Go Back   Preludepower.com > Prelude Forums > 3rd Gen
Reload this Page just bought a alarm system, are the doors neg 3 way locks?
Reply
Ads By Google
Thread Tools Display Modes
Old 11-08-2009, 05:11 AM   #1
4ws88
True Luder
4ws88's Avatar
4ws88 is on a distinguished road
i bought a CRIME GAURD 750i5 keyless and security unit today. Its made by omega, a big company i take it. 2 way pager the works.
i need to acess the wire the controls the starter for the starter kill and the door switches/dome light and power door locks. so i need to figure out if honda uses the 3wire neg pulse or 3 wire pos pulse or 5 wire reversal rest at ground system. also is the domelight neg switched. if anyone knows that would help out alot.and any instal advice would be cool. i havent done one of these in years
__________________
TECH CERTIFIED
88 SI 4WS 5 SPEED
94 z28 camaro corvette LT1 350. blew up the tranny
93 YAMAHA FZR 600 crotch rocket
91 jeep cherokee limited, bullet proof gas hog
4ws88 is offline   Reply With Quote
Old 11-09-2009, 02:47 AM   #2
2nd one
Donating Member
2nd one's Avatar
2nd one will become famous soon enough
the door lock wiring can be accessed in the driver door harness in the kick panel. the door locks are neg trigger and don't require a relay for the install. the output on the brain is or should be strong enough for the little bit thats required. at least with d.e.i. and code alarm (audiovox) it is. all of the wiring you need is located behind the underdash panel. the dome i cant remember on, its been a while for me, but use a meter and test on the ign harness so you don't have issues. the only relay you should use will be on the starter wire if its not built in the brain. are you doing remote start as well?
__________________
2nd one is offline   Reply With Quote
Old 11-09-2009, 09:20 AM   #3
4ws88
True Luder
4ws88's Avatar
cool, no im not doing remote start. i actually took the unit back im going to wait and get a better quality one. i want a alrm that has a proximity sensor that actually works or at least will go off if the car is touched. for the $100 for the crime gaurd it has a cheap feeling 2way remote and only one and a replacement one would likely be 50 so im going to shop around
__________________
TECH CERTIFIED
88 SI 4WS 5 SPEED
Old 11-09-2009, 09:25 AM   #4
SOHCinWA
Lude Dude
SOHCinWA's Avatar
SOHCinWA is on a distinguished road
Send a message via AIM to SOHCinWA Send a message via Yahoo to SOHCinWA
www.Compustar.com is all I will say. And they are local to you. So if anything goes bad, you can get it fixed right away. The best 2 way alarm system on the market.
__________________
June 5th NW Meet.
1991 Si
1992 GMC Typhoon R.I.P.
1990 Civic Sedan 1.5L Dual Carb'd 13.95 N/A "Pinky"
2005 GMC Yukon the "Monster Truck"
Window Tinting & Custom Vinyl lettering available. PM me for more info.
SOHCinWA is offline   Reply With Quote
Old 11-10-2009, 12:04 PM   #5
Ahnold
True Luder
Ahnold is on a distinguished road
I bought a Crimeguard prob about 8 years ago. It has worked great for me other than the piece of shit remotes. They have absolutely NO range to them. I have to be standing right next to the car for it to work. I even installed the auxillary antenna in an attempt to extend the range, but it didn't help.
Unless they have changed things recently, I'd go with something else. Clifford makes good stuff. Ive been very happy with the Clifford on my S2K.
Anyway, just a heads up.
__________________
1990 SI 4ws: B21 block de-stroked to 89mm, bored to 85mm = 2020cc's
2000 Turbo S2000
Ahnold is offline   Reply With Quote
Old 11-11-2009, 12:58 AM   #6
4ws88
True Luder
4ws88's Avatar
wow they have some nice stuff. wheres the shop/store in wa at?
__________________
TECH CERTIFIED
88 SI 4WS 5 SPEED
Old 11-11-2009, 11:54 AM   #7
psychoboy
Preludepower Member
psychoboy will become famous soon enoughpsychoboy will become famous soon enough
the schematic manual (ETM) says the key switches and the internal switch all switch negative.
Originally Posted by the 91 4WS ETM
Voltage is applied at all times through fuse 4 to the power door lock control unit.
When you use the key to turn the left door lock actuator or right door key switch to the LOCK position, a path to ground is supplied to one of the control unit's lock inputs. The power door lock control unit applies voltage to the door lock actuators: The doors lock.
When you use the key to turn the left door lock actuator or right door key switch to the UNLOCK position, a path to ground is supplied to the control unit's unlock input. Voltage is applied to the door lock actuators: The polarity of the voltage applied to the actuators is now reversed and the doors unlock.
Both doors can be electrically locked and unlocked from the driver's power door lock switch. Both doors can also be unlocked mechanically from the outside with a key.
basically they are on-off-on switches with ground at both 'on's. that ground pulse tells the logic box (in the passenger door) what to do.
find the grn/wht and grn/red wires going into the passenger door, these are coming from the lock switch in the driver door. if you give the grn/wht wire ground, you'll lock the doors. if you give the grn/red wire ground, you'll unlock the doors.
remember that honda driver's doors won't change the status of their locks when they are open, unless you are holding the handle open too...if you have the driver door standing open while you are tapping the grn/x wires...the driver's door won't do anything but make a noise
the dome light is negative switched.
__________________
There's a sucker born every minute...
swallowers are harder to find.
psychoboy is offline   Reply With Quote
Old 11-12-2009, 09:56 AM   #8
1funryd
Vendor
1funryd's Avatar
1funryd will become famous soon enough1funryd will become famous soon enough
Send a message via AIM to 1funryd Send a message via MSN to 1funryd Send a message via Yahoo to 1funryd
I have a Compustar when my brother in law owned a shop in Kent Desmoines.
Best money I spent, and the unit is 5 years old and still going strong.
I recommend it. I am wired for remote start, but since I did the swap to 5 speed, I need to redo a couple of things and hook up the proper coil wire.
Other than that the alarm is working great!
Edit:
Just go to any compustar dealer.
__________________
Sean
H22 Project Manager
(Clik Here)
Members: Danny_19 - 1FunRyd(H23 swapped) - B20luda
3rd Gen Prelude Owners are Rare Breed of Enthusiast's!!! (originally posted by: RED89si)
1funryd is offline   Reply With Quote
Old 11-12-2009, 10:45 AM   #9
SOHCinWA
Lude Dude
SOHCinWA's Avatar
Edit:
You can also get a signal from the tach wire or an injector wire too if need be.
__________________
June 5th NW Meet.
1991 Si
Reply
Bookmarks
  • Submit Thread to Digg Digg
  • Ads By Google
    Search Cloud
    2010 honda prelude 3rd gen prelude 4th gen prelude 5th gen prelude 5th generation prelude 6th gen prelude b21a1 car motivational posters convertible prelude dashboard paint edge2lyfe view profile floor jack reviews funny things to text your girlfriend h22 cams h22 manual tensioner conversion h22a4 h22a4 specs h23 vtec h23a vtec honda prelude 2010 honda prelude 5th gen how to text your girlfriend hp259 hp259 tire individual throttle bodies k1 attack for sale k20 prelude nice things to say to your girlfriend in a text nice things to text your girlfriend nitto neo gen reviews pcv valve symptoms power prelude prelude prelude convertible prelude forum prelude forums prelude power preludepower preludepower.com projector retrofit racing hart cp-035 rattle can paint job song suggester sweet things to say to your girlfriend in a text sweet things to say to your girlfriend over text sweet things to text your girlfriend things to text about things to text your girlfriend what to text your girlfriend www.preludepower.com
    Thread Tools
    Display Modes
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Forum Jump
    KickItBack = Cash Back
    Google
    vB.Sponsors
    PreludePower Forums
