Troubleshooting: Oil light + Battery Light + Car won't start - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 05-17-2009, 03:53 PM   #1
cokinut
True Luder
cokinut's Avatar
cokinut is on a distinguished road
Send a message via AIM to cokinut
I know the battery light means something wrong with the charging system (alternator, battery, etc.)
I know the when the oil light is blinking, it usually means low oil. constant light = something more serious like low oil pressure, something wrong with the oil pressure sending unit.
_________
Now, the car was running fine the day before etc. The oil level was spot on between the two holes on the dip stick, so no problem there. The alternator was replaced 1/2 year ago. The battery was replaced tonight.
Now, I tried to start the car this morning and the car won't crank over at all. When i turn the key, it just hangs there - no cranking. The fuel pump is priming engaging when turned to the on position. I tried jumping the battery for a few minutes and seems like there is no spark what so ever to help it crank. Headlights and all electronics seem like they are working great and getting good juice.
Why would the battery light and oil light come on at the same time? Can anyone shed light on this?
could it be a starter problem?
Main relay?
__________________
5D x 2 | 30D | 12-24 | 28-75 | 70-200 IS | 50 1.8 | 85 1.8 |various lighting | DelaCruz Photographics
cokinut is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-17-2009, 06:44 PM   #2
BlkLUDE5G
I am Prelude
BlkLUDE5G's Avatar
BlkLUDE5G is a jewel in the roughBlkLUDE5G is a jewel in the roughBlkLUDE5G is a jewel in the rough
not same symtomes i had but check that infamous immobilizer - its worth it anyway in case it craps out
__________________
BlkLUDE5G is offline   Reply With Quote Quick reply to this message
Old 05-17-2009, 07:31 PM   #3
cokinut
True Luder
cokinut's Avatar
with an immobilizer problem, wouldn't the key light be blinking?
__________________
Old 05-17-2009, 09:15 PM   #4
LudeActs
Ludacious
LudeActs's Avatar
LudeActs will become famous soon enough
The battery and oil ligt come on when the key is in the on position without the engine running. That is normal. I'd try pounding on the starter while a friend cranks the key. Sounds like a starter problem. Could also be the ignition switch or main relay though.
__________________
Ohio Honda Prelude Owners Community
LudeActs is offline   Reply With Quote Quick reply to this message
Old 05-17-2009, 09:31 PM   #5
joel_eb
_
joel_eb's Avatar
joel_eb has a spectacular aura aboutjoel_eb has a spectacular aura aboutjoel_eb has a spectacular aura about
Send a message via ICQ to joel_eb
once, this happened to me. my main fuel system's wiring had some of it's insulation rubbed off, causing a small short to the side of the transmission case somewhere. since it's on a 50A fuse it wasnt actually opening the circuit, becuase the draw wasnt large enough. it was enough current to heat up that wire, and all the surrounding wires enough to cook them all open. eventually, i made an insurance claim out of the whole deal, and got the parts that caught fire replaced, but all the shit that started the fire was on my head.
what i'm getting at is that my oil and battery light came on when this was happening. they seemed to be on "dim" for some unknown reason as well. for the sake of your wallet, i hope this isnt your issue. just throwing it out there, though.
__________________
"automatic"?...*shudder*
- Rep = 215! Thanks, MommysLittleMonster! n_n
*WTB*Acura RSX 2005-2006 17" x 7" Type S OEM 5-spoke Rim!!!
joel_eb is offline   Reply With Quote Quick reply to this message
Old 05-17-2009, 10:48 PM   #6
cokinut
True Luder
cokinut's Avatar
Thanks for that input. So when the prelude is on the "ON" position, the battery + oil light stay on. I was afraid because all the other lights on the right hand side (ABS, ATTS, Keylight) all went away. Thanks.
edit: What lights do actually stay on when in the "on" position?
__________________
Old 05-17-2009, 11:59 PM   #7
LudeActs
Ludacious
LudeActs's Avatar
Oil and battery are the only ones that stay on until you start the engine. Unless you have a trouble code, in which case, the check engine light will stay on also.
__________________
Old 05-18-2009, 07:30 AM   #8
5spd5gen
Brewski Turbo King
5spd5gen's Avatar
5spd5gen is a jewel in the rough5spd5gen is a jewel in the rough5spd5gen is a jewel in the rough5spd5gen is a jewel in the rough
_________
Main relay?
well if the car wont start it will always have those lights on, is yours an automatic or a 5 spd? and does the clutch feel like its kind of spongy? if it is you have an air bubble in ur clutch line, then youll need to bleed it if you want me too ill do a write up on it, happened to my buddies lude a couple weeks ago.
__________________
How much did the wedding cost?
Fucking Classy
5spd5gen is offline   Reply With Quote Quick reply to this message
Old 05-18-2009, 09:04 AM   #9
goldenstate
Getting Comfortable
goldenstate's Avatar
goldenstate is on a distinguished road
check the muffler fluid
goldenstate is offline   Reply With Quote Quick reply to this message
Old 05-18-2009, 09:23 AM   #10
5spd5gen
Brewski Turbo King
5spd5gen's Avatar
yea check that ur muffler bearings, ur halogen and blinker fluid, and if ur 2nd transmission is going bad you might lose 1st,3rd n 5th. if the wheels from the left side are on the right thats bad you better hope the front arent on the back cuz one pot hole and whamo!! all your tires will blow out, even if you only hit the hole with one tire. and for the muffler bearings go with titanium 367 bearings, and with a super rubber guard gaasket, dont forget to run the oil lines and coolant lines to keep ur muffler from over heating, and losing ur bearings cuz if u do that cylinder 3 and 4 will throw the rods and its a big mess....
__________________
Fucking Classy
Old 05-18-2009, 09:28 AM   #11
xxfallacyxx
Bearderator
xxfallacyxx's Avatar
xxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud ofxxfallacyxx has much to be proud of
Blinking oil light means something is VERY wrong with the oil pressure do not drive. Not cranking over sounds like starter problem. Start there, check fuses in engine bay etc. Updates are fundamental
__________________
Read this
J.L.D.E.P.P.M.S.3.C.N.Y.C.N.C.M.A.D
xxfallacyxx is offline   Reply With Quote Quick reply to this message
Old 05-18-2009, 01:21 PM   #12
cokinut
True Luder
cokinut's Avatar
I don't think it's the clutch, the clutch feels good and was working good the day before. I really think it's the starter. I'm at work right now and i'm going to check when I get home. Does anyone know the major ground points to check for (battery to chassis, transmission ground, engine block ground - are there any other major ones i should check for?).
I've also read that you can tap on the starter to see it "jumps" it. I'm going to try to pull out the starter tonight and bring it to a Pep boys to get tested - that or jump the starter directly from the battery to see if it cranks.
Btw, I have a 98 Type SH 5 speed.
Any info on how common the immobilizer might be a problem to starting the car?
__________________
Old 05-18-2009, 07:47 PM   #13
cokinut
True Luder
cokinut's Avatar
Just got back inside. Took a hammer, hit the starter a few times and it started working. Looks like the contacts in the starter or some internal issues were going on. I pulled it out in about 40 minutes and i'm going to get another tomorrow. I'll keep you guys posted.
__________________
Old 05-18-2009, 07:55 PM   #14
apocylypse444
True Luder
apocylypse444's Avatar
apocylypse444 has a little shameless behaviour in the past
omfg hahahaaha this kid is hilarious lol i literally shit my pants lulz.
apocylypse444 is offline   Reply With Quote Quick reply to this message
Old 05-18-2009, 09:14 PM   #15
xxfallacyxx
Bearderator
Cokinut like I said if your oil light is blinking that is really bad. Check your oil levels, and if they are ok, ask a mechanic to check your oil pressure. A blinking oil light means that oil pressure is too low, or dropped suddenly to levels below operation standards.
__________________
Read this
Old 05-18-2009, 10:17 PM   #16
goldenstate
Getting Comfortable
haha i love it
Old 05-18-2009, 10:50 PM   #17
cokinut
True Luder
cokinut's Avatar
sorry, forgot to update - when the car started, the oil light + battery light went off. just like ludeacts stated, those 2 lights come on on the on position. I feel like a newb because i've never actually paid attention to those lights when leaving the ignition in the on position. I'm going to install a new starter and see how that goes. I found it funny that you hitting the starter with a hammer actually does work. hah. Thanks for all your help.
__________________
Old 05-18-2009, 10:56 PM   #18
xxfallacyxx
Bearderator
Sometimes the internals of the starter jam up, and hitting it may loosen them. As for the oil light it's only supposed to be solid when you turn the ignition on, if it blinks i'd be suspicious of something. If your oil light blinks while driving, pull it over ASAP, seizing your engine is not something to take a chance with.
Weird, seize and weird are exceptions to the i before e rule. I knew about weird, but seize? really?
__________________
Read this
Old 05-20-2009, 02:35 PM   #19
egjdmh22a
I am Prelude
egjdmh22a's Avatar
egjdmh22a has a spectacular aura aboutegjdmh22a has a spectacular aura about
Send a message via MSN to egjdmh22a
dont forget to put a rabbits foot in the oil hole for good luck!!!!!
egjdmh22a is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
