The Official Oil Leak Guide - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 10-20-2010, 08:49 AM   #1
MommysLittleMonster
Opinionated Bastard
MommysLittleMonster's Avatar
MommysLittleMonster is a splendid one to beholdMommysLittleMonster is a splendid one to beholdMommysLittleMonster is a splendid one to beholdMommysLittleMonster is a splendid one to beholdMommysLittleMonster is a splendid one to beholdMommysLittleMonster is a splendid one to beholdMommysLittleMonster is a splendid one to beholdMommysLittleMonster is a splendid one to behold
Send a message via AIM to MommysLittleMonster
Prelude of the Month
Post The Official Oil Leak Guide
This is going to be the mother of all "oil issues" responses, mainly because I've seen entirely too many of these in the 5th gen thread.
H22's like to consume oil, and it is a well-known fact in the H-series community. From leaky seals, to FRM cylinder walls wicking oil into the combustion chamber, to bad valve seals- you are going to have to do a LOT of work if you want to cut down on your oil consumption. I've been in the position that many new 'Luders are in (not making much money and trying to repair my car), so I thought I would compile a list of things to do- from easiest/cheapest, to hardest/most expensive. Here is a link to the Helms manual download to help you along the way.
  • Seal it: If your car leaks oil, do something about it- replace the seals on the motor. Staring at them intently and wishing they would go away will not solve your problem.
    • VTEC Solenoid Gasket: This is perhaps the biggest culprit for stock H22's. The VTEC Solenoid is located just behind your distributor, with the small cylinder sticking out of the top of it. It will require you to remove a few 10mm bolts. Oil will drain out of it, so get ready with some rags or a catch can.
      • HOW YOU CAN TELL: There will be oil/black gunk on the top of your transmission casing, and along the passenger side of the block.
      • COST: Gaskets are usually ~$20.. from your local dealer.
      • Part #15825-P13-005
        Shown as #13 & #15 on the diagram:
    • Distributor O-Ring: Like that creepy old guy that hangs out around schools, this little number is well-hidden. Often times, what happens is the O-ring will dry out after sitting for a while, crack, and then leak oil. To get to the seal, you need to remove the distributor from the cylinder head. Remove the three 8mm bolts from the distributor cap, remove the rotor by taking the setscrew out of the shaft (you may need to click the motor over until you can see this set screw), and unbolt the distributor from the shaft.
      • HOW YOU CAN TELL: There will be oil leaking on the passenger side of the block, typically black gunk will be pooled on top of your transmission.
      • COST: Typically ~$2.
      • Part #30110-PA1-732
        Shown as #6 in the diagram:
    • Valve Cover Gaskets: Not quite as likely as the VTEC solenoid gasket, valve covers do in fact leak. This is the giant cover over the top of your engine, and is quite easy to remove. There are a few 10mm crown nuts you'll have to remove, then lift off of the top of the cylinder head. You can use a wide flat-blade screwdriver to help start pry it off. It's also advised to put a little high-temp silicone (Hondabond) in the sharp corners of the valve cover gasket, as they don't like to seal very well by itself. It's also a good idea to replace the spark plug well seals, too- they're the funny little guys that look like small rubber donuts. (NOTE- if you are mechanically inclined and your engine has many miles on it, you can also do a Valve Adjustment while you have the cover off. Link to writeup on HondaTech)
      • HOW YOU CAN TELL: There will be oil/black gunk around the base of the valve cover, usually on the back or sides of the block.
      • COST: Valve cover gaskets are usually ~$15, the small rubber seals for the sparkplug wells are ~$3 each.
      • Part #12341-P13-000 (cover gasket)
        ......#12342-PT2-000 (rubber seals for s.p.w.)
        Shown as #3 & #4 on the diagram.
    • Oil Cooler O-Ring: This guy is in a different area code in comparison to the last few seals mentioned, but is still a pain in the ass. This seal goes between the oil cooler and the block on an H22, and sometimes goes bad from heat cycles or age and cracks. This will cause you to dump all of that nice 10w-30 oil that you just changed all over your driveway, your exhaust, and everything south of the boarder. It will require that you use a 30mm deep-well socket to remove the oil cooler, and a torque wrench to torque it down to 54lbs-ft.
      • HOW YOU CAN TELL: Your mom will be screaming at you for dumping your oil on her driveway, and oil will be leaking from behind the oil filter and the block. Typically can be seen dripping into your axles and flex pipe.
      • COST: This little guy will run you about $4.
      • Part #91316-PE7-730
      • WRITEUP LINK: http://www.preludepower.com/forums/s...d.php?t=324248 (props to xxfallacyxx)
        Shown as #32 in the diagram:
    • Cam Cap Seals: A close relative to the VTEC solenoid gasket & valve cover gasket, this little black plug is a pain in your ass in more ways than you can count. There are multiple O-ring replacements for these little guys (BLOX, Golden Eagle, Skunk2, ect), personally I think the billet seals with O-rings is a better idea. However, following the OEM ideology of this thread, you can buy OEM replacements. It's a wise idea to use Hondabond sealing agent (although any high-temp sealer will work). You need to remove the valve cover, then remove the cam cap on top of it. Once the cam cap is off, you can replace the leaky bastard with a new one. BE SURE TO TORQUE THE CAP TO 7lbs-ft USING A TORQUE WRENCH!
      • HOW YOU CAN TELL: There will be black gunk/oil on the passenger side of the block, behind/next to the VTEC solenoid
      • COST: ~$7 from your dealership, ~$20 for an aftermarket replacement
      • Part #12513-P30-000
        Shown as #8 in the diagram:
        ________________________________________
  • All Other Major Seals: Most other seals beyond this point require major disassembly on your motor. If you are going this far, it is advised to do a full timing belt service while you have it apart. So, ask your mom if you can borrow the minivan for the weekend, or fire up your winter beater- because this is gonna get bumpy. Link to writeup for timing belt job/disassembly for jobs from here on out. Courtesy of JLUDE.
    • Cam Shaft Seals: UNLIKE cam cap seals, these hard plastic pipsqueaks are located under the valve cover, behind the cam gears, on the cylinder head. This will require that you remove the cam gears- meaning you need to remove the timing belt. Once the cam gears are removed, you can remove the seals with a small, flat-blade screwdriver and a little work. You can insert the new seals by sliding them over the cam shafts, and pushing them gently on with the cam gears. (NOTE- MAKE SURE THERE IS GREASE ON THE INSIDE OF THE SEAL. All OEM Honda seals come with grease pre-loaded in the seal, to prevent a dry start and premature wear of the seal)
      • HOW YOU CAN TELL: There will be oil leaking down the front of the block, coming from the seals behind the cam gears.
      • COST: Typically ~$7 each from your Honda Dealership.
      • Part #91213-PR3-004
        Shown as #38 on the diagram:
    • Balance Shaft Seal: Like the cam seals, you will need to remove your timing belt and front engine cover to do these. These typically don't leak as much, but it is a good idea to get fresh seals while you are this far in. To remove these guys, you need to break the bolt loose on the end of the balance shaft (good idea to leave the belt on the shaft wheel before doing this) and remove the retainer. Once they are out of the way, it's the same as doing the cam shaft seals.
      • HOW YOU CAN TELL: Oil will be leaking from the seal, typically black and dirty underneath seal.
      • COST: About $5.
      • Part #91233-PT0-003
    • Front/Rear Main Seals: The biggest bastards of them all, the front and rear main seals. The front main seal is located behind the crank pulley, while the rear main seal is buried behind the flywheel on the back of the motor. If you're going this far, you might as well plan on investing in a new clutch too!
      • HOW YOU CAN TELL: Oil will be leaking between the transmission case and the engine block, or out of the bottom of the timing cover and onto the oil pan
      • COST: $15 for the rear, $15 for the front.
      • Part #91214-PAA-A01 (rear)
      • ......#91214-PLE-003 (front)
        Shown as #45 in the diagram:
__________________________________________________ ____________
This concludes the "Seals" section. Any rep will be greatly appreciated, I will write more concerning other forms of oil consumption and repairs a little later.
__________________
1998 Prelude - 1998 ///M3 - 2003 Accord - 2015 WRX Limited
MommysLittleMonster is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-20-2010, 09:00 AM   #2
xxfallacyxx
Bearderator
xxfallacyxx's Avatar
xxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud of
This thread = instant rep Good work.
__________________
Read this
J.L.D.E.P.P.M.S.3.C.N.Y.C.N.C.M.A.D
xxfallacyxx is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 09:19 AM   #3
Kane666
Kane666's Avatar
Kane666 has a spectacular aura aboutKane666 has a spectacular aura about
Send a message via AIM to Kane666
repped. looks all laid out pretty for being in that small window lol i would put though that an aftermarket cam cap while more expensive is 100% the better way to go if that's your problem even though your doing an oem thing. rosko makes em.
Kane666 is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 11:02 AM   #4
RomPirate
Lude Boss
RomPirate's Avatar
RomPirate is a jewel in the roughRomPirate is a jewel in the roughRomPirate is a jewel in the rough
I don't rep much....
But when I do, I rep worthy threads.
ps. Wont let me rep you again lol
__________________
RomPirate is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 11:22 AM   #5
my97bb6
Lude Addict
my97bb6's Avatar
my97bb6 is on a distinguished road
despite a thread like this, noobs are going to come in ask the same retarded questions about their 22 consuming too much oil
just sayin
__________________
honda ftw!
my97bb6 is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 11:33 AM   #6
xxfallacyxx
Bearderator
Yep, but this should be stickied to help alleviate that.
__________________
Read this
Old 10-20-2010, 11:40 AM   #7
Josh97_BB6
Getting Comfortable
Josh97_BB6's Avatar
Josh97_BB6 is on a distinguished road
I <3 this thread, immediately helped me find my leaks within 5 minutes, I don't leak unless im driving so I knew it wasn't too serious. So, I read the first thing on this page, and Just by looks my V-TEC solenoid needs to be replaced for sure; along with my cam cap seals. VERY good write-up! Any noob like me who can read and apply the diagrams can even use this. THANKS!!
__________________
97 BB6-sold
1998 Pearl BB6~~~Love of my life~~~
Josh97_BB6 is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 11:42 AM   #8
red98
True Luder
red98's Avatar
red98 will become famous soon enough
Send a message via Skype™ to red98
x2 + needs to be stickied
__________________
San Marino Red 1998 Base Prelude
AEM SRI
Hytech Replica Header
3" exhaust w/ Vibrant components
AP1 wheels with Kuhmo Supras
Add me on PSN, say you're from PP.com! (there are 2 underscores in the name)
red98 is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 12:04 PM   #9
MommysLittleMonster
Opinionated Bastard
Exactly why I made this thread, very glad to hear it helped. Rep is always appreciated!
__________________
Old 10-20-2010, 12:05 PM   #10
BlkLUDE5G
I am Prelude
BlkLUDE5G's Avatar
BlkLUDE5G is a jewel in the roughBlkLUDE5G is a jewel in the roughBlkLUDE5G is a jewel in the rough
i wish it would let me rep you bro - stcky this one mods
__________________
BlkLUDE5G is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 12:19 PM   #11
catacon
Ludimus Catacus
catacon's Avatar
catacon is a jewel in the roughcatacon is a jewel in the roughcatacon is a jewel in the roughcatacon is a jewel in the rough
Nice thread. I don't leak oil, but I am sure it will happen eventually and this thread will come in handy.
Thanks! +rep
catacon is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 12:47 PM   #12
Sd_h22a
True Luder
Sd_h22a's Avatar
Sd_h22a has a spectacular aura aboutSd_h22a has a spectacular aura about
The Official Oil Consumption/Leak thread
Very nice thread. This will be useful. Sticky this ish!
__________________
Sexy avatar revolution!
Sd_h22a is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 01:27 PM   #13
zuptidi
Lude Cray
zuptidi's Avatar
zuptidi has a spectacular aura aboutzuptidi has a spectacular aura about
You should also add up the dizzy gasket,
Very common
__________________
2000 Lude H23vtec Bluetop (For Sale)
zuptidi is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 01:43 PM   #14
MommysLittleMonster
Opinionated Bastard
Very common
Aaaaand added.
Fail. I had it typed out, then must not have copied it over from word. Thanks!
__________________
Old 10-20-2010, 04:20 PM   #15
klager01
True Luder
klager01's Avatar
klager01 is on a distinguished road
This couldnt have come soon enough. I'm taking on the rear main seal next week and I'm planning on doing a write up because I couldnt find one between here and Prelude Online. Most of rest of these are on my list too, just for the sake of doing them. If the oil loss doesn't stop after that I dont know what I'm going to do. No money for a build right now lol. This should be stickyed/ in the resource thread too. I'd rep you if I could.
__________________
3.31.2010: 2001 EBP SH, Sold to a buddy
9.20.2011: 2009 SWP WRX
There will be BACON available by the way!
klager01 is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 04:51 PM   #16
96azureVTEC
Ludacious
96azureVTEC's Avatar
96azureVTEC will become famous soon enough
great post. figured out where i was leaking oil. repped
96azureVTEC is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 05:09 PM   #17
zuptidi
Lude Cray
zuptidi's Avatar
just today i bought the vtec solenoid gasket cause it's leaking
__________________
Old 10-20-2010, 05:16 PM   #18
Christian
True Luder
Christian's Avatar
Christian will become famous soon enoughChristian will become famous soon enough
awesome write up rep'd
__________________
Christian is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 06:52 PM   #19
aznxviet
Lude Addict
aznxviet's Avatar
aznxviet is on a distinguished road
Rep'd
aznxviet is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 09:10 PM   #20
shaylude01
boostdBBsex
shaylude01's Avatar
shaylude01 is just really niceshaylude01 is just really niceshaylude01 is just really niceshaylude01 is just really niceshaylude01 is just really nice
Wow amazing post. Repped. Sticky this shit ASAP!
__________________
Turbo Build Thread:
2001 EBP Prelude Base (USDM) -> Boosted - 10.3psi - First purchased car, a never ending project, goes with me to the grave
1993 Nissan 180sx -> GM 6.0L LS swap in progress
1991 Honda Accord
1978 GMC Sierra 2wd
1981 Chevy Silverado 4wd
2013 Chevy Silverado LTZ
shaylude01 is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 09:24 PM   #21
Darren's 01 SH
I am Prelude
Darren's 01 SH's Avatar
Darren's 01 SH is a name known to allDarren's 01 SH is a name known to allDarren's 01 SH is a name known to allDarren's 01 SH is a name known to allDarren's 01 SH is a name known to allDarren's 01 SH is a name known to all
Good stuff. I don't know how many more of these "official" threads I can sticky, the sticky list is getting way too long,lol.
__________________
PAID OFF!!!! 7/14/10
Turbo engine build in the process.
My build thread -project resurrection
Darren's 01 SH is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 09:26 PM   #22
Midori Si
Getting Comfortable
Midori Si is on a distinguished road
Awesome! I've had to replace the oil cooler seal and man, yea that is a beyotch! And everyone driving behind you stops you to let you know your car is smoking...
Midori Si is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 11:07 PM   #23
MommysLittleMonster
Opinionated Bastard
I haz a sticky! Thanks for adjusting the title and stickying the thread Darren, thank you guys for the rep! Glad to see it helped solve some confusion.
__________________
Old 10-20-2010, 11:27 PM   #24
hondastudent
Getting Comfortable
hondastudent is on a distinguished road
nice almost 2000000 miles
hondastudent is offline   Reply With Quote Quick reply to this message
Old 10-21-2010, 06:40 AM   #25
aznjap808
True Luder
aznjap808's Avatar
aznjap808 will become famous soon enough
Repped. Awesome thread bro!
aznjap808 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
