| Register | FAQ | Insurance | Members List | Calendar | Auto Escrow | Auto Loans |
Thread Tools | Display Modes |
#1 | |
Lude Dude
Only running on two cylinders
Ok here's my dilema, my car started feeling like crap and misfiring. When I checked it out I realized it was only running on 2 cylinders. I checked for codes and got a code 16 which is fuel injector circuit. I followed the flow chart and it said if I get a clicking at all the injectors then its the ecu. I was speaking to someone and they said it can't be because then the car wouldn't start. Any thoughts on this situation?
__________________
#2 |
Newbie
![]() Join Date: Mar 2011
cap wires plugs.....
__________________
91 si Black Project |
#3 | |
Lude Dude
I'm getting spark on all four and I had someone do a compression test and he said its pretty much even across the board.
__________________
#4 |
Ludicrous..
With the engine on, try pulling off the plug wires from each cylinder one by one to see if the idle stays the same or gets worse. If it stays the same you know that, that cylinder is not firing.
Usually this problem is caused by plug wires having a bad connection to the plugs or some other sort of electrical problem. I heard you say you have spark, but please re-check.
__________________
91 Red/tan JDM B20 SI 91 Black auto SI 4WS (parts/donor car) Pics: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#5 | |
Lude Dude
I did that and its how I determined I was only on two. Cylinders 1 and 2 are the ones that aren't running, I'm only running on 3 and 4.
__________________
#6 |
Prelude Aficionado
Soooo...we are getting spark to all 4 cylinders. The fuel injectors are working for all 4 cylinders and we have good compression for all 4 cylinders. Cylinders 1 and 2 are not firing.
It's either the Wrath of God or there is something wrong with the test procedures being applied.
__________________
#7 | |||
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. 1989 Prelude 2.0Si 4WS 2013 Subaru WRX 1978 Chevy K20 4x4 Quote:
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Quote:
#8 |
Prelude Aficionado
ya sounds like clogged injectors or just not working injectors.
__________________
2011 Honda CR-Z - DD 1991 Honda Prelude SE - LEATHER SEATS BABY - H22 - 180whp - 160tq To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#9 |
Getting Comfortable
![]() Join Date: Nov 2011
I just had this same problem. After changing the whole ignition system and messing with the injectors it ended up being the sensor on the end of the exhaust cam next to the distributor.
#10 |
Prelude Aficionado
I stand corrected.. I thought that he implied that he as getting "clicking" from all 4 injectors.
__________________
#11 |
Ludicrous..
It's not too hard (but dangerous) to take the injectors out and test them by having the entire fuel rail spray into a bucket. This gives you a quick, full answer if it's the fuel system or not. I'm still betting it's not.
The crank angle sensor sounds more plausible.
__________________
#12 |
Lude Dude
Injectors static open or closed is the money bet. Put a open end wrench on the injectors for the cylinders not working and slightly tap them. I've encountered paint flakes and such that seem to make it in there. Tapping them slightly may free them up. I've only had to do this 2 times, but worked each time. Worth a try.
#13 |
Deluded
or it could be the injector resistor box on the firewall. check all the connections from that all the way to the rail. if even one is off or lose then it will screw with most of ur electrical. i will also point out that with injectors the wiring is usually paired. meaning cyls 1 and 2 are paired and cyls 3 and 4 are paired. and since cyls 3 and 4 are working cyls 1 and 2 are not. so in conclusion i believe it be something electrical over an injector.
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
