| Register | FAQ | Insurance | Members List | Calendar | Auto Escrow | Auto Loans |
| View Poll Results: Septemeber 2011 1st-3rd Gen voting thread | |||
| rjudgey |
111 | 76.55% |
| ludeman69 |
34 | 23.45% |
| Voters: 145. You may not vote on this poll | |||
Thread Tools | Display Modes |
#1 |
Sky's out, thighs out
![]() Join Date: Sep 2008
September 2011 POTM 1st-3rd Gen Voting Thread
Sorry about the late POTM voting guys but I have been very busy with school.
rjudgey ![]() ![]() ![]() ![]() ![]() ![]() Car originally bought 14 years ago undergone a few different changes in the years now I have a mint Red EX this one has become a track/weekend warrior hasn't been used as a daily driver for 10 years. Model Honda Prelude DL (most basic also most lightest one made) Engine: Was ET 1.8l 12 valve SOHC. Now A20A4 with CR ratio 10.4:1 (hand built blue printed). Head 12 valve 3mm oversize inlet 3mm oversize exhaust valves custom made SI supplied blanks. Bronze Guides by SI valves. Prelude ET exhaust valve springs all round. Pipercams reground 285 degree camshaft 10mm lift. Inlet ports had welding and full port and flow job. Exhaust ports had reshaping and guide ends reshaped. Chambers deshrouded flowed and polished. Head skimmed 1.5mm to raise CR ratio. Induction custom stainless steel manifold with precision welding internals all flowed and surface texturized to help atomize fuel. Twin Weber DCOE 45's modified with countersunk butterfly screws, chokes bored to 42mm, internal parts flowed and casting marks removed, pipercross bellmouth trumpets 75mm long. Splitfire ignition leads, resistor less plugs indexed, Direct hit's capacitor modules, stock dizzy and coil. Custom Header 4-2-1 with 1.5" extra long primaries leading to 2" downpipes and 2.5" collector and mandrel bent system. (getting done this week old one is 2" and uses modified stock header) Gearbox later model 3G accord Bell housing with 1st Gen CRX D16ZC gearbox swapped onto it, new race spec bearings and new gaskets. Clutch Clutchnet Red plate with Organic spring hub onto custom machined stock flywheel weighing 10lbs. Axles std and original with 170k miles! Brakes Custom made Hi Spec Kit wtth Racing 4 lightweight compact calipers, AP 300mm x 28mm two piece disks custom bell housings from Hi Spec, custom made brackets from Hi Spec, all this fits inside a 15" wheel!! Rear Brakes just stock with Ferrodo pads and EBC disks. Suspension Poly bushes in front axle rear stock bushes. ARB front and rear is removed. Coilovers custom made by Gaz Shocks in UK (Essex) this is the only 2nd Gen to have Gaz shocks made, two way adjustable damping on front shocks 550lb springs rears are one way adjustable with 600lb springs shocks can handle upto 900lb springs. Front Upper wishbone arms camber location holes elongated to increase negative camber. Exterior colour Stratosphere Blue, side mouldings removed, rear wiper removed, front is stock single wiper, SI front and rear bumpers fitted. BSA 5 spoke alloys with Vredestein Sportrac 3 tyres 195/50/15. ZCW Bolt lightweight alloys in gloss black with Toyo R1R's fitted 195/50/15 (arriving next week). Interior inside stripped dash board remains, aerial removed, passenger and rear seats removed, passenger belt removed, rear compartment removed, bonnet and boot lightened and bonnet pins in place to replace hinges and locks, spare wheel and tools removed, any additional bolts removed, Stereo all gone replaced by gauges, inside of doors lightened, head light motors removed and lights fixed up, Centre cross beam and gearbox shock mount removed as engine mount dog bone reinforced stopping movement so these parts have no use. Some racing names stuck to side to make it look more racey! lol! I think thats about it entering PPC magazine 999 challenge on 16th September hoping to be in the top 5 at least and have a chance of winning. ludeman69 Thank you for the nomination! Here are some of the mods and parts I can remember, I'm sure there is some that I have forgotten about. 1991 Honda Prelude Si 4WS Engine: JDM B21a OEM Honda rebuid B20a5 head JDM B21 Intake manifold port and polished with no EGR 62mm Throttle Body H23 connecting rods Web Camshafts grind #13 AEM Tru-time Cam gears 8 Gauge ground wire upgrade Removed Charcoal Canister and Control Box Integra Cold Air Intake Heat wrapped with K&N Cone filter Slight wire tuck Fusebox relocated next to ECU Battery relocated to trunk Exhaust DC Sports Header and Downpipe LSD Sports Catback exhaust Drivetrain D2A4 OEM Honda Rebuild Accord 5th Gear New Shift Cables OEM Honda Clutch and pressure plate Suspension Tokico Struts H&R Sport Springs Secluded Adjustable Sway bar endlinks Mustardcat front and rear strut tower bars 16x7 Konig Feathers 205/55/16 Goodyear Eagles Interior Hacked short shifter Razo Shift knob Black Crown Royal shift boot Gloshift oil pressure and wideband gauges Jerry the Giraffe Exterior OEM Hood Bra for road trips 94-95 accord side skirts OEM Mud flaps Tinted tails and front sidemarkers Yellow fog lights rewired 50% tint in front and 5% tint in the rear BA squad sticker(Thanks Mulrich!) H4 Ebay conversion headlights Bio: I've had my prelude for 5 years since I was 14 and a freshman in high school. This car has gone through a lot of abuse, changes, and its had its highs and lows. As most other luders know your car is never completed, there are always more parts and changes to come. I started building the B21a when I was 16 and finished it about a year and a half later. Its ran great ever since and doesnt burn any oil after 20k miles. A few weeks ago I had a chance to put it on the dyno and it made 136hp and 135 ft lbs of torque on stock ecu and a leaky exhaust. I love preludepower and all its members. I have had my fair share of problems and a lot of members have helped out. Thank you to everyone for contributing to this forum in every way. ![]() ![]() ![]() ![]() ![]()
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. I'm saving for a Viper. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#2 |
I am Prelude
Goodluck rjudgey! Sick 2gen with probably one of the coolest carb builds I've seen
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. White 91 4ws-Built B21a- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Red 90 Civic Wagon RT4WD DOHC ZC- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. For sale thread 3G parts: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#3 | |
Bearderator
Some pics aren't working. Possibly a work firewall issue, will try again when I'm at home.
__________________
Read this To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ! Quote:
J.L.D.E.P.P.M.S.3.C.N.Y.C.N.C.M.A.D
#4 |
The Manager
![]() Join Date: Feb 2006
Next month there should also be a mass PM to nominate as well.
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. My 92' Prelude To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Custom H22 Turbo Kit (Without the Turbo) Yours for $1550 shipped.. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#5 | |
True Luder
![]() Join Date: Oct 2009
Never voted in POTM before but really like the car rjudgey, well done. |
#6 |
Lude Cray
![]() Join Date: May 2008
I'm a 3rd Gen guy, but I gotta say 2ND GEN FOR THE WIN this time around. Good luck to you both!
__________________
My Daily: 1988 Prelude 2.0 Si 4WS [Quality Upgrades from: Acura-OEM / Akebono / Alpine / Brembo / Castrol / Cusco / Energy Suspension / Honda-JDM / Ingalls / Interstate / K&N / NGK / Neuspeed / Polk / Prothane / SuperPro / Sylvania / Tokico / Kumho Ecsta ASX] |
#7 |
True Luder
Props to you rjudgey for a nice clean 2g with work done to that stock motor. What numbers are you lookin at? love the dual carbs with flow stacks. You be lookin like an ae86. and ludeman69 nice 3g bro. very clean. love those side skirts.
__________________
I got rhymes off tha dome, i come to yo home, take yo dog's bone, and put it in my mouf. |
#8 |
Lude Addict
...all I have to say is check my name...looks like it's going to be a landslide...
both wips are tight...love the sides..meshes with the rims...
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#9 |
Prelude Aficionado
I have to think abut this one. Hard to decide. The 2nd gen build is so cool. I am a motor head, and I see a lot in that engine build. The 3rd gen is clean under the hood though.
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#10 |
Prelude Aficionado
![]() Join Date: Feb 2004
2G Build
Thanks for the props guys, as you all know I've been around the prelude scene since the original Hondaprelude.com days and I've had my little ride for 15 years now, I'm a bit like the Honda prelude version of the film " The worlds fastest Indian!" lol!
Car has just had some more work done I've modified the upper arms basically elongated the slots that hold the upper ball joint on an extra 1/8" and now gives me upto -4 degrees camber, then I've also had the exhaust finally sorted out, didn't have quite enough money and time to get the header done but I've had the downpipe done to the ported and flowed cast header which is a 4-2 design anyway and isn't too shabby, this leads to 2 2" downpipes!! and then to a 2.5" system all mandrel bent with two silencers the car is seriously breathing much better now sounds better too it's actually incredibly loud! The interior has had a clean up and is completely stripped apart from dashboard, will be lining the inside doors and quarters with plastic sheeting. I've managed to get the weight down to approximately 850-860kg's was 900kg's before i started the serious stripping! Later date will be putting in a nicer bucket seat that's lighter and more comfy these Cobras are hard as nails and not that light. And will be replacing the wing mirrors with racing lightweight ones and also looking and plexi glassing the side windows and removing everything from the insides off the doors. At a competition tomorrow hoping to pick up a 1-3rd place car should be very competitive it's a Auto X event and combine Drag event who ever averages the fastest time across both events wins. ![]() ![]() Also if anyone wants to see more pics check out www.myspace.com/rjudgey
__________________
i like to hunt big game boy ricers are no challenge! Last edited by rjudgey; 09-15-2011 at 04:42 AM. |
#11 |
Prelude Aficionado
carbed engine
The Engine depending on Camshaft choice is between 185-200bhp but working on a better cylinder head and a high compression block with forged pistons for next time round which should see me well over the 200bhp mark!
__________________
i like to hunt big game boy ricers are no challenge! |
#12 |
Prelude Aficionado
both very clean cars.
__________________
2011 Honda CR-Z - DD 1991 Honda Prelude SE - LEATHER SEATS BABY - H22 - 180whp - 160tq To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#13 |
Getting Comfortable
Nice build rjudgey! I'm definately a 3rd gen guy, but you have got to admire the work put into that 2nd gen!
__________________
White 1988 S converted to SI w/ 5th gen tailights Blue 1988 Si with B20A swap (Sold) |
#14 |
Prelude Aficionado
2nd gen drag time
Ran a 1/4 mile competition yesterday 14.1s 100mph terminal pb for me last one was 14.5 at 94mph so well chuffed and was on wet road tyres not slicks or dry weather road tyres.
__________________
#15 |
Newbie
![]() Join Date: Aug 2011
I like the 3rd gen because of the giraffe, and because it is a 3rd gen. But some serious work has gone into that 2nd gen.
#16 |
Lude Cray
2g's for life!!!!
__________________
I believe there is a natural law of selection when it comes to opening the treasure chest, while others can give you a map, everyone must go in search of their own key. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#17 |
Prelude Aficionado
That second gen is pretty sick
__________________
#18 |
Wow! The dual carbs on the 2Gen are awesome.
Both very nice. I like the white paint job on the 3Gen but the work on the 2Gen puts it over the top.
__________________
1998 pearl white prelude, auto to 5spd conversion, 229k miles, aem intake, tanabe catback with magnaflow. find me on streetfire as gaborn73 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
