rywire H22 swap harness ? - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 09-18-2012, 09:42 PM   #1
rev_rage
I am Prelude
rev_rage's Avatar
rev_rage has a spectacular aura aboutrev_rage has a spectacular aura about
First off I would like to say that the rywire harness is not very good for 3rd gen preludes, they give no instructions for all these extra wires and it leaves you in the ahhhh fuck mode.
the brown/white(service check signal) wire, Rywire says to connect to b5 brown on the EF chassis
question #1. B5 or Brown wire on the 88-89 preludes is one of the wires for the jumper plug for setting the ignition timing, is this the same as the service check signal wire on the EF.
question #2. there is a pin missing on the rywire harness, the missing pin is supposed to connect White/green wire on the prelude fender harness, any clues on what this is for
connects to this jumper green arrow
__________________
1989 Honda Prelude H22
rev_rage is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-18-2012, 10:39 PM   #2
1funryd
Elite Member
1funryd is a jewel in the rough1funryd is a jewel in the rough1funryd is a jewel in the rough1funryd is a jewel in the rough
Send a message via AIM to 1funryd Send a message via MSN to 1funryd Send a message via Yahoo to 1funryd
question #2. there is a pin missing on the rywire harness, the missing pin is supposed to connect Yellow/red wire on the prelude fender harness, any clues on what this is for
Rev the two red arrows are the AC relays, so dont worry about those.
It looks like the white connector connects to the external ignitor that comes stock on our chassis.
Unless you ordered the internal ignitor wiring for the H22 distributor.
The two blow arrows are pointing to the fan connectors if I am correct.
And the one green arrow points to that a weird harness that I do not know the name of, I would ask MustardCat about that one.
__________________
My Facebook page -
Sean
3rd Gen Aftermarket Manager
(Clik Here)
Email:
(Danny19 - JDM RH Drive) (1Funryd - H23 Swap) (B20luda - Turbo Charged H22)Representing All of 3rd Gens!!!
1funryd is offline   Reply With Quote Quick reply to this message
Old 09-18-2012, 10:55 PM   #3
rev_rage
I am Prelude
rev_rage's Avatar
I am not asking about the red arrows(AC relay's) or the blue arrows(Radiator fan & sensor) just the green arrow.
Rywire H22 harness connections are made for Internal coil distributors. External coils are a custom option and cost more. I have a JDM internal dizzy
the Clean white connector on the 2nd pic connects to the plug that the green arrow is pointing too, but the white plug is missing one wire,
on the Green arrow plug that wire is Yellow/red, I do remember musturdcat posting about that one wire but he did not say where that Yellow/red leads too.
the white connector does not plug into the ignitor
__________________
Old 09-18-2012, 11:43 PM   #4
silverwrench
Getting Comfortable
silverwrench is on a distinguished road
isn't that the plug for the alternator?
silverwrench is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 06:38 AM   #5
Forza
Ludacious
Forza's Avatar
Forza has disabled reputation
Prelude of the Month
The green arrow is the OEM chassis to primary fuse box plug, this is where the Rywire chassis adapter plugs in. This plug connects ecu power, ecu ground, and so forth.
Rywire separated out the charge wires from thier chassis adapter which is the missing pin.
The missing pin you speak of is the hot (charge) wire from the alternator to the battery.
They offer a package with alternator and starter hot wires also, separating the alternator hot wire will reduce/isolate electronic noise and as a result it is not integrated, also since this harness is intended to be tucked it is ideal to seperate out the alternator charge wire.
Run alt charge wire separate to the harness from the fuse box to the alternator...this is what Rywire intends for you to do.
*Don't panic, once you get it setup you'll see it is actually quite simple and removes a lot of redundant oem wiring.*
Note: Mustardcat had to ground his main relay (90-91). I did not have to do this (88-89). Doing so in my case actually kicks on the fuel pump, I'm not sure why he needed to do this, but I didn't.
Here is the image he supplied =>
__________________
409 whp / 412 ft. lb BA4 || 287 whp NA1 Acura NSX
Forza is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 08:33 AM   #6
frijoles
Elite Member
frijoles's Avatar
frijoles will become famous soon enoughfrijoles will become famous soon enough
This thread scares me.
__________________
Build thread:
Accord Wagon build thread:
frijoles is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 10:09 AM   #7
rev_rage
I am Prelude
rev_rage's Avatar
First off I made the mistake of Identifying that missing wire as Yellow/red when its White/green. I will edit my first post
that being said, I understand that the missing wire is soppesed to be connected to the green plug which connects to the ALT/voltage regulator on the b20 ALT, if rywire removed this how do you regulate the voltage? is the voltage regulator eliminated on the green plug for JDM H22's or is the Voltage R. connected to the ALT main power terminal on the H.
thanks for helping
__________________
Old 09-19-2012, 01:25 PM   #8
Forza
Ludacious
Forza's Avatar
thanks for helping
The missing wire does not connect to the green alternator plug which contains voltage regulation circuitry.
The missing wire is the conduit for transmitting alternator output to the battery, typically this is a larger gauge wire.
Charge Voltage Regulation occurs just as it would stock...via a pin on the ecu that the harness plugs into.
__________________
Old 09-19-2012, 02:17 PM   #9
rev_rage
I am Prelude
rev_rage's Avatar
According to the OBD1 pinout that wire is supposed to go to a16 ALT control, and musturdcat says you need to run a line from the green plug
__________________
Old 09-19-2012, 02:33 PM   #10
Forza
Ludacious
Forza's Avatar
According to Mustardcat's site that is the charge warning indicator light not the ALT Control.
I would call Rywire on this and get answers since all of their harnesses are fundamentally the same.
__________________
Old 09-19-2012, 05:53 PM   #11
91OWNER
Elite Member
91OWNER's Avatar
91OWNER is on a distinguished road
rev rage
i hear you, i had the worst experience in my 49 years of products i bought.
a total waist of time over 1 1/2 years to get it right in my 91 with a h22a
91OWNER is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 06:27 PM   #12
TripleLude
Prelude Aficionado
TripleLude's Avatar
TripleLude has a spectacular aura aboutTripleLude has a spectacular aura about
According to the diagram located here:
http://www.preludebible.com/service-...alternator.pdf
White/green goes to the voltage regulator. The white/blue > black/yellow is the charge warning light.
__________________
TripleLude is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 06:32 PM   #13
ejd715
Lude Addict
ejd715 is on a distinguished road
Send a message via AIM to ejd715 Send a message via Yahoo to ejd715
I hope Sean can get this other company on board, because i have about had it with Rywire!
__________________
Project Black Majik Steering
1988 4WS H22 Swap is running!!!
1989 4WS 27k miles all stock!!!
ejd715 is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 09:05 PM   #14
MustardCat
Memento Mori
MustardCat's Avatar
MustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the Internet
There seems to be much confusion here...
Question 1: Rywire BRN/WHT does indeed go to B5 (BRN) on your OBD0 harness. SCS and jumper plug are the same thing.
Question 2: With the rywire harness you have to run two separate wires from the alt to the fuse box area:
First one is the larger wire that attaches to the stud on the alt, this wire runs directly into the fusebox. (I just cut this one out of the useless JDM harness that came with my H22.)
Second, you will see that the green alt plug on the rywire harness is missing one wire. You add this and run it to the missing pin in this plug:
This is simply the wire for the charge warning light and is technically not required, but if you don't add it your charge warning light will be on.
MustardCat is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 10:50 PM   #15
rev_rage
I am Prelude
rev_rage's Avatar
Thanks for clearing up question #1, I wasn't sure cause I have never heard of it being called SCS before, I always called it the jumper plug.
Ok here are some pics of the green plug from the, H22, b20a5 and Rywire harness.
This is the ALT plug from my JDM harness, it does have all 4 wires just like the b20 and like the b20 harness all the wires match in color
Here's a picture of the B20 ALT plug
here's the rywire harness ALT plug
as you can see the WHT/GRN wire is missing.
Here's the factory manual for the b20 showing that the WHT/GRN wire runs from the voltage regulater to the underhood fuse panel
H22 diagram showing the same thing
So why is this wiring missing, why did rywire not include this into there harness
The only thing I can think of at this point is the other wires are regulating the voltage.
__________________
Old 09-19-2012, 11:01 PM   #16
rev_rage
I am Prelude
rev_rage's Avatar
Heres the issue of the rywire harness regarding the resistor box.
Heres a pic of musturdcats Rywire harness and resister box, notice his has the grey plug and is hooked up to the JDM box
Heres a pic of my rywire Harness. B20a5 R-box is on the left, JDM r-box on the right, but why does my harness have the plug for the b20a5 R-box and not the JDM. I contacted Rywire and they said it would work. I am not to familiar on how R-boxes but I think JDM injectors and 3rd gen injectors are both low Independence correct?
__________________
Old 09-20-2012, 02:34 PM   #17
rev_rage
I am Prelude
rev_rage's Avatar
so I contacted rywire ans asked why is the White/green voltage regulator wire missing from the Green ALT plug, I cross referenced the B20a5 and H22 stock harness and both have that wire.
there response was Ya thats correct, we dont use it. thanks
__________________
Old 09-20-2012, 06:33 PM   #18
TripleLude
Prelude Aficionado
TripleLude's Avatar
Well, the harness looks good on the outside, so customers buy it. Right?
Ya I see this type of thing a lot now. Corners are cut and quality suffers, yet the product looks nice.
__________________
Old 09-21-2012, 08:19 AM   #19
Forza
Ludacious
Forza's Avatar
In Rywire's defense it is a component that is commonly disabled whilst tuning using Hondata, Neptune, Chrome, EcTune, etc...
My understanding is the Honda obd1 alternator's have an internal voltage controller as well (although I could be wrong).
I know each tuner that has touched my car disabled it first thing over the years.
__________________
Old 10-15-2012, 02:39 PM   #20
rev_rage
I am Prelude
rev_rage's Avatar
More rywire issues
I was doing a final check of the engine before I hooked up the s300 and came across another rywire issue. Looking at the labels for the wiring and noticed that I had the IACV plug connected to the IAT sensor, the IACV connector had longer wires then the IAC connector so I assumed that the longer wire was supposed to connect to the IAT sensor. So now I tried to switch the connectors to the right position but there is not enough slack in the wiring and will cause tension with the other connectors, like the water sensors. So now I starting to think that rywire either didn't make the wires long enough, or labeled them wrong so now I have to pull out the multimeter and check for continuity with the ecu plugs.
If anyone is planning on getting a rywire harness I would strongly advise not buying one, first they have a missing voltage regulator wire, and now I have to deal with IAT/IACV connectors. I know its not that hard to extend the wires or check for continuity, but when a customer spends 750$ on a harness they shouldn't have to worry about simple problems like this. I also just read that 4wsRyan(aka Blahblah311) has to have is harness sent back to rywire, not sure if this is rywire's fault but it sounds like they messed up on his connectors
__________________
Old 10-15-2012, 09:46 PM   #21
rev_rage
I am Prelude
rev_rage's Avatar
I was able to maneuver the the wiring enough to connect the IAT, it still is really tight and it most likely cause problems in the future but I will extend the wire a little and everything should be ok. I also checked the connector with the ECU pin and they were labeled correct.
__________________
Old 03-13-2015, 12:03 PM   #22
Rash
I am Prelude
Rash's Avatar
Rash is a jewel in the roughRash is a jewel in the roughRash is a jewel in the rough
I hope Ryan dies in a fire
__________________
JTC Customs
Rash is offline   Reply With Quote Quick reply to this message
Old 03-19-2015, 07:26 AM   #23
Forza
Ludacious
Forza's Avatar
I've had my Rywire H22 harness running on my B20A engine for years with zero issues.
Sent from AutoGuide.com Free App
__________________
Old 05-13-2017, 03:39 PM   #24
Ludercrs
Prelude Aficionado
Ludercrs's Avatar
Ludercrs will become famous soon enough
So I'm trying to follow this since i just got a Rywire harness to replace mine. and I never got any instructions with mine... just the harness, nothing else.
looking at my loose wires, and I don't have a Plain white one...
I have all the others listed there... so aside from Green and Green/Red which are not used. these are the colors i have left:
- Blue
- Blue/White
- Orange/Blue
- Orange/Black
i could probably identify the one that is supposed to be pure white based on the position in the plug? can someone let me know where that wire is located in the plug?
__________________
2011 Honda CR-Z - DD
1991 Honda Prelude SE - LEATHER SEATS BABY - H22 - 180whp - 160tq
Ludercrs is offline   Reply With Quote Quick reply to this message
Old 06-04-2017, 09:50 AM   #25
rev_rage
I am Prelude
rev_rage's Avatar
can't remember and not 100% sure but the blue or blu/wht wire is the signal wire for the MPH gauges in the 90-91. It connects to the tranny speed sensor.
__________________
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
