All Honda ECU Codes - Honda Prelude Forum : Honda Prelude Forums
Closed Thread
Thread Tools Display Modes
Old 11-29-2007, 04:43 PM   #1
1funryd
Elite Member
1funryd is a jewel in the rough1funryd is a jewel in the rough1funryd is a jewel in the rough1funryd is a jewel in the rough
Send a message via AIM to 1funryd Send a message via MSN to 1funryd Send a message via Yahoo to 1funryd
All Honda ECU Codes
Added to the sticky's
Sean
1
Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 97-98 85-91 93-97 95-98 85-98 Oxygen Sensor "A" (Primary)
defective circuit or unplugged / defective sensor
2
85-89 86-87 n/a 85-87 85-91 n/a n/a Oxygen Sensor "B"
3
85-98 86-98 97-98 85-91 93-97 95-98 85-98 MAP Sensor (Manifold Absolute Pressure)
4
90-98 88-98 97-98 88-91 93-97 95-98 85-98 CKP Sensor (Crankshaft Position Sensor)
5
85-98 * 86-98 97-98 85-91 93-97 96-98 85-98 MAP Sensor (Manifold Absolute Pressure)
mechanical problem / disconnected piping
* exc 94-95
6
85-98 86-98 97-98 85-91 93-97 95-98 85-98 ECT Sensor (Engine Coolant Temperature)
7
85-98 86-98 97-98 85-91 93-97 95-98 85-98 TP Sensor (Throttle Position)
8
85-98 86-98 97-98 85-91 93-97 95-98 85-98 TDC Sensor (Top Dead Center)
9*
85-98** 86-98 97-98 85-91 93-97 95-98 85-98 CYP Sensor (Cylinder)
* not a valid code for any throttle body injection Hondas
** not a valid code for V-6 engines
10
85-98 86-98 97-98 85-91 93-97 95-98 85-98 IAT Sensor (Intake Air Temperature)
12
85-98 86-98 * n/a 85-91 * n/a 95-98 85-98 EGR Lift Sensor (Exhaust Gas Recirculation)
* not a valid code if car is not equipped with an EGR valve (some Civic models are not)
13
85-98 86-98 97-98 85-91 93-97 95-98 85-98 BARO Sensor (Atmospheric Pressure)
14
88-98 88-98 97-98 88-91 93-97 95-98 88-98 IAC Valve (Idle Air Control)
15
90-95 88-95 n/a 88-91 93-95 95 88-95 Ignition Output Signal
missing or defective ignition output signal
16
90-95 88-95 n/a 88-91 93-95 95 88-95 Fuel Injector System
defective circuit or unplugged / defective fuel injector
17
88-98 88-98 97-98 88-91 93-97 95-97 88-98 VSS (Vehicle Speed Sensor)
19
n/a 88-95 n/a 88-91 93-97 n/a n/a Automatic Transmission Lock Up Control Solenoid Valve
defective circuit or unplugged / defective solenoid valve
20
90-98 88-98 97-98 88-91 93-97 95-98 92-98 Electrical Load Detector
21*
94-98 ** 92-95 n/a n/a 93-95 n/a 93-95 VTEC Solenoid Valve
* not a valid code if car does not have a VTEC engine
** not with V-6 engine
22*
94-98 92-98 n/a n/a 93-97 98 93-98` VTEC Oil Pressure Switch
defective circuit or unplugged / defective oil pressure switch
23
98 * 96-98 n/a n/a 94-97 n/a 92-98 KS (Knock Sensor)
* not a valid code if V-6 engine
30
90-98 * n/a n/a n/a n/a 95 92-98 * Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
* not a valid code for 1996
31
90-95 n/a n/a n/a n/a 95 92-95 Automatic Transmission Signal "B"
41
90-98 92-98 97-98 n/a 93-97 95-98 90-98 Primary Oxygen Sensor - Heater
circuit malfunction
43
90-95 92-95 n/a n/a 93-95 95 90-95 Fuel Supply System
defective or malfunctioning fuel supply system
45
96-98 96-98 97-98 n/a 96-97 96-98 96-98 System Too Lean or Too Rich
malfunction in the fuel monitoring systems
48
98 92-98 n/a n/a n/a n/a n/a LAF Sensor (Lean Air Fuel)
54
96 96-98 97-98 n/a 96-97 n/a n/a CKF Sensor (Crankshaft Speed Fluctuation)
58
98 * n/a n/a n/a n/a n/a n/a TDC Sensor 2 (Top Dead Center)
* with V-6 engine only
61
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor, Heated - Sensor 1 (Primary)
high voltage, low voltage, or slow response
63
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor, Heated - Sensor 2 (Secondary)
65
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor Heater (Secondary)
malfunctioning or defective oxygen sensor heater
67
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Catalyst system Efficiency Below Threshold
malfunctioning or defective catalyst system
70
96-98 96-98 97-98 n/a n/a 96-98 96-98 Automatic Transmission
malfunction with the automatic transmission controls
71
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 1 Misfire or a Random Misfire
a condition is present that is creating a cylinder misfire
72
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 2 Misfire or a Random Misfire
73
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 3 Misfire or a Random Misfire
74
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 4 Misfire or a Random Misfire
75
98 * n/a n/a n/a n/a n/a n/a Cylinder 5 Misfire or a Random Misfire
* valid code for V-6 engine only
76
98 * n/a n/a n/a n/a n/a n/a Cylinder 6 Misfire or a Random Misfire
80
96-98 96-98 n/a n/a n/a 96-98 96-98 Exhaust Gas Recirculation
insufficient flow detected
86
96-98 96-98 97-98 n/a 96-97 96-98 96-98 ECT Sensor (Engine Coolant Temperature)
circuit range / performance problem
90
97-98 96-98 n/a n/a n/a 98 97-98 Evaporative Emission Control System
leak detected in the fuel tank area
91
96-98 96-98 n/a n/a n/a 98 97-98 Fuel Tank Pressure Sensor
low input
92
96-98 96-98 97-98 n/a 96-97 96-97 96-98 Evaporative Emission Control System
These are 3rd Gen specific:
3rd generation ECU error codes and ECU location. To access the codes (if any) turn the ignition key to the on position but do not start the car. Locate the indicator LED and count the number of flashes. Single digit codes are indicated by a series of short flashes. Two digit codes use a long flash for the first digit followed by the appropriate number of short flashes. After a short pause the code will repeat. For multiple codes the codes will flash alternately with a pause between codes.
ie. For code 3 and 14....
The LED will flash 3 times, pause, flash once long then 4 times, pause and repeat from the beginning.
On '85-'87 Preludes the ECU is located in the left side trim panel beside the rear seat. On '88-'91 Preludes the ECU is located under the carpet on the right passenger floorboard.
Dont forget, if your throwing a code use the ONLINE MANUAL to isolate and fix the problem.
'85-'89 PGM-FI
Code 0 ECU
Code 1 Oxygen content A
Code 2 Oxygen content B
Code 3 MAP sensor
Code 4 Crank angle sensor
Code 5 MAP sensor
Code 6 Coolant temperature
Code 7 TPS sensor
Code 8 TDC position sensor
Code 9 No.1 cylinder position sensor
Code 10 Intake air temperature sensor
Code 11
Code 12 Exhaust gas recirculation system
Code 13 Atmospheric pressure sensor
Code 14 Electronic idle control
Code 15 Ignition output signal
Code 16 Fuel injector
Code 17 Vehicle speed sensor
'90-'91 PGM-FI
Code 0 ECU
Code 1 Oxygen content A *, Oxygen content **
Code 2 Oxygen Content B
Code 3 MAP sensor
Code 5 MAP sensor
Code 7 Throttle position sensor
Code 11
Code 14 Electronic air control
Code 41 ** Oxygen sensor heater
Code 43 ** Fuel supply system
* 2.0 liter engines
** 2.1 liter engines
Clearing ECU codes
Stored codes are earased from memory by disconnecting power to the ECU for at least 30 seconds. Disconnecting the negative battery cable will clear the memory of the ECU, as well as other solid-state equipment such as radios. The ECU may also be cleared by pulling the appropriate fuse from the underhood fuse and relay box. This may be the BACK-UP, CLOCK or CLOCK/RADIO fuse.
Sean
__________________
My Facebook page -
Sean
3rd Gen Aftermarket Manager
(Clik Here)
Email:
(Danny19 - JDM RH Drive) (1Funryd - H23 Swap) (B20luda - Turbo Charged H22)Representing All of 3rd Gens!!!
1funryd is offline   Quick reply to this message
Sponsored Links
Advertisement
Old 11-29-2007, 06:23 PM   #2
preludegofast13
I am Prelude
preludegofast13's Avatar
preludegofast13 is on a distinguished road
Prelude of the Month
You da man Sean!
__________________
-Bryan
preludegofast13 is offline   Quick reply to this message
Old 11-29-2007, 06:33 PM   #3
tricken
Lude Boss
tricken's Avatar
tricken is an unknown quantity at this point
Send a message via AIM to tricken
nothing that wasnt on prelude3g.com
__________________
95 accord wagon sold
71 vw squareback fi under the knife
........ coming soon
tricken is offline   Quick reply to this message
Old 11-29-2007, 07:03 PM   #4
1funryd
Elite Member
Very true, but since we look to this forum to provide us with answers, I felt it was pertinent and that it should be easily accessible to all.
So I made a new thread, that should pull up on the search and put it into the 3rd gen performance link, so that it was easier to access for all, new and old.
I too don't like having to dig throug mountains of usless threads to get a straight answer.
Sean
__________________
My Facebook page -
Sean
(Clik Here)
Email:
Old 11-29-2007, 08:06 PM   #5
motoxxxman
motoxxxman is an unknown quantity at this point
Send a message via AIM to motoxxxman Send a message via Yahoo to motoxxxman
this was already in the stickies.
i know it was, cuz i put it there. even got it from the same source you did;
http://www.hondacivicforum.com/m_45386/tm.htm
it's under common fixes, ecu error codes aka trouble codes
motoxxxman is offline   Quick reply to this message
Old 11-30-2007, 10:52 AM   #6
Bobnova
New title is new
Bobnova's Avatar
Location: Humboldt County (FAR northwest CA, on the coast)
Bobnova has a spectacular aura aboutBobnova has a spectacular aura about
Send a message via AIM to Bobnova
It's incorrect anyway, it's not 88-89 and 90-91, it's b20a5 and b21a1.
__________________
--Bobnova '89 2.0SI 4ws(309k miles), '76 Triumph TR7 FHC (63k miles)
24 years of professional automotive experience, specializing in Honda/Toyota/Subaru.
Bobnova is offline   Quick reply to this message
Sponsored Links
Advertisement
Closed Thread
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
