Nena's h23 vtec/turbo build :) - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 03-08-2008, 10:35 PM   #1
nenalokey
Lude Addict
nenalokey's Avatar
nenalokey is on a distinguished road
Send a message via AIM to nenalokey Send a message via MSN to nenalokey Send a message via Yahoo to nenalokey
So the time has come i can actually show you My project car. I'm going to keep this thread to keep you updated on how i fix my body and the outcome of my prelude!
3/09/2008
So today we went to go see if the f22 in my project lude was any good. To see if we can get it running, instead of having a totally dead car. and also to remove a/c and i was going to remove seats and do some covering of holes. and well this is what i found.
This was found on the bottom of the block in the middle, when we were draining the oil.
So we decied to take the head off and see what happened.
took out a/c and removed the radiator for now. Also removed the battery thingy since i'll be placing it in the back.
surprise number 2
covering up the hole so i don't get water inside...I need a glass sunroof asap
and more pics of my Baby
ENGINE:
As the title says I'm Building a h23vtec I plan on also boosting it.
What i have begun with shoof is giving me a h23 block that needs build. No pictures of it yet. I'm planning on put mahle pistons, mainley rods and such...
and i just purchased this.
Things i need to finish this.
H23 block [x]
H22 head [x]
Oil Pan [x] Gasket [ ]
Main bearings, rod bearing and thrust washers by ACL [ ]
Cranshaft oil seal [ ]
Oil pump [ ]
Pistons (turbo ones), piston rings and piston pin [ ]
Eagles rods (turbo) [ ]
water pump and timing belt [ ]
h22 head gasket [ ]
cleaning honing and boring the block [ ]
skunk 2 manifold [ ]
This list still doesn't included what i wanna get for the head.
I also need everything for a manual conversion.
Transmission [ ]
flywheel [ ]
clutch assembly
slave clynider and clutch master cylinder [ ]
starter 4 manual [ ]
driver side cv shfat and intermiate shaft [ ]
tranmission mount and braket [ ]
vss [ ]
shifter cable and holding pins [ ]
clevis pin and cotter pins [ ]
shifter cable bracket [ ]
shifter assembly [ ]
shift knob and boot [ ]
clutch pedal [ ]
both switches for clutch and their pug in connector [ ]
30 amp relay [ ]
and all bolts
It's going to get cleaned and check in my boy's shop in georgia in easter. this is my progress as of right now...
3/20/08
SO today i Towed her to where I'm staying. You can say my house now. Pulled everything out of the trunk and gutted all the side panels and shit out of there. I have a serious leaking problem...I so need to duct tape my tail light untill i can get the body work done. Is there another temp way around this untill i can get it fixed? I kinda washed her up a bit. But tommorow and this weekend I'll get into serious cleaning and the gutting out. I'm also hoping i can finish pulling out this piece of shit engine. I did manage to get the head off. BUT i can't lift it off by myself i need more clearance. I also did paint on of my valve covers. It's not done but I love the color!!!! Pretty much all i can think of. Here some pics!
Sorry i can't find my camera ...i got shitty cam pics...
3/21/08
Some more gutting and cleaning and a nice wash...
3/31/2008
sooooo...i sold the car. Yes i know...but i ran into another 4th gen that's so much prettier... and it is stick ready so i don't have do make it manual. I thought it would be cheaper that way. i was gonna make this into my DD. But i don
t need two broke down ludes sitting at my house for a month.
4/14/2008
SO... I just picked up my prelude!!! she beautiful...Expect for some ricerness....H23 Tranny in it already...and a f22b. I need a sunroof soon...and some work but this will be a faster build now i hope. The block will be in the shop getting sleeved in may.
Also i already started pulling shit out of it. alernator and cruise control are mostly out...I need a hoist and a new jack.
4/21/2008
Well i did some new work to the lude took off the head and such and did some "body work"
__________________
Current: 1989 Prelude Si *non-running*
1994 Prelude Si*Project* SOLD
1994 Prelude S SOLD
1997 Prelude base SOLD
1993 Prelude SI *GONE*
Team Lady Fuel
nenalokey is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-08-2008, 10:39 PM   #2
team123luder
Elite Member
team123luder's Avatar
team123luder has a spectacular aura aboutteam123luder has a spectacular aura aboutteam123luder has a spectacular aura about
Send a message via AIM to team123luder Send a message via MSN to team123luder
Prelude of the Month
Good luck and I hope you reach your goal... VTEC + BOOST = sex
__________________
SOLD!!!
team123luder is offline   Reply With Quote Quick reply to this message
Old 03-08-2008, 10:43 PM   #3
jdawgs92ludesi
Ludacious
jdawgs92ludesi is on a distinguished road
Send a message via AIM to jdawgs92ludesi Send a message via Yahoo to jdawgs92ludesi
def. keep us updated. this looks like a great project.
__________________
^^thanks Prelude85
92 prelude si
95 talon tsi- sold
07 scion tc
jdawgs92ludesi is offline   Reply With Quote Quick reply to this message
Old 03-08-2008, 10:47 PM   #4
BERTMAN
Lude Cray
BERTMAN's Avatar
BERTMAN is on a distinguished road
Send a message via AIM to BERTMAN
that car is almost a lost cause.
on top of a lot of engine work... you have a TON of cosmetic work.
i wish u best of luck.
subscribed
__________________
STi
BERTMAN is offline   Reply With Quote Quick reply to this message
Old 03-08-2008, 11:01 PM   #5
lagunabluelude
Lude Dude
lagunabluelude's Avatar
lagunabluelude is on a distinguished road
good luck
__________________
lagunabluelude is offline   Reply With Quote Quick reply to this message
Old 03-08-2008, 11:01 PM   #6
nenalokey
Lude Addict
nenalokey's Avatar
Yeah i know. I really didn't think it was that much work...untill i saw it today. But bright side is...i was going to replace the sunroof anyways. i can get the whole body fix for 500. I love knowing people.
and the car only cost me 300.
I'm in no hurry to get it running yet.
I rather fix it then see another lude go for scrap parts.
__________________
1994 Prelude S SOLD
Team Lady Fuel
Old 03-09-2008, 06:15 AM   #7
Breaking Point
I am Prelude
Breaking Point's Avatar
Breaking Point will become famous soon enough
Send a message via AIM to Breaking Point
Thumbs up
awsome! yea this is going to be a sweet project & im glad to see that it isnt in the scrap yard!, go for the gold bro, make it look good to!
subscribed!
__________________
rep me if ive helped you
on a long road to building...
Mackie,Me,Drae09-ludeboy,guy jason who showed at that meet, and 01ludechik
Breaking Point is offline   Reply With Quote Quick reply to this message
Old 03-09-2008, 10:43 AM   #8
nenalokey
Lude Addict
nenalokey's Avatar
I'm a girl
__________________
1994 Prelude S SOLD
Team Lady Fuel
Old 03-09-2008, 11:21 AM   #9
Prudz_lude
U Aware?
Prudz_lude's Avatar
Prudz_lude is a splendid one to beholdPrudz_lude is a splendid one to beholdPrudz_lude is a splendid one to beholdPrudz_lude is a splendid one to beholdPrudz_lude is a splendid one to beholdPrudz_lude is a splendid one to beholdPrudz_lude is a splendid one to beholdPrudz_lude is a splendid one to behold
good luck. those blue ludes always seem to find themselves h23vtec's hahaha
__________________
BB Squad #23 (v.2)
Prudz_lude is offline   Reply With Quote Quick reply to this message
Old 03-09-2008, 11:42 AM   #10
Si Speed
The Good Stuff
Si Speed's Avatar
Si Speed will become famous soon enoughSi Speed will become famous soon enough
subscribed!
No matter how hard it may be to believe, it's a she.
Si Speed is offline   Reply With Quote Quick reply to this message
Old 03-09-2008, 11:52 AM   #11
neonxiii
Prelude Aficionado
neonxiii's Avatar
neonxiii has a brilliant futureneonxiii has a brilliant futureneonxiii has a brilliant futureneonxiii has a brilliant futureneonxiii has a brilliant futureneonxiii has a brilliant futureneonxiii has a brilliant futureneonxiii has a brilliant futureneonxiii has a brilliant futureneonxiii has a brilliant futureneonxiii has a brilliant future
be careful nena, you really took a jump in the deep end here.
I have interior stuff that is in mint condition whenever ur ready (front/rear seats, sex blocker and black rug)
__________________
neonxiii is offline   Reply With Quote Quick reply to this message
Old 03-09-2008, 12:08 PM   #12
nenalokey
Lude Addict
nenalokey's Avatar
I have really been looking this up and searching it. And i have a ton of help so i should be good. If anything well i'll just start over.
__________________
1994 Prelude S SOLD
Team Lady Fuel
Old 03-09-2008, 01:04 PM   #13
acidcrakker
Back 2 Hackin
acidcrakker's Avatar
acidcrakker has a spectacular aura aboutacidcrakker has a spectacular aura aboutacidcrakker has a spectacular aura about
Wow GL
Was that car pushed off a cliff into a ditch
__________________
Honda prelude, since 1992
acidcrakker is offline   Reply With Quote Quick reply to this message
Old 03-09-2008, 01:14 PM   #14
Breaking Point
I am Prelude
aw , im sorry, i didnt know ...i just assumed....but i think thats even cooler! where im from its unheard of for a girl to be into cars unless" its cute" or watevr thats all that matters...but you never the less are taking on an intense project & i think you are crazy, but give u props & cant wait till your dun...keep us updated!
__________________
Old 03-09-2008, 10:47 PM   #15
bb4_bkh
Ludacious
bb4_bkh's Avatar
bb4_bkh is on a distinguished road
Send a message via AIM to bb4_bkh Send a message via MSN to bb4_bkh
indeed she is of the female population. cool, car knowledgeable, female population which didn't buy my h22 head but, seeing the project car for once, you have your work cut out for you lol. def keep us updated, looks like a good setup so far..lots o' $$$. and that primer car in the back would be your boyfriend's that you have talked about before? aim'd about interior
__________________
-92 Prelude S. H22A Swapped, 7psi - 130mph guardrail
-95 Prelude VTEC H22A swapped - D.D. 183whp/158tq. SOLD
-96 Prelude VTEC - H22A, project, needs paint, close to starting.
-2007 Suzuki RM-Z250. Weekend Whip.
bb4_bkh is offline   Reply With Quote Quick reply to this message
Old 03-09-2008, 11:03 PM   #16
BB4_
Lude Boss
BB4_'s Avatar
BB4_ will become famous soon enough
Send a message via AIM to BB4_
Great project. Good Luck.
Subscribed
You will be Female #2 to build an H23VTEC motor on this forum.
http://www.preludepower.com/forums/s...d.php?t=239601
^^Alot of good info still in her thread. (most pics are down though )
__________________
III M3
BB4_ is offline   Reply With Quote Quick reply to this message
Old 03-09-2008, 11:14 PM   #17
nenalokey
Lude Addict
nenalokey's Avatar
yes i know i saw her thread but i will be the first female to boost it!!!!!
__________________
1994 Prelude S SOLD
Team Lady Fuel
Old 03-09-2008, 11:20 PM   #18
Silvia
Oh Gee
Silvia's Avatar
Silvia is on a distinguished road
wow.. that lude sucks..
jk.. great project car for only 300 bucks..
Silvia is offline   Reply With Quote Quick reply to this message
Old 03-10-2008, 01:52 AM   #19
LUDE_4_LIFE
I am Prelude
LUDE_4_LIFE's Avatar
LUDE_4_LIFE will become famous soon enoughLUDE_4_LIFE will become famous soon enough
Wow, that prelude has seen better days. Good luck with your build.
__________________
1992 Honda Prelude SR H22A - SOLD
366WHP 300WTQ 11PSI ON A DYNOJET
2011 ZX-10R - 8.9 @156mph Mcintosh Swingarm, BST Carbon Fibre Rims, Guhl Flash, R77D Yosh, BMC, Bazzaz, 176whp
2008 GSX-R 750, R77 Yosh, PC5, K&N, -1, 131whp
LUDE_4_LIFE is offline   Reply With Quote Quick reply to this message
Old 03-10-2008, 02:31 PM   #20
lude_lover
Lude Cray
lude_lover's Avatar
lude_lover is on a distinguished road
Whats with girls and h23vtec? lol
__________________
My Build Thread
[CENTER]
lude_lover is offline   Reply With Quote Quick reply to this message
Old 03-10-2008, 02:52 PM   #21
nenalokey
Lude Addict
nenalokey's Avatar
Because...i dunno it's really what i want. Like i think it's perfect. I love the challenge. and my lude is a hot mess but i love it. I'm actually looking to get another 4th or 5th gen as a dd in about 3 mths.
__________________
1994 Prelude S SOLD
Team Lady Fuel
Old 03-12-2008, 04:43 PM   #22
Papadel
Newbie
Papadel's Avatar
Papadel is on a distinguished road
Congrats on the H23 vtec.
Papadel is offline   Reply With Quote Quick reply to this message
Old 03-17-2008, 09:31 AM   #23
nenalokey
Lude Addict
nenalokey's Avatar
I'm so bored and I'm waiting untill april to go pick up my block...So i've decied to paint my valve cover! Pink and green!
__________________
1994 Prelude S SOLD
Team Lady Fuel
Old 03-17-2008, 09:55 AM   #24
neonxiii
Prelude Aficionado
neonxiii's Avatar
i really hope you get this professionally done.
__________________
Old 03-17-2008, 10:32 AM   #25
nenalokey
Lude Addict
nenalokey's Avatar
Nope. I'm doing it myself!!! This is my extra valve cover and I'm picking out my design.
__________________
1994 Prelude S SOLD
Team Lady Fuel
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
