| Register | FAQ | Insurance | Members List | Calendar | Auto Escrow | Auto Loans |
Thread Tools | Display Modes |
#1 |
True Luder
![]() Join Date: May 2011
ABS (and BRAKE) light issues...
Recently I changed out my front rotors and pads. I was going to attempt to install new wheel studs on the driver's side because one is stripped out. Once I realized how involved it was going to be, I was already halfway through taking apart the hub assembly, etc. So I put everything back together and said f* it for now. Afterwards, my ABS light came on. Then it would go on and off occasionally. Now it's on 100% of the time.
I'm sure I messed something up when reinstalling everything... or maybe the ABS module is bad. I don't know. I haven't really tried to see if my ABS actually works.... but I know the light is always blaring me in the face lol. I did bleed the brake fluid system properly and I am not low on fluid.. And then now, it's strange, but my regular BRAKE light stays on sometimes. Usually when cold in the morning... but sometimes not. When I disengage the parking brake, the light stays on. It will go off, but sometimes come back intermittently. Then it will stay off for the most part. The whole thing is just strange to me because I've never had a car do this before. Suggestions? |
#2 | |
Newbie
#3 |
Prelude Power P-O
Check the fluid level in the reservoir and more importantly check the float in the reservoir cap because those are known to stick and will do exactly what you are talking about.
Sent from my DROIDX using Tapatalk
__________________
PAID OFF!!!! 7/14/10 Turbo engine build in the process. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. My build thread -project resurrection To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#4 |
Opinionated Bastard
![]() Join Date: Jul 2008
Sounds like you might have damaged the wheel speed sensor on the hub. I had an ABS light until I did three wheel speed sensor on my car too.
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. 1998 Prelude - 1998 ///M3 |
#5 |
Prelude Aficionado
__________________
1988 Prelude S - victim of an 80mph backflip 1991 Prelude Si - sold 1989 Accord DX - impounded To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. 2006 CRF150F - sold 2006 YZ250F - sold 2006 S2000 (Laguna Blue Pearl) - purchased bone stock on 6/16/12 |
#6 |
True Luder
Alright, I'll check the fluid again. I just checked it today and it was good. I will see about the floater thingy sticking maybe. That would cause the parking brake light to go on and off or stay on even when the brake is disengaged?
I could have sworn I tried to pull codes with the jumper pin for the ABS. The light just stayed solid. But I will try again. Mommys - you're saying the wheel speed sensor, separate from the ABS sensor (?), could be throwing the ABS light on? And what do you mean you did "three wheel speed sensor"? |
#7 |
True Luder
Light still keeps coming on and off. The parking break light. Fluid levels and condition is fine. No leaking.
E-brake cable messed up maybe? |
#8 |
Lude Addict
![]() Join Date: Jul 2011
i have the same issue on cold mornings with my parking brake, it stays on and then once the car warms up it goes away, i'm sure it's not hurting anything just annoying...
__________________
#9 |
True Luder
Well I finally got around to pulling the ABS light code. Or trying to. This is it. I just need to look up what the flashes indicate. I procrastinated until we had a bad snow storm here and I really needed my ABS! lol
http://youtu.be/iydi5wuBWZ8 |
#10 |
Prelude Aficionado
The link has already been provided.
__________________
#11 |
True Luder
Yes, thank you. It's code 14, it looks like.
Just not sure if that's a wheel speed sensor or the ABS sensor or what. Helms manual is a little gray. Going to have to take the wheel off tomorrow and check it out I guess. |
#12 |
True Luder
In order to follow the Helm trouble shooting process you need a multi tester. If the process makes no sense to you you should probably take it to a shop, unless you spot something obvious with your visual.
You'll also need to check the helm in order to reset the ABS light as just disconnecting the battery won't do it. |
#13 |
Lude Dude
the parking brake light is caused by the brake fluid level switch being intermittent. it typically goes bad after a while when the climate starts getting colder.
#14 |
Prelude Aficionado
Nope, he just needs to read the thread that was already linked.
__________________
#15 | |
True Luder
Thanks again. I will clear the code and see if it comes back. I have a feeling it will. If it does, has anyone here had success with a Code 14 ABS? |
#16 |
Lude Dude
sorry man i never actually saw the switch and my local honda dealership did the work for me. I bet its either in the center console attached to the ebrake or somewhere around the ebrake cables on the rear calipers.
#17 |
True Luder
Thanks, it's OK.
I pulled the wheel off to take a look. Yea, there WAS no wheel speed/ABS sensor there at all. Looked like it got cut or ripped off actually. It was a clean cut on the wiring, but the sensor part of it wasn't even there bolted down or anything. Looks like I'll be needing that $100 part soon lol |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
