Motor mounts?? - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 05-24-2012, 05:01 PM   #1
NorCalLuder
Lude Dude
NorCalLuder's Avatar
NorCalLuder is on a distinguished road
Motor mounts??
Okay so i searched the site and all over the internet, Couldnt find the answer.
(besides that there is a difference Between passenger side Cradle on the 88-89 and the 90-91)
I go to put my engine in today and the rear motor mount will not fit i think i might have the wrong one? The mount seems too wide.
Is there a difference between the A/T M/T Rear mounts?
And can someone point me in the direction of the correct one, I have a B20a5 M/T. (part number?)
Frustrated so any help would be appreciated.
__________________
Nor
Cal
6'8" and i love my lil prelude!!!
89 Lude Si 4ws Sorta Black
89 Lude Si Red
72 GMC Jimmy 6" on 33"s
53 Stepside 5 window chevy pickup
New pics of my new lude up>
NorCalLuder is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-24-2012, 06:33 PM   #2
hizzlehonda
Ludacious
hizzlehonda is on a distinguished road
Is the rear motor mount a new one?
hizzlehonda is offline   Reply With Quote Quick reply to this message
Old 05-25-2012, 09:09 AM   #3
NorCalLuder
Lude Dude
Ya its a new one it seems like its just a bit too wide for the Bracket.
__________________
Nor
Cal
89 Lude Si Red
Old 05-25-2012, 11:12 AM   #4
BA5
Lude Boss
BA5's Avatar
BA5 has a spectacular aura aboutBA5 has a spectacular aura about
It has been a while since I've looked in the manual, but since the rear mount bolts to the transmission as well as the engine, I do believe that they are different.
__________________
Mechanical Engineer
89 Honda Prelude 2.0Si 4ws - 18 DSP
99 Honda Prelude Type SH - Daily Driver
BA5 is offline   Reply With Quote Quick reply to this message
Old 05-25-2012, 01:21 PM   #5
luzer
Elite Member
luzer's Avatar
luzer has a spectacular aura aboutluzer has a spectacular aura aboutluzer has a spectacular aura about
Yes, they are definitely different. You may be able to use one from the AT if you also grab the bracket but I'm not sure if it would work. You're better off just getting the right mount.
I noticed that Honda doesn't carry them anymore for the MT. I guess I'll be using the one I filled with 3M window weld when I have to replace mine.
__________________
1991 Prelude Si ALB
2015 Ram 1500 EcoDiesel 4x4
luzer is offline   Reply With Quote Quick reply to this message
Old 05-25-2012, 11:22 PM   #6
Sciroccoboi16v
Lude Boss
Sciroccoboi16v's Avatar
Sciroccoboi16v is on a distinguished road
By just a bit too wide do you mean like they screwed up the mount measurements when they made it, coupled with the pinch factor of being installed you might need to shave a bit off the mount?
__________________
91 2.0SI 4WS conversion. Dead.
87 VW Scirocco 16v - also dead
91 B2200 with Kia sportage engine - alive.... for now
My car started FOR THE FIRST TIME IN 3 MONTHS yesterday. I'm soooooo pumped. It runs absolutely perfectly, just imagine a sewing machine but 100x better.
users go pickup a wrench nobody wonts your oninion
why would I use a wrench on an onion?
Sciroccoboi16v is offline   Reply With Quote Quick reply to this message
Old 05-26-2012, 07:29 AM   #7
NorCalLuder
Lude Dude
Ya thats what my plan ended up being im gonna shave a lil bit off of the mount and see if it fits then, The metal sleeve that goes through the middle is like a 1/4 inch too wide so im going to take an 1/8th inch off of both sides and see how that works out.
__________________
Nor
Cal
89 Lude Si Red
Old 05-26-2012, 09:06 AM   #8
Sciroccoboi16v
Lude Boss
I've done that before on cars. Should be fine. Its easy enough anyways. And with the rear mount its not likely you are going to screw up axle alignment with it
__________________
Old 05-26-2012, 09:28 AM   #9
88SE Lude
Prelude Aficionado
88SE Lude's Avatar
88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of
Unless it's a pattern part not OEM then that is extremely unlikely, these are Hondas not VWs !
and as others have said, the MT and AT parts are different.
__________________
"You are not entitled to an opinion. An opinion is what you have when you don't have any facts. When you have the facts, you don't need an opinion"
MustardCat - "You have free access to people with decades worth of experience here. Being asked to format your posts in a readable manner is very reasonable. Call your local Honda dealer and see how much they want per hour to have a master tech diagnose your problem..."
88SE Lude is offline   Reply With Quote Quick reply to this message
Old 05-26-2012, 10:06 PM   #10
TripleLude
Prelude Aficionado
TripleLude's Avatar
TripleLude has a spectacular aura aboutTripleLude has a spectacular aura about
I ran into this problem, but I was using the exact same mount that I pulled off. Turns out someone before me replaced that mount.
Solution: Rotary tool with carbide bit. I just carved out the holes on the mount to make them oval. Actually, I think one hole was like 5mm off and another was 2mm off.
__________________
TripleLude is offline   Reply With Quote Quick reply to this message
Old 05-27-2012, 08:34 AM   #11
NorCalLuder
Lude Dude
Thanks trip and everbody else i had the mount holes fixed used above solution ^^^^. Thanks
__________________
Nor
Cal
89 Lude Si Red
Old 05-27-2012, 09:16 AM   #12
Sciroccoboi16v
Lude Boss
Riight, so the integra that I shaved the mount on had something to do with VW? This makes no sense to me
__________________
Old 05-27-2012, 09:33 AM   #13
88SE Lude
Prelude Aficionado
88SE Lude's Avatar
Maybe you forgot to bring your SOH along?
BTW I have a Quattro, therefore I can make such comments about VW/Audi cars.
__________________
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
