CYP sensor gone bad. - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 05-18-2009, 09:10 PM   #1
dvp95
Getting Comfortable
dvp95 is on a distinguished road
Question for you guys. I have a 96 accord with a 98 h22a swap. My car was fine for awhile then I needed a new distributor. I got the TD-89 from distributor kings and swapped it in a few days ago. It ran well for 3 days then today I get a check engine light and fine out it is code 9 which is the CYP sensor.
When I installed it I ran into a little problem. There were 9 wires. 7 of the wires matched up fine but 2 wires (CYP) did not. The colors of the wires for the CYP sensor were reversed. The old and new distributor both had a white and peach wire coming from the CYP sensor but they were reversed ie. white was peach and peach was white. So when I wired them up I had the option of wiring them based on color like the original or based on position going into the CYP sensor. I chose to go with color. So my car ran for 3 days perfectly fine then today I get the CEL. So I wasnt sure if it was the wiring or not so I reversed those 2 wires and when I started the car would not idle well. The RPMs kept bouncing up and down and if I reved the engine the RPMs would drop and eventually stall. So I reversed the wires again back to what I had and again the RPMs were still messed up.
So now what? Can I swap in the CYP sensor from my old distributor? Do I need to get another distributor?
How are those 2 wires supposed to be hooked up?
I switched to a new distributor cause the ICM kept going bad and was recommended to get a new distributor. What causes an ICM to keep going out?
dvp95 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-19-2009, 11:14 PM   #2
akurit
True Luder
akurit's Avatar
akurit is on a distinguished road
this one has me a bit stumped but i think i can take it on but if anyone else has some ideas please share...maybe you could post pics..of how the wiring is in the original compared to the new one...i have ripped enough dizzys open and swap shit out of them..i just bought a del sol and the guy bought a brand new dizzy and the one sensor was bad in it so i swapped in all the old sensors from his original dizzy keeping the new internal coil and ignitor and it all worked out.
heres some of my experience with something i recently delt with umm but its all obd1 may still be useful
http://www.solsociety.com/forum/inde...howtopic=30928
http://www.honda-tech.com/showthread.php?t=2441044
http://honda.lioness.googlepages.com/distributorbearing
if only i had some better links like that about the obd2 h22a4 dizzy
let me know what you wthink
__________________
Honda Prelude 2001 SE DD
Honda Del Sol 1995 VTEC WIFE'S
Acura Legend 1990 LS SOLD
akurit is offline   Reply With Quote Quick reply to this message
Old 05-20-2009, 11:33 AM   #3
dvp95
Getting Comfortable
Thanks for your help. Here is the original thread I started about buying the correct distributor.
http://www.preludepower.com/forums/s...d.php?t=312225
Here is my question for you though.
When I swapped the new distributor kings distributor in it had 9 wires like my original TD-89 distributor. 7 of the wires went to the TDC and CKP sensors and the distributor (these were all fine). The problem was the other 2 wires that went to the CYP sensor. They both come with a white and peach wire. On the old distributor the white one was wired to the black wire and peach went to the yel/black wire of the distributor plug going to the accord harness. On the new distributor those colors were reversed in terms of position. What I mean is when you open the cap and rotor and look at the CYP sensor the white wire comes from on top of the sensor on one distributor and the peach one comes on top of the sensor on the other one. Hope that makes sense. Either way, is it supposed to be wired according to the color or the position from the sensor?
At first what I did was wired it according to color hoping that inside the sensor it was simply reversed. The car worked fine for 3 days then all of a sudden I got a CEL 9. So I switched the wires so that it was wired based on position (top wire goes to the same wire as the top of the old distributor went to). The car started but the idle kept fluctuating. So I switched it back and still the idle was fucked up.
Next day I started the car with the original wiring based on color and it started and drove. I decided to switch to my old CYP sensor and wire it like that sensor was hooked up for years and again it also worked.
So my questions.
1. What caused my ICM in my old distributor to repeatedly go bad? Is it cause of one of the sensors and changing the CYP sensor to that old one might fuck up the new ICM and have the same problems?
2. Does it matter how the CYP sensor is wired up? It has essentially been wired both ways and still works.
3. What caused the idle to be messed up because the next day it started and drove fine without changes?
4. How long before it fucks up again? argggggg. Right now it has been driving fine.
Old 05-20-2009, 03:23 PM   #4
akurit
True Luder
akurit's Avatar
So my questions.
i dont have time to give a proper diagnosis but i would say its wierd that it simply works by color...if it was me id trace the lines to the connector and see that this is the exact same as the old dizzy regardless of color. unless of course by some chance this is wired differently doubtful.
__________________
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
