Been a member here on prelude power since 2006, started off with a 1993 prelude H23 With Auto transmission. with in the first year of owning it i dropped out the h23 for a jdm h22a with automatic transmission. About a month into that the Auto trans started slipping. So out with the Auto and in with the standard. Swapped in a H23 5 Speed transmission. After that i had a pretty good run with the car it was more of a weekend cruiser on nice days. One day i let my brother borrow the car, and it was returned to me with a warped crank and destroyed key way.
Then I ran into financial issues and was forced to sell my evo, making me need to fix my prelude for a daily driver. So I ordered my second H22 from Hmotors online. I decided to paint my engine bay and try my hardest to get the car in the best shape i could on my budget. Dropped the new h22 in and painted the bay, replaced pretty much everything but the abs. Had the car for 6 months as my daily driver then i broke 16 teeth off the timing belt bending 6 valves. At this point i was up in the air about it almost sold this car several times but came to my senses and realized i have way to much heart and time invested in this car and fixed it again. had the head machined did the timing belt, water pump, tensioner and valves done.
Since then i have been hitting the streets hard in the prelude representing for lude owners everywhere. I may not have the best looking lude, but i am a die hard luder at heart and just keep taking the abuse this car gives me.
_________________________________________________________________________________________
This will be my first thread actually documenting the progress on my second h22 swap into this car.
here is a photo time line to show the life it has lived up to this point
before you go through the thread and see its progress.
DAY 1 OF OPERATION NEW MOTOR NEW LOOK:
Added October 16
after a quick pressure wash
Added October 17
Added October 18
Added October 24
Added October 26
Added October 31
Added November 2
Added November 4
Added November 7
Added November 11
Added November 27
heres where my car as far as i know is the only 4th gen with 2 mounting holes in the engine bracket which caused me a day.
then the right hole
this is the welded nut that is causing me problems
Added december 11th
Added January 23
ON THE ROAD AGAIN
new wheels finally:
Another set of new wheels i got: 1/23/12
start up video after head was machined/headgasket/waterpump/tensioner/timingbelt and 6 valves
Current Set up Consists of:
Modifications
Engine/Trans/Exhaust:
- JDM H22A (2nd H22 swap converted from h23a)
- H23 5 speed trans (converted 5spd from auto)
- Innovative Motor Mounts
- Cold Air Intake
- 4-2-1 Header
- 2.5 piping
- Hollowed Cat
- Meagan Racing Exhaust 3'
- Mishimoto Slim Fan on Switch
Interior/Audio:
- A/M Steering Wheel
- Digital Tachometer
- Alpine Head unit
- Infinity Speakers
Exterior:
- Spoon Front Lip
- eyelids
- depo 1 piece headlights
- Seibon carbon fiber hood
- LED 96 rear spoiler
- Depo black-housed headlights
- Accord 3 piece rear Lip
Suspension/Wheels:
- 15 inch XXR 501s gunmetal
- Acura CL Factory Wheels
- Tein Basic coilovers
- Sway Bar (Strut tower)
______________________________________________________________________________________________
FUTURE PLANS:
ENGINE:
(done)- NEW H22A FROM HMO
(done)- PAINT ENGINE BAY
(done)- NEW RADIATOR
(done)- EXHAUST
INTERIOR:
- STEERING WHEEL
- CENTER CONSOLE
- EL CLUSTER
EXTERIOR:
(done)- RIMS
(done)- OEM FRONT BUMPER
(done)- FRONT LIP
(done)- amber secondaries
(done)- eyelids
(done)- emblem
- OEM HOOD
- OEM FENDERS
- REAR MUD FLAPS
This is what i spent so far on the this swap:
Tools:
- Husky 1/2 Impact Gun $100.00
- Metric 1/2inch Socket set $50.00
- 36mm Axle Nut Socket $19.99
- 1/2 INCH 3 piece ext. kit $14.99
- 1/2 INCH 17mm deep socket $6.50
- Wire Strippers $8.00
- 10mm Combo Wrench $6.99
- Engine Leveler $40.00
Parts:
- JDM H22A 92-96 (www.hmotorsonline.com) $1,350 shipped
- Throttle Cable $30.00 shipped
- Shift Linkage Bracket $30.00 shipped
- Alternator Belt $13.99
- P/S Belt $12.99
- NGK Spark Plugs $12.00
- Mobil 1 Oil Filter $12.99
- GY Heater Hose $2.38
Fluids:
- Dex-Coolant(2 gal) $26.00
- Washer Fluid $2.00
- Super Cleaner(Floor) $8.00
- RTV High Temp Silicone $7.00
- Mobil 1 Oil $24.50
- Dot 3 Brake Fluid $4.50
- P/S Fluid(2) $8.00
Misc:
- Cotter Pin value pack $6.99
- Conduct Tite $15.99
- 3/8 Conduit 10ft $4.99
- BLK Wire Ties(20) $2.79
- Metric Hardware kit 150pc. $24.99
- 3/4 BLK Conduit $4.99
- 1/4 Hose Clamps(4) $2.50
- BLK High Temp 2000* Paint $8.50
- Bondo Filler 2lb $12.99
- Gloss BLK High heat(4) $22.76
- 10mm Bolts $15.00
- Honda Key Chain!(LOL) $7.99
- EZ Hose Clamps $2.99
- Dorman M12 Nut(2) $2.29
- Oil Drain Pan $9.99
Kinetic Motorworks:
- Repaird leaking fuel rail
- Replaced Starter $160.00
- Replaced Map Sensor $25.00
- Replaced Injector Clips
- Installed Power Steering Lines
- Replaced Clutch Slave Cylinder $30.00
- Connected Clutch Lines
- Installed Vacuum box for butterfly valves on intake
- Wired Headlights
- Filled Transmission Fluid
- Replaced Radiator $155.00
- Attached Fan to Radiator
- Replaced Thermostat
- Repaired Engine Mount
- Changed Oil
total at kinetic including labor was $1,404.88
ORIGINAL FIRST POST BELOW:
So today i sold my evo. Its a sad day in my life, but with this comes new hope for my prelude which i have been neglecting for 2 years now. With the little extra money i got from selling the evo i am purchasing a new H22 this week from h-motors online. I will start pulling the motor this coming weekend and plan on documenting the process to the best of my ability.
i will also be de-ricing my car to give it a nice new clean look to go with its fresh motor. I will be selling my CF invader hood for a stock hood. i also will be selling my WW big mouth front bumper for a stock front bumper as well.
i went yesterday to see my prelude and get my mind focused on bringing this car back to life. the car was covered in sap, its in really rough shape.
last pic of the evo
Added October 16
Added October 17
Added October 18
Added October 24
Added October 26
Added October 31
Added November 2
Added November 4
Added November 7
Added November 11
Added November 27
then the right hole
Added december 11th
Added January 23
ON THE ROAD AGAIN
new wheels finally:
Modifications
- Cold Air Intake
- 4-2-1 Header
- 2.5 piping
- Hollowed Cat
Interior/Audio:
- Alpine Head unit
- Infinity Speakers
Exterior:
- Spoon Front Lip
- eyelids
Suspension/Wheels:
FUTURE PLANS:
ENGINE:
(done)- EXHAUST
INTERIOR:
- STEERING WHEEL
- CENTER CONSOLE
- EL CLUSTER
EXTERIOR:
(done)- RIMS
(done)- FRONT LIP
(done)- eyelids
(done)- emblem
- OEM HOOD
- OEM FENDERS
- REAR MUD FLAPS
Tools:
Parts:
- P/S Belt $12.99
Fluids:
Misc:
- 10mm Bolts $15.00
Kinetic Motorworks:
- Wired Headlights
- Changed Oil
last pic of the evo
