Go Back   Preludepower.com > Performance and Style > Car Entertainment and Security
Reload this Page Pioneer deck troubles..
Notices
Reply
Ads By Google
Thread Tools Display Modes
Old 08-17-2009, 01:24 AM   #1
JoshR
Newbie
JoshR is on a distinguished road
Hey, I'm kinda new here but i thought you guys might be able to help out. I just bought a used pioneer DEH-p3000ib and i got a prelude harness and stuff and wired it up and im almost positive the wires all are all matching. So my problem is when i turn on the car the deck starts up as well except i cant get my ipod to play or the radio either for that matter. Theres no sound coming through the speakers.. I do not have a pioneer ipod cable but a hook up through the cigarette lighter. Do i need an ipod cable? And also there is a blue and white coated wire that came with the deck but my harness only has solid blue. I matched those cause they were the only 2 left. Anyone know how i can get this working? Please and thanks
JoshR is offline   Reply With Quote
Old 08-17-2009, 01:46 AM   #2
2nd one
Donating Member
2nd one's Avatar
2nd one is on a distinguished road
yes you need a cable, and if you have no sound, you either crossed a wire or two, or you have a blown speaker. easiest way to test is with a 9volt battery. you can tap the speaker leads(carside) and see if the speaker pops. if you get no sound, then you have a speaker that is blown. if you disconnect that speaker your sound will come back on. the radio cuts the internal amp if it detects a dead short. ie blown speaker or lead going to chassis ground. the right way to check the speakers is with an ohm meter. if they meter properly, you will get anywhere from 3.4 ohms to 5.6 ohms. the slightest movement of the cone will change the speakers impedence. those are good values and would allow the radio to function normal. if you used butt connectors when you did the install, you will need to cut them out to test the speakers. don't leave the radio hooked up either, if you are gonna do the 9volt battery trick. you are using a harness adapter for the car i presume. if not, none of the colors will match up.
__________________
2nd one is offline   Reply With Quote
Old 08-17-2009, 02:12 AM   #3
psud3ity
Preludepower Member
psud3ity's Avatar
psud3ity will become famous soon enough
Match up what it says in the headunit's manual to what the prelude harness says. Probably something to do with the wiring. The colors from my HU and harness didn't match what they should have been.
__________________
DESPERATLEY NEED A PASSANGER SIDE TAILLIGHT!!!! PM ME!!!
Car Audio Stuff:
psud3ity is offline   Reply With Quote
Old 08-17-2009, 04:14 AM   #4
2nd one
Donating Member
2nd one's Avatar
^^ thats odd, most all stereos are standardized now to match up to the aftermarket harness adapters. the only radios i have seen that don't are either really old, or off brands. where did you get your harness from? should be whites and grays for the fronts and purples and greens for the rear. red is accessory, yellow is 12 volts constant, black is ground, blue with white stripe is amp turn on, and blue is power antenna. pink if equipped is usually mute.
__________________
Old 08-17-2009, 12:12 PM   #5
JoshR
Newbie
You said Blue wire is for my antenna, which i think is my problem because my ipod hook up thing i have right now uses a shitty radio station to play my music but if my antennas npot working then that may be it.... Also i had a shitty nextar deck that came with the car and i dont think my speakers are blown... they are bad though. And i will look into getting a cable
Old 08-17-2009, 12:15 PM   #6
JoshR
Newbie
My deck only came with a Blue and white though no solid... and my harness only came with solid blue... no blue and white? should i just disconnect these?
Old 08-17-2009, 12:28 PM   #7
JoshR
Newbie
oh yeah, got harness from Visions Electronics or w.e its called
Old 08-17-2009, 01:00 PM   #8
zsudz922
True Luder
zsudz922's Avatar
zsudz922 is on a distinguished road
you can get the owners manual from here http://www.pioneerelectronics.com/PU...3000IB.Support
just fyi.
__________________
FOR SALE: 2 EXCELLENT condition 1/8 scale Nitro R/C 4WD Buggies with TONS of extras!! comes with original boxes ect..
also have an EXCELLENT condition PS2 system with network adapter and MORE! comes with original box and manuals.
PM me if interested!
zsudz922 is offline   Reply With Quote
Old 08-17-2009, 03:03 PM   #9
psud3ity
Preludepower Member
psud3ity's Avatar
My headunit sucks. Probably why the harness wasn't standard.
__________________
Car Audio Stuff:
Old 08-17-2009, 03:03 PM   #10
JoshR
Newbie
Thanks for the help guys, still havent resolved it but i will post how i did if i figure it out.
Old 08-17-2009, 06:23 PM   #11
2nd one
Donating Member
2nd one's Avatar
if the deck only supports that one wire, then you had it right when you hooked it up to the blue wire. the amp turn on lead will activate the antenna the whole time the radio is on. newer models have both, so when you switch your source to cd or ipod, the power antenna will drop. the way you have it wired, the antenna should be active until you either shut off the headunit, or shut off the car. so if you have sound until you use the ipod, then you may have an issue with the way you wired the fm transmitter. i would check there. if you have the older 3g 88-89, you also had an antenna in the rear glass that may be interferring with your transmitter as well, especially if you accidentally hooked up to it. then basically the radio is using one antenna and the transimtter is using the other. make sense.
__________________
Old 08-17-2009, 11:47 PM   #12
JoshR
Newbie
Had my buddy take a look, hes kinda a techy with car audio and yeah, what i wasnt hoping for all along is what im pretty sure happened: The guy who sold it to me sold it broken, im calling him tomorrow and getting my money back.
Old 08-17-2009, 11:56 PM   #13
2nd one
Donating Member
2nd one's Avatar
word. that sucks man g/l
__________________
Old 08-18-2009, 06:14 PM   #14
psud3ity
Preludepower Member
psud3ity's Avatar
beat him with a stick for your trouble.
__________________
Car Audio Stuff:
Reply
Bookmarks
  • Submit Thread to Digg Digg
  • Ads By Google
    Search Cloud
    2010 honda prelude 3rd gen prelude 4th gen prelude 5th gen prelude 5th generation prelude 6th gen prelude b20a3 b20a7 b21a1 bpi flowstack car motivational posters convertible prelude dashboard paint edge2lyfe view profile fastest prelude floor jack reviews funny things to text your girlfriend h22 cams h22 manual tensioner conversion h22a4 h22b h23 vtec h23a vtec honda prelude 2010 honda prelude 5th gen hp259 hp259 tire individual throttle bodies k1 attack for sale k20 prelude nice things to say to your girlfriend in a text nice things to text your girlfriend nitto neo gen reviews power prelude prelude convertible prelude forum prelude forums prelude power prelude power.com preludepower preludepower.com projector retrofit race shifting racing hart cp-035 rattle can paint job song suggester sweet things to text your girlfriend things to text your girlfriend what to text your girlfriend www.preludepower.com
    Thread Tools
    Display Modes
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Forum Jump
    KickItBack = Cash Back
    Google
    vB.Sponsors
    PreludePower Forums
