Reload this Page Always Lots of Problems - Dodged a bullet this time.
Notices
Reply
Ads By Google
Thread Tools Display Modes
Old 09-09-2009, 06:08 PM   #1
Mikeman101
Newbie
Mikeman101 is on a distinguished road
I bought the car last spring. It was a 1997 Prelude Base 5 speed off ebay with 120k miles on it. I bought it on the east coast and drove it home 1400 miles home to Minnesota, but not before it broke down twice. Once on the New York-Pennsylvania Border when it's bent axle came out of the differential approaching the tollbooth. The other stop was after I blew both front tires in Ohio. Luckily I had 14 autostores within a 2 mile radius and 1 of them had my size tire on hand, 205/45R-17 they are.
Anyways, the problems continued from there. My radiator started leaking shortly there after so I did the unthinkable and tried using stopleak. Well, the stopleak seemed to plug up the radiator after the leak because the leak got 5 times worse, then blocked up the cooling system. The car thermostate went into the red after driving it only 6 blocks. I waited 10 minutes til it cooled, drove it another couple blocks and stopped before it got into the red again, and so on 2 or 3 more times until I got home.
The next day I replaced the radiator and had the coolant flushed. Unfortunately at my next fill up I discovered oil in my coolant. So that little bit of over heating was enough to blow the head gasket and/or warp/crack the head/block. So I garaged it last August and left it alone until this spring when I got out of school.
Over the summer I did everything I could think of to this car, cleaned the EGR ports, changed the oil, flushed the coolant, replaced the head gasket/IM gasket/exhaust gasket/vtek gasket&filter, polished/milled/x-rayed the head, cleaned the IM/TB/IACV/Vtek Gasket, replaced the Cam seals/timing belt/water pump/balancer belt/autotensioner, and replaced the fuel filter.
I worked on it here and there and finally got it all done a couple weeks ago. Well, I am not very good with cars but was exstatic when the car started with no CELs and purred like a kitten, especially when I did all the work by myself and like I said I am retarded with cars. The car ran great for about 100 miles until the other day. I was about 45 min away from home and going 70 in cruise control when I got the strong smell of gas and the speed started dropping. I pushed in the clutch and the car died. I coasted over to the side of the road and tried to start it again but wouldn't turn over.
Got the car towed to a shop and just got a call. Turns out the Timing belt had slipped off. The belt got shredded but the good news is that they did a compression test and it turns out that I didn't bend any valves!
They are only charging a little over $300 in labor to do my timing belt again, and another $200 for the timing belt kit since the belt got shredded. I feel like I dodged a bullet this time. I really didn't wanna tow it home and put another head on it.
What do you guys think? Am I lucky or what? I am really curious to see how the timing belt came off. I think a bolt or two may not have been torqued down enough, maybe I should have used locktite on some of those pully bolts.
I am curious to see what my compression numbers were. I have always been curious what it would get but too nervous to do it.
Well, sorry for the long story but I have been meaning to share my story for some time now.
Mikeman101 is offline   Reply With Quote
Old 09-09-2009, 06:28 PM   #2
Podunkparte
Lude Addict
Podunkparte's Avatar
Podunkparte is on a distinguished road
HAHAHA No!
Sounds like you bought a car off of eBay without having it checked out at all and are paying the price.
__________________
97 Prelude SH
__________________________________
Podunkparte is offline   Reply With Quote
Old 09-09-2009, 07:06 PM   #3
Mikeman101
Newbie
Originally Posted by Podunkparte View Post
HAHAHA No!
I was kinda thinking that, but most of the stuff is because of my ignorance like using the stop leak on the radiator. The bent axel would have been nice to know about prior for bargaining purposes though.
Old 09-09-2009, 08:03 PM   #4
h22a4sam
True Luder
h22a4sam's Avatar
h22a4sam is on a distinguished road
Did you drive the car before you forked the cash over? Seems you bought someone else's nightmare. Sucks but for the most part it was stuff that was fixable. It would suck ass if the title was salvaged and it had a tweaked unibody.
__________________
h22a4sam is online now   Reply With Quote
Old 09-09-2009, 10:10 PM   #5
Mikeman101
Newbie
Thats just it. The body is fine, engine is great (other than the head gasket I fucked up), and the transmission was good. Didn't even have the 5th gear grind that I've read about with those models.
Old 09-09-2009, 10:28 PM   #6
flyinghonda
True Luder
flyinghonda's Avatar
flyinghonda is on a distinguished road
you are lucky only for the last part with the timing belt, but for the rest it's been pretty much hell for you.
__________________
96 Honda Civic EX Coupe (Sold)
98 Honda Prelude Base (DD)
84 VW Rabbit 1.8T (Race car project)
flyinghonda is offline   Reply With Quote
Old 09-10-2009, 04:00 AM   #7
shaylude01
CanuckBB6
shaylude01's Avatar
shaylude01 is on a distinguished road
Fuckin spammers. Damn thers alot around here these days...
Not bad though, coulda been worse for you. Couldof basically had to replace the head like you said, or some valves. Not bad not bad.
__________________
Build Thread:
shaylude01 is offline   Reply With Quote
Old 09-10-2009, 04:06 AM   #8
LOL_RICE
Preludepower Member
LOL_RICE's Avatar
LOL_RICE will become famous soon enough
$200 for a timing belt kit? Explain.
__________________
19 sec 1/4 at altitude.
It's a shame you never got the chance to quote me in your sig
LOL_RICE is offline   Reply With Quote
Old 09-10-2009, 09:08 PM   #9
Mikeman101
Newbie
I believe it has the timing belt, balancer belt, autotensioner pully, and some other berings I guess.
Reply
Bookmarks
  • Submit Thread to Digg Digg
  • Ads By Google
    Search Cloud
    2010 honda prelude 3rd gen prelude 4th gen prelude 5th gen prelude 5th generation prelude 6th gen prelude b20a3 b20a7 b21a1 bpi flowstack car motivational posters convertible prelude dashboard paint edge2lyfe view profile fastest prelude floor jack reviews funny things to text your girlfriend h22 cams h22 manual tensioner conversion h22a4 h22b h23 vtec h23a vtec honda prelude 2010 honda prelude 5th gen hp259 hp259 tire individual throttle bodies k1 attack for sale k20 prelude nice things to say to your girlfriend in a text nice things to text your girlfriend nitto neo gen reviews power prelude prelude convertible prelude forum prelude forums prelude power prelude power.com preludepower preludepower.com projector retrofit race shifting racing hart cp-035 rattle can paint job song suggester sweet things to text your girlfriend things to text your girlfriend what to text your girlfriend www.preludepower.com
    Thread Tools
    Display Modes
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Forum Jump
    KickItBack = Cash Back
    Google
    vB.Sponsors
    PreludePower Forums
