Go Back   Preludepower.com > Prelude Forums > 3rd Gen
Reload this Page heating up!!!!
Notices
Reply
Ads By Google
Thread Tools Display Modes
Old 08-14-2009, 11:15 PM   #1
streetking
R.I.P. Whorehouse :-(
streetking's Avatar
streetking is on a distinguished road
Send a message via MSN to streetking
heating up!!!!
okay, so im tired of trying to figure out what the hell is wrong with my lude. ive changed the thermostat like 3 times, changed the radiator, and the temp sending unit. what else could be causing my motor to heat up. its a rebuilt b21, so all the internals are new. plrase help. thanks.
streetking is offline   Reply With Quote
Old 08-14-2009, 11:43 PM   #2
devin_decater
True Luder
devin_decater is on a distinguished road
possible HG failure?
__________________
do you consider yourself smart?
a quick learner?
based on your spelling, you dont have any major brain defects..
devin_decater is offline   Reply With Quote
Old 08-15-2009, 12:10 AM   #3
streetking
streetking's Avatar
really? headgasket failure? like maybe they put on the wrong head gasket?
Old 08-15-2009, 12:12 AM   #4
scorpionsf
Donating Member
scorpionsf's Avatar
scorpionsf is on a distinguished road
are you leaking any anti-freeze?
scorpionsf is offline   Reply With Quote
Old 08-15-2009, 12:14 AM   #5
streetking
streetking's Avatar
nope. no leaks, well oil only but no anti freeze.
Old 08-15-2009, 02:02 AM   #6
GoldenLude89
Preludepower Member
GoldenLude89's Avatar
GoldenLude89 is on a distinguished road
coolant temp sensor.... autzone 25 bucks yo
__________________
GoldenLude89 is offline   Reply With Quote
Old 08-15-2009, 02:50 AM   #7
streetking
streetking's Avatar
i have not tried that yet. so will do. thanks guys.
Old 08-15-2009, 03:00 AM   #8
ludakiss
Lude Addict
ludakiss's Avatar
ludakiss is on a distinguished road
warped head? have you checked regulary how much coolant you have? are you loosing any?
__________________
1991 Toyota MR2 Turbo - summer car
1989 White Prelude 2.0 Si - daily driver
1989 Jeep Cherokee 4.0 liter - weekend fun
1988 Red Prelude S - parts car
1980 Lincoln Continental Town Car - burn rubber!
1989 Red Prelude 2.0 Si 4WS - parts car
ludakiss is offline   Reply With Quote
Old 08-15-2009, 03:55 AM   #9
streetking
streetking's Avatar
i check every few days. and no oil leaks.
__________________
banned for being in love
Old 08-15-2009, 04:23 AM   #10
1funryd
Vendor
1funryd's Avatar
1funryd will become famous soon enough1funryd will become famous soon enough
Send a message via AIM to 1funryd Send a message via MSN to 1funryd Send a message via Yahoo to 1funryd
Here is a good question, are you truly overheating or is the guage just displaying its overheating?
Another possibility is the one of the sensors or the guage itself might not be working right, still operating but not operating as it should so giving yo false possibilites.
__________________
Sean
H22 Project Manager
(Clik Here)
Members: Danny_19 - 1FunRyd(H23 swapped) - B20luda
3rd Gen Prelude Owners are Rare Breed of Enthusiast's!!! (originally posted by: RED89si)
1funryd is offline   Reply With Quote
Old 08-15-2009, 04:30 AM   #11
streetking
streetking's Avatar
yeah maybe sean. but it heats up, then cools down, then heats up, and it cools down. and it does this everytime i drive it. could it still be the gauge?
__________________
Old 08-15-2009, 06:26 AM   #12
dano
Preludepower Member
dano has disabled reputation
Don't mean to insult you or anything, but, are you putting the thermostat in the right way around ??? Spring toward the engine ??
__________________
dano is offline   Reply With Quote
Old 08-15-2009, 07:55 AM   #13
2nd one
Donating Member
2nd one's Avatar
2nd one is on a distinguished road
could possibly be air bound as well. these cars can be a pain to get the air out of the system. that would show the air being hotter than the coolant when it hits the sending unit.
2nd one is offline   Reply With Quote
Old 08-15-2009, 11:03 AM   #14
Mikeallen154
True Luder
Mikeallen154's Avatar
Mikeallen154 is on a distinguished road
i had that problem, it was the sensor for my fans going bad, and they were turning on and off at the wrong time and just eventually stopped turning on all together. Instead of replacing it, I just wired the fans to turn on when the cars turned on.
__________________
1989 Honda Prelude Si 4WS, b20a5 - pretty much stock for now, saving up for boost
Mikeallen154 is offline   Reply With Quote
Old 08-15-2009, 11:28 AM   #15
streetking
streetking's Avatar
i know how the thermostat goes in. and no im not insulted, but thanks for asking.
is there any other bleeding screw other than the one on the stat housing? cuz i opened that one after filling up the system, and it seemed to come out of there fine.
Old 08-15-2009, 01:28 PM   #16
TripleLude
Elite Member
TripleLude's Avatar
TripleLude will become famous soon enough
Sound like low fluid or improperly mixed fluid. If it is all water, or mostly water in the coolant system, it will turn to steam and not effectively be pumped through the system.
Drain and fill with exactly 50/50 mixture. (antifreeze / distilled water) Or just buy the pre-mixed 50/50 stuff.
__________________
TripleLude is offline   Reply With Quote
Old 08-15-2009, 02:27 PM   #17
2nd one
Donating Member
2nd one's Avatar
i just had to rebleed my system because i thought there was air in it. i did it with the car running and a piece of vacuum hose running to the reservoir. had to wait until the thermostat opened to get the rest of the air from the little coolant lines. thermostat is the highest point in the system, and as far as i know, its the only way to remove the air from the system. it was causing my temp needle to move around between normal and 3\4. now that the air is out, i got the needle to stabilize. the fan still came on as it should though.
__________________
Reply
Bookmarks
  • Submit Thread to Digg Digg
  • Ads By Google
    Search Cloud
    2010 honda prelude 3rd gen prelude 4th gen prelude 5th gen prelude 5th generation prelude 6th gen prelude b20a3 b20a7 b21a1 bpi flowstack car motivational posters convertible prelude dashboard paint edge2lyfe view profile fastest prelude floor jack reviews funny things to text your girlfriend h22 cams h22 manual tensioner conversion h22a4 h22b h23 vtec h23a vtec honda prelude 2010 honda prelude 5th gen hp259 hp259 tire individual throttle bodies k1 attack for sale k20 prelude nice things to say to your girlfriend in a text nice things to text your girlfriend nitto neo gen reviews power prelude prelude convertible prelude forum prelude forums prelude power prelude power.com preludepower preludepower.com projector retrofit race shifting racing hart cp-035 rattle can paint job song suggester sweet things to text your girlfriend things to text your girlfriend what to text your girlfriend www.preludepower.com
    Thread Tools
    Display Modes
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Forum Jump
    KickItBack = Cash Back
    Google
    vB.Sponsors
    PreludePower Forums
