white smoke from the end of the exhaust - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 09-29-2011, 01:01 AM   #1
bleong3292
Lude Dude
bleong3292's Avatar
bleong3292 is on a distinguished road
Ok, so I'm blowing white smoke out the back of my exhaust. Not a lot, but enough to worry me.
101k miles, 2000 prelude base. Smoke before I did exhaust work.
MPG sucks. Coolant level not low, did a compression test and (cylinder right of the block to the left) I got 162, 163, 165, and 170 psi, took a scope and looked at the piston heads and see carbon but not oily.
Might be a partially clogged pcv valve causing more vacuum that might suck some oil into the intake manifold. But Idk.
Any ideas? I work at a shop so tool are not a problem.
bleong3292 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-30-2011, 12:39 AM   #2
gearshredder
True Luder
gearshredder's Avatar
gearshredder is on a distinguished road
white smoke is indication of burning coolant. Compression test will usually not give accurate results in headgasket diagnosis. Try a leakdown test instead. The headgasket can also act as a one way valve and allow coolant in and compression in. Do a coolant system pressure test. Only other substance that I know makes white smoke is seafoam
gearshredder is offline   Reply With Quote Quick reply to this message
Old 09-30-2011, 07:17 AM   #3
MommysLittleMonster
Opinionated Bastard
MommysLittleMonster's Avatar
MommysLittleMonster is a splendid one to beholdMommysLittleMonster is a splendid one to beholdMommysLittleMonster is a splendid one to beholdMommysLittleMonster is a splendid one to beholdMommysLittleMonster is a splendid one to beholdMommysLittleMonster is a splendid one to beholdMommysLittleMonster is a splendid one to beholdMommysLittleMonster is a splendid one to behold
Send a message via AIM to MommysLittleMonster
Prelude of the Month
Very good advice. I would say he's spot on there.
__________________
1998 Prelude - 1998 ///M3 - 2003 Accord - 2015 WRX Limited
MommysLittleMonster is offline   Reply With Quote Quick reply to this message
Old 09-30-2011, 02:30 PM   #4
egjdmh22a
I am Prelude
egjdmh22a's Avatar
egjdmh22a has a spectacular aura aboutegjdmh22a has a spectacular aura about
Send a message via MSN to egjdmh22a
Did you over fill your oil?
__________________
94 Civic dx hatchback, Jdm H22A
Euro-R T2W4 Transmission with LSD
Hytech header, test pipe,3 inch exhaust
Zex dry 75 shot, P28 ECU with Neptune
197 WHP N/A 264 WHP bottle
street tires
egjdmh22a is offline   Reply With Quote Quick reply to this message
Old 09-30-2011, 06:01 PM   #5
aznjap808
True Luder
aznjap808's Avatar
aznjap808 will become famous soon enough
I had the same problem, blown headgasket.
__________________
228Hp
192Tq
99' SH Supercharged
The Build Thread:
aznjap808 is offline   Reply With Quote Quick reply to this message
Old 09-30-2011, 06:56 PM   #6
gearshredder
True Luder
unless mistaken, that would blue smoke. fuel is black smoke
Old 10-02-2011, 02:17 PM   #7
bleong3292
Lude Dude
bleong3292's Avatar
ill go do a coolant pressure test tmw, but i know im burning oil as well, the tech followed me one time and said i was burning oil. no i didnt overfill the oil when i changed my oil.
Old 10-03-2011, 06:11 AM   #8
NFZ503
Getting Comfortable
NFZ503 is on a distinguished road
[QUOTE=bleong3292;2848665]ill go do a coolant pressure test tmw, but i know im burning oil as well, the tech followed me one time and said i was burning oil. no i didnt overfill the oil when i changed my oil.
Engine leak down test is the best thing to do...If you want to find out if your headgasket is going bad. (air bubbles will be coming out from the radiator)
NFZ503 is offline   Reply With Quote Quick reply to this message
Old 10-08-2011, 08:51 PM   #9
Fubar
Getting Comfortable
Fubar's Avatar
Fubar is on a distinguished road
yeah gearshredder is right white= coolant blue= oil black=fuel
__________________
Delaware 302- foreverlow.com
(made on forza 3)
"Doesn't matter if you win by an inch or a mile winning is winning"
Fubar is offline   Reply With Quote Quick reply to this message
Old 10-09-2011, 10:09 AM   #10
01ludeness
Lude Addict
01ludeness's Avatar
01ludeness will become famous soon enough
Exactly...
__________________
01' Prelude JRSC, H23vtec, 8psi on E85, 309whp/243wtq.... check out my build thread:
01ludeness is offline   Reply With Quote Quick reply to this message
Old 10-19-2011, 06:40 PM   #11
SilverBB698
True Luder
SilverBB698's Avatar
SilverBB698 is on a distinguished road
good luck on that man. but yea white smoke would coolant. blue is oil.
__________________
MY Build Thread------>
SilverBB698 is offline   Reply With Quote Quick reply to this message
Old 10-20-2011, 05:31 AM   #12
scarface1346
Lude Dude
scarface1346 is on a distinguished road
same thing was happening to me whith other symptoms aswell it was the head gsaket hope its not same for you, good advice above check to see if you bubbles coming out of coolant. something you can try is in the morning before you start up car open rad cap top off coolant and with cap off start car check to see if coolant spits/bubbles out, if it does you have gases in your system and its probly head gasket. I did that test on my car and it shot out pretty good. when the mechanic did pressure test and compression test on my car prior to finding out it was head gasket the numbers on those test were good also like yours.
scarface1346 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
