DIY : Oxygen ( o2 ) sensor replacement - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 06-06-2008, 04:07 PM   #1
thefox
Getting Comfortable
thefox's Avatar
thefox is on a distinguished road
Post DIY : Oxygen ( o2 ) sensor replacement
Need 10 mm socket
Need 22mm wrench
Heat gun or blowtorch or driving for 15min
Gloves ( most needed )
2 lift ( better safe than sorry )
1hours of your time or less
Need those 2 babies ordered from sparkplugs.com for 100$ with shipping
First i went for a drive for 15min
Then lift the front right side of your car
Remove the front wheel ( not needed but better access )
Here are the 2 Oxygen ( O2 ) sensor next to your cat ( red square )
The one the right is Bank 1 sensor 1 and the one on the left is Bank 1 sensor 2.
Unplug the pin, near to your Oil Filter
Use the 22mm wrench to remove the first one closet to your motor ( counter-clockwise )
Unplug the pin for the second o2 ( close to the front right wheel )
For the second one. You'll need to remove the heat shield. Thats why you need the 10mm socket
Personally i only removed the 2 bolts in red square to get access to the O2
here they are the old ones
Make sure there is some anti-seize on the new ones( was already there )
Then install the new ones in. Make sure to tight them correctly before plug-in the pin. Because your wires will get twisted so if they aren't plugged in yet it will be easier to untwist them !!!
There is a specific amount of torque you have to apply 33ft lbs torque. But pretty much its was saying to tight them like a spark plug.
Finally unplug the Radio Fuse or unplug your battery for 30sec and start your engine.
Is just did 70km ( 43 miles ).
its smoother than it was
Better acceleration
Less black smoke when hitting vtec
Fuel saving i don't know yet
if there any details missing please let me know
thefox is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-06-2008, 04:17 PM   #2
Smitty2001
Lude Boss
Smitty2001's Avatar
Smitty2001 has a spectacular aura aboutSmitty2001 has a spectacular aura about
33 ft lbs torque on those sniffers.
Good write up man. I always thought you needed a special wrench to take those out? Ive seen 02 wrenches before (i think) Why can you use a normal one on our car?
__________________
Smitty2001 is offline   Reply With Quote Quick reply to this message
Old 06-06-2008, 06:46 PM   #3
thefox
Getting Comfortable
thefox's Avatar
thanks for the info. I really don't see why would we need a special wrench to do that. Specially the NGK were exactly the same as the ones i had. Maybe for older version i don't know.
Old 06-06-2008, 07:06 PM   #4
jonbar87
Lude Boss
jonbar87's Avatar
jonbar87 will become famous soon enough
(as for the old ones) vise grips work great
__________________
Want AMSOIL at dealer price?
jonbar87 is offline   Reply With Quote Quick reply to this message
Old 06-06-2008, 07:49 PM   #5
riversideS13
True Luder
riversideS13's Avatar
riversideS13 is on a distinguished road
bank 1 sensor just locate right in front of catalytic converter? or that is bank 2 sensor 1?
__________________
1997 Honda Prelude 5MT
riversideS13 is offline   Reply With Quote Quick reply to this message
Old 06-06-2008, 08:43 PM   #6
Crash_Control
True Luder
Crash_Control's Avatar
Crash_Control is on a distinguished road
As you go from the motor down your exhaust pipe on a 4 cyl the first O2 you come to is sensor 1 bank 1 the next one after the cat is bank 1 sensor 2
If you had a v type motor (6cyl or 8 cyl) the bank with cyl 1 in it is bank 1 and the other is bank 2 and then you would get bank 1 sensor 1 bank 2 sensor 2 before the cat
The sensor 1 is used to monitor your mixture for the ecu sensor 2 is only used to make sure the cat is doing its job.
Now as for tools you can use the wrenches or the o2 sensor socket if you get the right o2 socket ( there are several) you wouldnt have to remove the heat shield.
a 7/8 wrench also works
__________________
I liked working on Preludes so much I bought one for myself
Crash_Control is offline   Reply With Quote Quick reply to this message
Old 06-08-2008, 09:07 AM   #7
nbimprtlude20
Ludacious
nbimprtlude20's Avatar
nbimprtlude20 will become famous soon enough
Wouldn't bank 2 primary/upstream O2 sensor be considered Bank 2 sensor 1?
__________________
ASE certified...
- A1 Engine Repair
- A4 Suspension and Steering
- A5 Brakes
- A6 Electrical/Electronic systems
- A8 Engine Performance
nbimprtlude20 is offline   Reply With Quote Quick reply to this message
Old 06-08-2008, 05:56 PM   #8
BlaznHaitian
Lude Dude
BlaznHaitian's Avatar
BlaznHaitian is on a distinguished road
Would you be using the torch for loosening the bolt? Because I couldn't take mine out with just a regular wrench. What's the best way to remove them?
BlaznHaitian is offline   Reply With Quote Quick reply to this message
Old 06-08-2008, 08:47 PM   #9
nbimprtlude20
Ludacious
Yes, the torch would be to help crack the sensor loose. Yea a regular wrench works sometimes. There are special O2 sensor sockets that are nice, they basically just give you more contact surface on the sensor to turn it and you can put more muscle into it. But if you just basically can't budge it with the regular wrench as your problem then getting it hot will help.
__________________
ASE certified...
- A1 Engine Repair
- A5 Brakes
Old 06-08-2008, 09:28 PM   #10
95VTEC
Getting Comfortable
95VTEC's Avatar
95VTEC is on a distinguished road
You are correct. Also if you have a 96, 97 or 98 model Prelude with a MIL on for 02 sensor it is covered under the extended emissions warranty. 150k for 96-97 and 100k for 98s.
__________________
1995 Prelude Si-VTEC
"VTEC is for cheaters"
95VTEC is offline   Reply With Quote Quick reply to this message
Old 06-08-2008, 09:34 PM   #11
freezingcoffee
Lude Dude
freezingcoffee is on a distinguished road
thanks!!!
freezingcoffee is offline   Reply With Quote Quick reply to this message
Old 06-10-2008, 07:07 AM   #12
nbimprtlude20
Ludacious
I am anticipating having to replace my upstream O2 sensor. Though I am going to hook up my meter and force it rich and lean, check the crosscounts. Even though the car has over 100,000 miles on it, I could just replace them both and consider it maintanence
__________________
ASE certified...
- A1 Engine Repair
- A5 Brakes
Old 06-10-2008, 10:08 AM   #13
Si Speed
The Good Stuff
Si Speed's Avatar
Si Speed will become famous soon enoughSi Speed will become famous soon enough
Very user friendly guide man.
Si Speed is offline   Reply With Quote Quick reply to this message
Old 06-10-2008, 10:12 AM   #14
JLude
Idiotic Thread Locker!
JLude's Avatar
JLude is just really niceJLude is just really niceJLude is just really niceJLude is just really nice
Send a message via AIM to JLude
Good writeup!
But I must shun you for using Fram bottom line oil filters. Use Walmart's Super Tech 2000 filters...they are cheaper but MUCH better than Fram. They actually tested them to be on par with some of the high end filters like Wix, Pure-One and Mobil 1 !
__________________
Building your custom HID Projector RETROFITS since 2005! PM FOR DETAILS.
Former 5th, 4th and 3rd gen Prelude owner. Current: 2004 Toyota Tundra V8 DC 4x4, '00 Civic LX beater, '06 Yamaha FZ6S, '07 Victory Kingpin - Still a Prelude enthusiast!
JLude is offline   Reply With Quote Quick reply to this message
Old 06-11-2008, 07:00 AM   #15
thefox
Getting Comfortable
thefox's Avatar
yeah i was on a rush to change my oil filter thats why i used FRAM.
Old 06-11-2008, 07:37 AM   #16
AJ06
8====D ---> ( | ) = win
AJ06's Avatar
AJ06 is on a distinguished road
I was also about to scorn u on the Fram
__________________
The more you say it, the closer you are to getting a response of "Well my car deserves it more than you" or even worse, "My car gives me pleasure when I spend money on it..."
AJ06 is offline   Reply With Quote Quick reply to this message
Old 06-12-2008, 10:32 AM   #17
monkeyxprelude
True Luder
monkeyxprelude's Avatar
monkeyxprelude is on a distinguished road
hey, quick question bout the o2 sensors, say im trying to install gauges, and i needa tap a wire into my o2 sensor for my air\flow ratio gauge, which wire do i tap into???
monkeyxprelude is offline   Reply With Quote Quick reply to this message
Old 03-29-2009, 03:12 PM   #18
NightHawkLude
Lude Addict
NightHawkLude's Avatar
NightHawkLude is on a distinguished road
good write up, took me awhile to find this one.
NightHawkLude is offline   Reply With Quote Quick reply to this message
Old 03-29-2009, 10:48 PM   #19
TheJGB3
Ludacious
TheJGB3's Avatar
TheJGB3 will become famous soon enoughTheJGB3 will become famous soon enough
Here is a pic of an O2 sensor 22MM socket
available at Advance Auto, O'reilley's, Checker, etc.
__________________
AEM SRI & brake pads
JDM Type S frt & Megan Racing rr strut bars
OEM lip kit
OEM CF trim kit & JDM CF gauge bezel
JDM Foglights w/USDM switch
JDM Type S red-stitched seats, shift knob, steeringwheel
Clear front sidemarkers w/ Amber LED bulbs
polyurethane motor mount inserts
ASE Re-Certified Technician
Suspension and Steering (A4)
Brakes (A5)
Heating and Air Conditioning (A7)
Exhaust System Specialist (X1)
Automobile Parts Specialist (P2)
Automobile Service Consultant (C1)
TheJGB3 is offline   Reply With Quote Quick reply to this message
Old 03-30-2009, 11:03 AM   #20
Neo Moogle
Lude Dude
Neo Moogle's Avatar
Neo Moogle is on a distinguished road
I'm in the middle of doing some PM on my car. I was thinking about going ahead and replacing the o2 sensors, but there aren't any check engine codes saying that they are faulty, would it still benefit the car the change them?
__________________
2000 Prelude SH-Pearl White
Neo Moogle is offline   Reply With Quote Quick reply to this message
Old 07-13-2010, 11:00 AM   #21
petronas
Lude Dude
petronas's Avatar
petronas is on a distinguished road
Do you guys know if all Preludes with the H22A with Manual Transmission came with 2 o2 sensors? (Post and Pre Cat?).
I'm in Australia and Honda Australia tells me there is only one o2 sensor?
__________________
petronas is offline   Reply With Quote Quick reply to this message
Old 07-13-2010, 03:15 PM   #22
vtecpower20
True Luder
vtecpower20's Avatar
vtecpower20 will become famous soon enoughvtecpower20 will become famous soon enough
All the 1995 and earlier prelude models that are OBDI only have one O2 sensor. 96 and newer have 2.
vtecpower20 is offline   Reply With Quote Quick reply to this message
Old 07-13-2010, 09:23 PM   #23
coloradolude
Lude Dude
coloradolude's Avatar
coloradolude is on a distinguished road
great right up! i think i need to do this, my check engine light is on and autozone pulled the codes and said it was my o2 sensors. my spedometor is not working and my v-tech is not kicking in, my gas milage is low and it is idleing at about 400 (300) when a/c is on. im really worried and need to fix this fast. would love to do it myself and learn about more than i already know... please message me if u have some tips or pointers for me. thanks luders!!!!
coloradolude is offline   Reply With Quote Quick reply to this message
Old 07-13-2010, 09:31 PM   #24
vtecpower20
True Luder
It's pretty straight forward. Look at the pretty pictures above for reference if you can't figure it out without them. Just jack up the car, remove old sensor, put in new sensor, lower the car back down, reset the ECU, and be on your way. Took me less than 10 minutes to change mine in 20 degree weather last winter.
Old 07-13-2010, 10:00 PM   #25
petronas
Lude Dude
petronas's Avatar
Ok I found out AUDM models only have one o2 sensor, strange...
__________________
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
