Go Back   Preludepower.com > Prelude Forums > 3rd Gen
Reload this Page Bigger oil Filter
Reply
Ads By Google
Thread Tools Display Modes
Old 02-08-2010, 11:26 PM   #1
PreludeFreak89
Lude Dude
PreludeFreak89's Avatar
PreludeFreak89 is on a distinguished road
Bigger oil Filter
If I remember right someone found a bigger filter for a porshe?? that fit our cars but it was too long so you had to dent in the cap? well sence doing that ruins the filter, I thought I would find one that will fit, and be bigger! The best benefits of a bigger filter would be better filtration and increased filtering capacity! This is the best match i could come up with!
This is stock: Napa gold #1334 or Wix #51334
Flow Rate : 9 - 11 gpm
Gasket I.D. (Inches) : 2.01"
Gasket I.D. (mm) : 51.05 mm
Oil Filter Gasket O.D. (Inches) : 2.49"
Oil Filter Gasket O.D. (mm) : 63.25 mm
Oil Filter Height (Inches) : 3.194"
Oil Filter Height (mm) : 81.13 mm
Oil Filter O.D. (Inches) : 3.252"
Oil Filter O.D. (mm) : 82.6 mm
Oil Filter Style : Spin-On Lube Filter
Oil Filter Thread Size (mm) : 20 x 1.50 mm
This is what i found: Napa gold #1344 or Wix #51344
Oil Filter Height (Inches) : 4.069"
Oil Filter Height (mm) : 103.35 mm
Oil Filter O.D. (Inches) : 3.242"
Oil Filter O.D. (mm) : 82.35 mm
PreludeFreak89 is offline   Reply With Quote
Old 02-08-2010, 11:48 PM   #2
cudaboy
Donating Member
cudaboy's Avatar
cudaboy will become famous soon enoughcudaboy will become famous soon enough
Send a message via Yahoo to cudaboy
yeah I posted in that thread and I think it was devin or lucifer caitiff that tried the dented filter. I came up with a mobil one extra capacity by extra wide listed in that thread.
__________________
Originally Posted by Orgasm Donor
and you won't need to trade your left nut for a custom alt
Damn I'm sure going to miss my left nut.
'91 Si 4ws 5spd(black) "Black Betty"
'70 'Cuda 340 C.I.D. Alpine White, Black Vynil Top, Leather Interior, Rim Blow, Overhead Consolette. Factory Posi 3.55:1, 15" ralleyes, --Fully Loaded and Extremely Rare!
"Both Perfectly formal for any Black Tie Event"
cudaboy is offline   Reply With Quote
Old 02-08-2010, 11:51 PM   #3
cudaboy
Donating Member
cudaboy's Avatar
here ya go:
http://preludepower.com/forums/showt...bil+oil+filter
mobil m1-105
__________________
Old 02-09-2010, 12:05 AM   #4
PreludeFreak89
Lude Dude
Yeah its about the same size as the one i found
Here are the specs on the m1-105
Flow Rate : 11 - 13 gpm
Gasket I.D. (Inches) : 2.462"
Gasket I.D. (mm) : 62.54 mm
Oil Filter Gasket O.D. (Inches) : 2.834"
Oil Filter Gasket O.D. (mm) : 71.98 mm
Oil Filter Height (Inches) : 3.141"
Oil Filter Height (mm) : 79.78 mm
Oil Filter O.D. (Inches) : 3.66"
Oil Filter O.D. (mm) : 92.96 mm
Old 02-09-2010, 12:56 AM   #5
cudaboy
Donating Member
cudaboy's Avatar
so what does your napa gold cost? I think I payed around $11 or $12 for each filter at I think advance and autozone was higher. I haven't installed it yet. Black Betty rarely gets driven as I some work to do. Thats what I have been working on the last two nights. I am printing out online shopmanual pages rather than going upstairs and photocopying my helms '91 paperback. Found out that the online manual works great on adobe acrobat 9 or so on '90-'91 supplement and you can use the contents to get to what you want while on the '88-89 its just a bunch of files with no titles. Lame.
Got to install my hawk ceramic pads, paint calipers blue, install goodridge brake lines if I buy them. Raise my idle because of teggy 9.75 lb lightweight fly install. Adjust belts because me dumping the clutch and dieing. again the lightweight fly. Install new ps hoses and bleed system and replace with genuine honda fluid. Install new waterneck with autometer water temp electric sensor. Install water temp gauge and oil pressure gauge. Bleed coolant. Recharge battery as haven't driven the lude in over a month. lol May be doing some of this in below 20 farenheit. Oh yeah install my block heater. Install my ac evaporator core box to give direction flow for fan so I have heat and defrost.
__________________
Old 02-09-2010, 01:47 AM   #6
PreludeFreak89
Lude Dude
napa gold filters are wix filters, the price depends on what napa you go to cause they all have different pricing. where i live they're only 7 bucks, but i work at napa so i get them at cost (2.99)
Old 02-09-2010, 09:15 AM   #7
TripleLude
Elite Member
TripleLude's Avatar
TripleLude will become famous soon enough
Just use the K&N oil filters. They are huge and last 8,000 miles.
__________________
i know ive seen some like orange-ish brown-ish gell-ish substance inside the connector under the plastic covering on the ing sing output
TripleLude is offline   Reply With Quote
Old 02-09-2010, 12:58 PM   #8
ba4ludeb20a
Lude Addict
ba4ludeb20a's Avatar
ba4ludeb20a is on a distinguished road
Prelude of the Month
x2, they are like 10 bucks tho, but they are good
__________________
^^ check it out
ba4ludeb20a is offline   Reply With Quote
Old 02-09-2010, 02:30 PM   #9
Red89LudeSi
Not a Dude.
Red89LudeSi's Avatar
Red89LudeSi is on a distinguished road
Send a message via AIM to Red89LudeSi
Or you can just use the Honda 15400-PCX-004 Filter for an S2K. Its wider like the old Honda filters for our cars
__________________
More cars than I know what to do with.
300 WHP Club! Thanks slowmotion
Red89LudeSi is offline   Reply With Quote
Old 02-09-2010, 03:02 PM   #10
TripleLude
Elite Member
TripleLude's Avatar
I heard they fit but it's tight. Almost like they are too big. Maybe there is a brand out there that doesn't have a clearance issue, idk. I do know that with a K&N you get what you pay for.
__________________
Old 02-10-2010, 10:57 AM   #11
Red89LudeSi
Not a Dude.
Its not too tight, you heard wrong. Before the K-series and Hybrid Civic came out in 2002/2003 ALL Hondas from 86 forward used that same size filter it was labeled 15400-P0H-505. At that time they created the smaller in diameter and taller 15400-PLM-A01 (or A02...depends on the manufacturer) for the Honda line-up but added the 15400-PCX-004 fot the S2K since it required the larger filtering capacity.
Basically the PCX is the old school filter but is only sold for S2K's. Its what came on your prelude when it was new, it just had a different part number. Honda changes part numbers based on manufacturers, but tries to keep all their filters the same for the entire line up.
__________________
Reply
Bookmarks
  • Submit Thread to Digg Digg
  • Ads By Google
    Search Cloud
    2010 honda prelude 3rd gen prelude 4th gen prelude 5th gen prelude 5th generation prelude 6th gen prelude b21a1 car motivational posters convertible prelude dashboard paint edge2lyfe view profile floor jack reviews funny things to text your girlfriend h22 cams h22 manual tensioner conversion h22a4 h22a4 specs h23 vtec h23a vtec honda prelude 2010 honda prelude 5th gen how to text your girlfriend hp259 hp259 tire individual throttle bodies k1 attack for sale k20 prelude nice things to say to your girlfriend in a text nice things to text your girlfriend nitto neo gen reviews pcv valve symptoms power prelude prelude prelude convertible prelude forum prelude forums prelude power preludepower preludepower.com projector retrofit racing hart cp-035 rattle can paint job song suggester sweet things to say to your girlfriend in a text sweet things to say to your girlfriend over text sweet things to text your girlfriend things to text about things to text your girlfriend what to text your girlfriend www.preludepower.com
    Thread Tools
    Display Modes
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Forum Jump
    KickItBack = Cash Back
    Google
    vB.Sponsors
    PreludePower Forums
