Go Back   Preludepower.com > Prelude Forums > 3rd Gen
Reload this Page S and Si fuel tank differences
Reply
Ads By Google
Thread Tools Display Modes
Old 03-06-2008, 12:12 PM   #1
SquishyPanda
Preludepower Member
SquishyPanda's Avatar
SquishyPanda has disabled reputation
So I was pondering my fuel pump issue, wherein I lose fuel pressure during left turns at a little over half tank (120 miles or so), and I lose pressure during acceleration, too, at a little under half tank (after 200 miles).
Is it possible that the S tank (which I didn't bother to switch out during my engine swap) has no baffles in the tank, since the float bowls act as a reserve in case fuel sloshes away from the pump pickup? Does the Si tank have baffles? I want to go look, but I'm really nervous about sitting on top of a big open container of gasoline while it's starting to get warm outside.
If there are no baffles in the S tank, then I'm just hosed and have to continue putting up with refilling the tank every 150 miles. If there are baffles, then I goofed something up installing the pump (though I re-adjusted it twice since I discovered the problem 2 days after the swap) and I can fix it.
__________________
Red Panda
v1.0: Original B20A3
v2.0: B20A5
v2.5: Rebuilt B20A5 (Pretty much done. Idles funny, but runs and drives pretty OK.)
v3.0: Under Construction
Watches, Cameras and Cars. Boys never outgrow their toys. We just find more expensive ones to play with.
SquishyPanda is offline   Reply With Quote
Old 03-06-2008, 12:19 PM   #2
GUESSMAN
Preludepower Member
GUESSMAN's Avatar
GUESSMAN is on a distinguished road
I still have the 91' Si tank sitting on my back porch and I can look in it when I get home from work and try to see if there are any baffles in it. My S tank is still on my car so I can't help you there. Sorry.
__________________
88' S JDM H22A (Sleeper Mode "S")
Check this thread out for Electrical Componets and location: Warning takes a while to load all the pictures!!!!!!
Check out this thread for my H22A start-up 12-5-08!!!!
GUESSMAN is offline   Reply With Quote
Old 03-06-2008, 12:28 PM   #3
SquishyPanda
Preludepower Member
Cool thanks. You still have the carb motor in your S, though right? So you haven't had fuel pressure issues during corners?
__________________
Red Panda
v2.0: B20A5
Old 03-06-2008, 12:32 PM   #4
GUESSMAN
Preludepower Member
GUESSMAN's Avatar
No, I yanked the S motor out last summer. It was having all kinds of problems but that was not one of them. Idle problems is what I was having, but I just figured it was those pain in the ass carbs. Sorry man, I'm not much help there.
__________________
Old 03-06-2008, 12:33 PM   #5
preludegofast13
Preludepower Member
preludegofast13's Avatar
preludegofast13 is on a distinguished road
Prelude of the Month
IT does maintain fuel pressure with a full tank, or does it still drop?
__________________
-Bryan
preludegofast13 is offline   Reply With Quote
Old 03-06-2008, 02:53 PM   #6
GUESSMAN
Preludepower Member
GUESSMAN's Avatar
I took the fuel pump out of my 91' Si tank and looked in there and I see where the fuel pump sits down into some sort of baffle. Just to let to know what I saw.
__________________
Old 03-06-2008, 03:44 PM   #7
SquishyPanda
Preludepower Member
Everything is fine from full all the way down to almost half tank (about 120 miles on the odo). Then it starts cutting out on really hard left turns. Then as I use more fuel, it's more sensitive, as in it takes less lateral G's to cause it to cut out. The motor doesn't stall, so I guess it's getting some fuel, but it just bogs. When I get down to the 200 mile mark (usually just under half-tank) the problem starts showing up under hard 1st and 2nd gear acceleration. By 240 miles on the odo, it does it on the freeway in 5th gear if I stomp on it. If I roll into the gas, it's fine, since I'm not triggering the acceleration enrichment, I guess.
It never happens under hard braking or right turns, though, presumably because the pump is mounted forward and on the left side of the tank. I don't know if this is reversed for RHD preludes.
I originally thought that I had put just put the pump too high up on the bracket, but when I was at work this morning I was pondering opening the tank again when I got home. Somewhere in the train of thought the baffles idea came up and now it seems to make a lot of sense.
I've replaced the fuel pump before while the motor was still carbureted. The FI pump is the same size, and I'm still using the carbed bracket (modified to house a return line) in the carbed tank. Nothing really changed except the guts of the pump. It's not likely that I messed it up, especially since I opened it up to mess with it once already since the swap.
__________________
Red Panda
v2.0: B20A5
Old 03-06-2008, 05:41 PM   #8
jlude90
Preludepower Member
jlude90 will become famous soon enough
so, did you change over to a high pressure pump?
i'm assuming you did. but i just have to ask
i never had this problem in my S, and i'm pretty sure the part numbers are all the same for all models, but i'll check
EDIT: well smack my ass and call me sally, they are different
damn, not you have me worrying...dammit
__________________
Originally Posted by 98VTEC
Its a bunch of fruitcakes in a pie that doesnt mix, with no baking experience.
jlude90 is offline   Reply With Quote
Old 03-06-2008, 05:48 PM   #9
SquishyPanda
Preludepower Member
I do have an Si pump in the tank. Everything is hunkey-dorey until I get to that half-tank mark.
__________________
Red Panda
v2.0: B20A5
Old 03-06-2008, 05:56 PM   #10
jlude90
Preludepower Member
damn dude, that sucks, i guess i'll have to see what happens when i get down there
how can you tell this is happening?
does the engine start to die out or what?
can you actually tell its losing pressure or how do you know?
__________________
Old 03-06-2008, 06:24 PM   #11
SquishyPanda
Preludepower Member
the motor bogs but doesn't stall. It follows a pattern that makes sense with fuel sloshing away from the pump pickup (problem only appears during left turns and acceleration, starts at half tank).
The only variables at work are inertia and fuel level. I put my Sherlock Holmes hat on and deduced it, Watson.
__________________
Red Panda
v2.0: B20A5
Old 03-07-2008, 01:26 AM   #12
tweety-lude
Newbie
tweety-lude is on a distinguished road
Send a message via MSN to tweety-lude
fuel tank
Hi, I have 4 Prelude in pieces and one I use. My husband try to put a new fuel tank but inside was not the same than the original. In my 4 Prelude, I have "S" and "SI". I use an "SI". So the fuel tank for "S" and SI" are not same. The fuel pump doesn't go deep anough in the "S" model. I hope you understand me ...
tweety-lude is offline   Reply With Quote
Old 03-07-2008, 01:35 AM   #13
tsiah
no mo mod
tsiah's Avatar
tsiah will become famous soon enoughtsiah will become famous soon enough
metal man had to swap tanks on his S>Si conversion...
the car would die at "1/2" tank (I say "1/2" because he'd only driven ~80 miles and the gauge read half...) after we swapped the tank over, no more problems with the fuel level reading incorrect or the car dying after 80 miles of driving
__________________
-Tyler
Try Honesty
Happy Owners Never Drive Anything else
Ask for a new stranger? Tell them your's is defective, it's stuck in the on position.
tsiah is offline   Reply With Quote
Old 03-07-2008, 08:43 AM   #14
jlude90
Preludepower Member
crap
__________________
Old 03-07-2008, 10:45 AM   #15
project88si
Newbie
project88si's Avatar
project88si is on a distinguished road
Send a message via AIM to project88si
i had the same problem with my swap for a while i just kept it above half a tank but i think its because i think the carb fuel pump bracket is straight and the fi fuel pump bracket is bent and doesnt make it to the bottom of the tank
project88si is offline   Reply With Quote
Old 03-07-2008, 01:40 PM   #16
SquishyPanda
Preludepower Member
Hmm... guess I'll just put up with it for now, then. I'm pretty sure it's not a depth issue, though, because I'm using an S bracket in an S tank. The bracket is curved and a pain in the balls to snake in. But apparently there are differences all around. Maybe some combination of goofy shit I did to put this car together just isn't working.
When I've got some money (someday) I'll keep an eye out for a 3g Si part-out and pick up the tank and bracket.
__________________
Red Panda
v2.0: B20A5
Old 03-07-2008, 05:23 PM   #17
jlude90
Preludepower Member
yeah, my Si pump was an absolute bitch to get in but i got it, so i figured i was golden
__________________
Old 03-08-2008, 09:30 AM   #18
tricken
Preludepower Member
tricken's Avatar
tricken is on a distinguished road
Send a message via AIM to tricken
the si tank has baffles like things makes it a pain in the ass to do a pump swap
__________________
95 accord wagon f22 vtec dropped and scraping the sides
tricken is offline   Reply With Quote
Old 03-08-2008, 09:49 AM   #19
SquishyPanda
Preludepower Member
OK so we've established that the Si has baffles. What I need to confirm now is whether or not the S tank does.
__________________
Red Panda
v2.0: B20A5
Old 03-08-2008, 05:10 PM   #20
89vtec
Newbie
89vtec is on a distinguished road
nice i not the only one that had that problem.....
after the b18c swap in the car it did exactly what you are saying... my car is an s model .
so originaly it was carburated but now it s fuel injection.
i went to the honda dealer for some help and we looked at the diagrams for the fuel tanks and the s model has no baffle to retain the gas in the curves...
im running with the gsr gas pump and the si model gas tank for 2 years with no problem....
89vtec is offline   Reply With Quote
Old 03-09-2008, 06:15 PM   #21
preluderguy
Lude Dude
preluderguy is on a distinguished road
about the loss of pressure
i would say IMO, that the fuel pump is overheating at that point when it is not fully submerged in gas... probably just a bad pump.... i had a cadillac that stalled when taking onramps too fast... and in extremely hot weather at idle with a low gas level...
i would start simple.... just throw a new pump in there... i bet thats what it is....
i mean it makes sense.... the motor is made up of a coil of wires....and if it shorts out... it creates heat.... and when there isnt gas surrounding it, it cannot disperse the heat....so when your fuel get too low it over heats and the coils expand (hence, binding the motor)
like i said ... in my opinion
preluderguy is offline   Reply With Quote
Old 03-10-2008, 04:09 PM   #22
SquishyPanda
Preludepower Member
that's a valid point, but I'm 99.9% sure that's not my issue. It's been doing this for a while, and the pump would have completely burned out by now. The pump also wouldn't overheat and seize instantly when the fuel sloshes away. My motor bogs, but doesn't stall, and it happens as soon as I go into a left turn at the right speed. It comes right back when I straighten out, though, so it's sucking in enough dribbles to keep the motor alive. The baffle issue just makes more sense with what I'm experiencing. Especially now that there's confirmation that the S tank doesn't have any.
Oh well. I'll just put up with refilling frequently.
__________________
Red Panda
v2.0: B20A5
Old 03-10-2008, 04:15 PM   #23
GUESSMAN
Preludepower Member
GUESSMAN's Avatar
I have that 91' Si tank on my back porch if you want it now. I just got my 88' Si car with a tank still on it.
$150.00 plus shipping and it yours. It cost me that much at the junk yard.
__________________
Old 03-10-2008, 05:16 PM   #24
SquishyPanda
Preludepower Member
nah I'm good. I gotta spend all my money on school right now, because I transfered late and missed the financial aid deadlines Gotta find $3k for this quarter somewhere.
__________________
Red Panda
v2.0: B20A5
Old 03-10-2008, 08:45 PM   #25
GUESSMAN
Preludepower Member
GUESSMAN's Avatar
No problem at all. Just a heads up. good luck with your schooling.
peace
__________________
Reply
Bookmarks
  • Submit Thread to Digg Digg
  • Ads By Google
    Search Cloud
    2010 honda prelude 3rd gen prelude 4th gen prelude 5th gen prelude 5th generation prelude 6th gen prelude b21a1 car motivational posters convertible prelude dashboard paint edge2lyfe view profile floor jack reviews funny things to text your girlfriend h22 cams h22 manual tensioner conversion h22a4 h22a4 specs h23 vtec h23a vtec honda prelude 2010 honda prelude 5th gen how to text your girlfriend hp259 hp259 tire individual throttle bodies k1 attack for sale k20 prelude nice things to say to your girlfriend in a text nice things to text your girlfriend nitto neo gen reviews pcv valve symptoms power prelude prelude prelude convertible prelude forum prelude forums prelude power preludepower preludepower.com projector retrofit racing hart cp-035 rattle can paint job song suggester sweet things to say to your girlfriend in a text sweet things to say to your girlfriend over text sweet things to text your girlfriend things to text about things to text your girlfriend what to text your girlfriend www.preludepower.com
    Thread Tools
    Display Modes
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Forum Jump
    KickItBack = Cash Back
    Google
    vB.Sponsors
    PreludePower Forums
