Reload this Page HOW TO: Paint Gauge Rings
Reply
Ads By Google
Thread Tools Display Modes
Old 06-10-2009, 02:59 PM   #1
JPsBB6
True Luder
JPsBB6's Avatar
JPsBB6 is on a distinguished road
Searched to see if it had been done before. Didn't see one, so I figured, why not? If there is one, then I'll stop and not worry about having to take pics.
Disclaimer: I am not responsible for any damage you cause to your vehicle when following this DIY.
Please read through before attempting.
Parts list:
*5th Gen Prelude (Pretty important)
*Phillips Screwdriver
*Some way to remove the rings (I used a chisel)
*Some way to glue rings back in (I used Permatex 5 Min. Plastic Weld)
*Something to mix the glue with and on
*Paint (I used Krylon Fusion white as a base, and I believe Krylon chrome (buddy brought it over, and took it back, lol...))
Optional:
*Cleaning wipes
Take the two screws out of the top of the black cover:
Now tug at the bottom of the cover to remove it:
Now remove the four screws holding the gauge cluster in:
And the two at the top.
Now you can either remove the cluster or leave it in. I opted to take it out, because it made pushing the clips easier.
Now go around the cluster, and push all the little black clips to remove the surround from the actual cluster.
It should now look like this:
Note: Try to not touch the needles... Just slide it off to the side for now..
Do the same for the clear plastic cover.
It should look like this now:
Now take the part with the rings, look on the back, and note all the spots where the rings are held in. You need to knock them off in order to remove the rings. I used a chisel.
Also recommended:
Originally Posted by Shimee View Post
When I did mine I used a center punch to push out the little studs. This way I didn't cut off any length trying to remove them.
To reattach these you can take one of two routes: glue or heat. They're made from polypropylene so a hot solder gun touched to the studs will just melt them down and reform a collar. But then removing them again will be a little more difficult.
Originally Posted by H22LudeSH View Post
I used a scribe to poke out the plastic posts.
After knocking them all off, you should be able to just pull the rings out.
Painted: (A base-coat is always a good idea...)
Let the rings sit so that the paint dries (Half an hour or so should be good. Read the instructions on the can.)
Now you can begin putting stuff back together. Since I knocked off the little tabs that held the rings in, I needed to glue the rings back in. I ended up using a 5 min. Plastic Weld that I purchased a while ago. Squeeze the glue out, mix the two glues together, and apply to the back where the rings where held in at.
Glued:
After letting the glue dry, assemble the whole unit simply by pushing the tabs back in until they snap. Place the cluster back in its home (if you removed it like I did). Screw the cluster back in with the four screws. If you pulled the cluster out, make sure everything works by turning on the ignition, and possibly even starting the car and driving it around. (To make sure that the tach and speedo work before you finalize everything.) Now, before putting the black cover piece on, clean up around the cluster. (Not necessary, but might as well do it while it is apart...)
Eww..
Now snap the cover back in place, and screw it back in on top with the two screws.
Sit back and enjoy your work.
JPsBB6 is offline   Reply With Quote
Old 06-10-2009, 02:59 PM   #2
JPsBB6
True Luder
JPsBB6's Avatar
Finished product:
Thanks for looking!
Old 06-10-2009, 03:03 PM   #3
Shimee
Shimee's Avatar
Shimee is a glorious beacon of lightShimee is a glorious beacon of lightShimee is a glorious beacon of lightShimee is a glorious beacon of lightShimee is a glorious beacon of light
__________________
Click to see my >>
> footwell lights, temperature cable fix, EDM rear fogs, Morimoto projectors, replica fogs, and more!
Rep me!! I NEED TO BEAT neonxiii!!
Shimee is offline   Reply With Quote
Old 06-10-2009, 03:03 PM   #4
billiam
iamNOTerator
billiam's Avatar
billiam has a spectacular aura aboutbilliam has a spectacular aura aboutbilliam has a spectacular aura about
nice work so far! I used a scribe to poke out the plastic posts.
theres already a write-up out there, just not on this site. You should keep going though so we have one on here
http://www.ntpog.org/mods/fifth-gaug...h-gauges.shtml
__________________
god damn it fal! stop gaying up the thread with ur colorful fishies
billiam is offline   Reply With Quote
Old 06-10-2009, 03:06 PM   #5
JPsBB6
True Luder
JPsBB6's Avatar
Oh well, it's already been done, lol. I was gonna just glue them back on. Gonna make a note of that, though. Thanks.
Old 06-10-2009, 03:12 PM   #6
BlkLUDE5G
Preludepower Member
BlkLUDE5G's Avatar
BlkLUDE5G has a spectacular aura aboutBlkLUDE5G has a spectacular aura about
what color we painting these??
__________________
LET THE BUILDING COMMENCE:
INJEN Tanabe/// Spoon Magnaflow
BB Squad #66 (v.2)!
BlkLUDE5G is offline   Reply With Quote
Old 06-10-2009, 03:17 PM   #7
JPsBB6
True Luder
JPsBB6's Avatar
Probably silver. Unless I think of a different color, like a graphite color.
Old 06-10-2009, 03:27 PM   #8
Shimee
Shimee's Avatar
Get rustoleum chrome or duplicolor chrome. It's a nice shiny silver (even though the bastards say it's chrome ).
Or take a trip to autozone. They have these rustoleum trim paints in three varieties: chrome, gold, or aluminum. Aluminum is more a brushed, satin silver than shiny silver.
__________________
Click to see my >>
Old 06-10-2009, 03:31 PM   #9
Smitty2001
Preludepower Member
Smitty2001's Avatar
Smitty2001 will become famous soon enoughSmitty2001 will become famous soon enough
good stuff. Your goods are dirty though man. Looks like someone spilled soda/pop on the top of your gauge cluster.
__________________
Smitty2001 is offline   Reply With Quote
Old 06-10-2009, 03:40 PM   #10
JPsBB6
True Luder
JPsBB6's Avatar
Thanks for the tips, much appreciated. Gonna go to work, first though. (I work at Pep Boys.)
I know. I pulled it out, and thought wtf? Gonna clean it up before I put it all back together, though.
Old 06-11-2009, 09:33 AM   #11
JPsBB6
True Luder
JPsBB6's Avatar
Finished. Let me know if something sounds confusing or missing.
Old 06-11-2009, 12:56 PM   #12
99Lewd
Newbie
99Lewd is on a distinguished road
Very nice writeup with detailed pics
99Lewd is offline   Reply With Quote
Old 06-11-2009, 01:06 PM   #13
prelude2perfect
Preludepower Member
prelude2perfect's Avatar
prelude2perfect is on a distinguished road
Prelude of the Month
I just recently did this with my car. It's definately a very easy way to give the interior a more classy look
__________________
My Boosted 5th Gen
prelude2perfect is offline   Reply With Quote
Old 06-11-2009, 02:40 PM   #14
EUSTACH
Donating Member
EUSTACH is on a distinguished road
nice write up.
__________________
BRAND NEW ZEX KIT FOR SALE
EUSTACH is offline   Reply With Quote
Old 09-03-2009, 02:17 PM   #15
rushi
Newbie
rushi's Avatar
rushi is on a distinguished road
Send a message via AIM to rushi
Thanks for the writeup! I used VHT Chrome paint, works damn well both in daylight and at nighttime.
rushi is offline   Reply With Quote
Old 09-03-2009, 02:39 PM   #16
Shimee
Shimee's Avatar
Originally Posted by rushi View Post
Thanks for the writeup! I used CHT Chrome paint, works damn well both in daylight and at nighttime.
See my sig.
__________________
Click to see my >>
Old 09-03-2009, 07:02 PM   #17
JPsBB6
True Luder
JPsBB6's Avatar
Thanks man...
I have a new pic I have to throw on here. I'm on my iPod, so I can't do it right now.
__________________
*^^^Click for the my Progress Page!^^^*
Old 09-04-2009, 07:30 AM   #18
Psychochimp
Preludepower Member
Psychochimp's Avatar
Psychochimp is on a distinguished road
Send a message via AIM to Psychochimp
Finished product:
Thanks for looking!
Nice DIY gauge bezel painting!!! Nice write up, but I think you needed to head to the nearest gas station ASAP!!!
__________________
Off topic but..do you have to remove the stock sideskirt when install a Wingwest sideskirt...?
Why would you have 1 side skirt on top of another?!?!
Do you wear boxers over your tighty-whities?!?!?!
Psychochimp is offline   Reply With Quote
Old 09-04-2009, 08:55 AM   #19
JPsBB6
True Luder
JPsBB6's Avatar
Lol... That was before I could start driving it because it was unregistered and uninsured... Trust me, it never goes that low. Except for yesterday.
__________________
Old 09-04-2009, 01:07 PM   #20
comebackid
toughnuts
comebackid's Avatar
comebackid is on a distinguished road
nice write-up! I was wondering if anyone has painted their gauge rings anything but silver? i was thinking red might be cool, but i don't know if it would end up looking to ricer.
__________________
jdm h22a swap complete! Loving the NA life! Next step: cams, cam gears, injectors, fuel pump and aem ems. possible e85.
comebackid is offline   Reply With Quote
Old 09-06-2009, 07:50 PM   #21
JPsBB6
True Luder
JPsBB6's Avatar
Someone on here did them in red, I believe. Can't think of the name off the top of my head, though...
Here's the pic that was promised:
__________________
Old 10-07-2009, 10:48 PM   #22
BEEFYMcGangBang
Lude Dude
BEEFYMcGangBang's Avatar
BEEFYMcGangBang is on a distinguished road
not to bring it back from the recent dead, but im actually doing this as i type. and yes its 1:48 am.
BEEFYMcGangBang is offline   Reply With Quote
Old 10-10-2009, 07:49 PM   #23
JPsBB6
True Luder
JPsBB6's Avatar
Lol, so how'd they turn out?
__________________
Old 10-18-2009, 08:32 PM   #24
BEEFYMcGangBang
Lude Dude
you tell me:
I used krylon brushed aluminum. SHIT LOOKS HOT!!!
Old 10-18-2009, 08:36 PM   #25
Ludeh22A
True Luder
Ludeh22A's Avatar
Ludeh22A is on a distinguished road
Send a message via Yahoo to Ludeh22A
I wonder if red would look good? or would it look kinda lame
has anyone done it red?
Ludeh22A is offline   Reply With Quote
Reply
Bookmarks
  • Submit Thread to Digg Digg
  • Ads By Google
    Search Cloud
    2010 honda prelude 3rd gen prelude 4th gen prelude 5th gen prelude 5th generation prelude 6th gen prelude b21a1 car motivational posters convertible prelude dashboard paint edge2lyfe view profile floor jack reviews funny things to text your girlfriend h22 cams h22 manual tensioner conversion h22a4 h22a4 specs h23 vtec h23a vtec honda prelude 2010 honda prelude 5th gen how to text your girlfriend hp259 hp259 tire individual throttle bodies k1 attack for sale k20 prelude nice things to say to your girlfriend in a text nice things to text your girlfriend nitto neo gen reviews pcv valve symptoms power prelude prelude prelude convertible prelude forum prelude forums prelude power preludepower preludepower.com projector retrofit racing hart cp-035 rattle can paint job song suggester sweet things to say to your girlfriend in a text sweet things to say to your girlfriend over text sweet things to text your girlfriend things to text about things to text your girlfriend what to text your girlfriend www.preludepower.com
    Thread Tools
    Display Modes
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Forum Jump
    KickItBack = Cash Back
    Google
    vB.Sponsors
    PreludePower Forums
