Go Back   Preludepower.com > Prelude Forums > 3rd Gen
Reload this Page Hybrid Axles: H22 with AZ Motor Mounts
Reply
Ads By Google
Thread Tools Display Modes
Old 01-12-2007, 04:55 PM   #1
Deathwish
Lude Dude
Deathwish is on a distinguished road
Hybrid Drive Axles: B21A1 –H22A for AZ Mounts
After trying a number of different combinations and searching through a junkyard for a day I found the beam length needed to make a set of axles for the AZ mounts. Originally I tried the combination outlined by the guy from Latvia and quickly discovered that they would not even come close to working.
See Below:
^**** This combination will not work****^
After measuring up some of the axles I had lying around on my shelf’s I discovered that the H22/23 driver’s side beam was 6mm shorter. I then re-assembled the new combination using the two H22 driver’s beams instead of accord beams. This time the spindles and upper control arms would all go back together. After getting the wheels back on I loaded the drivers side suspension using a jack to bring the axle to parallel the ground (The most the axle will ever push in to the inner joint) and discovered that it was binding and would not work.
See Below:
1: 3rd Gen lude outer joint
2: Prelude 1994 driver’s side beam
3: H22 inner joint and intermediate shaft
4: H22 inner joint
5: Prelude 1994 driver’s side beam
6: 3rd Gen lude outer joint
So I went to the junkyard and started the process of disassembling, measuring, and reassembling axles to try and find a combination that would work. I knew that I did not need much; if I could find a set that was 5 mm shorter they would work.
These are the results of my search:
I found a set out of 1990 Acura Integra axles that were perfect. The Integra uses an axle combinations that has the same lengths on both the passenger and drivers side, in an attempt to reduce torque steer. So it does not mater whether you get drivers or passenger beams.
So the final working combination:
2: Integra 1990 (Driver’s / Passengers) Beam
4: H22 inner joint
5: Integra 1990 (Driver’s / Passengers) Beam
Works perfectly with no biding at all. Hope this helps and happy luding
Created by: Bryan
AKA: Deathwish // Ludes4Life
Deathwish is offline   Reply With Quote
Old 01-12-2007, 05:14 PM   #2
jyluder
Lude Addict
jyluder's Avatar
jyluder is on a distinguished road
Freakin Awsome!!!!!!!!
jyluder is offline   Reply With Quote
Old 01-12-2007, 05:17 PM   #3
IvoGiev
True Luder
IvoGiev's Avatar
IvoGiev is on a distinguished road
Send a message via ICQ to IvoGiev Send a message via Skype™ to IvoGiev
glad you found that out.great work.
can you show me picture of those mounts in your car?i am curious how they look cause they sound alot different than the Latvian ones which i have.
maybe a pic of the mounts before install too will be good.
thanks in advance.
p.p.
i wish to you all who wants H22 in their 3th gen ludes to accomplish your will.
cause i can tell from my own experience-it worth the efforts 100%
today i went for a drive with a friend who i haven't seen for more than an year and he was laughing like an idiot all the time.his smile was so vast that even when the police pulled us over ,they asked him why is he so happy
his answer was something like: well,i haven't seen that guy for a long time and since than he made a beast from that car.i just enjoy the ride.
it was a weird day today
__________________
IvoGiev is offline   Reply With Quote
Old 01-12-2007, 05:37 PM   #4
007Pilon
Lude Addict
007Pilon's Avatar
007Pilon is on a distinguished road
Damn Deathwish, thats some serious dedication, mad props to you. I'm sure you had a fun time pulling apart so many junkyard suspensions to check out axles. Good Job!
__________________
Rob
89 2.0si
007Pilon is offline   Reply With Quote
Old 01-12-2007, 06:04 PM   #5
Hprelude5R
Hprelude5R's Avatar
Hprelude5R will become famous soon enoughHprelude5R will become famous soon enough
Send a message via AIM to Hprelude5R
How well will those Integra bits stand up to H22 goodness is the question. I'd be willing to bet that those swapped cars won't remain stock forever. :P
Great job with all the dirtywork tho.
Rep point for you.
__________________
PP.COM NEEDS YOU! We've lost sponsors as of the new year. Donate to this valueable resource today!
showroom
GIT YO HANDS OFF MY S2000 BY-ITCH.
I like to consider myself a pretty decent jerk, but I still have aways to go I think.
yeah, you pretty much do
Hprelude5R is offline   Reply With Quote
Old 01-12-2007, 06:44 PM   #6
nolimitphillyboyzzz
Preludepower Member
nolimitphillyboyzzz's Avatar
nolimitphillyboyzzz is on a distinguished road
Send a message via AIM to nolimitphillyboyzzz Send a message via MSN to nolimitphillyboyzzz
great find.
__________________
now rocking the c.f. stuff...!!!!
best price for turbo parts here~~~~>
for the tristate area cats...
for 3rd gen front wilwood big brake kit & big rotor kit for rears..!
nolimitphillyboyzzz is offline   Reply With Quote
Old 01-12-2007, 06:48 PM   #7
klaye88
Preludepower Member
klaye88's Avatar
klaye88 is on a distinguished road
Send a message via AIM to klaye88
WOW! I wonder how many cans of PB Blaster he went through. Also, What Kind of Axle grease did you use for the inners and outers? NICE WORK!
__________________
88 4WS yellow as hell!
89 Golden Cherry daily driver
90 RED, on the road again!
90 B21 white new to the family! soon to have a B20a5!
LISCENSED CAR AUDIO DEALER..... PM ME FOR MY PHONE # OR PM/EMAIL ME!
klaye88 is offline   Reply With Quote
Old 01-12-2007, 07:26 PM   #8
Deathwish
Lude Dude
All of the beams that I collected have the same spline counts and thickness. These are beam spline counts and thickness not outer joints. The differences are in the inner and outer joints. The only other thing is that the H22 has re-enforced finger bearings. They have a slider attached to them the slides into a grove on the inner joints. As well the actual finger joint could be considered slightly buffer but not by anything that really matters IMO. Unless you plan to make more then 300-350WHP I really doubt you will have a problem with the axles. But slicks might change that. I have some pics of the differences I will try and post up.
Thx for all the support.
Old 01-12-2007, 08:06 PM   #9
Deathwish
Lude Dude
Here are some pictures of some of my collection of axles. This should clear up any of the things that I cannot explain with words. I don’t have pics of the teg’s but they look the exact same as the 90 lude and the 94 accord.
1994 Honda Prelude:
1994 Honda Accord:
1990 Honda Prelude:
94 Lude Vs 94 Accord
The mix:
Old 01-12-2007, 08:26 PM   #10
Hprelude5R
Hprelude5R's Avatar
That's alot of juice. Go teggies.
Good to know.
I'll link this thread in my sig. Again, thanks for all the effort.
__________________
showroom
Old 01-12-2007, 08:47 PM   #11
ipath13
Preludepower Member
ipath13's Avatar
ipath13 is on a distinguished road
wow thats amazing mad props!!
__________________
past rides: 1987 nissan pulsar NX, sent to the wreckers
1988 2.0si 4ws...accident r.i.p. just passed 245,000miles.
1996 dodge ram indy pace truck - sold
1996 dodge ram 4x4 laramie slt, parts truck. pulled the motor, cut the truck in half hahaha. gone to the wreckers.
current ride: 1990 prelude sr 4ws
ipath13 is offline   Reply With Quote
Old 01-12-2007, 10:15 PM   #12
team123luder
Elite Member
team123luder's Avatar
team123luder has a spectacular aura aboutteam123luder has a spectacular aura aboutteam123luder has a spectacular aura about
Send a message via AIM to team123luder Send a message via MSN to team123luder
Prelude of the Month
Good to know.
Honda axles are very strong bro... like he mentioned... unless high hp is in the mix and or slicks.. no need to worry. Spin your wheels a bit in first gear to relief stress from the axles and or transaxle and you'll be golden.
__________________
FOR SALE!!!!
team123luder is offline   Reply With Quote
Old 01-12-2007, 11:01 PM   #13
danny_d19
Fuuuuuuuuuuuuuuuuu
danny_d19's Avatar
danny_d19 is just really nicedanny_d19 is just really nicedanny_d19 is just really nicedanny_d19 is just really nicedanny_d19 is just really nice
Outstanding work Deathwish
__________________
danny_d19 is offline   Reply With Quote
Old 01-13-2007, 08:46 AM   #14
J90lude
Lude Addict
J90lude's Avatar
J90lude is on a distinguished road
Send a message via AIM to J90lude Send a message via Yahoo to J90lude
Wow
J90lude is offline   Reply With Quote
Old 01-13-2007, 10:19 AM   #15
4WSRV
Elite Member
4WSRV's Avatar
4WSRV is on a distinguished road
Send a message via AIM to 4WSRV
DeathWish,
Thank you for the info on the axles that work on the AZ mount. Now put this in the sticky section.
Thank again
4WSRV is offline   Reply With Quote
Old 01-13-2007, 04:26 PM   #16
Ludercrs
Preludepower Member
Ludercrs's Avatar
Ludercrs is on a distinguished road
Send a message via MSN to Ludercrs
an email i got from Raxles.com since i was wondering aboutthe axles they made.
Thank you for you inquiry!
For this h22 / Prelude conversion we offer 100% NEW axles that
require NO core return.
They are specifically made to fit with NO seal boss modification.
They are complete with new nuts and hub seals included.
We build these out of HD NEW components using Amsoil synthetic
racing grease and the BEST CV boots.
We have developed these units after MUCH research and MANY
successful installs.
They utilize the PRELUDE style inner joints which are 100%
necessary to prevent the inner joint from "popping out". The Integra style inner joints are too
SHORT at the transmission spline side.
They are $174.95 each.
__________________
1991 Honda Prelude SE - LEATHER SEATS BABY - H22 - 180whp - 160tq
Ludercrs is offline   Reply With Quote
Old 01-13-2007, 06:59 PM   #17
butterthegreat
Preludepower Member
butterthegreat's Avatar
butterthegreat will become famous soon enough
Send a message via ICQ to butterthegreat Send a message via AIM to butterthegreat Send a message via MSN to butterthegreat Send a message via Yahoo to butterthegreat
The original method worked just fine for me....
__________________
I can already picture butter as a mod. " Give me all your preludes or get banned
" the 3rd gen hitler himself
PreludePower.com's "OFFICIAL" 3rd gen Prelude Whore
butterthegreat is offline   Reply With Quote
Old 01-13-2007, 07:13 PM   #18
Ludercrs
Preludepower Member
Ludercrs's Avatar
well I'm just wondering cus on 1 side a company that made some says Integra ones are too short...
but on the other hand you're saying the Integra ones are NEEDED for these different mounts?
was the change in the mounts THAT different?
__________________
Old 01-13-2007, 10:00 PM   #19
team123luder
Elite Member
Yes. PRI mounts are completely out of place and resulted in a nasty vibration due to engine placement. AZ mounts fixed this and thus we need to use different mounts.
B20luda has an H22 in his 3rd gen. He's using stock axles. Go figure.
__________________
FOR SALE!!!!
Old 01-13-2007, 10:29 PM   #20
Deathwish
Lude Dude
No offence but they haven’t a clue about what they are saying. I’m sure they build a great product but that is just it. They are just trying to sell their product, which is not a bad thing. However, they should get their facts straight. In actuality the Integra axles are somewhat long. The inner joint has approximately 35 mm of total travel. The fingers on the inner joint are suppose to sit somewhere in the middle (17.5mm) of the inner joint housing, however they actually sit farther in towards the tranny side NOT, I REPEAT NOT FARTHER OUT. There is absolutely no way the inner joint is going to “pop out”. If anything I would have the Integra axles shortened by another 8mm but there is really no reason to. If you do not believe me that is fine but there is really no need to spend almost $400 on axles that you really don’t need.
I like their reply to you.
100% NEW // Really
Complete with NUTS // WOW bonus
HD NEW components // Prove it
Amsoil Synthetic RACE grease // New grease
The Best CV BOOTS // Just what is the best CV boot
Utilize the PRELUDE style inner joints // If you what to you can just swap them on to the Integra axles not an issue.
successful installs. // I’m sorry have they actually got a set of AZ mounts
They might as well get down on their knees and beg. I’ am not saying don’t buy their axles but I do think they a trying a little to harder and haven’t the slightest clue about what they are saying. However, I would say if you do not believe me go to a junk yard get the bits and pieces and make your own. Guaranteed they will not be short.
Anyways: Good luck
Thanks for all the compliments I really appreciate it.
Old 01-13-2007, 11:09 PM   #21
Ludercrs
Preludepower Member
Ludercrs's Avatar
well the thing is... I don't have an engine... and can't find out for myself.
I also don't have the time.
I'm looking for something I can buy that is Good quality and will last a VERY long time (cus I plan on keeping my Lude for a Very long time as a Summer car)
So I could try and ask them to get Integra ones when they make them i really don't know but I also don't wanna go to a Junk yard and get stuff that's used and just brush it off and put it in my car...
__________________
Old 01-13-2007, 11:42 PM   #22
Deathwish
Lude Dude
That’s fine. I would recommend Gator Axles. By far the best axles I have ever come in contact with. Call them or fill out a tech sheet and you will get a one off set of custom high horse power axles. They don’t build OEM axles like Raxles, only one off sets and yes they will cost more. I would get a set if I thought it was necessary but I my opinion it really is not. Nothing wrong with using good old OEM parts.
Edit: Also I wouldn't recommend just brushing off anything.
Old 01-13-2007, 11:52 PM   #23
Ludercrs
Preludepower Member
Ludercrs's Avatar
was a figure of speech :P
__________________
Old 01-14-2007, 10:00 AM   #24
team123luder
Elite Member
What wrong with old parts? You still own a prelude damn it. And non of them are new.
__________________
FOR SALE!!!!
Old 01-14-2007, 10:11 AM   #25
TripleLude
Elite Member
TripleLude's Avatar
TripleLude will become famous soon enough
wow. awsome thread. +1 believe it or not, now i am tempted to go H22 swap instead of turbo... we'll see.
__________________
i know ive seen some like orange-ish brown-ish gell-ish substance inside the connector under the plastic covering on the ing sing output
TripleLude is offline   Reply With Quote
Reply
Bookmarks
  • Submit Thread to Digg Digg
  • Ads By Google
    Search Cloud
    2010 honda prelude 3rd gen prelude 4th gen prelude 5th gen prelude 5th generation prelude 6th gen prelude b21a1 car motivational posters convertible prelude dashboard paint edge2lyfe view profile floor jack reviews funny things to text your girlfriend h22 cams h22 manual tensioner conversion h22a4 h22a4 specs h23 vtec h23a vtec honda prelude 2010 honda prelude 5th gen how to text your girlfriend hp259 hp259 tire individual throttle bodies k1 attack for sale k20 prelude nice things to say to your girlfriend in a text nice things to text your girlfriend nitto neo gen reviews pcv valve symptoms power prelude prelude prelude convertible prelude forum prelude forums prelude power preludepower preludepower.com projector retrofit racing hart cp-035 rattle can paint job song suggester sweet things to say to your girlfriend in a text sweet things to say to your girlfriend over text sweet things to text your girlfriend things to text about things to text your girlfriend what to text your girlfriend www.preludepower.com
    Thread Tools
    Display Modes
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Forum Jump
    KickItBack = Cash Back
    Google
    vB.Sponsors
    PreludePower Forums
