Throttle Screw H22A idle setting - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 10-28-2009, 04:51 PM   #1
Tengoku
True Luder
Tengoku has disabled reputation
Send a message via AIM to Tengoku
my h22a idles really low, like 300-500 and sometimes feels like its going to die when I step on the gas and then let it fall to idle. I want to set it to 700 but when I looked under the hood the screw did not have a slot for a flathead is that normal???
how would i then adjust my idle? I was thinking about getting a dremel with a cutting blade and making my own slot so I can turn it.
and what should these h22a's be running idles at?
Thanks
__________________
...H22a Euro R Swap Completed!...
New Project Car !!CHECK IT OUT!!
Tengoku is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-28-2009, 06:09 PM   #2
motoxxxman
motoxxxman is an unknown quantity at this point
Send a message via AIM to motoxxxman Send a message via Yahoo to motoxxxman
it should idle at around 750.
the screw does have a slot, but they put a gob of paint over the screw from the factory so the screw cant rattle loose. get a pin or something sharp and scrape the paint off to reveal the slot.
BUT:
BEFORE TOUCHING THE IDLE SCREW!!!!!....
do a valve lash adjustment, do a full tune-up, and properly adjust the ignition timing to stock spec. i can almost guarantee you that the low idle is being caused by a problem with something, NOT from the idle screw needing to be adjusted. if you adjust the idle screw to get it to idle at a normal rpm, you are just covering up a different problem, and probably causing more damage to something.
the idle screw is the LAST thing you want to adjust the get it to idle right, because 99% of the time the screw is set exactly how it should be, and something else needs tweaking or replacement.
motoxxxman is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 06:32 PM   #3
Tengoku
True Luder
great advice! Thanks
is the slot top or bottom of the screw?
__________________
Old 10-28-2009, 06:52 PM   #4
Blue01
Prelude Aficionado
Blue01 is a jewel in the roughBlue01 is a jewel in the roughBlue01 is a jewel in the rough
You have a Euro-R throttle body?
__________________
2001 Base 5MT - Accord swap
2003 FE4/FRC 6MT - Stock, tow vehicle
Blue01 is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 07:35 PM   #5
Tengoku
True Luder
Yeah I think so, if euro r throttle bodies came with the euro r h22. I cant tell by looking at the throttle body but I think its safe to assume.
__________________
Old 10-28-2009, 07:38 PM   #6
Blue01
Prelude Aficionado
If it was bolted to the engine it probably is.
I don't believe it has a throttle screw. Also no FITV.
What ECU are you running the motor on?
__________________
Old 10-28-2009, 07:46 PM   #7
ill-icit_lude
Ludacious
ill-icit_lude's Avatar
ill-icit_lude will become famous soon enough
That's pretty odd that were having the same exact problem, I thought R crew would have worked that all out I don't feel as bad anymore. I swapped to obd1 injectors and my idle came back up but im still having idle issues, and stabilizing issues
ill-icit_lude is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 08:37 PM   #8
motoxxxman
wait, are you using obd2 injectors with a resistor box?
Old 10-28-2009, 09:23 PM   #9
ill-icit_lude
Ludacious
I'd think that R crew got that right. My idle is still shitty at times it will start to idle fine and then when I drive it it goes back to the same old shitty idle but I think that may due to what we talked about steve
Old 10-28-2009, 10:50 PM   #10
Tengoku
True Luder
It doesnt really have any idling problems, just idles low.. other than that its driving fine so far.
... I was however having some bogging/jerking problems recently, but its fine now... i dont know if it will come back.. havent had much time diagnose the problem...
__________________
Old 10-29-2009, 12:12 AM   #11
Tengoku
True Luder
I was wondering if this would work... putting a nut on the throttle screw to make it idle a bit higher.
I need to find a thinner as this nut makes it idle a lot higher than I want.
Check out the video, it doesnt idle too bad but when its at around 500 the car vibrates more than I would want it to.. when i throttle the rpm to 750 the vibrations are a lot less....
__________________
Old 10-29-2009, 12:34 AM   #12
ill-icit_lude
Ludacious
How are you running an obd2 map? is the whole car running obd2?
Old 10-29-2009, 08:45 AM   #13
Tengoku
True Luder
Car is running OBD1
BlackBerry9530/5.0.0.328 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105
Old 10-29-2009, 11:08 AM   #14
Blue01
Prelude Aficionado
On what ECU?
Your stray vac line might be for the air injection thingy on that engine...maybe.
__________________
Old 10-29-2009, 11:41 AM   #15
team123luder
Elite Member
team123luder's Avatar
team123luder has a spectacular aura aboutteam123luder has a spectacular aura aboutteam123luder has a spectacular aura about
Send a message via AIM to team123luder Send a message via MSN to team123luder
Prelude of the Month
Air injection thingy? Blasphemy coming from blue
__________________
SOLD!!!
team123luder is offline   Reply With Quote Quick reply to this message
Old 10-30-2009, 02:04 AM   #16
Tengoku
True Luder
I placed a springy type mechanism on the screw that holds the throttle in place on the TB which raises the rpm +150-200 ... its working out great! my idle is at 700 rpm and has less vibrations. Still have to test it out more with more driving....
__________________
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
