Reload this Page 5 Speed swap getting your car to start
Notices
Reply
Ads By Google
Thread Tools Display Modes
Old 10-17-2009, 07:24 PM   #1
xxfallacyxx
Preludepower Member
xxfallacyxx's Avatar
xxfallacyxx has a spectacular aura aboutxxfallacyxx has a spectacular aura about
So as some of you know, a couple of months ago I had my car swapped to a 5speed and ditched the seriously failing automatic transmission from hell.
Well, I finally got around to wiring up my reverse lights and discovered that the transmission shop that did my swap did something interesting. Usually after a swap is done, you need to short two pins on a 10pin connector that used to go to the auto transmission to make the car think it was in P or N and allow it to start. The shop actually kept the "unit" that's on the end of that 10pin connector harness, it looks something like this:
It's pretty small, appr. 2" square. Obviously I chopped mine of the wires so I could redo them myself. Remove the five screws though and this is what you get:
Turned out that this little "unit" is the jumper for all the different gear selections of the auto transmission, and by shorting the different wires together via the tracks on the inside of it, it tells the ECU what gear the car is in. My transmission shop simply left it in park and attached to the 10pin connector instead of removing it with the transmission. Car worked. All you would have to do afterward would be simply cut wire #3, add a second length of wire to it (so it'd be a T, three ends). Then take the new end and attach it to one lead from the reverse switch of the manual transmission. For the other end, cut wire #9 and attach to that.
If you attempt this wiring be absolutely sure that you can return it to the way it was in case that you cannot get this to work.
__________________
i love snow! my mom just got about 6 inches or more the other night, and it started snowing at the rockafeller tree when we were there
Yeah she did.
I took the time to read this thread,line for line,and came out in the end with only one opinion,
FALLACY WILL NEVER BE BALD!!
ALL HAIL THE BEARD!!!
If you like pirates, you'll love this
(<--that's a clicky
xxfallacyxx is offline   Reply With Quote
Reply
Bookmarks
  • Submit Thread to Digg Digg
  • Ads By Google
    Search Cloud
    2010 honda prelude 3rd gen prelude 4th gen prelude 5th gen prelude 5th generation prelude 6th gen prelude b20a3 b20a7 b21a1 bpi flowstack car motivational posters convertible prelude dashboard paint edge2lyfe view profile fastest prelude floor jack reviews funny things to text your girlfriend h22 cams h22 manual tensioner conversion h22a4 h22b h23 vtec h23a vtec honda prelude 2010 honda prelude 5th gen hp259 hp259 tire individual throttle bodies k1 attack for sale k20 prelude nice things to say to your girlfriend in a text nice things to text your girlfriend nitto neo gen reviews power prelude prelude convertible prelude forum prelude forums prelude power prelude power.com preludepower preludepower.com projector retrofit race shifting racing hart cp-035 rattle can paint job song suggester sweet things to text your girlfriend things to text your girlfriend what to text your girlfriend www.preludepower.com
    Thread Tools
    Display Modes
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Forum Jump
    KickItBack = Cash Back
    Google
    vB.Sponsors
    PreludePower Forums
