sent the injectors out for a cleaning and flow test. Those should be back any day now as well.
18 MAY 15:
I painted the modified radius rod and front subframe. I also added some spacers to the crossmember:
The P28 I'm using is taller than the stock ECU and I was using some spacers under the mounting plate to give it more room. But I decided to try for a more stock fit by cutting out a section of the mounting plate and having the bottom of the ECU flush with it:
Old 05-20-2015, 09:45 PM   #34
MustardCat
Memento Mori
MustardCat's Avatar
20 MAY 15:
Got the injectors back, one was stuck closed:
Picked up the mounts too. They look professional now:
Motor is going back in this weekend.
Old 05-21-2015, 05:22 PM   #35
2rare2die
Lude Dude
2rare2die is on a distinguished road
wow! very nice work! defiantly going to be watching for more
__________________
88 B20
03 civic Em2
1965 ford f250
86 lude carb. needs work??????
89 s parts lude
2rare2die is offline   Reply With Quote Quick reply to this message
Old 05-22-2015, 12:42 PM   #36
1funryd
Elite Member
1funryd's Avatar
1funryd is a jewel in the rough1funryd is a jewel in the rough1funryd is a jewel in the rough1funryd is a jewel in the rough
Send a message via AIM to 1funryd Send a message via MSN to 1funryd Send a message via Yahoo to 1funryd
Nice work Dave!!!
__________________
My Facebook page -
Sean
3rd Gen Aftermarket Manager
(Clik Here)
Email:
(1Funryd - H22 Swap) - Ludcifer - INX - MustardCat(B20a)
1funryd is offline   Reply With Quote Quick reply to this message
Old 05-22-2015, 10:25 PM   #37
MustardCat
Memento Mori
MustardCat's Avatar
Thanks.
22 MAY 15:
Started to put it all back together today.
Mounts installed:
About half way done:
The crossmember still needs some more spacers to bring it down to the bottom of the downpipe:
Old 05-23-2015, 03:27 AM   #38
frijoles
Elite Member
frijoles's Avatar
How far does it hang now, vs the AZ or ESP mounts?
__________________
Build thread:
Old 05-23-2015, 05:54 AM   #39
ogsmakdade
Ludacious
ogsmakdade's Avatar
ogsmakdade will become famous soon enoughogsmakdade will become famous soon enough
Send a message via AIM to ogsmakdade
top work. I love when people tackle issues head on!
__________________
Wait, is your name "Original Gangster Smack Daddy"?
And I just thought it was awgs-mac-daid this whole time.
preludecentral.com Home of DEPOG
ogsmakdade is offline   Reply With Quote Quick reply to this message
Old 05-23-2015, 07:42 PM   #40
MustardCat
Memento Mori
MustardCat's Avatar
Eh it's hard to say for sure. Right now it's approximately 1" - 1.5" lower than the B20. Off the shelf H mounts probably have it 2.5" - 3" lower than the B20.
B20:
From today:
23 MAY 15:
I made a little mistake. I didn't check the left axle clearance with the axle, I just eyeballed it. When I put it in the boot was touching the subframe lightly. Luckily there was enough room to work and modify the subframe without pulling the motor again.
I forgot the before picture but here are the afters:
When I was about to put the right axle in I peeked into the diff and saw a shape that didn't make sense. Fished this out with some pliers:
Rare JDM sunflower seed for sale, $200.
I'm almost done in the bay, just a little clean up left:
Here is a side view of the overhang and ground clearance, AZ vs now:
Tomorrow I'm going to put together a lightweight front bumper cover support so I can hang the front end and then start working on the ECU/wiring stuff.
Old 05-28-2015, 09:16 PM   #41
MustardCat
Memento Mori
MustardCat's Avatar
28 MAY 15:
Still ongoing.
I made the bumper cover support:
Got the ECU plate sorted out:
Installed for testing, what a mess:
I took the car for a test drive. Everything works and the mounts didn't explode either! Runs way smoother than before since I'm using 62A urethane and don't have the motor pry bared into place for belt clearance. Power is way better too it seems, the basemap I chose in Neptune this time is for a H22 with bolt on's so it's fairly close.
I've got some of the final poly bushings for the suspension I need coming then I will be able to align it. I also cleaned the car really well and took some insane stuff off the paint with a claybar, but I still need to hit it with the polisher.
Finally the valve cover is also off right now getting powder coated because it was suffering the same paint issues the block was.
Old 05-28-2015, 11:57 PM   #42
cruz85
True Luder
cruz85's Avatar
cruz85 has disabled reputation
threads like this make want to keep my lude.
__________________
Gallery:
cruz85 is offline   Reply With Quote Quick reply to this message
Old 05-29-2015, 06:30 AM   #43
ReyKe
Prelude Aficionado
ReyKe's Avatar
ReyKe will become famous soon enough
Good shit Dave, I like your methods, approach, and outcomes. Always a pleasure to see your process and execution.
__________________
Good cars are bought
Great cars are built
Awe-inspiring cars are raced
2011 the beginning of the end
F*$K Plasti-Dip
ReyKe is offline   Reply With Quote Quick reply to this message
Old 05-29-2015, 04:20 PM   #44
Cheeze-91lude
Ludacious
Cheeze-91lude is on a distinguished road
This is awesome. Good job man.
__________________
Follow me on instagram:cesar_91prelude
Cheeze-91lude is offline   Reply With Quote Quick reply to this message
Old 05-30-2015, 01:36 AM   #45
logan_the_kid
Newbie
logan_the_kid is on a distinguished road
this is amazing! good job man! id be interested in getting the specs for your mounts so i can fab myself up a set !!
logan_the_kid is offline   Reply With Quote Quick reply to this message
Old 06-03-2015, 04:48 PM   #46
MustardCat
Memento Mori
MustardCat's Avatar
I've got them modeled but I'm going to put some miles on this setup before I release anything.
3 JUN 15:
I'm still waiting for my rear radius rod bushings to ship so I'm kinda stalled for now. But I did get these in:
I also got the valve cover back and installed my Rosko wire cover along with it:
Old 06-03-2015, 08:23 PM   #47
ReyKe
Prelude Aficionado
ReyKe's Avatar
I know I'm stating the obvious, but damn your car is clean
__________________
F*$K Plasti-Dip
Old 06-03-2015, 08:31 PM   #48
MustardCat
Memento Mori
MustardCat's Avatar
Just the engine. Car needs a respray at this point.
Old 06-03-2015, 11:17 PM   #49
cudaboy
Elite Member
cudaboy's Avatar
Hi Dave! Which bushings have you ordered for the rear strut/radius rods? Frijoles has had pics of the accord cb7 I think he called it fitting. They would be the firmest with the least amount of play. I have them and the ones you modified for the front. The ones you modified for the front should of been a direct fit as part numbers go for the rear. I also have the acura integra ones. They would be inbetween the ones you mounted to the front for the rear. If the big cb7 fit these middle acura ones should fit too. For the most play would be direct part number fit for the rear would be the moog blue ones. These moog are shaped like the oem rubber ones from Honda. But they advertise them as a step between rubber and polyurethane. I haven't bought the moog ones yet. I probably will eventually so I can play with the different sizes to see what I like best. The acura ones you would probably not use the metal internal collar that come with them. They are just a hair tighter then the puck ones like you modified for the front. I think the term moog uses for advertising their blue bushings is "thermoplastic".
__________________
Old 06-04-2015, 09:11 AM   #50
MustardCat
Memento Mori
MustardCat's Avatar
I ordered the same ones I used for front.
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
