Bouncing RPM - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 09-13-2011, 05:56 AM   #1
djadragon
Getting Comfortable
djadragon's Avatar
djadragon is on a distinguished road
Bouncing RPM
I have this issue started couple months ago and now it got worse and worse.
Here's the video below so you get the idea:
This issue happens when normal cruising on the highway and in the city. However, pressed a little more gas, the RPM stay NORMAL and same goes when I let go the gas as well.
I've replaced or checked the following:
-Spark plugs
-Spark plug wires
-Ignition Coil
-Swapped whole Distributor included ICM
-I went to Autozone and Advanced Auto Part to have them test my alternator. Both came out Ďpassedí.
-Replaced battery last month
That's all I can think of.
So, does anyone have a clue related this issue????
djadragon is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-13-2011, 12:48 PM   #2
realblag
True Luder
realblag's Avatar
realblag is on a distinguished road
Looks like an electrical issue with the cluster. Obviously, it is not a problem with anything under the hood because it would be impossible for the motor to change rpm that quickly.
realblag is offline   Reply With Quote Quick reply to this message
Old 09-13-2011, 01:57 PM   #3
catacon
Ludimus Catacus
catacon's Avatar
catacon is a jewel in the roughcatacon is a jewel in the roughcatacon is a jewel in the roughcatacon is a jewel in the rough
Ignore this.
catacon is offline   Reply With Quote Quick reply to this message
Old 09-13-2011, 02:54 PM   #4
dontbuyprelude
Lude Dude
dontbuyprelude's Avatar
dontbuyprelude is on a distinguished road
i vote for ignition control module or bad gauge cluster. the tachometer gets its signal from the icm. check to make sure the electrical connector(s) is "clicked in" on icm and cluster.
dontbuyprelude is offline   Reply With Quote Quick reply to this message
Old 09-13-2011, 05:59 PM   #5
cinci-91-H
Guest
Posts: n/a
Hmmgh, on a third gen Prelude the tach signal comes from the negative side of the coil. That's how my H22a is running in my 3rd gen. Are you sure it comes from the ICM on a 5th gen?
Old 09-14-2011, 04:37 AM   #6
djadragon
Getting Comfortable
djadragon's Avatar
From my understanding, I had swapped the whole Distributor which included ICM as well. It does the same issue. However, I donít believe there is any issue related cluster. That being said, there were slightly jerks when cursing normal highway speed. I have a feeling I might have a bad TPS???
Old 09-14-2011, 01:45 PM   #7
ritzcracker
Getting Comfortable
ritzcracker is on a distinguished road
crazy enough a bad ground could cause this... i had this in one of my 4th gens and it was a loose ground by the thermostat from when i did my swap... wouldn't hurt to double check the grounds in the bay
__________________
HPOC (Hawaii Prelude Owners Club)
ritzcracker is offline   Reply With Quote Quick reply to this message
Old 09-14-2011, 06:50 PM   #8
dontbuyprelude
Lude Dude
yes. in the the helms on page 23-59 it states that "tachometer: indicates 100 rpm at 200 pulses per minute of the ignition control modul (ICM)."
so yes tach gets its readings from icm.
Old 09-14-2011, 06:55 PM   #9
dontbuyprelude
Lude Dude
the icm is the little black box that has the "5th spark plug wire" thingy going to it. theres 4 wires for the cylinders and the last one goes to icm.
as for the jerking is it happening when your ac is on?
Old 09-14-2011, 07:14 PM   #10
cinci-91-H
Guest
Posts: n/a
Thanks man. I agree, it has to be related to the tach itself. That needle was jumping all over the place. The motor tone didn't seem to change at all.
So OP, are you feeling something from the car when this occurs?
Old 09-21-2011, 10:26 AM   #11
AK203
Newbie
AK203 is on a distinguished road
Mine does it too... Only in vtec... I dont kno what it is smh
AK203 is offline   Reply With Quote Quick reply to this message
Old 09-22-2011, 11:50 AM   #12
2oprelude00
True Luder
2oprelude00's Avatar
2oprelude00 will become famous soon enough
my money would be bad coil ive worked at honda for a year now and have seen many cars including my car do this. there is a tsb that has been out for a while on this ill try to pull it up.
2oprelude00 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Bookmarks
Tags
bouncing rpm, rpm bounce
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
