Cost of cleaning egr ports/valve? - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 08-01-2006, 07:09 PM   #1
xPhax
Getting Comfortable
xPhax is on a distinguished road
Check engine light is on and the code is P0401. Insufficient flow detected. I looked it up and found out it could be a dirty egr valve or clogged egr port. So I tried removing the nut off the egr valve to clean it but it stripped. I used a bolt out and it still won't move. I'm thinking of bringing it to the dealership so they can remove the stripped nut and clean the egr valve and ports at the same time. How much does the dealership usually charge to clean the egr valve and egr ports?
xPhax is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-01-2006, 07:28 PM   #2
lilredlude
I am Prelude
lilredlude's Avatar
lilredlude will become famous soon enough
Send a message via AIM to lilredlude
probably more since the bolt is stipped.
it takes like 10 minutes to do, but my guess is the'd charge you at least 100
__________________
-Michelle
95 Jeep Grand Cherokee
86 Honda Interceptor 500cc
01 Honda Prelude Base
lilredlude is offline   Reply With Quote Quick reply to this message
Old 08-01-2006, 08:25 PM   #3
prelude1897
prelude1897's Avatar
prelude1897 is a jewel in the roughprelude1897 is a jewel in the roughprelude1897 is a jewel in the rough
Send a message via AIM to prelude1897
you dont' have to take it to the stealership, you can just take it to any mechanic shop and they can probably take it off for you
__________________
97 Prelude-wrecked
00 Prelude-daily driver
99 Prelude-RHD Prelude
98 Prelude-Parts Car-SOLD
97 Prelude-RHD project#2
99 Prelude-Parts car-SOLD
01 Prelude-Parts car-SOLD
94 Prelude-VTEC status-Traded
98 Prelude-traded for 94 prelude
97 Prelude-Parts car-SOLD
Retrofit Service PM me
prelude1897 is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 05:00 AM   #4
Ricedadee
Lude Cray
Ricedadee's Avatar
Ricedadee has disabled reputation
Send a message via AIM to Ricedadee
Sea Foam it !!
__________________
Do you have your decoder ring?
Who got myspace!!
Ricedadee is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 03:06 PM   #5
xPhax
Getting Comfortable
A local shop just removed the stripped nut for free. I brought the car home and cleaned the egr valve. I also resetted the cel. If the light comes back on again I'm going to bring it to the dealership to clean the egr ports. Hopefully the cel doesn't come back on because I have to smog my car now by the end of the month.
Old 08-03-2006, 03:35 PM   #6
mustangtw5901
Getting Comfortable
mustangtw5901 is on a distinguished road
I had the same problem with my car. Cleaning the Egr valve itself may or may not fix the problem. In my case, the CEL came back on after cleaning the egr valve. If it comes back on, your egr ports in the manifold are most likely clogged. What you would need to do is remove the intake manifold port plugs and clean the ports out with some carb cleaner and a coat hanger. You'll need to go to the delearship to get the replacement plugs, there are six total and it should only cost a bit more than a dollar for them. The easiest way to do it is to get a small slide hammer (the dent puller type), I got mine from advance auto parts for like 8 bucks. You will need to drill a small hole in each of the plugs and screw in a long self tapping screw, then attach the slide hammer through the screw and pop the plug out. Clean out each port with some carb cleaner and a coat hanger, then install a new plug with a brass punch. There is a TSB with the procedure floating around somewhere, do a search and you might find it. I've had people tell me the delear charged them $400 to have this done, so if your handy with a wrench then I would do it myself. You'll save a ton of money. Good Luck.
mustangtw5901 is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 03:55 PM   #7
stereo
Elite Member
stereo is on a distinguished road
Send a message via MSN to stereo Send a message via Yahoo to stereo
if it's a 97 and you have less then 140k on it you might be able to get it done under the extended emission warranty.
stereo is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 04:18 PM   #8
Ricedadee
Lude Cray
Ricedadee's Avatar
SEA Foam all the way Seam foam is a product that you could by at autozone it's oxygen sensor safe and is recommended for fuel injector cars just ask for it they will know I recommend getting two types one that is in a can and one in spray..
The can stuff is always good to use i use quarter of it in the gas tank, 1/3 of it in the oil, and the rest in the break booster line then turn the car off have two ciggs then start the car for the smoke show around the neighborhood yeah haw..
do this at least 3 oil changes you'll see the differnces
I hope you guys arent putty carb cleaner in the TB it's a big no no in the car
__________________
Who got myspace!!
Old 08-03-2006, 07:17 PM   #9
mustangtw5901
Getting Comfortable
Seafoam is a great product, but it did not help in my case. Believe me, I tried that first and still got the CEL. Stereo is right. If your car's got under 150K it may be covered under the extended emissions warrenty. I have 207K on my car so it was not covered under warrenty.
Old 08-03-2006, 08:15 PM   #10
hojo82
Lude Dude
hojo82 is on a distinguished road
Send a message via AIM to hojo82
i had this same problem and after i cleaned the ports the light came back on....turned out the egr valve was bad...think it was like $180 - $200 for the replacement. You can check this buy unbolting the valve (the saucer looking think in front of the throttle body) and making sure the plunger moves freely under vaccum pressure
hojo82 is offline   Reply With Quote Quick reply to this message
Old 08-04-2006, 12:29 PM   #11
xPhax
Getting Comfortable
So far my cel hasn't come on. Should I wait another day or two before I bring it to get smogged? I'll give Honda a call later today about the emission warranty since my mileage is only 133,033 and it's a 97.
Old 08-04-2006, 12:43 PM   #12
hojo82
Lude Dude
mine took about 50 miles to come back on. u will pass emissions as long as the cel isnt on (at least thats how it is in north carolina)
what state u liv e in?
Old 08-04-2006, 04:52 PM   #13
xPhax
Getting Comfortable
I live in in WA state. They plug their scan tool in the diagnostic port for codes if the car is OBDII. I driven about 80 miles so far. Still no cel. Should I wait a little longer for the ecu to gather more data so it'll be ready for smog or should it be okay if I was to bring it in tomorrow?
Old 08-04-2006, 06:04 PM   #14
hojo82
Lude Dude
i dont think they plug it in as long as its not lit up
if it hasn't came on after a day or 2 then ur good to go
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
