Need help ASAP. Car got overheated...now it won't even start. - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 04-16-2011, 01:38 PM   #1
webglasses
True Luder
webglasses is on a distinguished road
I have a 99 SH Prelude. The car got overheated bc of a coolant leak from the main line (the radiator hose to the engine). There was a cut on hose so the coolant got all over the engine bay. The car shut off when I got almost to the house. Replace the radiator hose...it starts fine for a couple of days...then it won't start...it only cranks. Replace the ignition coil and the module inside the distributor cap bc it was going bad. It works after pushed start the car...starts fine for another couple of days. Now it doesn't even starts...a weak crank for a couple of seconds...then only a clicking noise now. What is the problem with my car? Much help is appreciated.
webglasses is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-16-2011, 01:39 PM   #2
Wing8806
Faptastic
Curveball Champion, Alien Clones Champion
Wing8806's Avatar
Wing8806 is a name known to allWing8806 is a name known to allWing8806 is a name known to allWing8806 is a name known to allWing8806 is a name known to allWing8806 is a name known to all
Have you checked your spark plugs? Have you had your starter checked?
__________________
2001 Prelude - Project
2008 Mugen Si - Daily
Do not trust Kane666 aka Jason Myers.
Wing8806 is offline   Reply With Quote Quick reply to this message
Old 04-16-2011, 01:49 PM   #3
webglasses
True Luder
the starter is still new...change it half a year ago. Check the spark plugs is was dry except for the the 4th plug
Old 04-16-2011, 01:57 PM   #4
Wing8806
Faptastic
Wing8806's Avatar
Just because it's new doesn't mean not check it lol. There's always a chance something went wrong - better safe than sorry.
So your coolant is topped, and it ran after you fixed the leak. At lest it doesn't sound like you seized the motor.
__________________
Old 04-16-2011, 02:02 PM   #5
webglasses
True Luder
Yeah...it ran after I got it fixed. The car cranks, but it doesn't crank anymore only clicking sound. I check the starter after it died on me...so it's still good.
Old 04-16-2011, 02:19 PM   #6
Wing8806
Faptastic
Wing8806's Avatar
Stupid question - is your battery good, and have you checked that your grounds are tight?
__________________
Old 04-16-2011, 02:26 PM   #7
webglasses
True Luder
Yeah...I took the battery to autozone and they it was 89% charged...so it good. I checked the ground also. Could it be the fuel pump or the injectors?
Old 04-16-2011, 02:36 PM   #8
Wing8806
Faptastic
Wing8806's Avatar
It's possible the fuel pump. But you would still be able to start up with the leftover fuel in the system. It would run for 10 seconds or so but it'd still run.
I kill my fuelpump power too many times and forget about it - surprised it's not burned up yet.
Howabout your ignition switch? on some years there was a recall.... do a quick search on the symptoms for that real quick
edit*
http://www.preludepower.com/forums/s...gnition+switch
__________________
Old 04-16-2011, 03:05 PM   #9
webglasses
True Luder
The recalls for the ignition switch is only for 97s and 98s...so mine is rule out. Still looking around to see what the symptoms are.
Old 04-16-2011, 04:38 PM   #10
psud3ity
Prelude Aficionado
psud3ity's Avatar
psud3ity is a name known to allpsud3ity is a name known to allpsud3ity is a name known to allpsud3ity is a name known to allpsud3ity is a name known to allpsud3ity is a name known to all
Check your coolant and oil for contamination. If you see a milky brown sludge in either you probably warped the head. Do a compression test as well just to make sure you still have compression in the motor. Either would indicate a headgasket.
__________________
391HP @ 12psi - Soon to be 650HP
psud3ity is offline   Reply With Quote Quick reply to this message
Old 04-16-2011, 04:42 PM   #11
webglasses
True Luder
Alright...I'll check that. How hard it is to fix the warped head is the problem?
Old 04-16-2011, 04:53 PM   #12
webglasses
True Luder
I just checked both...there are not any milky brown sludge. But my oil cap smell like gas...don't know how that get into my motor...probably from the spark plugs I'm guessing.
Old 04-16-2011, 06:27 PM   #13
Shiloh51933
Lude Addict
Shiloh51933's Avatar
Shiloh51933 will become famous soon enough
Possibly plugs, more likely injector seals since you ran her overheated. U know now to never run a.motor u care about overheating, pull over.and.shut. I'd tow mine home or try and diagnose/repair onsite. Bad injectors would make more sense from your posted symptoms. If you haven't done a compression test then do a test asap and I would bechecking your injectors.
Shiloh51933 is offline   Reply With Quote Quick reply to this message
Old 04-16-2011, 06:30 PM   #14
psud3ity
Prelude Aficionado
psud3ity's Avatar
Some heads can be redecked by a machine shop. I had to do that on my BMW when I let it overheat and the head warped. $500 later... Not to mention you're taking the ENTIRE engine apart to replace the gasket.
That's a good sign that theres not any milky stuff in your coolant, that means that oil hasn't found it's way in there which would be a sign of a blown headgasket/warped head. As for the gas smell, you may have flooded the engine trying to start it. Take the plugs out, pull the fuel pump fuse, and crank the motor a few times. That should clear the flooding condition. Wipe the excess gas off the plugs and put the fuse back in.
In EXTREME cases (Learned this trick from RX7 owners, rotaries are notorious for flooding if you start the car, move it 5 feet, and then park) gas can contaminate the oil, and that will cause a low compression state, which is only compounded by trying to start the car, which adds more fuel to the problem. A quick way to raise compression is to remove the plugs, take a teaspoon of oil and drop it in each cylinder through the plug holes, If you have a syringe and can shoot it directly onto the piston through the hole it works best. This artificially raises the compression of the motor a bit. Put her back together and start the car. EXPECT LOTS OF SMOKE. LOTS. Until that oil burns off at least. Do NOT try this in a closed garage. The car may stall out once the oil burns off, and that would indicate your compression is still too low to run the car. I'd suggest changing the oil and trying again at that point. But at least you may be able to get it started.
Good luck. I can't agree with shiloh more though, DO NOT RUN A CAR OVERHEATED. EVER. Tow it home.
__________________
Old 04-16-2011, 07:30 PM   #15
webglasses
True Luder
The plugs were kinda of wet and it was kinda of black (probably from the gas). The car doesn't even crank...just clicking noise now. I probably change the oil tomorrow and see what happen. Also need the compression tool to do the compression test. How do I do the oil test if it doesn't even cranks?
Old 04-17-2011, 01:46 AM   #16
psud3ity
Prelude Aficionado
psud3ity's Avatar
Did you burn out your starter or kill your battery? Jump start the thing. If it's your starter going bad you can try either jumping the car directly from the post on the starter (negative terminal to - battery, + terminal to the post on the starter). Sometimes hitting it with a high enough voltage will force the starter motor to turn. Other trick would be having someone hold the key in the start position and hitting the starter motor with a hammer. If the brushes in the starter are binding either way is likely to break them free.
__________________
Old 04-17-2011, 12:38 PM   #17
webglasses
True Luder
Maybe...I'll try to hit the starter and see what's up. I'm going to change the oil while I'm at it. Hopefully it will run.
Old 04-17-2011, 12:39 PM   #18
webglasses
True Luder
This is a stupid question...Does having gas in the motor lower the compression?
Old 04-17-2011, 05:36 PM   #19
webglasses
True Luder
Just change the oil...my battery was low, so I went to Autozone and got it recharge. The only problem right now is there is no spark so the car won't start. What is the problem? The mechanic that came to my house thinks is the distributor...but I'm going to check the spark plug wires first. Any suggestions?
Old 04-18-2011, 08:24 PM   #20
webglasses
True Luder
bump for more help...and updates - just change the distributor from the junkyard...still doesn't work. No sparks at all. Will the a bad ECM be causing this?
Old 04-18-2011, 10:31 PM   #21
prodigyofchaos
99 SH
prodigyofchaos is on a distinguished road
when i wasn't getting spark it was the ground for my engine. i would check that since it is cheap
prodigyofchaos is offline   Reply With Quote Quick reply to this message
Old 04-18-2011, 11:17 PM   #22
webglasses
True Luder
Where do you check that? I checked the ground for the battery...both at the passenger headlight and the transmission...is that the same thing?
Old 04-18-2011, 11:26 PM   #23
gearshredder
True Luder
gearshredder's Avatar
gearshredder is on a distinguished road
Well, Have you checked ALL your fuses? Start with that.
Try starting it with starting fluid does it start?
No spark? pull the wire from the ignition coil. Spark there?
DON'T THROW PARTS AT IT!
Check for voltage at the coil. If you know know how, get a meter and a manual.
Get a noid light tester, check for injector firing.
When a mechanic says "Thinks", Don't go replacing the distributor.
gearshredder is offline   Reply With Quote Quick reply to this message
Old 04-18-2011, 11:27 PM   #24
gearshredder
True Luder
Forget the ground, just bypass it, get a jumper cable and connect just The black wire. One from the negative on the battery and one to somewhere on the engine. Don't touch the red wire. Or just get a scrap piece of wire or something.
Old 04-18-2011, 11:31 PM   #25
webglasses
True Luder
Yeah...we checked all the fuses and the connection...all are good. I checked everything before started to buy stuffs. Haven't try starting fluid yet...how do you do that?
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
