Would E85 help pass a smog test? - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 08-01-2009, 04:44 PM   #1
BA4Guy
Getting Comfortable
BA4Guy's Avatar
BA4Guy is on a distinguished road
I tried looking but didn't see any discussions on this, but has anyone tried using E85 or just adding ethanol to the tank to help pass a smog test? I searched around the net and have seen several discussions that ethanol helps burn much cleaner exhaust. But I just wanna make sure it's ok for a one shot thing in my Prelude. The shop told me I need a new catalytic converter which will cost a total of around $500 and I said feck that
I'm in calif and since there's no E85 stations near me, I'm thinking of just going to the hardware store and getting straight ethanol like I read on another forum
Anybody tried this or heard of it?
http://forums.nasioc.com/forums/show...0&postcount=15
BA4Guy is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-01-2009, 04:52 PM   #2
luzer
Elite Member
luzer's Avatar
luzer has a spectacular aura aboutluzer has a spectacular aura aboutluzer has a spectacular aura about
No, you don't want to run e85 in your 3rd gen. It wasn't designed to run on that much ethanol. There's a wiki on it...
http://en.wikipedia.org/wiki/E85_in_standard_engines
__________________
1991 Prelude Si ALB
2015 Ram 1500 EcoDiesel 4x4
luzer is offline   Reply With Quote Quick reply to this message
Old 08-01-2009, 05:01 PM   #3
JGrove
Lude Cray
JGrove's Avatar
JGrove will become famous soon enough
You can''t run ethanol in your stock fuel system. You would need larger fuel injectors and have the computer reprogrammed for it. Don't go around the block to get next door.
Can you use a Wrench? Is your Catalytic Converter some how welded in? A Cat is not going to cost you $500. Here, I'll help you out
http://sd.autohausaz.com/autohausaz/...ic%20Converter
$130 shipped.
JGrove is offline   Reply With Quote Quick reply to this message
Old 08-01-2009, 07:09 PM   #4
BA4Guy
Getting Comfortable
BA4Guy's Avatar
http://sd.autohausaz.com/autohausaz/detailw.jsp?sid=m3zd4j55i3q2rxzgi1ewby55&partner=a utohausaz&year=1988&make=59&model=6060~829~~193~~~ @Prelude%202.0%20Si,%20DOHC&category=241035@Exhaus t&part=241054@Catalytic%20Converter
$130 shipped.
Thanks. Unfortunately that one says "illegal in Calif"
So you guys say I cannot run ethanol AT ALL? The smog test failure wasn't too bad. And I'm not convinced it's the cat converter. They even want to charge me $100 to specifically test it to verify it's bad. I just want to run enough ethanol to pass the test.
Old 08-02-2009, 02:40 AM   #5
luzer
Elite Member
luzer's Avatar
You can run a percentage of ethanol mixed with gas, up to about 50%. But e85 is 85% ethanol, which it too much unless your car was designed to run on it.
__________________
1991 Prelude Si ALB
Old 08-02-2009, 07:46 PM   #6
TripleLude
Prelude Aficionado
TripleLude's Avatar
TripleLude has a spectacular aura aboutTripleLude has a spectacular aura about
E85 will help pass an emissions test only if it is failing because the car is either (a) running too rich or (b) has unburnt fuel in the exhaust gasses.
If you want to try against better advice, go put 1 gallon of E85 in your car and fill it up the rest with premium gas. Then go take the test. Any more than a gallon could burn valves and the air/fuel mixture ratio will be dangerous.
__________________
TripleLude is offline   Reply With Quote Quick reply to this message
Old 08-06-2009, 07:13 PM   #7
BA4Guy
Getting Comfortable
BA4Guy's Avatar
Thanks. Yeah I wasn't going to run E85 fuel, just wanted to put maybe a gallon or so in the tank with the fuel gauge reading a little less than a quarter of a tank
Old 08-06-2009, 07:18 PM   #8
White894wsi
Elite Member
White894wsi's Avatar
White894wsi is on a distinguished road
Send a message via MSN to White894wsi
Move out of California with all of there stupid Nanny laws...
__________________
I am too lazy to be dumb...
1988 2.0Si Black- Build Thread
1991 2.1Si Red SOLD
White894wsi is offline   Reply With Quote Quick reply to this message
Old 08-06-2009, 07:28 PM   #9
luzer
Elite Member
luzer's Avatar
Yeah, I misunderstood what you were doing. You will be fine doing that.
I'm definitely glad I live in an area that doesn't yet require emissions testing.
__________________
1991 Prelude Si ALB
Old 08-06-2009, 07:36 PM   #10
89595
Ludacious
89595 will become famous soon enough
smog sucks balls in cali
89595 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
