| Register | FAQ | Insurance | Members List | Calendar |
Thread Tools | Display Modes |
#26 | |
GPS Enabled
Wait, the TL1000 is a V-twin. Where are the other two injectors going to go? Or do you have two of these?
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Yes, that really is my license plate Quote:
| Sponsored Links | |||
Advertisement | |||
#27 | |
I did a little research for you. It seems the Si tank has baffles so that the fuel doesn't slosh away from the fuel pump when going around corners when the tank isn't full. The S tank does not have these baffles. They are not needed because the carbs store fuel in the float bowls, and don't require a constant flow of gas from the tank. Fuel injection does require a constant flow in order to maintain fuel pressure. So I would conclude that you will need to replace the S tank with an Si tank.
__________________
1989 Prelude 2.0Si 4WS To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. 2006 Chevy Silverado 4x4 2002 Chevy Silverado 4x4 Quadrasteer 1978 Chevy K20 4x4 Quote:
#28 |
Lude Addict
Luzer thanks every much thats a good piece of info for me.
and about the injectors we was thinking of drilling out the S man for 4 honda SI injectors. we would have to make a custom fuel rail but thats no big deal. all the itb are for is the thrould plates (sorry about spelling not my strong point). so it lookins like a junk yard run for me. ihave to get a tank and a pump. well im gonnna be moving down to my dads house now so i might get more done in a fast time so you all can watch this work out really good im hoping
__________________
1988 Honda Prelude S B20A3 wit SI swap and also 4WS swap Next in the List: Turbocharging the A5 the make over and turbo thread of my A5 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EVERY 3rd gen'er should buy the COMETIC MLS headgasket the more the cheaper it is for everyone Hold On Not DoneAccelerating |
#29 |
Lude Addict
well guess starting to pack up for FL and cant wait to go out and get more parts for the car but is there anything else little that i might need??? i looked right over the gas tank but just hit up the thread
__________________
#30 |
Preludepower Member
http://www.preludepower.com/forums/s...ight=gas+tanks
Heres the thread about the gas tanks. Don't forget to get the return line. That will take you some time to get out. You have to yank just about everything out of the car to get to it.
__________________
88' S JDM H22A (Sleeper Mode "S") To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Check this thread out for Electrical Componets and location: Warning takes a while to load all the pictures!!!!!! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Check out this thread for my H22A start-up 12-5-08!!!! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#31 | ||
__________________
#32 |
Lude Addict
well thanks for the thread and ill keep this posted on how its going
i dont think much will happne for the next week or two because im in the middle of some stuff and trying to move to orlando to my dads but really thanks guys im sure you two will have some more help for me down the road
__________________
#33 | |
yeah luzer the tanks are different. the si has a cup that the fuel pump sits in so when you take hard corners fuel stays at the pump. the s does not because there will be enough fuel in the floats of the carbs to sustain fuel to the engine while cornering.
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. 3g baby go twin carbs! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. "if a square peg has more HP then its going in a round hole" Quote:
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. new power steering re-route kit: GB To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#34 |
Preludepower Member
man Dank, have not see you in a while. I hope the ride is running smooth.
hey Honda, If I can think of anything else, I'll post what I come up with. Good luck with the move. Make sure to clearly mark all the boxes with the Honda parts as, Fragile, breakable, glass..what ever you think will not get crushed, don't want to mess them up do you? There is no differences in the wiring going to the gas tank, both are the same for S and Si. only thing that comes to mind at the moment. To bad you don't live close to me, I have an 88' S and 88' Si tank sitting on my back porch. I would give them to you, I don't need them and an old B20A3 block with the carbs still on them. You could look at doing something even harder like running 4 carbs. That would be pretty cool, one carb per cylinder. I know i have you thinking now. good luck
__________________
#35 |
Lude Addict
ya i need a tank lol. i was thinking about doing a carb thing but thats alot of jetting i was gonna use a set of carbs off of a r1 but we found a better way but if you have a si tank i think i could make a stop on the way done to Fl
__________________
#36 |
Preludepower Member
well stop on by if you can. The tank is not going anywhere. Plus it's alread off the car so it cuts out a lot of hard work that you would have to do. PM me if you are serious. Like I said, it's yours for FREE!!!!! just make sure it get's a good home and not in a scrap heap. I might have some other goodies that you are looking for too.
__________________
#37 |
Lude Addict
alright thanks all im doin now is waiting on my dad we are driving down together
__________________
#38 |
Lude Addict
well got the micro squirt computer today its at my dads snow is stopping me from driving down to orlando
__________________
#39 | |
Preludepower Member
__________________
#40 |
Lude Addict
I KNOW i hate snow it really blowsit would be ok if michigan didnt lay salt but thats whaat kills cars here and the underside of my car looks like it came off the line yesterday
__________________
#41 |
Preludepower Member
![]() Join Date: Sep 2004
its different, it will work if done right, if your using microsquirt, go wasted spark! i would have fitted a twin cam head with itbs if i wanted them but each to their won i guess, post up some pics and a video when your done, would be interesting to see the gains too!
good luck!
__________________
don't front and never try to be what you're not Cause you can be quick, jump the candlestick, burn your back and fuck Jill on a hill, but you still ain't Jack |
#42 | |
Preludepower Member
__________________
#43 |
Lude Addict
i know how lucky i am. all the cars i work on at the career ceneter is alll rusty and i sucks. I LOVE WORKING on my lude and my brothers lude because they are both like new
__________________
#44 |
Lude Addict
gotta si pump and tank today from a friend so more things are comin together come to find out the computer i had was junk but O well i have to get one of those still its ONLY 400 dollars dam thats kill me
__________________
#45 |
Lude Addict
o ya also got the fuel lines today to
__________________
#46 |
Preludepower Member
![]() Join Date: Jun 2008
one off ftmfw the hole reason i got a lude was cus it was differnt got tired of seeing civics eveywere my first lude was a 88S i hope this works out for you i be watching
#47 | |
Preludepower Member
![]() Join Date: Apr 2007
I cant wait to see this thing run and what kind ecu are you runnin SI, standalone piggy back on pk2 ecu ???
__________________
H22 SWAP SOON To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Quote:
#48 |
Lude Addict
using a micro squirt computer so i can plug in a laptop to it and change stuff on the fly and gonna turbo it after i get it all tuned
__________________
#49 |
True Luder
Why would you turbo it AFTER you tuned it for N/A? Why not, if you're going to be using a fully tunable ECU, put yourself a tiny tune on it and ad the 3rd and 4th injectors on it and only have them kick on when in boost or half throttle? It'll run and idle on two injectors until you step on it.
__________________
1988 Honda Prelude Si 4WS (my part-out) 1989 Plymouth Horizon (DD) 1997 VW Golf GTi VR6 (DD) 1990 VW Cabriolet (DD) 1981 Toyota 4x4 Pickup (DD) 1998 Ducati 900SS (DD) ...yeah, I like to have options and drive something different every day. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#50 |
Lude Addict
thats a good idea save gas and stuff nice never thought about that
__________________
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
