Go Back   Preludepower.com > Performance and Style > Forced Induction
Reload this Page h22 butterfly removal
Reply
Ads By Google
Thread Tools Display Modes
Old 10-28-2009, 12:49 AM   #1
samowen27
Newbie
samowen27's Avatar
samowen27 is on a distinguished road
I am building a h22a4 with darton sleeves wiscoe pistons eagle h beam rods and a bryan crower valvetrain. My question is can I delete my butterfly stack out I mean take it all the way out the reason i ask is I'm running a turbo kit and I think there hurting my performance but I would like to be able to pass emissions also but if i cant i will just register my car in anothe city anyways I WOULD APPRICATE SOMEONES INPUT ON THIS
samowen27 is offline   Reply With Quote
Old 10-28-2009, 05:41 AM   #2
kerry400f
Preludepower Member
kerry400f's Avatar
kerry400f is on a distinguished road
Step 1: Take mani apart
Step 2: Pull Butterflies Out
Step 3: Put mani back together
Step 4: Enjoy
__________________
1994 Prelude Si
-H22A Swap Complete 10/13/2009
-Turbo Complete 05/24/2010 - 315hp/250tq at 10psi JK Tuned
2006 Yz450f
2003 Nissan Sentra Ser Spec-V
1992 F-150 (Sold)
kerry400f is offline   Reply With Quote
Old 10-28-2009, 10:24 AM   #3
LUDE_4_LIFE
Preludepower Member
LUDE_4_LIFE's Avatar
LUDE_4_LIFE will become famous soon enough
Prelude of the Month
^Indeed. Yes it will work good for you. As for passing emissions, have fun doing that even with the butterfly's in. It can be done, but it isn't always so easy. Just get a fake.
__________________
1992 Honda Prelude SR H22A
351WHP 284WTQ 11PSI ON A DYNAPACK
366WHP 300WTQ 11PSI ON A DYNOJET
IN CAR VIDEO, HAVING SOME FUN
DYNO VIDEO'S
DYNOJET
DYNAPACK
LUDE_4_LIFE is offline   Reply With Quote
Old 10-28-2009, 11:16 AM   #4
samowen27
Newbie
samowen27's Avatar
well I have passed my emissions test because I made everthing plug and play it takes me 30 min to set it up. my brother told me to just take the butterflys off but i will take the whole thing off and just change the bolts and studs around to make it fit. thank you for responding did you notice any difference with them out at a idle or WOT
Old 10-28-2009, 11:32 AM   #5
marcus81184
Lude Addict
marcus81184's Avatar
marcus81184 is on a distinguished road
What do iabs have to do with emissions?
marcus81184 is offline   Reply With Quote
Old 10-28-2009, 12:48 PM   #6
g-gameslude
Preludepower Member
g-gameslude's Avatar
g-gameslude is on a distinguished road
some n/a guys just remove the plate and have the upper plenum bolted to the runners and see gains. i suggest that. by reducing your runner length it will also move your powerband up in the rpm range.
g-gameslude is offline   Reply With Quote
Old 10-28-2009, 02:15 PM   #7
marcus81184
Lude Addict
Also, when you remove your iab plate the phellum, and manifold don't match up perfectly. You have to plug a small section.
The intake manifold nuts are pita to reach. You might as well add a hondata gasket, and do some porting if you remove.
Old 10-28-2009, 05:58 PM   #8
LUDE_4_LIFE
Preludepower Member
You might notice a difference at idle, and you will lose just a little bit of low end jam. Better you do it now before your car gets tuned then afterwards.
__________________
DYNO VIDEO'S
DYNOJET
DYNAPACK
Old 10-28-2009, 06:34 PM   #9
samowen27
Newbie
samowen27's Avatar
well it probably has no function for emissions but there is a sensor at the bottom of the intake and when i switch back to my 0bd2 computer with my vtec hack it might throw a code plus the egr is activated by vacuum and the way the intake is designed it could trow a code but this is not a big deal.
Old 10-31-2009, 10:05 AM   #10
Sordz
Newbie
Sordz is on a distinguished road
my motor made over 600whp with the butterflys but I have recently removed them and the shafts and welded up the holes on the ends because I also agree with you they may be holding us back.
Sordz is offline   Reply With Quote
Old 11-09-2009, 07:58 AM   #11
LudeBB6
Lude Addict
LudeBB6's Avatar
LudeBB6 is on a distinguished road
Send a message via AIM to LudeBB6
Butterflies won't fail you on inspection for emissions unless there are other things out of whack in which case it isn't likely that it's the butterflies that are causing you to be out of spec for emissions.
LudeBB6 is online now   Reply With Quote
Reply
Bookmarks
  • Submit Thread to Digg Digg
  • Ads By Google
    Search Cloud
    2010 honda prelude 3rd gen prelude 4th gen prelude 5th gen prelude 5th generation prelude 6th gen prelude b21a1 car motivational posters convertible prelude dashboard paint edge2lyfe view profile floor jack reviews funny things to text your girlfriend h22 cams h22 manual tensioner conversion h22a4 h22a4 specs h23 vtec h23a vtec honda prelude 2010 honda prelude 5th gen how to text your girlfriend hp259 hp259 tire individual throttle bodies k1 attack for sale k20 prelude nice things to say to your girlfriend in a text nice things to text your girlfriend nitto neo gen reviews pcv valve symptoms power prelude prelude prelude convertible prelude forum prelude forums prelude power preludepower preludepower.com projector retrofit racing hart cp-035 rattle can paint job song suggester sweet things to say to your girlfriend in a text sweet things to say to your girlfriend over text sweet things to text your girlfriend things to text about things to text your girlfriend what to text your girlfriend www.preludepower.com
    Thread Tools
    Display Modes
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Forum Jump
    KickItBack = Cash Back
    Google
    vB.Sponsors
    PreludePower Forums
