Turbo Setup STICKY - Page 3 - Honda Prelude Forum : Honda Prelude Forums
Old 03-19-2010, 01:38 AM   #51
archie21
archie21 is on a distinguished road
[Car And Motor]
1991 Prelude Si
B20A5
wiseco forged pistons
sparks forged hbeam rods
supertech h22 valve springs
arp studs
[Turbo Parts]
Garret-AiResearch T3 IWG
H22 manifold
JDM Poonage intercooler and piping
Greddy BOV
Custom DP
[Fuel Management]
p06 and phearable.net chip kit/basemap
[Boost]
5psi so far
[No Tune, Street Tune, Dyno Tune]
not that far yet unfortunately
[Notes]
will be adding 880 precision injectors and push 25psi once tuned.
archie21 is offline   Reply With Quote Quick reply to this message
Old 03-30-2011, 07:18 AM   #52
jebat_preluder
jebat_preluder is on a distinguished road
[Car And Motor]
1993 ba8 Prelude
jdm h22a 80% stock
[Turbo Parts]
Td04
h22a custom turbo header
custom turbo piping
tial wastegate 38mm
custom downpipe
bov sqv hks
evo3 intercooler
apexi fake boost meter
[Fuel Management]
p28 with s300 hondata chipping
510cc evo 3 injector
[Boost]
7psi @ 0.5bar so far
dynojet
268.1hp
231.2 tork
afr 11.3
jebat_preluder is offline   Reply With Quote Quick reply to this message
Old 09-27-2011, 08:57 AM   #53
typemismatch
typemismatch is on a distinguished road
[Car And Motor]
1992 Prelude S full interior
JDM H22A
[Internals]
CP pistons (10:1 CR)
Pauter X-beam rods
ARP head studs, main and rod bolts
Skunk2 valves, retainers, dual valve springs
GE sleeved and o-ring
OEM Honda headgasket
Stock H22 cams and gears
Nippon Eneos 0-50W oil
[Extra Stuff]
Generic Oil Catch Can
NGK plug wires
NGK plugs
Skunk2 intake manifold
KS H23 tensioner conversion
KS Balance shaft eliminator
GReddy timing belt
[Tranny]
T2T4 JDM LSD
Comp Clutch 6-puck sprung hub
Comp Clutch lightweight flywheel
Comp Clutch pressure plate
[Turbo]
Precision PTE 5857 .63 A/R turbine, ported shroud S compressor cover
Treadstone TRE8 or TRE10? intercooler and 2.5" piping kit
LoveFab mini-me equal length turbo manifold
LoveFab 3" down pipe, open down pipe
Tial 44mm Wastegate, open dump
Tial 50mm BOV
Hondata boost control solenoid
[Fuel Management]
Hondata S300 with P72 ECU
AEM Uego Wide band O2 With gauge
GM 3 bar map sensor
Injector Dynamics ID1000cc injectors
AEM fuel rail/FPR
Walbro 255lph fuel pump
E85
[Dyno Tune]
Tuned by Shane @ DBPerformance in Rogers, MN
469.8hp/340tq @ 15psi max
415hp/280tq @ 12psi current tune
[Future]
Upgraded fuel system:
Walbro 400lph in-tank
Injector Dynamics ID2000cc or FIC 2150cc injectors
-8 AN fuel lines
Kenne Bell boost a pump
Direct power fuel relay mod
[Notes]
Ran out of injector at 15psi with fuel pressure set to stock base 43.5psi
1992 Prelude S - 469hp/[email protected] - [email protected]
2007 Civic Si - FG2 - almost stock (DD)
92 EG H2B - build thread
typemismatch is offline   Reply With Quote Quick reply to this message
Old 09-27-2011, 03:50 PM   #54
gc8dc95
Lude Boss
gc8dc95 is on a distinguished road
[Car]
1989 Honda Prelude 2.0Si
[Engine]
B20A5
81.5mm Wiseco Pistons 9:1
Bisimoto I-Beam Rods
Cometic Headgasket
ARP Headstuds
[Turbo]
Precision SC6152E .63ar
CX Racing FMIC
Tial Bov
Tial V44 Wastegate
WeiRtech Tubular Manifol
[Fuel]
5gal Fuel Cell
Inline Walbro 255 and Bosch 044
-8an Fuel Lines
Rosko Racing Fuel Rail
1000cc PTE Injectors
[Electronics]
MSD Digital 6
HVC-II Coil
Chipped P06 with Ectune
[Tires]
MH 24.5x8.5x15 Slicks
Tuned on VP [email protected] = 420whp 340wtq
Best 1/4 = [email protected]
Best 1/8 = [email protected]
The car has more in it with some more boost, better driving, and headwork.
89 Prelude SI Turbo [email protected] 420whp/340wtq 1/4 = [email protected]
gc8dc95 is offline   Reply With Quote Quick reply to this message
Old 05-11-2012, 04:54 PM   #55
phattzy
phattzy's Avatar
phattzy is on a distinguished road
[CAR]
89 Honda Prelude SI 4WS
[ENGINE]
- b20a6 fully forged bottom end
- scat h22a h-beam rods
- acl race series bearings
- decked and honed block
- custom dished JE pistons C/R 8.5:1
- JE pistons pro-seal ring kit
- 5 layer cometic MLS head gasket
- heavily port/polished head
- decked head
- heavier springs
- custom oversized fuel rail
- twin feed rail
- bosch 1680cc indy blue injectors
- 3/8 billet inline fuel filter
- upgraded 3/8 fuel lines
- walbro 255lph lift pump
- 3ltr surge tank
- modifed intank chamber
- double spacer ( blacktrax style ) plenum
- modifed h22 throttle body
- custom steam pipe top mount turbo manifold
- turbonetics twin scroll gtk 450 turbo
- turbosmart 38mm ultra gate with 14psi spring
- turbosmart eboost2 EBC
- turbosmart type3 supersonic BOV
- 2.5 " hot pipe -- 800/400/75mm intercooler -- 3" cold pipe
- AEM adjustable cam gears
- gates racing timing belt
- sard FPR
- excel super coil
- topgun 8.8mm race leads
- 2.5" dump pipe
- 3" stainless full exhaust
- magnaflow highflow cat
- soild engine mounts
- adaptronics E420C ECU
- custom stainless airbox
- custom stainless catch can
- x3 -10 elbows
- x2 5/8" ORTAC breather hose
- SPEX 1/10 hour meter
- Innovate motorsports LC1 wideband
DRIVELINE
- stage 3 button clutch
- 5 speed
- stock flywheel
- stock drive shafts
BRAKES / SUSPENTION
- braid brake line kit
- slotted rotors all round
- front brake dust covers removed
- stock shocks
- new upper and lower ball joints
- JDM style spring/sleeve kit 4" raise/lower
- 17" rims 225/45/17 front 235/45/17 rear
OUTSIDE
- aftermaket front bar , cut and modded to fit intercooler
- accord side skirts
- vented bonnet
- bonnet struts installed
- x4 2 5/8 autometer bonnet gauges
- tinted tail lights and garnish
- body moulds colour coded
- 5000k h4 xenon headlight bulbs
INSIDE
- short shifter
- custom rollcage
- ADR approved monza 4-point harness's
- fire extinguisher
- LED down lights wired to key barrell dimmer
- autometer 2 5/8 oil pressure gauge
- autometer 5" monster tacho 10,000 rpm carbon fibre series
- autometer 2 5/8 boost gauge
- false boot floor
- everything else stock
- battery relocated to boot
- carbon vinyl trim thru out
- momo nero pedal kit
SOUND
- pioneer head unit
- mb quart splits (front)
- sony 6x9's (rear)
- jbl dual voice coil 15" sub (boot)
- clarion 300 wrms mono block amp (boot)
- 120 amp circuit breaker
GARAGE :
BUILD THREAD :
VIDEOS
phattzy is offline   Reply With Quote Quick reply to this message
Old 06-02-2015, 01:09 PM   #56
ty_93
ty_93 is on a distinguished road
[Car And Motor]
1997 Prelude Base
H22a
[Motor/Turbo Parts]
Stock block H22a - (10.6cr) ARP Head Studs / Honda HGasket
Pro series intake mani
70mm TB
Spoolin Performance Manifold
Turbonetics t3/to4e 60 trim .63Ar Turbine
Precision 39mm Wastegate
Mishimoto intercooler
Synapse Blow off valve
[Trans]
ACT 6 puck clutch and pressure plate
Duralast OEM flywheel
Duralast Gold CV Axles
[Fuel Management]
Walbro 255 pump
AEM fuel rail
Rc 750cc Injectors
E85
Hondata s300v3
[Boost]
9.7psi with Grimmspeed MBC
Dyno Tune with Excessive Autosports in Sioux falls, SD
307whp and 270lbs at 9.7psi
ty_93 is offline   Reply With Quote Quick reply to this message
Old 06-15-2019, 09:09 AM   #57
mchef117
mchef117 is on a distinguished road
[Car And Motor]
2001 Prelude Type sh
H22a
[Motor/Turbo Parts]
93 h22a closed deck block with a 97 type s head fresh rebuild with arp head studs
70mm skunk2 alpha r TB
Greddy log style manifold
Garret gt30 with upgraded ball bearing kit
Tial 39mm Wastegate
JDM sports intercooler
HKS Blow off valve
[Trans]
Exedey extra pressure clutch
Fidanza Lightweight Aluminum Flywheel
[Fuel Management]
Walbro 255 pump
AEM fuel rail
Rc 750cc Injectors
93
Hondata s300v2
[Boost]
Havent finished the turbo set up yet. Waiting on an obd2b to obd1 jumper and a aem wideband to finish
mchef117 is offline   Reply With Quote Quick reply to this message
