Burning oil - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 08-16-2012, 11:42 AM   #1
masonprelude
Getting Comfortable
masonprelude's Avatar
masonprelude is on a distinguished road
Burning oil
My prelude burning oil from somewhere, blue smoke comes out the muffler, a slow leak. Before I start checking the engine (h22a4) I just wanna hear some ideas on what it can be. Thanks
masonprelude is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-16-2012, 11:51 AM   #2
schmitty
Lude Boss
schmitty's Avatar
schmitty has a spectacular aura aboutschmitty has a spectacular aura aboutschmitty has a spectacular aura about
How much smoke? When do you see it? (Take-off, VTEC, etc.)
H22 engines burn oil from the factory. Keep it topped off. Staying in the lower RPMs and out of VTEC will help a little bit.
Average consumption is 1 quart every 3k miles.
__________________
- PM me if you have questions
be the change you want to see in the world
schmitty is offline   Reply With Quote Quick reply to this message
Old 08-16-2012, 12:07 PM   #3
masonprelude
Getting Comfortable
When I take-off and im using quaker synthetic oil
Old 08-16-2012, 12:14 PM   #4
xxfallacyxx
Bearderator
xxfallacyxx's Avatar
xxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud of
The FRM sleeves in the block cause piston ring wear, which leads to oil burning. It's normal for B21A1 and H22/H23 Preludes. How many miles?
__________________
Read this
J.L.D.E.P.P.M.S.3.C.N.Y.C.N.C.M.A.D
xxfallacyxx is offline   Reply With Quote Quick reply to this message
Old 08-16-2012, 12:24 PM   #5
98__SH
Lude Addict
98__SH's Avatar
98__SH will become famous soon enough98__SH will become famous soon enough
I notice mine burns a bit out the muffler when it's fully topped up, but that might just be that I'm looking out the back more after a top up.
But yeah how many miles are on your Lude?
__________________
I don't always drive Honda, but when I do, I prefer the Prelude...
You must prepare well for the Touge
2002 Subaru WRX w/STi Parts and Access Port (crashed)
1998 Honda Prelude SH (
98__SH is offline   Reply With Quote Quick reply to this message
Old 08-16-2012, 12:46 PM   #6
masonprelude
Getting Comfortable
162k
Old 08-16-2012, 02:27 PM   #7
realblag
True Luder
realblag's Avatar
realblag is on a distinguished road
Have your engine compression tested. The oil is either making its way into the combustion camber around the rings or through the valve stem seals. If your compression test is ok, then you need the head rebuilt. If the compression test is bad (assuming the valves are properly adjusted and the seats are good), your rings/cylinder walls are worn.
__________________
My addiction:
I hep U:
realblag is offline   Reply With Quote Quick reply to this message
Old 08-16-2012, 03:02 PM   #8
masonprelude
Getting Comfortable
Ok I will get that tested
Old 08-17-2012, 10:16 AM   #9
mikemikemike
Ludacious
mikemikemike's Avatar
mikemikemike is on a distinguished road
And stop using this junk. Quakerstate is bad, and on an old engine I would not be running syntethic. You should be running regular or at most semi-synthetic oil.
__________________
99 Prelude (Base <- The faster version of the two
sorry someone pissed in your cheerios.
mikemikemike is offline   Reply With Quote Quick reply to this message
Old 08-17-2012, 10:38 AM   #10
masonprelude
Getting Comfortable
Oops ok
Old 08-17-2012, 12:05 PM   #11
mikemikemike
Ludacious
Oops ok
There is oil thread on here somewhere but also stay away from royal purple (full synthetic anyway).
__________________
Old 08-17-2012, 12:09 PM   #12
masonprelude
Getting Comfortable
So dont use synthetic oil at all?
Old 08-17-2012, 12:35 PM   #13
mikemikemike
Ludacious
I wouldn't and don't. I run semi. Synthetic is not the best to use on older motors for the seals sake.
__________________
Old 08-17-2012, 01:29 PM   #14
hatedenemy
Lude Boss
hatedenemy's Avatar
hatedenemy will become famous soon enoughhatedenemy will become famous soon enough
Send a message via AIM to hatedenemy
OH EM GEEEEE.....
This is not an issue with oil type used.
Make sure your oil is 5w30 or 10w30. You can use coventional, semi syn, or full syn.
Usually you will have more oil consumption with synthetic oil. This can get expensive for you. You would need to be on top of your oil levels all the time--which you should be anyway!!
A lot of times going from convential to full syn on a motor that speant 100K miles on convential can sludge up the engine. Full syn will break loose the sludge built up from abuse on convential oil. This just means your first couple oil intervals on syn should be a bit premature.
Full syn has the ability to leak easier than convential due to molecule size.
No matter what--if you have a seal leaking you need to replace it. If you go from convential to syn and find a leaking seal it has to be replaced! Does not matter what oil your using at the point the seal was bad anyway!
For the record, I use Mobile 1 5w30 full syn. I check my oil level every other day if not everyday. I run my engine
If you do a compression test yourself. With the engine cold, break the spark plugs loose. Then tighten them to 16 ft lbs. Run the engine until warm. Remove the spark plugs. Check battery voltage. Verify its 12+V. Place your foot on the throttle and fully depress. Run the compression test on a cylinder and record results. Check voltage on the battery again between each test. Record the voltage if you like. If you get a cylinder where the numbers are low, add a teaspoon or so of oil into the cylinder chamber. Run the compression test again for that cylinder and record results. If you see an increase in numbers after adding a teaspoon of oil then you can be certain you have an issue with the piston rings. If you see no change then you can still have an issue with the piston rings or other issues.
__________________
BB Squad #16 (v.2)
hatedenemy is offline   Reply With Quote Quick reply to this message
Old 08-17-2012, 03:19 PM   #15
mikemikemike
Ludacious
Originally Posted by hatedenemy View Post
OH EM GEEEEE.....
...Never said it was, I noticed he said he is using synthetic which is rough on the seals especially at his mileage. This is not an oil thread, as I pointed out there is one already. I said it in passing.
__________________
Old 08-17-2012, 05:41 PM   #16
northwestinnovations
Getting Comfortable
northwestinnovations is on a distinguished road
OUr shop bb6 tends to burn oil but only typically when going into v-tech, we have replaced the rear main seal as it decided to pour oil out.
__________________
mykep83 = NORTHWESTINNOVATIONS
PARTS ARE WHAT I DO
EBAY WILL DISAPPOINT.
HKS, GREDDY, APEXI, AUTOMETER, DC SPORTS, GARRETT, STOPTECH,DIABLO, TEIN, TAKATA, THERMAL, TIAL, TOKICO, VOLK.... JUST NAME DROPPING A FEW
remember to like us on face book
northwestinnovations is offline   Reply With Quote Quick reply to this message
Old 08-17-2012, 05:41 PM   #17
Getting Comfortable
Though the car is still burning a little much, issue will be resolved when the rebuild begins
__________________
PARTS ARE WHAT I DO
Old 08-17-2012, 05:52 PM   #18
bloodSHed
'01 Milano Red - BB615
bloodSHed's Avatar
bloodSHed will become famous soon enough
VTEC loves oil.
__________________
2001 Prelude Type SH w/ H23A VTEC & T2W4 Tranny: Bought on 12/16/2011
2006 Mitsubishi Lancer Evolution: Bought on 2/17/2015
Build Thread -
AEM - BP Initiatives - Cometic Gasket - Enkei Racing - Hondata
Hybrid Racing - Innovative Mounts - JTC Customs - KAIZENSPEED - Ksport
Mishimoto - NEUSPEED - SpeedFactory - ST Suspensions - Vibrant Performance
bloodSHed is offline   Reply With Quote Quick reply to this message
Old 08-17-2012, 10:09 PM   #19
realblag
True Luder
realblag's Avatar
^^^^ lol
__________________
My addiction:
I hep U:
Old 08-17-2012, 10:18 PM   #20
hatedenemy
Lude Boss
hatedenemy's Avatar
Originally Posted by bloodSHed View Post
VTEC loves oil.
You lucky sob. Where does one get this? I need meez a car phone
And as said by others. When engine is max oil level youll lose some oil from the cover through the breather but mostly through the pcv. This is usually from running the engine hard that youll get that but you can be certain every prelude is doing that. Then there are quite a few common areas prone to eventually leak/seep.. youll always lose oil through piston ring blow by. This is natural by design. Some suffer more than others.
I avoid comparing oil consumption rates from others. Do you trust a persons scientific ability to accurately measure oil loss at a determined mileage mark? 90% of the time you can bet there is guestimating going on or the amount is pulled from between the cheeks lol.
__________________
BB Squad #16 (v.2)
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
