Reload this Page Smoke..
Reply
Ads By Google
Thread Tools Display Modes
Old 08-23-2009, 06:21 AM   #1
Shrillmill
True Luder
Shrillmill is on a distinguished road
Smoke..
when I drive on the highway and then like get off and stop and go again my car makes big clouds of smoke.
and smells like ass.
Its an auto.
Yea....
Its been doing it for a while...
Maybe bent valves?
__________________
1998 base prelude auto for now.
Shrillmill is offline   Reply With Quote
Old 08-23-2009, 07:40 AM   #2
EagleEyez
Corner Killer
EagleEyez's Avatar
EagleEyez has a spectacular aura aboutEagleEyez has a spectacular aura about
Its an auto.
Yea....
Maybe bent valves?
Ha, your car wouldnt run.
Is that all the info you can write and give us? You cant tell time of day? Was your car cold or hot? Did it lose power? White smoke or black smoke? Did it smell sweet or burnt? Were you at 100% throttle? Were you full on oil? Did you have too much oil? Have you replaced your oil recently? Did you look under the hood after? See anything unusual? Any lights on dash? How many miles on the car? See any fluid on the ground? Do you maintain it or just drive it? BE HONEST!!!
What info you did give leaves us at nothing but guessing and you could do that just the same.
__________________
Jason was an Army Ranger...if it's too much for him we might as well just pack up our balls and go home.
"I have captured and secured the H22 beast! Let the building comence"!
"The beast has been borne again! Test drive proves....."Masterpiece"
-Hand Built by EagleEyez-
EagleEyez is offline   Reply With Quote
Old 08-23-2009, 12:27 PM   #3
egjdmh22a
Preludepower Member
egjdmh22a's Avatar
egjdmh22a will become famous soon enough
Send a message via MSN to egjdmh22a
damn do you have a flashlight in his face when you ask all this???
__________________
egjdmh22a is offline   Reply With Quote
Old 08-25-2009, 01:47 PM   #4
Shrillmill
True Luder
I had just gotten off work when i wrote that tired.
car has 14x,xxx miles. did oil like 1200 miles ago.
Its been doing it for a few months.
But not always.
It does it maybe 4 times a week.
When I drive on the hwy like 80 or so.
and then come to a stop and start to go again it smokes
it smells rich.
Its white smoke.
Not alot to make a big cloud but to make a trail.
__________________
Old 08-25-2009, 02:23 PM   #5
JLude
Idiotic Thread Locker!
JLude's Avatar
JLude is a jewel in the roughJLude is a jewel in the roughJLude is a jewel in the roughJLude is a jewel in the rough
Send a message via AIM to JLude
Do you check your oil level at least every 300 miles? YES you need to on the H22 motor! White smoke is either oil or coolant. Could be a lot of things: Headgasket, bad ring seals, etc. Best to do a compression test after you verify that you aren't leaking fluids.
__________________
Building your custom HID Projector RETROFITS!!! PM FOR DETAILS.
'90 Si 4WS, 2002 SSM S2000, 2000 Tacoma V6 4x4 TRD, 2006 Yamaha FZ6, '92 Civic LX 4dr
JLude is online now   Reply With Quote
Old 08-25-2009, 02:43 PM   #6
psud3ity
Preludepower Member
psud3ity's Avatar
psud3ity will become famous soon enough
My slushbox would smoke after I parked my car right before it died...
__________________
My review of
i'll smoke a bowl for you, psud3ity. hope it chills you out a little.
psud3ity is offline   Reply With Quote
Old 08-26-2009, 05:53 AM   #7
migoreng
Lude Dude
migoreng is on a distinguished road
blue smoke after deceleration, when starting, taking off = worn valve stem seals?
migoreng is offline   Reply With Quote
Old 08-26-2009, 09:15 AM   #8
Nismo2Honda
Preludepower Member
Nismo2Honda's Avatar
Nismo2Honda is on a distinguished road
Send a message via AIM to Nismo2Honda
Prelude of the Month
Mine does the same, I've noticed recently It smokes sometimes. when I get going from a light. I don't pay any mind to it, Car still runs and pulls hard so ehhhh.
__________________
Team BB6
Known simply as "V"
Best 1/4: 14.8 Best trap: 97 mph
Nismo2Honda is offline   Reply With Quote
Old 08-26-2009, 01:32 PM   #9
bb6ryder
Newbie
bb6ryder's Avatar
bb6ryder is on a distinguished road
it could b alot of things might b the gromets in the vc seals leakin oil in to the spark plugs
__________________
you really never acquire true happiness until you hit 150mhp and realize life is like a highway with curves bumps and splits in the road but as long as you drive a honda its all good
bb6ryder is offline   Reply With Quote
Old 08-26-2009, 05:51 PM   #10
migoreng
Lude Dude
could be oil gradually being sucked through the pcv valve?
i smoke for a few seconds at the light sometimes, usually after some hard driving...and it stinks
FYI i've taken my pcv valve out a few times and it has always been covered in oil..looks like bits of oil can easily get sucked up during high pressure/vacumm...the rubber grommet is also covered in a thin film of oil.
i might DIY a catch can later which i haven't been bothered to do for the last 6 month or so =_=
Old 08-26-2009, 06:36 PM   #11
Shrillmill
True Luder
I check my oil all the time.
Like every other day or so.
The coolant is full.
Um.
Maybe is oil threw the pcv.?
Maybe is rings.
Ugh.
I guess more reason to drive it till it stops working right....
__________________
Old 08-26-2009, 06:49 PM   #12
5thgenftmfw
Preludepower Member
5thgenftmfw's Avatar
5thgenftmfw is on a distinguished road
White smoke.......... = coolant being burned through the exhaust.
Right?
If so.. Then the #1 culprit for coolat burnage is headgasket.
__________________
Psssshhhh, it's just a Honda, right?
Everyone would be a better person if they were a member of pp. Crime rate would go down, ass talkers would be eliminated, and domestics wouldn't exist.
5thgenftmfw is offline   Reply With Quote
Old 08-26-2009, 07:31 PM   #13
migoreng
Lude Dude
when people say headgasket problem is it a major problem or can there be minor head gasket problems?
like is it possible to have a hairline crack that will cause you to loose coolant slowly over a few months or will a car suddenly just billow out white smoke when the gasket cracks?
Old 08-27-2009, 06:26 AM   #14
JLude
JLude's Avatar
Headgaskets failures can be minor. I've replaced 4 headgaskets on fixer upper Hondas and most of them still ran fine and didn't smoke but coolant was leaking into the cylinder(s) and burning out the exhaust, sucking the radiator dry in about 50 miles! On the Accord I'm working on now there is also some oil getting into the coolant through a failed head gasket.
__________________
Old 08-27-2009, 04:51 PM   #15
Shrillmill
True Luder
I dont go threw coolant tho.
Ive only had to put some in once since I got the car.
And it wasnt even alot.
idk.
__________________
Old 10-23-2009, 03:04 AM   #16
migoreng
Lude Dude
need some advice. sorry for the long post but i want to know if there are any fixes at all. like could it be a sensor problem or something else. this smoking has been happening for a while. car is completely stock except for a k&n panel filter.
i'm noticing blue/white smoke puffing randomly usually when i come to a stop from cruising or getting back on the throttle after engine braking (overrun?)
my car goes through around 1/3quart of oil (10w40 synthetic) every 600miles or 200-300ml/1000km...
the car still makes good power, has good fuel consumption and coolant level is fine.
no blue/white smoke puffs out when i start the car in the mornings and no smoke after idling for a few minutes.
i did a test today...i was cruising down the highway at 110kph in 5th for the last 10-15mins...so i slow down to 90-100kph and downshift to 4th and engine brake for around 10 seconds. i down shift to 3rd, slow to around 50-60kph and give around 15-20% throttle...no blue/white smoke in my rear view.
i cruise down the road normally around 60kph in 4th and let go of the throttle for a few seconds and step on it. no smoke visible in the rear view. i do it once or twice more and then notice a puff of white smoke rise above the rear wing.
i do it 3 or 4 more times while still maintaining a speed of 60kph and only managed to make the exhaust puff a cloud white smoke once more.
other times i would stop at the lights and there's a cloud of white smoke that reaches my door but that's very rare.
sometimes i would slow down using engine braking, lights turns green, i shift into second, give a decent amount of gas and shoot out a small cloud of blue smoke that lingers around for 2-3 seconds.
i did my 200,000km service 4000km ago. changed timing belt, waterpump, tensioner and all oil seals. compression test was fine. i think the second cylinder was 178psi. the rest were between 180-185psi. mechanic said my valve stem seals were fine.
Old 10-23-2009, 04:24 AM   #17
DmansLude
True Luder
DmansLude will become famous soon enough
So did u even replaced the pcv valve yet? I mean with honda oem not the cheap aftermarket one(I got the cheap one at Kragen and the smoke got worse). Because pcv valves do wear out over time.
DmansLude is offline   Reply With Quote
Old 10-23-2009, 11:42 AM   #18
MommysLittleMonster
Grinnin' like I'm guilty
MommysLittleMonster's Avatar
MommysLittleMonster is a jewel in the roughMommysLittleMonster is a jewel in the roughMommysLittleMonster is a jewel in the roughMommysLittleMonster is a jewel in the rough
Send a message via AIM to MommysLittleMonster
Do you always have to engine break? That's probably a large part of why your car is smoking excessively. Also, why are you running 10w-40? 10w-30 is what you SHOULD be running, synthetic too...
__________________
170whp / 145lbs-ft
MommysLittleMonster is offline   Reply With Quote
Old 10-23-2009, 06:43 PM   #19
migoreng
Lude Dude
i have been using an aftermarket pcv valve for the last year(20,000km). it's brown/black but don't know what brand but it looks cheap. it cost me around 1/4 of the price of a genuine pcv valve.
i roll in gear when i'm not accelerating as no fuel gets injected? when i'm approaching a turn i usually downshift 1 or 2 gears and i roll in gear to the lights.
why would engine braking cause excessive smoke and how do you guys usually use the gears when rolling to the lights/corner or rolling down a long hill?
my car has 200,000km and everyone recommends 10w40 max. that's why i'm using it.
Old 10-24-2009, 03:27 AM   #20
DmansLude
True Luder
Engine braking will cause increased manifold vacuum (due to closed throttle but the rpm is still high so the cylinders still take in more air than the IAC can provide) So, the pcv valve is another short way for the manifold to get air in. The pcv is actually a two way valve. When there is too much vacuum, it will close itself. But if there is high pressure in the manifold(due to backfire), it will also close itself. But the point is it can only do that a few times before the spring inside is weaken and start letting everything in or out including a lot of oil.
BTW. I have 188k miles (about 300,000 km) on my 98 and i still use 5w-30 with no problem, not even burning oil. How hot is it over there though?
Old 10-24-2009, 05:51 AM   #21
KraserK
Lude Addict
KraserK's Avatar
KraserK is on a distinguished road
wow that is some valuable information! thank yo alot! I hope to get my lude lasting that long. Im wondering would you have a pic of the pcv valve? I dont get how it has a spring inside of it? I thot the pcv valve was just a tube of plastic
KraserK is offline   Reply With Quote
Old 10-24-2009, 03:48 PM   #22
DmansLude
True Luder
Here's the link. It has a diagram of the PCV. http://www.filtercouncil.org/techdata/tsbs/94-2R1.html
Old 10-24-2009, 08:27 PM   #23
migoreng
Lude Dude
i don't get how the spring can weaken? so what's the best thing for me to do?
well we're heading towards summer here so maybe 35degrees celsius max in the middle of the day (95f?)
Old 10-25-2009, 04:13 AM   #24
DmansLude
True Luder
It gets weaken because of the heat. Remember there was a thread of some luder here that made some plastic catch can and it melted and collapsed. Yeah, the oil and vapor are that hot. And when you expose that kind of heat to a small metal spring pretty much constantly it will lose its spring tension over time. I would recommend that u use 10w-30 instead of 40 because that's just a bit thick for an h22.
Old 11-17-2009, 06:48 PM   #25
pv97lude
Newbie
pv97lude's Avatar
pv97lude is on a distinguished road
Its an auto.
Yea....
Maybe bent valves?
I seem to have the same problem as you, i also have a auto prelude and its a 97 and has 190xxx miles on the body and about 15xxx on the motor me and my dad rebuilt for a project, but mine seems to be way way worse, i look like a deisel anywhere i go on cold start up and even when its warm?? help?? lol, but once it gets warm it seems.. to be fine, but if i ever look out of my rear view mirror when i hit vtec, black/grey smoke. i will soon try to put a video up once i figure out how. We just recently changed the head gasket because my radiator fluid is literally black, so we flushed it and it stilll has the same problem, black, like oil. so black smoke and black in coolent tank?? linked maybe?? it drives fine, except for i always have a problem with it over heating.
__________________
pv97lude is offline   Reply With Quote
Reply
Bookmarks
  • Submit Thread to Digg Digg
  • Ads By Google
    Search Cloud
    2010 honda prelude 3rd gen prelude 4th gen prelude 5th gen prelude 5th generation prelude 6th gen prelude b21a1 car motivational posters convertible prelude dashboard paint edge2lyfe view profile floor jack reviews funny things to text your girlfriend h22 cams h22 manual tensioner conversion h22a4 h22a4 specs h23 vtec h23a vtec honda prelude 2010 honda prelude 5th gen how to text your girlfriend hp259 hp259 tire individual throttle bodies k1 attack for sale k20 prelude nice things to say to your girlfriend in a text nice things to text your girlfriend nitto neo gen reviews pcv valve symptoms power prelude prelude prelude convertible prelude forum prelude forums prelude power preludepower preludepower.com projector retrofit racing hart cp-035 rattle can paint job song suggester sweet things to say to your girlfriend in a text sweet things to say to your girlfriend over text sweet things to text your girlfriend things to text about things to text your girlfriend what to text your girlfriend www.preludepower.com
    Thread Tools
    Display Modes
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Forum Jump
    KickItBack = Cash Back
    Google
    vB.Sponsors
    PreludePower Forums
