Understanding how your Thermo cooling system works - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 06-22-2010, 08:27 PM   #1
beatngyou27
True Luder
beatngyou27's Avatar
beatngyou27 will become famous soon enough
Send a message via AIM to beatngyou27 Send a message via Yahoo to beatngyou27
Ok so I have been searching and searching and have to go through many threads to figure out my electrical fan problem and cooling system.
This is for a 1988 prelude 2ws B20A5
This thread should be your one stop fix thread. Majority of tests ran with the vehicle in the ON position not running.
There is also 3 thermo sensors that are located on my car and the wiring and system diagram I have only show 2 so for my thread purposes I labeled them my way.
I am not an expert on preludes so feel free to correct me or even add to this discussion. All prices are not exact just a estimate.
Always start withe easiest to check. fuses and relays and battery connection.
Components
Battery
Condenser Fan Relay (under hood)
Radiator Fan Relay (under hood)
Fan Timer Unit
Fuse # 17 (15a) under dash
Fuse # 19 (70a), 20 (40), 39 (20a), 36 (15a) under-hood
Temp Sending Sensor (on Thermo housing)
3 Thermo Sensors (2 on thermo housing 1 on Radiator)
Ignition (white wire)
What Fan Works When
I dont have A/C but I was told that when the A/C is turned on BOTH fans turn on to keep the A/C cold. When the vehicle is turned off the Fan timer will kick on the fan in order to keep the engine cool shortly after the key is removed. The passenger side fan is the cooling fan and is double the size as the A/C fan, It turns on during street driving to prevent overheating since there isnt a constant wind blowing through the radiator.
Testing Your Fans
Testing your fans is easy. If you unplug your fans or even remove (it would be easier). Hook up on one side to a battery source and other to a ground source. If the fan fails to turn then your problem is at the fan.
Thermo Switch A
Testing the connection at the Thermo Switch (A) at the bottom of the radiator to the fan. Unplugging this connector and jumping it with a paper clip verifies that everything from the plug to the fan is working correctly and the problem lies with the switch. Part # 36426. $ 30.00
If your fan does not trigger on then that is where your problem is, anywhere between the switch and the fan i:e any of the listed components above.
Thermo Sensor B
This Thermo sensor is located at the housing of the Thermostat. It is an off yellow color plug with a yellow/green stripe and a green/white stripe wire. This tells the fan control unit when the coolant temp is >226*F.AFTER the key has cycled from on to off if the coolant is >226* the condenser fan will run until coolant temp <214*F.
You cant jump to test this wire like Switch A if you do there is a risk of disrupting your ECU. Part # 36426. $ 30.00
Thermo Sensor C
This Thermo sensor is located at the housing of the Thermostat. It is a Blue color plug with a white/green stripe and a black wire. This sensor is for the ECT. You cant jump to test this wire like Switch A if you do there is a risk of disrupting your ECU. Part # WT5009. $ 36.00
Thermo Temp Sending Unit
This little switch is located at the water neck also and is a single prong unit. This switch sends the temp to the gauge cluster. If this is in-op then you will have no reading on your gauge cluster but fans will still operate as normal. Part # WT622. $ 20.00
Understanding How A Relay Works
There is 4 prongs to these relays they are labeled A,B,C,D in your wiring diagrams according to http://media.honda.co.uk/car/owner/media/manuals/PreludeManual/index.html many people are unaware of how these majestic creatures work or even why there needed so hopefully I can break it down to understand.
The first picture is of a relay not energized. There is a C and B that are +. And D would be the negative to polarize the coil. A would be your Fan.
When the ground is applied to the coil it retracts the lever and connects power to A completing the circuit with power and actuating your fan.
Testing Your Relay
1. Remove Radiator or condenser relay in the under-hood relay box.
2. There should be continuity between the A & B terminals when the battery is connected to the C and D terminals. There should be no continuity when the battery is disconnected.
Purging the air in your Cooling System
Ok there are many different ways of doing this and Im sure they all get the job done. So Im going tell you how I did it and I will also display how the manual says to do it.
1. Take the radiator cap off and fill to the water neck.
2. Place cap back on
3. Start vehicle and let it warm up, and let the fan kick on twice
4. Use a rag or a large towel to open radiator cap. This will be under pressure but mine wasnt enough to burn me but whos to say yours wont be, so use caution.
5. Loosen the bleeder once again and fill to the water neck if needed. You should see bubbles or water dripping out of the bleeder bolt.
6. Tighten the bleeder bolt
7. Start the vehicle with the radiator cap off and fill if needed after fan kicks on twice again.
8. Install cap.
Fan Timer Unit
This box is located on the passenger side of the vehicle at the right foot. (picture below) this controls the driver side fan / condenser fan. This module tells the fan when the car is shut off and shortly after the fan kicks on. The purpose of this is to cool the engine when the car has come to a shut off point, because that is when the car is about to reach its hottest. So even though the water pump is not pumping there is still pressure momentum moving the fluid through the system and fluid still needs to be cooled to prevent engine damage.
Changing the Thermostat & How It Works
When the engine started cold, the thermostat is closed. The engine coolant / antifreeze does not circulate through the radiator. Instead it returns back into the engine through the by-pass tube. This helps to warm up the engine faster. As soon as the engine temperature reaches the normal range, the thermostat opens and the engine coolant starts circulating through the radiator where it cools down.
If the coolant temperature in the radiator drops too low, for example when driving on a freeway in a cold weather, the thermostat closes again to keep the temperature within operating range.
-Replacing The Thermostat
1. There are 2, 10mm bolts that are located on the housing that need to come out in order to uncover the Thermostat.
2. Once those are out wiggle the housing and it should pop right off. There will be some slight fluid leak from the connection of the housing you can avoid this by draining some of the antifreeze approximately 1qt or just count to 2onethousand.
3. Then you should have the Thermostat exposed, so just pop it out with your hands or pliers if needed (remember not to force anything).
4. Your new thermostat should include 2 parts, a rubber seal and the Thermostat
5. Now it is important to place the seal and the thermostat in correctly.
6. Looking in the empty housing to which you just popped the Thermostat out of you should notice 2 little notches.
7. Now inspecting the new Rubber seal you should notice there are 2 protruding notches that will fit right in the housing ones.
8. Now slip the Rubber seal on the Thermostat with the notchs facing the housing notches.
9. Pop the thermostat in and it should sit right in.
10. Place the Thermostat cover that is attached to the upper Radiator hose over and Bolt down the 2, 10mm bolts. The End
Thanks to pp.com member TSIAH for clearing things up for me and for future luders
__________________
Beatngyou27's Auto to Manual Trans Swap:
Beatngyou27'S Understanding How Your Thermo Cooling System Works:
Beatngyou27's Build Thread:
beatngyou27 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-22-2010, 08:59 PM   #2
TripleLude
Prelude Aficionado
TripleLude's Avatar
TripleLude has a spectacular aura aboutTripleLude has a spectacular aura about
Nice work. Pictures and looks easy to understand. When it is finished, send me a PM and let me know. I will take care of the FAQ sticky and like to keep it updated.
__________________
TripleLude is offline   Reply With Quote Quick reply to this message
Old 06-22-2010, 09:50 PM   #3
stlschindler
Needs Sensitivity Train'n
stlschindler's Avatar
stlschindler will become famous soon enoughstlschindler will become famous soon enough
Nice write up and keep it coming. This type of stuff is really helpful to your fellow luders. I repped you.
__________________
1937 Pontiac Deluxe 6 Two Door
1988 Dodge D50 Work Truck
1989 Jeep YJ, Chevy 350, 37s
1991 Prelude, 4ws, 5 Spd
2013 Pilot 4WD Touring (Wife's)
2014 Cadillac CTS-V (2 Doors & 3 Pedals)
2015 Smart Car - Future Smartbusa - Youtube it
stlschindler is offline   Reply With Quote Quick reply to this message
Old 06-22-2010, 10:56 PM   #4
schuyler91
Lude Addict
schuyler91's Avatar
schuyler91 is on a distinguished road
good job and info chris. keep the good work up. shit if i have issues ill just send the lude to you when i want to be lazy. haha
__________________
ONLY THE STRONG WILL SURVIVE!!!!!!!!!!!! donkey punches for sale!!!!
I would buttfuck a fat farting old woman for that car. Do they accept monthly payments?
rofl, sounds like something from jackass. Glue our chests together...god you better not fucking do that.
schuyler91 is offline   Reply With Quote Quick reply to this message
Old 06-22-2010, 11:44 PM   #5
beatngyou27
True Luder
will do. thank you
lol you gonna UPS your car to me
__________________
Old 06-23-2010, 12:09 AM   #6
schuyler91
Lude Addict
schuyler91's Avatar
i might. dont tempt me.
__________________
Old 06-23-2010, 12:11 AM   #7
rev_rage
I am Prelude
rev_rage's Avatar
rev_rage has a spectacular aura aboutrev_rage has a spectacular aura about
You should also include this page, its got pics on thermostat replacement
https://www.preludepower.com/forums/s...hermostat+pics
rev_rage is offline   Reply With Quote Quick reply to this message
Old 06-23-2010, 12:30 AM   #8
tsiah
no mo mod
tsiah's Avatar
tsiah has a spectacular aura abouttsiah has a spectacular aura about
I don't know what you did with the editing on this post but it made it very annoying to quote and post in different pieces...
You need to brush up on the difference between a sensor, switch and a sending unit. They do different things.
Originally Posted by beatngyou27 View Post
Thermo Sensor A
Testing the connection at the Thermo Sensor (A) at the bottom of the radiator to the fan. Unplugging this connector and jumping it with a paper clip verifies that everything from the plug to the fan is working correctly and the problem lies with the switch. Part # 36426. $ 30.00
If your fan does not trigger on then that is where your problem is, At the fan.
If you jump this and the fan DOESN'T turn on, the problem could lie anywhere between the switch and the fan. IE: the relay, a fuse, any of the wiring, etc.
I don’t have A/C but I was told that when the A/C is turned on BOTH fans turn on to prevent overheating.
This is to keep the A/C cold. Not to prevent overheating.
Thermo Sensor B
This Thermo sensor is located at the housing of the Thermostat. It is an off yellow color plug with a yellow/green stripe and a green/white stripe wire. This sensor tells the fan when the engine has cooled off enough and shuts the passenger side fan off. You can’t jump to test this wire like Sensor A.
Thermo Sensor C
This Thermo sensor is located at the housing of the Thermostat. It is a Blue color plug with a white/green stripe and a black wire. This sensor I believe tells the Transmission not to shift into high gear until the engine is warmed up. You can’t jump to test this wire like Sensor A.
That is for ECT. No you can not jump it like the other switches (its not a switch, its a sensor) you could damage the ECU if you jumped the wires together.
This little switch is located at the water neck also and is a single prong unit. This switch sends the temp to the gauge cluster. If this is in-op then you will have no reading on your gauge cluster nor will any fans kick on to cool the engine.
This is not true. It is only wired to the gauge. If it doesn't work, you won't have a gauge. The fans will still work, the ECU will still know coolant temp.
for example...I don't have one.
I have an aftermarket gauge and sending unit. My fans work fine.
__________________
-Tyler
Try Honesty
Happy Owners Never Drive Anything else
Ask for a new stranger? Tell them your's is defective, it's stuck in the on position.
tsiah is offline   Reply With Quote Quick reply to this message
Old 06-23-2010, 01:01 AM   #9
beatngyou27
True Luder
i appreciate the constructive critizism and the reason i stated if the sending unit doesnt work neither will my fans is cuz i had that problem but im sure your right since your running no sensor it was probably linked to another problem i was having at the same time. i will update it tommorrow. thank you again
__________________
Old 06-26-2010, 05:23 PM   #10
tsiah
no mo mod
tsiah's Avatar
Looks pretty complete. Good write up Hopefully it will come up in future searches and we won't have a large number of repost threads.
__________________
-Tyler
Try Honesty
Old 08-17-2010, 04:47 PM   #11
TripleLude
Prelude Aficionado
TripleLude's Avatar
Hey I have a question. Today was a really hot day out (like 102*F locally). I used the AC for all my driving. I parked the lude and went into Walmart for 10 minutes. When I returned to the car, the condenser fan was running, but the radiator fan was not running. When I turned the ignition on, the condenser fan shut off. Is this ok or is there a problem?
Note: No problems with the radiator fan, it is just the condenser fan. Just wondering if a relay/switch/control-unit is failing, or if it was just a really hot day.
__________________
Old 08-29-2010, 06:01 PM   #12
Dexter
Prelude Aficionado
Dexter's Avatar
Dexter will become famous soon enough
Send a message via AIM to Dexter Send a message via Yahoo to Dexter
Nice write up! Now I know why relays click!!!!! You're the man!
__________________
Dexter is offline   Reply With Quote Quick reply to this message
Old 08-29-2010, 08:20 PM   #13
beatngyou27
True Luder
I think its normal i just recently added my condensor fan so im a little behind lol. the guy i bought the car from had the plug for the condensor plugged into the radiator fan and the only time the fan would kick on was when the timer unit started it on ignition off. so since i just recently added my new fan now i have both but it seems like the condensor runs when engine is off and radiator fan when engine on. to me seems ok. sorry i wrote back so late ive been in hidding
__________________
Old 09-21-2010, 07:23 PM   #14
cudaboy
Elite Member
cudaboy's Avatar
cudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internet
Send a message via Yahoo to cudaboy
yeah I did the test in the shop manual. Everything was fine. The timer may be bad. by the way what you circled is the compressor control unit and not the fan timer. If memory serves me right the fan timer is lower and connection is in bottom of housing and not front.
Edit: also all three sensor switches are different. two are switches: one located in bottom of radiator is labled 90 and you should use that number when looking online at autoparts stores websites. The other is on the water neck and is labled 108. It is blue with blue connector. The third is not a switch and just a temp sending unit for ecu only. It is white with grey connector.
__________________
CUDABOY'S STRUT TOWER BAR GROUP BUY: I HAVE 1 FRONT OF BLACK ON BLACK W/SILVER BAR FRONT $150/SH +3 SETS F/R U CHOOSE COLOR MINI G.B. $265 SH.
'91 Si 4ws 5spd(black) "Black Betty"
'70 'Cuda 340 C.I.D. Alpine White, Black Vynil Top, Leather Interior, Rim Blow, Overhead Consolette. Factory Posi 3.55:1, 15" ralleyes, --Fully Loaded and Extremely Rare!
cudaboy is offline   Reply With Quote Quick reply to this message
Old 09-22-2010, 03:18 AM   #15
fordhater
True Luder
fordhater's Avatar
fordhater is on a distinguished road
Nice writeup. Sure not all the information is perfect but hell these cars are old and nothing ever goes right on the informational or mechanical side of things. Even in my line of work we still have problems like this...mostly because the Army won't get rid of their damn generators until they actually blow up...and then they rebuild them. If you think working on the Prelude is nuts try working on a 60Kw 400Hz generator that saw hell in Vietnam.
Now if only I could bring myself to dig into the wires on my Lude...
fordhater is offline   Reply With Quote Quick reply to this message
Old 12-01-2011, 03:16 AM   #16
konartis
Getting Comfortable
konartis is on a distinguished road
So the coolant travels through the lower rad hose, up the radiator and back into the engine? Just want to clarify.
konartis is offline   Reply With Quote Quick reply to this message
Old 12-01-2011, 03:35 AM   #17
cudaboy
Elite Member
cudaboy's Avatar
Well the water pump drives off the the timining belt which is powered by the crank and goes in the direction of clockwise. So coolant in the lower pipe on the backside of the engine feeds through the lower radiator hose and goes to the rear engine pipe through the timing belt water pump and up through the head of engine. It then goes through the upper head water neck for thermostat to upper radiadiator hose and upper radiator.
__________________
Old 12-01-2011, 04:02 AM   #18
cudaboy
Elite Member
cudaboy's Avatar
just make sure to checkout my 108 degree or 90 degree celsius temp sensors and switches in many of my threads.
__________________
Old 12-01-2011, 06:32 AM   #19
dano
Prelude Aficionado
dano has disabled reputation
^^ You say the engine turns "clockwise" . If you are looking at the engine from the timing belt side, drive belts side, the engine turns counter clockwise.
Our engines are "normally" thought of as turning counter clockwise.
Silly Cuda.
Is it just me or does anyone else find it hilarious that Konartis read thru this whole article and thought the coolant ran backwards. I guess the first thing beatngyou27 should have addressed was the direction of the coolant flow.
__________________
dano is offline   Reply With Quote Quick reply to this message
Old 12-01-2011, 09:04 AM   #20
cudaboy
Elite Member
cudaboy's Avatar
sorry dano I was tired when I posted that. That was central time. I had the coolant going in the right direction with the impellar just not the belt.
__________________
Old 12-01-2011, 10:50 AM   #21
NUDEintheLUDE
Getting Comfortable
NUDEintheLUDE is on a distinguished road
Amazing, just in time for what i needed to know.
NUDEintheLUDE is offline   Reply With Quote Quick reply to this message
Old 12-01-2011, 07:13 PM   #22
cudaboy
Elite Member
cudaboy's Avatar
Looks pretty acurate but the there is only two thermosensors. The one for the gauge, single wire, and the ecu one on thermostat housing that I call the water neck. The other two are just switches one in the waterneck that has nothing to do with the ecu and the other one at the bottom of the radiator. I will have look at some of my new switches to confirm the temps you have. The stock switches are stamped 108 for 108 celsius/ 226.4 Farenheight at water neck and the one in the radiator is stamped 90 for 90 celsius/194 Farenheight. Well some brands of switches aftermarket are stamped. Most of mine aren't however one radiator switch that is 90 stamped from the factory is stamped 87-92 celsius/ 188.6-197.6 Farenheight.
ECU SENSOR PART #'S FROM ROCK AUTO + PRICES:
ORIGINAL ENGINE MANAGEMENT Part # 9342 {Click Info Link for Alternate/OEM Part Numbers25174240, 37870PJ7003, 37870PK2005, 37870PK2015, 5862028470} (Only 4 Remaining)
$12.00
AIRTEX / WELLS Part # 5S1468 {#37870PJ7003, 5862028470, SU4006}
Si 4WS; Si Model
$13.76
BECK/ARNLEY Part # 1580154
$20.79
STANDARD MOTOR PRODUCTS Part # TX37 {Click Info Link for Alternate/OEM Part Numbers213718, 25174240, 37870PJ5003, 37870PJ7003, 37870PK2005, 37870PK2015, 5862028470} Intermotor
$22.99
FOUR SEASONS Part # 36426
$49.79
SENSOR ASSY., WATER TEMPERATURE (HADSYS)
Part NO.: 37870-PK2-015
Our vast assortment of genuine Honda parts come from an authorized Honda dealer located in Southern California. Buying such genuine parts like SENSOR ASSY., WATER TEMPERATURE (HADSYS) will go a long way towards ensuring the proper operation of your vehicle. You can take comfort knowing that every part, including 37870-PK2-015, is backed by Honda manufacturer's warranty.
Honda's Retail Price: $37.57 You Save: $10.33 Your Price: $27.24
FITS ALL THESE MODELS SO YOU SHOULD BE ABLE TO GET ONE OF THESE IN STOCK AT YOUR AUTOPARTS STORE OR HONDA DEALER!
ACCORD 2D '88-89ACCORD 2D '90-93ACCORD 2D '94-97ACCORD 2D '98-02ACCORD 3D/4D '86-89ACCORD 4D '02ACCORD 4D '90-93ACCORD 4D '94-97 E2/V-6 E2ACCORD 4D '98-01ACCORD 5D '91-93ACCORD 5D '94-97CIVIC 3D '88-91CIVIC 4D '88-91CIVIC 5D '88-91CRX '88-91INSIGHT '04-06ODYSSEY '95-98ODYSSEY '99-04PILOT '03-07PRELUDE '88-91PRELUDE '92-96PRELUDE '97-01S2000 '00-07
FOR A/C CONDENSOR FAN ON THERMOSTAT WATER NECK SWITCH IS 108 CELSIUS FAN SWITCH:
KEMPARTS Part # RF130
Radiator Fan Switch A-108; Si 4WS; Si ALB [Wholesaler Closeout -- 30 Day Warranty] (Only 4 Remaining)
$10.65
AIRTEX / WELLS Part # 1S4415 {Click Info Link for Alternate/OEM Part Numbers37773PJ0661, 37773PJ0A01, 88923773, SW579}
(Stamped A-108 ); Si 4WS; Si Model
Choose: [Wholesaler Closeout -- 30 Day Warranty] (Only 3 Remaining) ($15.22)[Regular Inventory] ($28.79)$15.22
STANDARD MOTOR PRODUCTS Part # TS208 {Click Info Link for Alternate/OEM Part Numbers213725, 25174244, 37773PJ0661, 37773PJ0A01} Intermotor
On Cylinder Head;
Choose: [Wholesaler Closeout -- 30 Day Warranty] (Only 1 Remaining) ($19.28 )[Regular Inventory] ($35.79)$19.28
FOUR SEASONS Part # 36561
Engine Mounted; ID No.A-108
$39.79
Honda Part: SWITCH, THERMO (A-108 )
Part NO.: 37773-PJ0-661
Our vast assortment of genuine Honda parts come from an authorized Honda dealer located in Southern California. Buying such genuine parts like SWITCH, THERMO (A-108 ) will go a long way towards ensuring the proper operation of your vehicle. You can take comfort knowing that every part, including 37773-PJ0-661, is backed by Honda manufacturer's warranty.
Honda's Retail Price: $59.58 You Save: $16.38 Your Price: $43.20
FITS ALL THESE MODELS:
ACCORD 3D/4D '86-89PRELUDE '83-87PRELUDE '88-91
9. Temp Switch 108C on coolant neck off head
Top Left: Blue connector and sensor: 22mm Deep
Socket Switch for a/c fan slash cooling.
9b. Coolant Sensor ECU water neck off head
Far Right: Gray connector, White sensor
19mm Deep Socket
10. Coolant Switch 90C at Bottom of the
Radiator for Radiator Fan(Passenger side/usdm)--- TBA
__________________
Old 12-01-2011, 07:40 PM   #23
FuzzyGreen
Lude Boss
FuzzyGreen's Avatar
FuzzyGreen will become famous soon enough
I may need to re-read the above post again cause I'm a bit confused still.
Which are switches and which are sensors?
I know the 1 wire sensor in the neck below the bleeder valve is for the instrument gauge and nothing else. It's an analog style sensor.
Then there are 2 switches farther in on the neck. These are both 2 wire switches and testing from my Mcguyver candy thermo on stove ohm meter showed that they are indeed switches that click on at specific temps.
Then there is the sensor or switch, not sure, that plugs into the bottom of the radiator. Some models don't have this one also.
My 91 manual alb has all 4.
My 91 4ws auto has all thermo-neck ones, but doesn't have the radiator one (unless it is just hidden somewhere else).
To make matters worse, some models only have 1 instrument sensor and 1 switch on the thermostat neck.
__________________
91 Red/tan JDM B20 SI 4WS
Pics:
FuzzyGreen is offline   Reply With Quote Quick reply to this message
Old 12-01-2011, 08:08 PM   #24
cudaboy
Elite Member
cudaboy's Avatar
9b with grey connector is for ecu. I didn't call it a switch because I assumed it supplies small voltage to the ecu. The other big one with the thicker socket contact area is the switch for ds condensor fan. It runs while the a/c is on and engine gets hot enough 108 celsius. It also runs after engine is shut off if the temps exceed 108 celsius. I believe the fan timer should shut the fan off after 15 minutes. It is just an open close switch. Like the one in the radiator. They both have the extra thick body the socket makes contact with in a form of hex. The thicker body is for the switch I presume.
__________________
Old 08-16-2012, 11:44 PM   #25
redloudlude
Lude Boss
redloudlude's Avatar
redloudlude has disabled reputation
Prelude of the Month
After reading this thread. Few times ,I still need info on how I can test my fan timer before I shell out 130 dollars also can any one tell me in a easy way to understand how to check my condenser fan and radiator fan relay ,I just purchased a fan switch from hondapartsunlimited.com out of two choices for the same radiator fan switch and my fans don't come on at all ever! The reason I disconnected my manual fan switch is smog shop says its very illegal come on if it ain't one thing its another. Ca smog ...no fun!
__________________
black 89 prelude h22a ,red 89 b20a5, 3rd gen nothing better!
redloudlude is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
