Go Back   Preludepower.com > Prelude Forums > 3rd Gen
Reload this Page H22 Swap Checklist - Parts to get...
Reply
Ads By Google
Thread Tools Display Modes
Old 03-12-2008, 12:13 PM   #1
1funryd
Vendor
1funryd's Avatar
1funryd will become famous soon enough1funryd will become famous soon enough
Send a message via AIM to 1funryd Send a message via MSN to 1funryd Send a message via Yahoo to 1funryd
Exclamation H22 Swap Checklist - Parts to get...
Ok I did this for the newbies and some of us oldies as well. It is a checklist of the parts need to do the H22 basic swap. This is for the Si models only. The S models will need more work to make this swap work.
Edit: 4-1-2009
I wanted to clarify some things to those who are not aware of the weight differences between three motors since we now have a little support for the B series mounts.
Engine weights with 5 speed trannys on a palet:
  1. B20a -
    B20 at aprox 410 lbs
    auto trany installed and on a pallet.
  2. H22a -
    H22a at aprox 445lbs 5 speed trany installed on a pallet.
  3. B18 -
    B18 in his
    civic so i weighed the b18 at aprox 380 lb 5 speed tranny installed and sitting on a pallet on the scales.
*Note: The above information was taken from a member who weight out all three motors in this thread: http://www.preludepower.com/forums/s...=260249&page=3
Here are writeups that will help you on your journey with the H22 swap:
These are some original swaps, so some information is outdated, but they will help you to see what is involved.And here is a review regarding the AZ Race swap kit, and some usefull tips when installing.Parts Needed:
1. AZ Race Mounts - sold through me(1FunRyd - contact: onefunrydperformance@q.com)
2. H22 engine, tranny, engine harness, and ecu. (Deathwish thank you for posting up your swap pics for the intial AZ Race review)
3. Your stock engine harness and the H22 engine harness to be sent to www.rywire.com ask for Ryan or if you can do it yourself then that just saves you some money. The 88-89 ludes who do this swap will need the OBD1 conversion harness that rywire.com can provide for a fee.
The 90-91 ludes just plug right into the P13(H22 stock) ECU. **Edit**: 90 2.0S/90-91 2.0Si models are still OBD0 and will require you to upgrade to an OBD1 format. 90-91 Si models are OBD1.
Update Edit: Igniter wiring
originally posted by 91Owner -
hey sean
cinci filled me in on what i think could be added to the swap thread.
first my car is 91 auto b20a5 with the igniter on the shock tower. the h22a has the igniter in the distributor .i used a msd coil and connected to the stock coil wires inside the cap. not knowing i was connecting to the internal igniter started my car with both connected and it runs very ruff.
so maybe should be on the post for newcomers to only use one and disconnect the other.
when cinci mentioned this today was the first time i've read that anywhere. to a newbe like i was that is key info that would make the life of a first time swapper much easyer
gordie
Here is the link with many pictures to the Rywire H22 modified engine Harness: http://www.preludepower.com/forums/showthread.php?t=256659 - I want to Thank Teamluder123 for his contribution by organizing this for the project, thanks bro.
  • Please Call 408-715-7989 to place an order or for urgent troubleshooting.You can reach us via Email at:
    peter@rywire.com or ryan@rywire.com
    Our mailing address is:
    Rywire
    1177 Fargate Circle
    San Jose, CA 95131
4. The 92-96 Prelude shifter assenbly and linkage for proper shifting.
Other Honda Models for the shift assembly:
Shifter boxes and cables.... You need either 92-96 Prelude shifter box AND cables, 90-96 Accord shifter box AND cables or 97-2001 Prelude shifter box and Cables.
Here is another thread that will show the typical issues when swapping shift linkage and which ones to use:
***Help with H22 Shifter Linkage
Pimpstecy ***
5. The 90-91 Preludes have an electronic VSS speed sensor so no need to do anything except plug it in. **The 88-89 Preludes have to take off the electroninc part of the VSS on the H22 tranny and use the clip that secures the speedometer cable to the 88-89 VSS. Here is picture of the 90-91 VSS which is the same as the H22 VSS **Note for the 88-89 luders I would recommend keeping the rubber boot that comes stock on your old VSS so you can swap it on to the H22 VSS:
Update 8-30-2009: Here is how the 88-89 swapped ludes need to secure the Speedo cable to make your speedometer work. This does not solve the signal need to make the VTEC solenoid kick on, but it will solve the speedometer issue. For those who will be going P28 and have the VTEC programmed by RPM then you will not have to worry about not getting VTEC.
*I am going to try and have a special bracket made and sell it so all 88-89 H22 swappers can still have their speedometers working.
6. A modified Radius Rod for lowered ludes so the radius rod will clear the crank pulley. Or you can swap the crank pulley out for an aftermarket aluminum one which is smaller.
Edit 4-16-09: AZ Race is producing a traction bar that will clear the crank pulley and clear the AC pump.
7. In order to keep the A/C you will need to modify the ac lines from an shop that can make custom ones. And you will need to get some longer bolt that fit the front crossmember to accomodate 3" worth of washers used to space out the front cross memeber. This will allow room for the H22 compressor to fit down below. It will however lower the front crossmember. (I want to thank Osvoldo516 for his contribution to this information - )
8. Powersteering can be kept as well, you will need the have the H22 bracket and your preludes hardline from the sensor to the rack sent to me to be fabricated to work properly in the swap.
Here is the H22 bracket I need to make it work (Thank you Tmoney for your contribution into solving the powersteering issue - ):
9. Axles can be done through Gator axles or Raxles.com. Give Marty a call at raxles.com and he will tell you the specs. Call Glen at Gator axles as well.
Edit: 3-29-2009
Another cheaper option that has been done, is to use the stock: 90-93 Accord axles for the swap. This has been done by B20luda and a few other members and they said no modification needs to be done.
*Note: this is only for the 90-91 Preludes, the 88-89 will need to change their hubs to 90-91 hubs.
90-91 28 spline count hubs.. Or if not, then purchase Raxles.com axles.
The choice is yours. Here is an example of Raxles work. (Edit) I forgot to mention that the recommendation for upgrading the hubs to the 90-91 Hubs due to it having 28 spline count, the 88-89 Preludes have only 26 spline count. It is not necessary but was recommended by Gator axles due to the increase in power:
Installed on Osvlado516's lude:
10. There is a High Recommendation to change out the auto belt tentioner to a manual one due the the faliure rate of the auto one. Here is the writeup link below(A big Thank You to 98Vtec for his write-up):
How to: H22 Auto Belt Tensioner conversion to H23 Manual Belt Tensioner
H22 Auto:
H23 Manual:
H22 Timing Belt Replacement Write-up: (Clik Here)
11. I forgot to state that you need the Rear Engine bracket from the 4th or 5th gen Prelude, some H22's swaps are sold with Accord rear brackets. It is important that you note this down or AZ Races' rear engine mount will not fit.
12. Clutch Swap for the H22 swap:
How to use the stock slave cylinder hose for H22 Swap
osvaldo516
This thread will continue to get updates as necessary. I welcome all input for this swap as there are many ways to do things. I know this will help a lot of people who are deciding whether they want to do this or not.
Enjoy!!
**Note: This will be in the Stickies under the --**3rd Gen Performance Upgrade Inventory**--
And for those who would like to see where it all began here is the Second part of the Original AZ Race H22 Project thread: I want to thank some of the background guys who gave their insight and advice and own experience for this project to come together. I thank you!
  • DeadEnd
  • JTCDudeman
  • DailyInterluder
  • AZ RACE & Adam - You guys are amazing!
And last but not least, I want to thank all the intial group buy members who trusted me with this immense project and their money to bring our cars to a level respect it and we deserved!
Lude on brothers & sisters Lude on!!!
3GP Aftermarket Specialist,
Sean
Email: onefunrydperformance@q.com
__________________
Sean
H22 Project Manager
(Clik Here)
Members: Danny_19 - 1FunRyd(H23 swapped) - B20luda
3rd Gen Prelude Owners are Rare Breed of Enthusiast's!!! (originally posted by: RED89si)
1funryd is offline   Reply With Quote
Old 03-12-2008, 12:20 PM   #2
GUESSMAN
Preludepower Member
GUESSMAN's Avatar
GUESSMAN is on a distinguished road
Sweet!!!! Sean, thanks for all of this important info. This should help everyone with the swap.
Thanks for the info on the shifter cables too.
__________________
88' S JDM H22A (Sleeper Mode "S")
Check this thread out for Electrical Componets and location: Warning takes a while to load all the pictures!!!!!!
Check out this thread for my H22A start-up 12-5-08!!!!
GUESSMAN is offline   Reply With Quote
Old 03-12-2008, 12:24 PM   #3
1funryd
Vendor
1funryd's Avatar
Always here to help when I can. I felt its time to start organizing everyones projects and put it all in one place and update it as necessary. That way it cuts down on unecessary threads and posts. It wont eliminate it but it should help cut down some.
Now when someone pulls a search they should get this thread.
__________________
Sean
H22 Project Manager
(Clik Here)
Old 03-12-2008, 12:29 PM   #4
johcamp
Preludepower Member
johcamp's Avatar
johcamp is on a distinguished road
Nice sean. This is very informative. When i get my turbo'd lude done and sell my house an h22 is going into the beater. This will be a good reference for me!!!
Thanks!
__________________
- John
1988 2.0 si - Turbo Build
1991 2.1 si - Beater
1988 2.0si part out here:
Go Here
to check out my ride.
My 3rd gen Build Thread:
SEARCH - does a body good
johcamp is offline   Reply With Quote
Old 03-12-2008, 12:44 PM   #5
Mephastapholes
Lude Dude
Mephastapholes's Avatar
Mephastapholes is on a distinguished road
Send a message via AIM to Mephastapholes
Got a recommendation for which after market pulley to use? I really like Unorthodox racing's stuff.
__________________
Who wants to come over and help me put in my H22??
Mephastapholes is offline   Reply With Quote
Old 03-12-2008, 12:48 PM   #6
1funryd
Vendor
1funryd's Avatar
That will be up to you, almost all H22 aftermaket stuff can be installed on the motor. Except the super charger system, I dont believe we have enough clearance for all the bracketry and pulley system. This has not been tried yet.
But all turbo kits will fit with some minor modding for the charge piping in the front of the engine.
__________________
Sean
H22 Project Manager
(Clik Here)
Old 03-12-2008, 01:08 PM   #7
89SIracer
Lude Dude
89SIracer's Avatar
89SIracer is an unknown quantity at this point
awesome thread. my only question is, how much would it cost 2 swap minus motor/tranny cost, no ac, w/ ps, and sending out harness?
89SIracer is offline   Reply With Quote
Old 03-12-2008, 01:20 PM   #8
1funryd
Vendor
1funryd's Avatar
That is a question only you can answer. There are no prices on this thread because we all have different hook ups and ways to get parts for different prices. And prices change to reflect cost increases.
I only provided the checklist, you will need to do the search for the motor package and wiring, axles and so forth. Just get in contact with rywire.com for the harness work. Nothing is set in stone as far as prices go.
__________________
Sean
H22 Project Manager
(Clik Here)
Old 03-12-2008, 01:27 PM   #9
GUESSMAN
Preludepower Member
GUESSMAN's Avatar
One more question.
Since my 88 S didn't have Cruise Control, I didn't bother reading anything about being able to keep it.
My question is, do you have to do anything special to still be able to use it with the swap?
__________________
Old 03-12-2008, 01:31 PM   #10
1funryd
Vendor
1funryd's Avatar
One more question.
I would consult with the online manual on that, because there are quite a few connections to make it all work.
I am not sure how what you need to do to make a non cruise control model work with a cruise control one.
__________________
Sean
H22 Project Manager
(Clik Here)
Old 03-12-2008, 01:36 PM   #11
Dark_star_Raceing
True Luder
Dark_star_Raceing's Avatar
Dark_star_Raceing is on a distinguished road
Awesome Sean,Glad to see this on here!
__________________
Thats Dark_star_Race_ING
Dark_star_Raceing is offline   Reply With Quote
Old 03-12-2008, 01:44 PM   #12
GUESSMAN
Preludepower Member
GUESSMAN's Avatar
It's cool. Sorry about being a newbie. I'll just look my other Lude over really good because it has cruise on it.
I just didn't know if I was going to be able to keep cruise (if I had it) with a H22A swap.
Thanks again Sean
__________________
Old 03-12-2008, 04:56 PM   #13
blahblah311
Donating Member
blahblah311's Avatar
blahblah311 will become famous soon enough
Prelude of the Month
you da man 1funryd
__________________
91 Prelude
00 Accord
blahblah311 is offline   Reply With Quote
Old 03-12-2008, 06:13 PM   #14
osvaldo516
Donating Member
osvaldo516's Avatar
osvaldo516 is on a distinguished road
Awesome!!!!!
osvaldo516 is offline   Reply With Quote
Old 03-12-2008, 06:45 PM   #15
TheMachinist
Newbie
TheMachinist's Avatar
TheMachinist is on a distinguished road
Nice write up Sean. Your like the king of prelude information.
TheMachinist is offline   Reply With Quote
Old 03-12-2008, 06:47 PM   #16
1funryd
Vendor
1funryd's Avatar
Tanx guys! And I will keep updating it as information comes along.
__________________
Sean
H22 Project Manager
(Clik Here)
Old 03-12-2008, 06:54 PM   #17
team123luder
Elite Member
team123luder's Avatar
team123luder has a spectacular aura aboutteam123luder has a spectacular aura aboutteam123luder has a spectacular aura about
Send a message via AIM to team123luder Send a message via MSN to team123luder
You need to update the information.
__________________
FOR SALE!!!!
team123luder is offline   Reply With Quote
Old 03-12-2008, 07:00 PM   #18
1funryd
Vendor
1funryd's Avatar
Tanx you Mario, "It has begun....(Mortal Combat!!)"
__________________
Sean
H22 Project Manager
(Clik Here)
Old 03-12-2008, 07:35 PM   #19
Gargoyle24
Preludepower Member
Gargoyle24's Avatar
Gargoyle24 is on a distinguished road
are the same parts needed for all versions of the h22?
__________________
---88 2.0Si---
B20A5
359,175km (222,690mi) lude is running again, got a new car too, and a new job, so all i need now is the space to work and a gf that'll let me
"The value of life can be measured by how many times your soul has been deeply stirred." -Soichiro Honda-
"I want the Prelude to run like a German machine... But I want it to have feel, like an Italian car." -Takeomi Miyoshi, Honda Prelude 3G project leader.
Gargoyle24 is offline   Reply With Quote
Old 03-12-2008, 09:03 PM   #20
danny_d19
Fuuuuuuuuuuuuuuuuu
danny_d19's Avatar
danny_d19 is just really nicedanny_d19 is just really nicedanny_d19 is just really nicedanny_d19 is just really nicedanny_d19 is just really nice
It's about time you put this together
lol Nice work as usual Sean
__________________
danny_d19 is offline   Reply With Quote
Old 03-12-2008, 09:07 PM   #21
team123luder
Elite Member
This is for an OBD1 H22 swap ONLY!
__________________
FOR SALE!!!!
Old 03-12-2008, 09:31 PM   #22
jlude90
Preludepower Member
jlude90 will become famous soon enough
carb to H22 is an absolute bitch i think it should be noted, i would HIGHLY recommend putting the Si interior harness in first, unless you are VERY VERY good at wiring or want to pay through the nose if you don't have a hookup
but with the Si wiring its a cinch
__________________
Originally Posted by 98VTEC
Its a bunch of fruitcakes in a pie that doesnt mix, with no baking experience.
jlude90 is offline   Reply With Quote
Old 03-12-2008, 09:52 PM   #23
BoostJunkie
Preludepower Member
BoostJunkie's Avatar
BoostJunkie is on a distinguished road
you gonna throw anything out there about the hubs?
i believe i remember reading that you said to use the 90-91 hubs because they were stronger than the 88-89 hubs.
i suppose you dont have to. but it should be noted.
BoostJunkie is offline   Reply With Quote
Old 03-12-2008, 10:41 PM   #24
90preludeLad
i g0t, y0u w4nT...
90preludeLad's Avatar
90preludeLad is on a distinguished road
this is perfect. thanks a lot sean. i will deffinetly be using this someday.
__________________
-andrew
Check Out My
and
Photoshoots (not for the 56k luders
90preludeLad is offline   Reply With Quote
Old 03-12-2008, 11:18 PM   #25
1funryd
Vendor
1funryd's Avatar
It has been added.
And I want to thank all of you for the support of this thread.
Because I know eventually half of the luders on here will want to swap to the H22 due to the availability of parts and engines. Well at least in theory.
I was waiting for as much information as possible to gather, and I was a little swamped with some other projects as well.
Sean
__________________
Sean
H22 Project Manager
(Clik Here)
Reply
Bookmarks
  • Submit Thread to Digg Digg
  • Ads By Google
    Search Cloud
    2010 honda prelude 3rd gen prelude 4th gen prelude 5th gen prelude 5th generation prelude 6th gen prelude b21a1 car motivational posters convertible prelude dashboard paint edge2lyfe view profile floor jack reviews funny things to text your girlfriend h22 cams h22 manual tensioner conversion h22a4 h22a4 specs h23 vtec h23a vtec honda prelude 2010 honda prelude 5th gen how to text your girlfriend hp259 hp259 tire individual throttle bodies k1 attack for sale k20 prelude nice things to say to your girlfriend in a text nice things to text your girlfriend nitto neo gen reviews pcv valve symptoms power prelude prelude prelude convertible prelude forum prelude forums prelude power preludepower preludepower.com projector retrofit racing hart cp-035 rattle can paint job song suggester sweet things to say to your girlfriend in a text sweet things to say to your girlfriend over text sweet things to text your girlfriend things to text about things to text your girlfriend what to text your girlfriend www.preludepower.com
    Thread Tools
    Display Modes
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Forum Jump
    KickItBack = Cash Back
    Google
    vB.Sponsors
    PreludePower Forums
