OBD2 P13 pin out location - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 01-28-2011, 11:02 AM   #1
acidcrakker
Back 2 Hackin
acidcrakker's Avatar
acidcrakker has a spectacular aura aboutacidcrakker has a spectacular aura aboutacidcrakker has a spectacular aura about
Hey, need to know the pinout locations on the p13 obd2 ecu.
__________________
Honda prelude, since 1992
acidcrakker is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-28-2011, 11:23 AM   #2
hjdanzi
"THE DOCTOR IS IN"
hjdanzi's Avatar
hjdanzi is just really nicehjdanzi is just really nicehjdanzi is just really nicehjdanzi is just really nicehjdanzi is just really nice
Send a message via MSN to hjdanzi
Prelude of the Month
Not from a p13, but i guess it will do it.
__________________
DO YOU WANT TO
THEN CLICK ON IT!!!
SIGNATURE MADE BY INFAMOUZ (THANKS BRO)
hjdanzi is offline   Reply With Quote Quick reply to this message
Old 01-28-2011, 11:33 AM   #3
acidcrakker
Back 2 Hackin
Is that the 96 obd2 ecu. I need that one in particular because they differ from the 97 and up ecu's
__________________
Old 01-28-2011, 11:35 AM   #4
hjdanzi
"THE DOCTOR IS IN"
hjdanzi's Avatar
This is from an obd2-A.. not B... BUT... i know p13 from 96 4th gens may differ a little... Print that in colour, and inspect the wires colours... if they match then you are good to go. Im preety sure this pinout location i posted will do it. Maybe with the pins you need...
Compare it and let me know...
__________________
DO YOU WANT TO
THEN CLICK ON IT!!!
Old 01-28-2011, 11:40 AM   #5
hjdanzi
"THE DOCTOR IS IN"
hjdanzi's Avatar
Here you go... it has some extra pins.. but its the same.
OBDII H22a 96
Layout
A1->A11----Blank--C1->C10---D1->D5
A12->A24--Blank--C11->C22--D6->D12
A25->A32--Blank--C23->C31--D13->D16
Pin---Color ---------Desc.
A1----yel------------Injector #4
A2----blu------------Injector #3
A3----red------------Injector #2
A4----brn------------Injector #1
A5----orn/blu-------Secondary O2 heater
A6----blk/wht-------HO2S heater
A7----orn------------EGR Control Solenoid Valve
A8----grn/yel-------VTEC Solenoid Valve
A9----brn/blk-------GND (dig)
A10---blk------------GND (power)
A11---yel/blk-------PGM-FI Power
A12---blk/blu-------Idle Air Control Valve
A13
A14
A15---red/yel-------Evap Purge Control Solenoid Valve
A16---grn/orn-------Fuel Pump Relay
A17---pnk/blu-------A/C Clutch Relay
A18---gry/red-------MIL
A19---wht/grn-------ALT
A20---yel/grn--------ICM
A21
A22---brn/blk--------GND (dig)
A23---blk------------GND (power)
A24---yel/blk--------PGM-FI Power
A25---wht-----------Intake Control Solenoid Valve
A26---red/blu-------IAB Control Solenoid Valve
A27---grn-----------Radiator Fan Relay
A28---grn/wht------EVAP Bypass Solenoid Valve
A29---orn/grn------Evap control cansiter vent shut valve
A30
A31-
A32-
C1---lt grn/blk------Ref. Voltage for ATTS or TCM (not used)
C2---blu------------CKP Detect
C3---grn------------TDCP Detect
C4---yel------------CKP Detect
C5---blu/orn-------A/C Switch Signal Input
C6---blu/red-------Starter Switch Input
C7---red/wht-------SCS
C8---lt grn ---------K Line (scan tool)
C9-- -
C10---wht/yel------ECM Backup Power
C11-- -
C12---wht----------CKP GND
C13---red----------TDC M Side
C14---blk----------CYP M Side
C15---blu/blk------VTEC Pressure Switch
C16---grn----------P/S Pressure Switch
C17---wht/grn-----ALT Detect signal
C18---blu/wht------VSS Signal
C19 -
C20 - -
C21 - -
C22---brn/yel------IMO Immobilizer Code Signal
C23- -
C24 - -
C25 - -
C26 - -
C27 - -
C28 - -
C29 - -
C30 - -
C31 - -
D1----red/blk----------TPS Detect
D2----red/wht---------ECT Engine Coolant Temp. Detect
D3----red/grn---------MAP Detect
D4----yel/red----------Vcc1 (Power for MAP)
D5----wht/blk----------BKSW Brake Switch Detect
D6----red/blu----------KS (Knock Sensor Detect)
D7----wht--------------HO2S Detect
D8----red/yel----------IAT Intake Air Temp Detect
D9----wht/blk----------EGR Valve Lift Sensor
D10---yel/blu----------Vcc2 (Provides Sensor Voltage)
D11---grn/blk----------SG2 (Sensor Ground)
D12---grn/wht---------SG1 (Sensor Ground)
D13- -
D14---wht/red---------SHO2S (Secondary O2 Sensor Detect)
D15---wht/blu---------PTANK (Detects fuel tank pressure signal)
D16---grn/red---------EL (Detects ELD Signal)
Note: some of the pins listed for OBDII don't apply to te 96 and were only added in 97 but the layout is the same.
__________________
DO YOU WANT TO
THEN CLICK ON IT!!!
Old 01-29-2011, 08:58 AM   #6
acidcrakker
Back 2 Hackin
Would you happen to know the pin sizes of the following pins?
A8
C15
D6
I might have to do a small harness for someone with this ECU, Ive never done a harness for the ecu before. He has got like a Honda accord and is puttin in an obd2 motor with the obd2 P13. So I need to know what pin sizes to make with the ecu.
__________________
Old 01-29-2011, 10:17 AM   #7
hjdanzi
"THE DOCTOR IS IN"
hjdanzi's Avatar
A8
C15
D6
Sizes? No man, sorry im clueless about that.
__________________
DO YOU WANT TO
THEN CLICK ON IT!!!
Old 01-29-2011, 10:30 AM   #8
acidcrakker
Back 2 Hackin
OBD1 ecus have 2 different size pins.
Another question because I can just go to the junk yard and pull these.
Are these OBD2 pins the same as the other obd2 ecu's for the 97's and up?
__________________
Old 01-29-2011, 12:13 PM   #9
hjdanzi
"THE DOCTOR IS IN"
hjdanzi's Avatar
Sorry Jim, I never saw a 96 lude in my life. I wouldnt know... And it would be preety foolish from my part, to give erroneous information just to be repped. From my research, what i know is that all obd2 pins are the same. No matter if its REAL obd2... or a prelude 96obd2... But i cant tell you for sure, cause ive never saw one. Blake should know this, i guess.
__________________
DO YOU WANT TO
THEN CLICK ON IT!!!
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
